AZ8 Posted May 24, 2019 Share Posted May 24, 2019 After installation, /etc/apt/apt.conf.d/50unattended-upgrades is empty. What is the proper origins to automatically install at least security patches? Link to comment Share on other sites More sharing options...
Igor Posted May 24, 2019 Share Posted May 24, 2019 12 minutes ago, AZ8 said: What is the proper origins to automatically install at least security patches? https://www.google.si/search?q=configuring+unattended-upgrades Our defaults. I recently re-add adjusted conf, but it will remain disabled by default.https://github.com/armbian/build/tree/master/packages/bsp/common/etc/apt/apt.conf.d Link to comment Share on other sites More sharing options...
mbarmem Posted November 24, 2019 Share Posted November 24, 2019 Hi, Any possibility to send an email notification after running unattended-upgrades? Link to comment Share on other sites More sharing options...
Igor Posted November 25, 2019 Share Posted November 25, 2019 9 hours ago, mbarmem said: Hi, Any possibility to send an email notification after running unattended-upgrades? Anything is possible. See manual if this is build in otherwise make scripts ... Link to comment Share on other sites More sharing options...
technik007_cz Posted November 25, 2019 Share Posted November 25, 2019 14 hours ago, mbarmem said: Hi, Any possibility to send an email notification after running unattended-upgrades? https://help.ubuntu.com/lts/serverguide/automatic-updates.html Link to comment Share on other sites More sharing options...
Henrik Posted February 19, 2020 Share Posted February 19, 2020 Hi, I updated to armbian 20.02. Now 50unattended-upgrades is removed and 02-armbian-periodic is set to default. How can i permanently save unattended-upgrade config-files? Link to comment Share on other sites More sharing options...
Werner Posted February 19, 2020 Share Posted February 19, 2020 Did not try this by myself yet, but you could give "dpkg-reconfigure unattended-upgrades" a shot. 20 minutes ago, Henrik said: Hi, I updated to armbian 20.02. Now 50unattended-upgrades is removed and 02-armbian-periodic is set to default. How can i permanently save unattended-upgrade config-files? Link to comment Share on other sites More sharing options...
Henrik Posted February 19, 2020 Share Posted February 19, 2020 Thanks. I will try it. Link to comment Share on other sites More sharing options...
Henrik Posted March 22, 2020 Share Posted March 22, 2020 Packages that were upgraded: linux-buster-root-current-bananapi linux-dtb-current-sunxi linux-image-current-sunxi linux-u-boot-bananapi-current After the upgrade: 50unattended-upgrades is removed and 02-armbian-periodic is set to default. Any other ideas to save config permanently ? Link to comment Share on other sites More sharing options...
stut Posted March 22, 2020 Share Posted March 22, 2020 45 minutes ago, Henrik said: Any other ideas to save config permanently ? Make your config file and run "dpkg-divert --no-rename --add /path/to/configfile" -- this should prevent any upgrades from touching or even renaming the config file. Link to comment Share on other sites More sharing options...
Henrik Posted March 22, 2020 Share Posted March 22, 2020 I will give it a try. dpkg-divert --no-rename --add /etc/apt/apt.conf.d/02-armbian-periodic dpkg-divert --no-rename --add /etc/apt/apt.conf.d/50unattended-upgrades Link to comment Share on other sites More sharing options...
