OldBikerPete Posted May 30, 2019 Share Posted May 30, 2019 Hello forumees. I am running as root on an OrangePI Zero+ which uses a H2 processor running a CL version of arrmbian 3.4.113 which works fine. I have recently obtained a SimCom SIM7600CE GSM/GPS module which has only a USB interface. I tracked down drivers for it but the Linux version must be compiled to a module which I have managed (with a number of warnings) after a couple of hiccups. Now trying to install the compiled module is resulting in error messages. I think the problem is compatability with armbian which is beyond my expertise, so I am asking for help. Below is the CL dialog of my attempts to install the module. ```````````````` root@gpsControl:/usr/src/SIM7600LinuxDriver/GobiSerial# insmod GobiSerial.ko insmod: ERROR: could not insert module GobiSerial.ko: Unknown symbol in module ############ root@gpsControl:/usr/src/SIM7600LinuxDriver/GobiSerial# cd /lib/modules/3.4.113-sun8i root@gpsControl:/lib/modules/3.4.113-sun8i# ls build modules.alias modules.builtin.bin modules.devname modules.symbols GobiSerial.ko modules.alias.bin modules.dep modules.order modules.symbols.bin kernel modules.builtin modules.dep.bin modules.softdep ########### root@gpsControl:/lib/modules/3.4.113-sun8i# modinfo GobiSerial.ko filename: /lib/modules/3.4.113-sun8i/GobiSerial.ko license: Dual BSD/GPL description: GobiSerial author: Qualcomm Innovation Center version: 2011-07-29-1026 srcversion: 09B011938149D9A32402EAF alias: usb:v1E0Ep9001d*dc*dsc*dp*ic*isc*ip* alias: usb:v05C6p9000d*dc*dsc*dp*ic*isc*ip* alias: usb:v05C6p9046d*dc*dsc*dp*ic*isc*ip* alias: usb:v05C6p1E0Ed*dc*dsc*dp*ic*isc*ip* alias: usb:v05C6p920Dd*dc*dsc*dp*ic*isc*ip* alias: usb:v05C6p920Cd*dc*dsc*dp*ic*isc*ip* depends: usbserial vermagic: 3.4.113-sun8i SMP preempt mod_unload modversions ARMv7 p2v8 parm: debug:Debug enabled or not (bool) ################# root@gpsControl:/lib/modules/3.4.113-sun8i# depmod GobiSerial.ko depmod: ERROR: Bad version passed GobiSerial.ko root@gpsControl:/lib/modules/3.4.113-sun8i# ```````````````````````````````` I have attached the source of the module, the Makefile and a full log of the 'make all' Makefile GobiSerial.c make.log Link to comment Share on other sites More sharing options...
sfx2000 Posted May 30, 2019 Share Posted May 30, 2019 (edited) If it's really a Gobi, then consider libqmi/libmbim and modemmanger - they're in the upstream repos... and there's a PPA as well... https://launchpad.net/~aleksander-m/+archive/ubuntu/modemmanager-bionic Might work out of the box there - modemmanager is pretty cool, abstracts out a lot of the lower level stuff... That should get Gobi working as a modem - for GNSS oriented stuff, better to go with a GPS module like the uBlox Neo-6/7/8 modules, they're great for navigation and timing stuff, and they typically will interface with UART rather than USB Edited May 30, 2019 by sfx2000 updated for GNSS comment Link to comment Share on other sites More sharing options...
