Orange Pi Win Plus.Some GPIO pins are not working
sadkhann
Hello friends;
I have board which Orange Pi Win Plus running Armbian. My problem is, boards 7, 8, 10 and 16 physical pins are not working. When I tried to I/O with this pins, console says: Segmentation Error.
Is it possible to fix it or is it normal?
Thank You.
Do you mean S_PWM, S_UART_TX, S_UART_RX and PL9 according to schematic ?
How do you try it ?
Which image are you running ?
I added screenshot and marked yellow dot the unworking pins. I running Armbian which
Armbian Xenial
desktop legacy kernel 3.10.y
and before this image I tried
Armbian Stretch
mainline based kernel 4.19.y
and
Armbian Bionic
desktop mainline based kernel 4.19.y
both
I can work with other pins with no problem but these pins are not working.
#include <stdio.h>
#include <wiringPi.h>
// LED Pin - wiringPi pin 0 is BCM_GPIO 17.
#define LED     15
int main (void)
  printf ("Raspberry Pi blink\n") ;
  wiringPiSetup () ;
  pinMode (LED, OUTPUT) ;
  for (;;)
    digitalWrite (LED, HIGH) ;  // On
    delay (500) ;               // mS
    digitalWrite (LED, LOW) ;   // Off
    delay (500) ;
  return 0 ;
All those pins are on PL gpio bank. This bank is powered with 1.8V instead of 3.3V on other banks.
So, if you connect something one those, you need to be aware about voltage level and maybe need a voltage shifter.
To test them and check them with voltmeter, you can use gpio sysfs, here an example :
echo 354 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio354/direction
echo 1 > /sys/class/gpio/gpio354/value
For the "Segmentation Error", it maybe simply a bug of wiringPi not been able to access PL PinController (pinctrl@1f02c00) which is not the same for all other banks (pinctrl@1c20800) ...
Thank you for replying me I am so glad.  I realized what you are considering. The codes you write, do I write them console or a file? I haven't done this type of stuff, can you explain a little bit deeper?
Now I tried a lot and find the solution with your help. In your way the GPIO pins looks fine but how to I control them? The classical way of
gpio mode 16 out
gpio write 16 1
not works with this pins.
As written above was at the console/shell, but you could write a bash script too, here is a blinking script :
#!/bin/bash
while true ; do
	echo 0 > /sys/class/gpio/gpio354/value
	spleep 0.25
	spleep 0.25
done
The above way ...
Or you can also use python library such pyA64 from https://pypi.org/project/pyA64/
#!/usr/bin/env python
"""Basic blinking led example.
import os
import sys
if not os.getegid() == 0:
    sys.exit('Script must be run as root')
from time import sleep
from pyA64.gpio import gpio
from pyA64.gpio import port
led = port.PD5
gpio.init()
gpio.setcfg(led, gpio.OUTPUT)
try:
    print ("Press CTRL+C to exit")
    while True:
        gpio.output(led, 1)
        sleep(0.1)
        gpio.output(led, 0)
        sleep(0.1)
        gpio.output(led, 1)
        sleep(0.1)
        gpio.output(led, 0)
        sleep(0.1)
        sleep(0.6)
except KeyboardInterrupt:
    print ("Goodbye.")
