Error with repository https://apt.armbian.com
canabino
I did a new install of Armbian 5.88 Debian Stretch
I then ran
apt update
I got the following error:
Err:8 https://apt.armbian.com stretch Release
  server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
Reading package lists... Done
E: The repository 'https://apt.armbian.com stretch Release' does no longer have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
I then ran
apt-get install --reinstall ca-certificates
but still get the same error.
Edited by canabino
I don't understand because it is comunicating with the debian servers correctly.
It just fails at Armbian's
This is a new install
root@rockpi:~# apt-get update
Hit:1 http://security.debian.org stretch/updates InRelease
Ign:2 http://cdn-fastly.deb.debian.org/debian stretch InRelease
Hit:3 http://cdn-fastly.deb.debian.org/debian stretch-updates InRelease
Hit:4 http://cdn-fastly.deb.debian.org/debian stretch-backports InRelease
Hit:5 http://cdn-fastly.deb.debian.org/debian stretch Release
Ign:7 https://apt.armbian.com stretch InRelease
Now I get this.
Spoiler
Get:1 http://security.debian.org stretch/updates InRelease [94.3 kB]
Get:3 http://cdn-fastly.deb.debian.org/debian stretch-updates InRelease [91.0 kB]
Ign:6 https://apt.armbian.com stretch InRelease
Get:7 http://security.debian.org stretch/updates/main arm64 Packages [479 kB]
Get:4 http://cdn-fastly.deb.debian.org/debian stretch-backports InRelease [91.8 kB]
Ign:9 https://apt.armbian.com stretch Release
Get:10 http://security.debian.org stretch/updates/main armhf Packages [484 kB]
Ign:11 https://apt.armbian.com stretch/main arm64 Packages
Ign:12 https://apt.armbian.com stretch/main armhf Packages
Ign:13 https://apt.armbian.com stretch/main all Packages
Ign:14 https://apt.armbian.com stretch/main arm64 Contents (deb)
Ign:15 https://apt.armbian.com stretch/main all Contents (deb)
Ign:16 https://apt.armbian.com stretch/main armhf Contents (deb)
Ign:17 https://apt.armbian.com stretch arm64 Contents (deb)
Ign:18 https://apt.armbian.com stretch all Contents (deb)
Ign:19 https://apt.armbian.com stretch armhf Contents (deb)
Ign:20 https://apt.armbian.com stretch/stretch-utils all Packages
Ign:21 https://apt.armbian.com stretch/stretch-utils armhf Packages
Ign:22 https://apt.armbian.com stretch/stretch-utils arm64 Packages
Ign:23 https://apt.armbian.com stretch/stretch-utils armhf Contents (deb)
Ign:24 https://apt.armbian.com stretch/stretch-utils arm64 Contents (deb)
Ign:25 https://apt.armbian.com stretch/stretch-utils all Contents (deb)
Ign:26 https://apt.armbian.com stretch/stretch-desktop armhf Packages
Ign:27 https://apt.armbian.com stretch/stretch-desktop arm64 Packages
Ign:28 https://apt.armbian.com stretch/stretch-desktop all Packages
Ign:29 https://apt.armbian.com stretch/stretch-desktop all Contents (deb)
Ign:30 https://apt.armbian.com stretch/stretch-desktop armhf Contents (deb)
Ign:31 https://apt.armbian.com stretch/stretch-desktop arm64 Contents (deb)
Err:11 https://apt.armbian.com stretch/main arm64 Packages
Fetched 1240 kB in 1min 50s (11.2 kB/s)
W: The repository 'https://apt.armbian.com stretch Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Failed to fetch https://apt.armbian.com/dists/stretch/main/binary-arm64/Packages  server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
E: Some index files failed to download. They have been ignored, or old ones used instead.
I had this issue but after reconfiguring the ca-certs I got the root of the problem:
Err:6 https://apt.armbian.com buster Release
  Could not wait for server fd - select (11: Resource temporarily unavailable) [IP: 2001:bb8:4008:20:5054:ff:fea8:96fc 443]
adding 193.40.103.96 apt.armbian.com to /etc/hosts fixed it for me
3 hours ago, jinxjim said:
I am getting packages from deb.debian.org using IPv6 address without any issues, just armbian seems to be slow or some other issue, hence fixing it as IPv4 in the hosts file fixed the problem
OK, we will check if issue is on our side.
Hi Igor,
The problem still occurs. I changed to the China mirror https://mirrors.tuna.tsinghua.edu.cn/armbian and it works OK with IPv6.
It does not affect me and I have already 2 workarounds, just to let you know that IPv6 is not working at apt.armbian.com but it does have an IPv6 address assigned to it.
Hi,
Since a few days, from time to time, I get a similar issue :
W: The repository 'http://apt.armbian.com stretch Release' does not have a Release file.
E: Failed to fetch https://apt.armbian.com/dists/stretch/main/binary-armhf/Packages  server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
I don't know about reconfiguring ca-certificates, but by forcing apt-get to use IPv4, I could workaround the issue. But I must insist : sometimes, it works without forcing apt-get to use IPv4.
echo 'Acquire::ForceIPv4 "true";' | sudo tee /etc/apt/apt.conf.d/99force-ipv4
If someone has an idea how to find out the exact root cause, I'm available to do some testing.
