[solved]orange pi zero plus got a higher temperature in armbian 5.83
noxlin
update: the 5.59.180828 nightly building version may display a error temperature degree。
 test real temperature using a thermometer ,two version display the same degree in thermometer about 49degree idle。
1. same board:orange pi zero plus  v1.1,same room temp.
2. armbian 5.59.180828 nightly , idle cpu temp. about:49 degree.
Welcome to ARMBIAN 5.59.180828 nightly Debian GNU/Linux 9 (stretch) 4.14.67-sunxi64
Linux opizeroh5 4.14.67-sunxi64 #85 SMP Tue Aug 28 10:55:16 CEST 2018 aarch64 GNU/Linux
Stop monitoring using [ctrl]-[c]
Time      CPU n/a    load %cpu %sys %usr %nice %io %irq   CPU
12:30:54:   ---      0.00   1%   0%   0%   0%   0%   0% 49.4°C
12:31:00:   ---      0.00   0%   0%   0%   0%   0%   0% 49.2°C
12:31:05:   ---      0.00   0%   0%   0%   0%   0%   0% 49.4°C
12:31:10:   ---      0.00   0%   0%   0%   0%   0%   0% 49.2°C
12:31:15:   ---      0.00   0%   0%   0%   0%   0%   0% 49.5°C
12:31:20:   ---      0.00   0%   0%   0%   0%   0%   0% 49.0°C
12:31:25:   ---      0.00   0%   0%   0%   0%   0%   0% 48.9°C
12:31:30:   ---      0.00   0%   0%   0%   0%   0%   0% 49.0°C
12:31:35:   ---      0.00   0%   0%   0%   0%   0%   0% 48.6°C
12:31:40:   ---      0.00   0%   0%   0%   0%   0%   0% 49.0°C
12:31:45:   ---      0.00   0%   0%   0%   0%   0%   0% 49.4°C
2. ARMBIAN 5.83 stable idle cpu temp. about:57 degree.
Welcome to ARMBIAN 5.83 stable Debian GNU/Linux 9 (stretch) 4.19.38-sunxi64
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
04:37:59:  120MHz  0.09   1%   1%   0%   0%   0%   0% 57.6°C  0/6
04:38:04:  120MHz  0.08   1%   1%   0%   0%   0%   0% 57.5°C  0/6
04:38:09:  120MHz  0.07   1%   0%   0%   0%   0%   0% 57.4°C  0/6
04:38:15:  120MHz  0.07   1%   0%   0%   0%   0%   0% 57.5°C  0/6
04:38:20: 1008MHz  0.06   3%   1%   1%   0%   0%   0% 57.7°C  0/6
04:38:25:  120MHz  0.06   1%   0%   0%   0%   0%   0% 57.5°C  0/6
04:38:30:  120MHz  0.05   1%   1%   0%   0%   0%   0% 57.6°C  0/6
04:38:35:  120MHz  0.05   1%   1%   0%   0%   0%   0% 57.4°C  0/6
thanks
