Igor Posted March 22, 2020 Share Posted March 22, 2020 22 hours ago, Tido said: Ubuntu's Icon set URLs to a new icon in the code is preferred way. 1 hour ago, Tido said: So, my PR only contains the readme.md That's o.k. I'll check it later. Currently working on code fixes and I don't have more ports to attach devices. My home office has only 8 x 10GB and 42 x 1GB ports Link to comment Share on other sites More sharing options...
Tido Posted March 24, 2020 Share Posted March 24, 2020 IS ANYBODY OUT THERE ??? I have improved the How To, Igor improved the Tool even more. Will you please give it a chance and test your Single-Board-Computer (SBC) - who doesn't like to test and tinker ;). If you depend on your installation do a backup of your SDcard first and then, please give it a try: https://github.com/armbian/autotests Report back here or on github if bad or good. If good even more, who doesn't like to hear it works well. Thank you 1 Link to comment Share on other sites More sharing options...
Igor Posted March 24, 2020 Share Posted March 24, 2020 When people will realise, when we will know how to tell them that, that stability of their systems depends from the things like this, then perhaps someone will also follow and wire stuff together, perhaps find it interesting to deal with and do it instead of me ... This is essentially a (cool) tool for us to quickly see how things looks from the users perspective. Now and for the future. With most boards at once. If anyone wants to have this look or help to creates that looks, one shell join. But I don't expect people staying in the line to help out. Even its is in their, ours interest. 1 Link to comment Share on other sites More sharing options...
Tido Posted March 28, 2020 Share Posted March 28, 2020 On 3/22/2020 at 8:53 PM, Igor said: URLs to a new icon in the code is preferred way. Which is making an internet connection necessary. Your current update including the icon is my preferred method. As mentioned before I would look for SVG as this scales smoothly. I stopped looking for icons of SVG because of your comment before. - any changes on your side? You have edited my suggestion (PR) for the ReadME.md and removed the installation procedure I put there. To simulate my initial situation on Ubuntu Mate 18.04.4 I did remove: sudo apt-get remove sshpass iperf3 jq The test is running twice, my root user credentials are given. My phone is laying around bluetooth enabled, WiFi on the router is on - Rock Pi 4B. I got 2x Syntax error and 1x [ err. ] Wrong sources were installed plus the missing software `dpkg -l sshpass git iperf3 jq` Spoiler $ ./go.sh [ o.k. ] Host ###.###.###.7 found [ Run 1 out of 2 ] [ o.k. ] [ ###.###.###.7 ] [ o.k. ] 0002-update-and-upgrade.bash [ 10:21:09 ] [ o.k. ] Updating and upgrading [ packages ] [ o.k. ] 0008-connect-wireless-devices-on-2.4Ghz.bash [ 10:21:09 ] [ o.k. ] 0013-iperf-on-all-wired-interfaces.bash [ 10:21:12 ] [ o.k. ] 0014-iperf-on-all-wireless-interfaces.bash [ 10:21:13 ] [ o.k. ] 0015-connect-wireless-devices-on-5.0Ghz.bash [ 10:21:14 ] [ o.k. ] 0017-iperf-on-all-wireless-interfaces.bash [ 10:21:14 ] [ o.k. ] 0018-io-tests-memory.bash [ 10:21:15 ] (standard_in) 1: syntax error (standard_in) 1: syntax error [ o.k. ] Max random memory throughput on 16Mb files [ Read: MBits/s - Write: MBits/s ] [ o.k. ] 0019-io-tests-drive.bash [ 10:21:15 ] (standard_in) 1: syntax error (standard_in) 1: syntax error [ o.k. ] Max random roofs throughput on 16Mb files [ Read: MBits/s - Write: MBits/s ] [ o.k. ] 0111-bluetoth.bash [ o.k. ] 0115-strong-stressing.bash [ 10:21:15 + 18s ] /media/Daten_1/01_Computer/01.05_GIT/autotests/tests/0115-strong-stressing.bash: Zeile 9: sshpass: Befehl nicht gefunden [ o.k. ] 0116-dvfs.bash [ 10:21:15 ] [ o.k. ] 9500-install-kernel-sources.bash [ err. ] Wrong sources were installed [ o.k. ] 9999-reboot.bash [ 10:21:15 ] [ o.k. ] Rebooting in 3 seconds [ o.k. ] Host ###.###.###.7 found [ Run 2 out of 2 ] [ o.k. ] [ ###.###.###.7 ] [ o.k. ] 0002-update-and-upgrade.bash [ 10:21:38 ] [ o.k. ] Updating and upgrading [ packages ] [ o.k. ] 0008-connect-wireless-devices-on-2.4Ghz.bash [ 10:21:38 ] [ o.k. ] 0013-iperf-on-all-wired-interfaces.bash [ 10:21:41 ] [ o.k. ] 0014-iperf-on-all-wireless-interfaces.bash [ 10:21:42 ] [ o.k. ] 0015-connect-wireless-devices-on-5.0Ghz.bash [ 10:21:43 ] [ o.k. ] 0017-iperf-on-all-wireless-interfaces.bash [ 10:21:43 ] [ o.k. ] 0018-io-tests-memory.bash [ 10:21:44 ] (standard_in) 1: syntax error (standard_in) 1: syntax error [ o.k. ] Max random memory throughput on 16Mb files [ Read: MBits/s - Write: MBits/s ] [ o.k. ] 0019-io-tests-drive.bash [ 10:21:44 ] (standard_in) 1: syntax error (standard_in) 1: syntax error [ o.k. ] Max random roofs throughput on 16Mb files [ Read: MBits/s - Write: MBits/s ] [ o.k. ] 0111-bluetoth.bash [ o.k. ] 0115-strong-stressing.bash [ 10:21:44 + 18s ] /media/Daten_1/01_Computer/01.05_GIT/autotests/tests/0115-strong-stressing.bash: Zeile 9: sshpass: Befehl nicht gefunden [ o.k. ] 0116-dvfs.bash [ 10:21:44 ] [ o.k. ] 9500-install-kernel-sources.bash [ err. ] Wrong sources were installed [ o.k. ] 9999-reboot.bash [ 10:21:44 ] [ o.k. ] Rebooting in 3 seconds This whole procedure took 0 minutes. Link to comment Share on other sites More sharing options...
Igor Posted March 28, 2020 Share Posted March 28, 2020 34 minutes ago, Tido said: You have edited my suggestion (PR) for the ReadME.md and removed the installation procedure I put there. To simulate my initial situation on Ubuntu Mate 18.04.4 I did remove: Yes, since its not needed. Script should take care of that. Well, a sudo apt install has to be added ... 34 minutes ago, Tido said: The test is running twice, my root user credentials are given. My phone is laying around bluetooth enabled, WiFi on the router is on - Rock Pi 4B. I got 2x Syntax error and 1x [ err. ] Wrong sources were installed plus the missing software `dpkg -l sshpass git iperf3 jq` - syntax error has to be ironed out, working on it - wrong sources is a correct response of a test case. My tests are now automatically upload to https://dl.armbian.com/_test-reports/ Link to comment Share on other sites More sharing options...
Tido Posted March 31, 2020 Share Posted March 31, 2020 On 3/28/2020 at 11:05 AM, Igor said: Well, a sudo apt install has to be added ... in the code and then the execution needs sudo? Link to comment Share on other sites More sharing options...
Igor Posted March 31, 2020 Share Posted March 31, 2020 18 minutes ago, Tido said: in the code and then the execution needs sudo? The only sudo here is for installing dependencies. https://github.com/armbian/autotests/blob/master/go.sh#L13 Link to comment Share on other sites More sharing options...