21 hours ago, Igor said:
No idea what else could be wrong?
On my side, no, I don't. I intermittently got this error message during my tests to automate my SBC's installation (from scratch). But the image and the network configuration of the SBC have been the same since the beginning. And I haven't change my network setup lately.
The only idea I can think of is a network issue between your hosting provider and my ISP or maybe my ISP's DNS server giving me a wrong answer.
Since I also had this problem:
Your time is probably off. I installed an image from a while ago and the time on the board didn't update. Then the certificates are invalid, because they're only valid for 30 days. I did set the time roughly correct to get it going:
sudo date --set="2020-06-26 09:05:59.990"
After that everything starts working again.
Having the same issue.
Spoiler
Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; export LANGUAGE=; apt-get update 2>&1' with exit code '100': Get:1 file:/var/cache/openmediavault/archives  InRelease
Ign:1 file:/var/cache/openmediavault/archives  InRelease
Get:2 file:/var/cache/openmediavault/archives  Release
Ign:2 file:/var/cache/openmediavault/archives  Release
Get:3 file:/var/cache/openmediavault/archives  Packages
Ign:3 file:/var/cache/openmediavault/archives  Packages
Get:4 file:/var/cache/openmediavault/archives  Contents (deb)
Ign:4 file:/var/cache/openmediavault/archives  Contents (deb)
Get:5 file:/var/cache/openmediavault/archives  Contents (deb)
Ign:5 file:/var/cache/openmediavault/archives  Contents (deb)
Get:6 file:/var/cache/openmediavault/archives  Contents (deb)
Ign:6 file:/var/cache/openmediavault/archives  Contents (deb)
Hit:7 http://deb.debian.org/debian bullseye InRelease
Hit:8 http://security.debian.org bullseye-security InRelease
Hit:9 http://deb.debian.org/debian bullseye-updates InRelease
Hit:10 http://httpredir.debian.org/debian bullseye-backports InRelease
Hit:11 http://packages.openmediavault.org/public shaitan InRelease
Hit:12 http://security.debian.org/debian-security bullseye-security InRelease
Hit:13 https://openmediavault-plugin-developers.github.io/packages/debian shaitan InRelease
Hit:14 https://openmediavault.github.io/packages shaitan InRelease
Get:15 https://download.docker.com/linux/debian bullseye InRelease [43.3 kB]
Ign:16 https://apt.armbian.com bullseye InRelease
Err:17 https://apt.armbian.com bullseye Release
  Redirection from https to 'http://stpete-mirror.armbian.com/apt/dists/bullseye/Release' is forbidden [IP: 173.45.128.12 443]
E: The repository 'https://apt.armbian.com bullseye Release' no longer has a Release file.
OMV\ExecException: Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; export LANGUAGE=; apt-get update 2>&1' with exit code '100': Get:1 file:/var/cache/openmediavault/archives  InRelease
E: The repository 'https://apt.armbian.com bullseye Release' no longer has a Release file. in /usr/share/openmediavault/engined/rpc/apt.inc:251
Stack trace:
#0 /usr/share/php/openmediavault/rpc/serviceabstract.inc(588): Engined\Rpc\Apt->Engined\Rpc\{closure}('/tmp/bgstatusnO...', '/tmp/bgoutputli...')
#1 /usr/share/openmediavault/engined/rpc/apt.inc(255): OMV\Rpc\ServiceAbstract->execBgProc(Object(Closure))
#2 [internal function]: Engined\Rpc\Apt->update(NULL, Array)
#3 /usr/share/php/openmediavault/rpc/serviceabstract.inc(123): call_user_func_array(Array, Array)
#4 /usr/share/php/openmediavault/rpc/rpc.inc(86): OMV\Rpc\ServiceAbstract->callMethod('update', NULL, Array)
#5 /usr/sbin/omv-engined(537): OMV\Rpc\Rpc::call('Apt', 'update', NULL, Array, 1)
#6 {main}
Tried all of this
dpkg-reconfigure ca-certificates
\\Also added "173.45.128.12 apt.armbian.com" to /etc/hosts after pinging it and getting the IP-address
Ipv4 echo "'Acquire::ForceIPv4 "true";' | sudo tee /etc/apt/apt.conf.d/99force-ipv4"
Getting the following:
Spoiler
Hit:7 http://httpredir.debian.org/debian bullseye-backports InRelease
Hit:8 http://deb.debian.org/debian bullseye InRelease
Hit:9 http://security.debian.org bullseye-security InRelease
Hit:10 http://packages.openmediavault.org/public shaitan InRelease
Hit:11 http://deb.debian.org/debian bullseye-updates InRelease
Get:13 https://download.docker.com/linux/debian bullseye InRelease [43.3 kB]
Hit:15 https://openmediavault-plugin-developers.github.io/packages/debian shaitan InRelease
  Redirection from https to 'http://imola.armbian.com/apt/dists/bullseye/Release' is forbidden [IP: 173.45.128.12 443]
 And yes - NTP working correctly and time is OK
