guidol Posted July 10, 2019 Share Posted July 10, 2019 Today I did want to compile a image, but at the start of creating the image I do get the following messages: [ o.k. ] Downloading sources [ o.k. ] Checking git sources [ u-boot v2019.04 ] fatal: read error: Connection reset by peer fatal: read error: Connection reset by peer [ .... ] Fetching updates fatal: read error: Connection reset by peer [ .... ] Checking out error: pathspec 'FETCH_HEAD' did not match any file(s) known to git. after that lines the compile do work like there is no problem..... Link to comment Share on other sites More sharing options...
guidol Posted July 10, 2019 Author Share Posted July 10, 2019 BTW: inside the image creation I also do get the value-changes for apt & buster: E: Repository 'http://httpredir.debian.org/debian buster InRelease' changed its 'Suite' value from 'testing' to 'stable' E: Repository 'http://httpredir.debian.org/debian buster-updates InRelease' changed its 'Suite' value from 'testing-updates' to 'stable-updates' E: Repository 'http://security.debian.org buster/updates InRelease' changed its 'Suite' value from 'testing' to 'stable' I dont know if they would be accepted in the script because of the E: (for Error)? Link to comment Share on other sites More sharing options...
Grin Posted July 10, 2019 Share Posted July 10, 2019 I have the same problem. And the compilation ends with an error. Yesterday everything was fine. [ o.k. ] Downloading sources [ o.k. ] Checking git sources [ u-boot v2018.05 ] [ .... ] Creating local copy fatal: read error: Connection reset by peer fatal: read error: Connection reset by peer [ .... ] Fetching updates fatal: read error: Connection reset by peer [ .... ] Checking out error: pathspec 'FETCH_HEAD' did not match any file(s) known to git. [ o.k. ] Checking git sources [ linux-sun8i sun8i ] [ .... ] Creating local copy [ .... ] Fetching updates remote: Enumerating objects: 45974, done. remote: Counting objects: 100% (45974/45974), done. remote: Compressing objects: 100% (40178/40178), done. remote: Total 45974 (delta 5234), reused 45827 (delta 5178), pack-reused 0 Receiving objects: 100% (45974/45974), 129.72 MiB | 5.93 MiB/s, done. Resolving deltas: 100% (5234/5234), done. From https://github.com/igorpecovnik/linux * branch sun8i -> FETCH_HEAD * [new branch] sun8i -> origin/sun8i [ .... ] Checking out [ o.k. ] Checking git sources [ sunxi-tools master ] [ .... ] Creating local copy [ .... ] Fetching updates remote: Enumerating objects: 88, done. remote: Counting objects: 100% (88/88), done. remote: Compressing objects: 100% (83/83), done. remote: Total 88 (delta 14), reused 36 (delta 4), pack-reused 0 Unpacking objects: 100% (88/88), done. From https://github.com/linux-sunxi/sunxi-tools * branch master -> FETCH_HEAD * [new branch] master -> origin/master [ .... ] Checking out [ o.k. ] Checking git sources [ rkbin-tools master ] [ .... ] Creating local copy [ .... ] Fetching updates remote: Enumerating objects: 333, done. remote: Counting objects: 100% (333/333), done. remote: Compressing objects: 100% (235/235), done. remote: Total 333 (delta 105), reused 309 (delta 97), pack-reused 0 Receiving objects: 100% (333/333), 27.92 MiB | 5.71 MiB/s, done. Resolving deltas: 100% (105/105), done. From https://github.com/armbian/rkbin * branch master -> FETCH_HEAD * [new branch] master -> origin/master [ .... ] Checking out [ o.k. ] Checking git sources [ marvell-tools A3700_utils-armada-18.12 ] [ .... ] Creating local copy [ .... ] Fetching updates remote: Enumerating objects: 289, done. remote: Counting objects: 100% (289/289), done. remote: Compressing objects: 100% (156/156), done. remote: Total 289 (delta 147), reused 210 (delta 130), pack-reused 0 Receiving objects: 100% (289/289), 5.78 MiB | 4.64 MiB/s, done. Resolving deltas: 100% (147/147), done. From https://github.com/MarvellEmbeddedProcessors/A3700-utils-marvell * branch A3700_utils-armada-18.12 -> FETCH_HEAD * [new branch] A3700_utils-armada-18.12 -> origin/A3700_utils-armada-18.12 [ .... ] Checking out [ o.k. ] Checking git sources [ marvell-ddr mv_ddr-armada-18.12 ] [ .... ] Creating local copy [ .... ] Fetching updates remote: Enumerating objects: 120, done. remote: Counting objects: 100% (120/120), done. remote: Compressing objects: 100% (112/112), done. remote: Total 120 (delta 54), reused 16 (delta 4), pack-reused 0 Receiving objects: 100% (120/120), 1.48 MiB | 3.11 MiB/s, done. Resolving deltas: 100% (54/54), done. From https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell * branch mv_ddr-armada-18.12 -> FETCH_HEAD * [new branch] mv_ddr-armada-18.12 -> origin/mv_ddr-armada-18.12 [ .... ] Checking out [ o.k. ] Checking git sources [ marvell-binaries binaries-marvell-armada-18.12 ] [ .... ] Creating local copy [ .... ] Fetching updates remote: Enumerating objects: 4, done. remote: Counting objects: 100% (4/4), done. remote: Compressing objects: 100% (4/4), done. remote: Total 4 (delta 0), reused 3 (delta 0), pack-reused 0 Unpacking objects: 100% (4/4), done. From https://github.com/MarvellEmbeddedProcessors/binaries-marvell * branch binaries-marvell-armada-18.12 -> FETCH_HEAD * [new branch] binaries-marvell-armada-18.12 -> origin/binaries-marvell-armada-18.12 [ .... ] Checking out [ o.k. ] Checking git sources [ odroidc2-blobs master ] [ .... ] Creating local copy [ .... ] Fetching updates remote: Enumerating objects: 32, done. remote: Counting objects: 100% (32/32), done. remote: Compressing objects: 100% (31/31), done. remote: Total 32 (delta 1), reused 29 (delta 1), pack-reused 0 Unpacking objects: 100% (32/32), done. From https://github.com/armbian/odroidc2-blobs * branch master -> FETCH_HEAD * [new branch] master -> origin/master [ .... ] Checking out [ o.k. ] Checking git sources [ testing-reports master ] [ .... ] Creating local copy [ .... ] Fetching updates remote: Enumerating objects: 139, done. remote: Counting objects: 100% (139/139), done. remote: Compressing objects: 100% (81/81), done. remote: Total 139 (delta 62), reused 115 (delta 56), pack-reused 0 Receiving objects: 100% (139/139), 34.42 KiB | 370.00 KiB/s, done. Resolving deltas: 100% (62/62), done. From https://github.com/armbian/testings * branch master -> FETCH_HEAD * [new branch] master -> origin/master [ .... ] Checking out [ o.k. ] Compiling [ sunxi-tools ] Setting version information: 42ffc5f [ o.k. ] Installing [ rkbin-tools ] [ o.k. ] Cleaning output/debs for [ orangepizero default ] [ o.k. ] Cleaning [ u-boot/v2018.05 ] grep: /home/user/development/armbian/build/cache/sources/u-boot/v2018.05/Makefile: No such file or directory grep: /home/user/development/armbian/build/cache/sources/u-boot/v2018.05/Makefile: No such file or directory grep: /home/user/development/armbian/build/cache/sources/u-boot/v2018.05/Makefile: No such file or directory grep: /home/user/development/armbian/build/cache/sources/u-boot/v2018.05/Makefile: No such file or directory [ o.k. ] Compiling u-boot [ 0 ] [ o.k. ] Compiler version [ arm-linux-gnueabihf-gcc 7.4.1 ] [ .... ] Checking out sources error: pathspec 'HEAD' did not match any file(s) known to git. [ o.k. ] Cleaning [ u-boot/v2018.05 ] [ o.k. ] Started patching process for [ u-boot sun8i-orangepizero-default ] [ o.k. ] Looking for user patches in [ userpatches/u-boot/u-boot-sunxi-legacy ] [ warn ] * [l][c] 0020-sunxi-call-fdt_fixup_ethernet-again-to-set-macaddr-f.patch [ failed ] [ warn ] * [l][c] 4kfix-limit-screen-to-full-hd.patch [ failed ] [ o.k. ] * [l][c] Merrii_Hummingbird_A20.patch [ warn ] * [l][c] add-a20-olinuxino-micro-emmc-support.patch [ failed ] [ warn ] * [l][c] add-a20-optional-eMMC.patch [ failed ] [ o.k. ] * [l][c] add-awsom-defconfig.patch [ warn ] * [l][c] add-bananapi-bpi-zero.patch [ failed ] [ warn ] * [l][c] add-beelink-x2.patch [ failed ] [ warn ] * [l][c] add-emmc_support_to_neo1_and_2.patch [ failed ] [ warn ] * [l][c] add-nanopi-air-emmc.patch [ failed ] [ warn ] * [l][c] add-nanopi-duo.patch [ failed ] [ warn ] * [l][c] add-nanopi-m1-plus2-emmc.patch [ failed ] [ warn ] * [l][c] add-nanopineoplus2.patch [ failed ] [ warn ] * [l][c] add-orangepi-plus2-emmc.patch [ failed ] [ warn ] * [l][c] add-orangepi-zero-usb-boot-support.patch [ failed ] [ warn ] * [l][c] add-orangepi-zeroplus.patch [ failed ] [ warn ] * [l][c] add-orangepi-zeroplus2_h3.patch [ failed ] [ warn ] * [l][c] add-sunvell-r69.patch [ failed ] [ warn ] * [l][c] add-tritium-series.patch [ failed ] [ warn ] * [l][c] add-xx-boot-auto-dt-select-neo2.patch [ failed ] [ warn ] * [l][c] add-xx-nanopi-k1-plus-emmc.patch [ failed ] [ warn ] * [l][c] add-xx-nanopineocore2.patch [ failed ] [ warn ] * [l][c] add_emmc_olinuxino_a64.patch [ failed ] [ warn ] * [l][c] add_emmc_orangepiwin.patch [ failed ] [ warn ] * [l][c] adjust-default-dram-clockspeeds.patch [ failed ] [ warn ] * [l][c] adjust-small-boards-cpufreq.patch [ failed ] [ warn ] * [l][b] do-not-relocate-initrd.patch [ failed ] [ warn ] * [l][c] enable-DT-overlays-support.patch [ failed ] [ warn ] * [l][c] enable-autoboot-keyed.patch [ failed ] [ warn ] * [l][c] enable-ethernet-orangepiprime.patch [ failed ] [ warn ] * [l][b] enable-old-kernel-compat.patch [ failed ] [ warn ] * [l][c] enable-r_pio-gpio-access-h3-h5.patch [ failed ] [ warn ] * [l][c] fdt-setprop-fix-unaligned-access.patch [ failed ] [ warn ] * [l][c] fix-usb1-vbus-opiwin.patch [ failed ] [ warn ] * [l][c] h3-Fix-PLL1-setup-to-never-use-dividers.patch [ failed ] [ warn ] * [l][c] h3-enable-power-led.patch [ failed ] [ warn ] * [l][c] h3-set-safe-axi_apb-clock-dividers.patch [ failed ] [ warn ] * [l][c] lower-default-DRAM-freq-A64-H5.patch [ failed ] [ warn ] * [l][c] sun8i-set-machid.patch [ failed ] [ warn ] * [l][c] sunxi-boot-splash.patch [ failed ] sed: can't read .config: No such file or directory [ error ] ERROR in function compile_uboot [ compilation.sh:199 ] [ error ] U-boot compilation failed [ o.k. ] Process terminated Link to comment Share on other sites More sharing options...
Igor Posted July 12, 2019 Share Posted July 12, 2019 Network issue, can't download stuff from Microsoft Github. Link to comment Share on other sites More sharing options...