Tido Posted March 31, 2020 Share Posted March 31, 2020 28 minutes ago, Igor said: installing dependencies there is no information given, that my system is downloading software. I hate these kind of installer like Firefox, TEAMS and so on. autotests$ ./go.sh [sudo] Password for tido: Setup finished. Edit userconfig/configuration.sh and run ./go.sh again! reto@X470-ULTRA:/media/Daten_1/01_Computer/01.05_GIT/autotests$ First run, on line 127 it couldn't find something: autotests$ ./go.sh ./go.sh: Zeile 127: /media/Daten_1/01_Computer/01.05_GIT/autotests/reports/data.in: Datei oder Verzeichnis nicht gefunden [ o.k. ] 0. RockPi-4B Linux 5.4.28-rockchip64 stable [ 11.13 ] [ o.k. ] Host 11.13 found [ Run 1 out of 2 ] I have configured 2 passes and it took 17 minutes - is this normal? [ o.k. ] Rebooting in 3 seconds [ RockPi-4B ] diff: /media/Daten_1/01_Computer/01.05_GIT/autotests/reports/data.in: Datei oder Verzeichnis nicht gefunden This whole procedure took 17 minutes. Link to comment Share on other sites More sharing options...
Igor Posted March 31, 2020 Share Posted March 31, 2020 1 hour ago, Tido said: First run, on line 127 it couldn't find something: Will be fixed. 1 hour ago, Tido said: I have configured 2 passes and it took 17 minutes - is this normal? In my case, 21 devices, 2 passes = 357 minutes. Link to comment Share on other sites More sharing options...
Tido Posted April 1, 2020 Share Posted April 1, 2020 22 hours ago, Igor said: 357 minutes. Is it the download that makes it so long and if so, why does it need a download in it? If it is only for you, fair enough - but if testers just want to test locally their devices and apart from that this generates quite some load on the servers and network traffic. How many user switch the kernels or need the sources - I guess most don't. So, if it is for a minorty only, why should everybody doing it. Last but not least, you want many to use it and to help/report - it should be kept like a Mini (car) "As little as possible, as much as required". Just my 2 cents, for me it is obviously too much. I like the idea to report back online to collect the data, but the nightly/stable & sources is just a waste of resources IMHO. Link to comment Share on other sites More sharing options...
Igor Posted April 1, 2020 Share Posted April 1, 2020 20 minutes ago, Tido said: Is it the download that makes it so long and if so, why does it need a download in it? Sources install is the slowest process. Not just download, but also unpacking, lots of small files. 20 minutes ago, Tido said: If it is only for you, fair enough - but if testers just want to test locally their devices and apart from that this generates quite some load on the servers and network traffic. I plan to group tests later ... now just trying to make usable ones and create an engine. Since this is not designed for end users in first place, things like this does not matter. 20 minutes ago, Tido said: How many user switch the kernels or need the sources - I guess most don't. This tools is for analysing the situation. 20 minutes ago, Tido said: for me it is obviously too much. For me, it tells very little at this point. Current tests are inside only to build a system around ... while several hundreds of testes should be the correct number. I doubt we will ever get there, but it has to be made possible. https://www.toolsqa.com/software-testing-tutorial/ Link to comment Share on other sites More sharing options...
Igor Posted April 2, 2020 Share Posted April 2, 2020 New Armbian CI autotest facility: Switch: https://amzn.to/2w91QIZ USB PSU: https://amzn.to/2R2mzW8 HUB: https://amzn.to/343ysQS 2 Link to comment Share on other sites More sharing options...
Tido Posted April 2, 2020 Share Posted April 2, 2020 On 4/1/2020 at 10:08 PM, Igor said: to make usable ones How long or how many times does it try to get the WiFi connection? I am asking, because mine was not successful in both passes. Link to comment Share on other sites More sharing options...
