gahabana Posted June 12, 2019 Share Posted June 12, 2019 hi, i have a problem not being able to build for Odroid-N2. To isolate the issue i created new copy of git ... it fails on kernel build. all defaults. zh@acus:~/git$ git clone https://github.com/armbian/build.git armbian Cloning into 'armbian'... remote: Enumerating objects: 151, done. remote: Counting objects: 100% (151/151), done. remote: Compressing objects: 100% (121/121), done. remote: Total 49101 (delta 83), reused 65 (delta 30), pack-reused 48950 Receiving objects: 100% (49101/49101), 325.95 MiB | 8.33 MiB/s, done. Resolving deltas: 100% (32873/32873), done. Checking out files: 100% (2951/2951), done. zh@acus:~/git$ cd armbian zh@acus:~/git/armbian$ ./compile.sh docker BOARD=odroidn2 KERNEL_ONLY=yes KERNEL_CONFIGURE=no BRANCH=default > ~/armbian.odroidn2-deefault-kernel-only.txt and last few lines of the build output look like this: CC [M] drivers/net/wireless/rtl8812au/hal/phydm/halrf/rtl8814a/halrf_8814a_ce.o CC [M] drivers/net/wireless/rtl8812au/hal/phydm/rtl8814a/phydm_rtl8814a.o CC [M] drivers/net/wireless/rtl8812au/hal/phydm/txbf/haltxbf8814a.o CC [M] drivers/net/wireless/rtl8812au/hal/btc/halbtc8723bwifionly.o CC [M] drivers/net/wireless/rtl8812au/hal/btc/halbtc8822bwifionly.o CC [M] drivers/net/wireless/rtl8812au/hal/btc/halbtc8821cwifionly.o CC [M] drivers/net/wireless/rtl8812au/core/rtw_mp.o LD [M] drivers/net/wireless/rtl8812au/88XXau.o LD drivers/net/wireless/built-in.o LD drivers/net/built-in.o LD drivers/built-in.o GEN .version LD vmlinux.o MODPOST vmlinux.o CHK include/generated/compile.h UPD include/generated/compile.h CC init/version.o LD init/built-in.o KSYM .tmp_kallsyms1.o KSYM .tmp_kallsyms2.o LD vmlinux SORTEX vmlinux SYSMAP System.map OBJCOPY arch/arm64/boot/Image Building modules, stage 2. MODPOST 1431 modules scripts/Makefile.modpost:107: recipe for target '__modpost' failed Makefile:1329: recipe for target 'modules' failed [ error ] ERROR in function compile_kernel [ compilation.sh:407 ] [ error ] Kernel was not built [ @host ] [ o.k. ] Process terminated All other boards i can build well. -Build host is Ubuntu 18.04, i tried native (above is in docker container) but in that case download of linaro fails for some reason ... but that is not the issue in docker container. My guess is it is very easy to reproduce. would appreciate if someone could check it out ? .... ] downloading using http(s) network [ gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar.xz ] [#5fb5ad 4.6MiB/24MiB(18%) CN:1 DL:6.3MiB ETA:3s] [#5fb5ad 13MiB/24MiB(53%) CN:1 DL:7.7MiB ETA:1s] [#5fb5ad 22MiB/24MiB(90%) CN:1 DL:8.3MiB] [ error ] ERROR in function download_and_verify [ general.sh:869 ] [ error ] verification failed thank you ! Link to comment Share on other sites More sharing options...
Igor Posted June 12, 2019 Share Posted June 12, 2019 Can you provide some info from output/debug folder ... on my test KVM virtual x64 machine running Bionic it builds fine. Under Docker, native as well. - removing Docker image? - removing build directory and start from scratch? Link to comment Share on other sites More sharing options...