Igor Posted April 2, 2020 Share Posted April 2, 2020 44 minutes ago, Tido said: How long or how many times does it try to get the WiFi connection? Currently it does not retries. Only once. Will do two retries, otherwise error. 1 Link to comment Share on other sites More sharing options...
lanefu Posted April 3, 2020 Author Share Posted April 3, 2020 6 hours ago, Igor said: New Armbian CI autotest facility That's pretty sweet!. Are you using NFS images, or just swappign sdcards? Link to comment Share on other sites More sharing options...
Igor Posted April 3, 2020 Share Posted April 3, 2020 3 hours ago, lanefu said: That's pretty sweet!. Are you using NFS images, or just swappign sdcards? SD card swapping at this point. For that it would be ideally to use @Hijax invention. But already without, I see where things needs repair. Link to comment Share on other sites More sharing options...
Hijax Posted April 5, 2020 Share Posted April 5, 2020 @Tido et all, here comes the files of the project I started but had to suspend. Firstly, as I by mistake did a short circut using the only board I have assembled. Secondly - covid syndrome (the same number of tasks at work, twice the number of meetings and no workshop entry) Anyway, latest files I have on my github. Zipped. 3 folders - 3 KiCad projects: source files, bom, other docs needed and so on. Have a fun and stay healthy! armbian-testing.zip Link to comment Share on other sites More sharing options...
Tido Posted April 5, 2020 Share Posted April 5, 2020 (edited) 8 hours ago, Hijax said: KiCad projects: source files, bom, other docs needed @TonyMac32 & @martinayotte I thought, there are some PCB manufacturer that do also the assembly, as long as your board uses parts they 'have'. Do you already have experience with such an approach? Could you support to replace/find another part if one isn't in the assemblers list? (my knowledge is too little) PS: I think the __MACOSX in the .zip is empty - it contains only some 212 bytes files. PPS: I think this is what it should look like completed @Hijax all PCBs are needed, or is one just an improvement? https://forum.armbian.com/topic/10841-the-testing-thread/?do=findComment&comment=83460 Edited April 5, 2020 by Tido PPS: Link to comment Share on other sites More sharing options...
martinayotte Posted April 5, 2020 Share Posted April 5, 2020 4 minutes ago, Tido said: there are some PCB manufacturer that do also the assembly Right ! But never tried such services ... Link to comment Share on other sites More sharing options...
Hijax Posted April 5, 2020 Share Posted April 5, 2020 12 minutes ago, Tido said: PS: I think the __MACOSX in the .zip is empty - it contains only some 212 bytes files. Well, it is Mac OS resource "garbage" you can delete it. Link to comment Share on other sites More sharing options...
Igor Posted April 6, 2020 Share Posted April 6, 2020 19 hours ago, Hijax said: Anyway, latest files I have on my github. Zipped. 3 folders - 3 KiCad projects: source files, bom, other docs needed and so on. Do we have someone to build this together? I can ask around, just need to know. Link to comment Share on other sites More sharing options...
Tido Posted April 6, 2020 Share Posted April 6, 2020 5 hours ago, Igor said: Do we have someone to build this together? This is not the big deal, but it would cost a fortune in my country just to get an empty PCB in such little quantity. So, it was my idea to find a company in China as mentioned in this posting: https://forum.armbian.com/topic/10841-the-testing-thread/?do=findComment&comment=98628 to manufactur these. If you have some contacts in your country or China to support this - would be good to ask. Link to comment Share on other sites More sharing options...
Hijax Posted April 6, 2020 Share Posted April 6, 2020 @Tido no idea what country is yours but I can suggest ... use google for searching china pcb prototyping. I have recently used easyeda service, or jlcpcb. They manufacture 5 pcs (of each board, hence 3 times 5 pcs) for as little as 2USD plus delivery. Check their site. They can also do some basic assembly (I was not using that option yet, they can have some parts at their stock, anyway you may discuss the SMD soldering only as THT is simpe one) Happens I have 4 set of boards (as I assembled one set only) and I can send those somewhere, to @Igor for example? 1 Link to comment Share on other sites More sharing options...
Tido Posted April 6, 2020 Share Posted April 6, 2020 (edited) On 4/5/2020 at 10:23 PM, martinayotte said: Right ! But never tried such services . Okay, I gave it a try. First I tried to improve the Bill-of-Materials form Hijax. I tried to identify the SMT parts (added a column in the attached file and put some text into it what I have changed). Then I searched for the parts of the BOM here: https://jlcpcb.com/parts LED and Resistor I have identified based on Hijax given size and jlcpcb categories. However, Multiplexer and such is way above my knowledge. There are only 9-10 parts to check in total, I have done the ground work. Can you help please?? If JLCPCB doesn't fit, but we have the parts list ready (checked and amended from you) we can try others like https://www.pcbway.com/pcb-assembly.html Edit: just thinking, would a Google doc be better to edit together? Edited April 12, 2020 by Tido removed the file, created a Google Doc instead. Link to comment Share on other sites More sharing options...
Tido Posted April 12, 2020 Share Posted April 12, 2020 I just rebuilt the spreadsheet on Google Docs, I guess this is much easier to collaborate on it. If you know or can identify parts help in anyway on the spreadsheet, please do so ! Everybody with this link can edit the spreadsheet: https://docs.google.com/spreadsheets/d/1oY_UJ96TEbG_bAzAeGBGShQAwNG9pA1H8YOkfF7M-3Q/edit?usp=sharing Link to comment Share on other sites More sharing options...
martinayotte Posted April 12, 2020 Share Posted April 12, 2020 34 minutes ago, Tido said: I just rebuilt the spreadsheet on Google Docs I think the 2 last parts, 74LS151 and 74LS157, should be HC not LS, since HC is 3.3V compatible but not LS which are 5V only ... Link to comment Share on other sites More sharing options...
Hijax Posted April 12, 2020 Share Posted April 12, 2020 17 minutes ago, martinayotte said: I think the 2 last parts, 74LS151 and 74LS157, should be HC not LS, since HC is 3.3V compatible but not LS which are 5V only ... Very true... Link to comment Share on other sites More sharing options...
Tido Posted April 12, 2020 Share Posted April 12, 2020 What about MOLEX_47219-2001 SD card connector - Second or 3rd party source? Link to comment Share on other sites More sharing options...
Hijax Posted April 12, 2020 Share Posted April 12, 2020 Just now, Tido said: What about MOLEX_47219-2001 SD card connector - Second or 3rd party source? I have sourced that from tme.eu Link to comment Share on other sites More sharing options...
Tido Posted April 12, 2020 Share Posted April 12, 2020 @Hijax, By second source I mean the "same" product from another manufacturer that has the same footprint like the one we already have, for example: 47219-2001 - Hinge Memory Socket, 47219 Series, Micro SD, 8 contacts, 5000 cycles https://sg.element14.com/molex/47219-2001/connector-micro-sd-8pos/dp/2614940 DM3CS-SF - Hinge Memory Socket, DM3, 8 contacts, https://ch.farnell.com/hirose-hrs/dm3cs-sf/steckverbinder-micro-sd-hinge/dp/1764376 460DE08C3 - Hinge Memory Socket, 460DE, 8 contacts, https://ch.farnell.com/multicomp/460de08c3/stecker-micro-sd-hinged/dp/1686452 502774-0891 - Push - Push Memory Socket, 502774, Micro SD, 8 contacts, https://ch.farnell.com/molex/502774-0891/steckverbinder-microsd-8pos/dp/2064063 DM3D-SF - Push - Push Memory Socket, DM3, 8 contacts, https://ch.farnell.com/hirose-hrs/dm3d-sf/steckverbinder-micro-sd-push-pull/dp/1764377 Why did you choose the one with a hinge and not: Hirose DM3CS (Hinge, Push-Pull, manual, without ejection mechanism) Hirose DM3AT and DM3BT (Push - Push, with ejection mechanism) Hirose DM3D (Push -Pull, manual, without ejection mechanism) Link to comment Share on other sites More sharing options...
