NicoD Posted July 11, 2019 Share Posted July 11, 2019 Hi all. I've just finished reviewing the Khadas VIM3. It's an amazing SBC with unmatched performance. It's got the Amlogic A311D SoC. Comparable with the S922X of the Odroid N2. But the 4x A73 cores are clocked at 2.2Ghz and the 2 x A53 cores to 1.8Ghz. So it performs a lot better. It also comes with an NPU, MIPI-DSI and MIPI-CSI. And can be powered with USB type-c from 5V up to 20V. Here my review video. Here all my gathered information. Khadas VIM3 ----------- Ubuntu server - fan over fins ----------------------------- Blender BMW no fan thermal pad : 59m with copper shim : 58m18s with 5V fan : 45m01s with 5V fan over CPU : 43m28s Ubuntu XFCE - fan over CPU, not over fins ----------------------------------------- Blender no fan : 55m22s Blender 3V fan : 43m03s Blender 5V fan : 42m51s Blender with fan : 48m45s Armbian Bionic Small cores @1.9Ghz Big cores @1.7Ghz Blender with fan : 46m29s Armbian Disco Small cores @1.9Ghz Big cores @1.7Ghz Blender with fan : 46m56s Armbian Buster Small cores @1.9Ghz Big cores @1.7Ghz Kdenlive 16m bench 3V lxde : 1h09m (using 1GB zram + 4GB swap file. Not enough ram with 2GB) Video playback -------------- Ubuntu ------ Up to 4K 30fps with MPV. Very slight screen tearing. Anything lower is perfect Youtube playback with Firefox up to 1440p 30fps perfect KODI doesn't work (yet) No VPU acceleration for now. All done by CPU. LibreElec --------- Up to 4K 30fps with MPV. Very slight screen tearing. Anything lower is perfect Wifi doesn't work. power consumption ----------------- Idle no fan : 0.27A 5V (governor set to interactive) Maxed out with fan : 1.4A 5V (fan is 0.15A) Temperatures (fan over CPU, not over fins) ------------------------------------------ Idle No fan : 44°C Maxed out No fan : 75°C heavy throttling. 1Ghz small cores / 1.8Ghz big cores Idle 3V fan : 34°C Maxed out 3V fan : 73°C very light throttle. Takes 5min to reach 70°c. +10min to start throttling Idle 5V fan : 32°C Maxed 5V : 70°C no throttling Transfer speeds --------------- eMMC 16GB : 60 MB/s write : 165.9 MB/s read SSD over USB3 : 380.3 MB/s write : 286.1 MB/s read SSD over USB2 : 40.2 MB/s Samsung EVO plus with on-board sd-reader : 10.2MB/s write 22.1MB/s read with USB3 sd-reader : 31.7MB/s write 88.6MB/s read Ethernet internet speed : 53.9 Mbps 11.5 Mbps Wifi internet speed : 43.7 Mbps 11.2 Mbps Issue's ------- When using a 2.4Ghz dongle for mouse in the right USB3 port, wifi connection is slow. When using a USB3 device in the USB3 port wifi stops working. Use left USB2 port for those. Ubuntu server boots/shuts down slower than XFCE version. Shut down stop job for ifup for eth0 (not in use) 1m30s Boot hangs a while. Can't find the reason. After -> Scanning for Btrfs filesystems. Done. about 30s Can't install Tensorflow khadas@Khadas:~/tensorflow$ pip3 install tensorflow-1.8.0-cp35-none-linux_aarch64.whl tensorflow-1.8.0-cp35-none-linux_aarch64.whl is not a supported wheel on this platform. Android : Can't connect wifi. I can type wifi password, but can't go further. No connect button. Tips ---- Use interactive governor for better thermals and power consumption with low use/idle. Plus/Minus ---------- + Best single core performance + best multi-core performance for an ARM SBC + Nice case + PSU + USB-c cable included + remote + eMMC + Amazing low power consumption / best performance per watt + Can be powered with 5V up to 20V + NPU - Wifi issue with USB3/No 5Ghz wifi. Could have solved the USB3 interference - Placing of the buttons would be better on the back. They often get pressed when plugging a USB device. You do get used to it. - No VPU and X11 drivers (yet) - Slow On-board SD-card reader Greetings, NicoD 1 Link to comment Share on other sites More sharing options...
lanefu Posted July 11, 2019 Share Posted July 11, 2019 20 minutes ago, NicoD said: Here all my gathered information. Would you mind running TK's SBC bench?https://github.com/ThomasKaiser/sbc-bench Link to comment Share on other sites More sharing options...
NicoD Posted July 11, 2019 Author Share Posted July 11, 2019 @lanefu Sorry, I forgot to share my benchmark file. I did find out that 7-zip multicore results are not to be trusted on SBC's with different cluster performance. The VIM3 has a very big difference so it only uses 500% of 600%. The N2 has a smaller difference in performance between A73/A53 so uses 550% in 7-zip multicore scores. (also lack of memory is a problem) CPU Miner is good, 7zip single core benchmarks are good. And for me Blender is important too. Reasons why benchmarks can be misleading ---------------------------------------- throttling 32-bit/64-bit Difference in cores A53/A7/A15/A72 distro (ubuntu/debian...) distro version kernel version driver versions compiler version software version/outdated repositories desktop Mate/Xfce/LXDE/... display resolution/headless background processes cpu clockspeed ram clockspeed/latency ram useage/swap/zram process sheduler optimizations for the system/distro crypto engine for encryption Undervoltage config settings Wifi dongle CONFIG_HZ=250 - 1000 or any other 7-zip works a bit better on 32-bit vs 64-bit, it doesn't use all cores at 100% in multi-core scores. The percentage differs with different distro's and boards. So it's not completely exact. 7-zip has problems with big-LITTLE architecture for multi-core benchmark. Better to test the clusters seperately. Blender works a lot better on 64-bit than on 32-bit. It uses 100% of the cores. CPU Miner only works on 64-bit. Works better in Ubuntu Bionic than in Debian Stretch. Blender : BMW render @ 1080p 7-zip : Numbers are average of 3 of decompressing only All tests are done with a fan when necessary so no throttling occurs. 64-bit SBC's Khadas VIM3 |SBC bench result |CPU Miner |7-zip s/c A53 |7-zip b/c A73 |7-zip multi avg. of 3 |Blender Ubuntu 18.04.02 http://ix.io/1MFD 13.10kH/s 1577 2311 10578 42m51s Armbian@1.9S.C./1.7B.C. http://ix.io/1NRJ 48m45s Odroid N2 |SBC bench result |CPU Miner |7-zip s/c A53 |7-zip b/c A73 |7-zip multi avg. of 3 |Blender Ubuntu Bionic http://ix.io/1Brv 11.35kH/s 1564 1879 9988 50m28s NanoPC T3+ |SBC bench result |CPU Miner |7-zip s/c |7-zip b/c |7-zip multi avg. of 3 |Blender Armbian Bionic http://ix.io/1iRJ 10.99kH/s 1290 10254 1h10m25s Arbmian Stretch http://ix.io/1qiF 8.55kH/s 1275 10149 1h13m55s Rock Pi 4B |SBC bench result |CPU Miner |7-zip s/c |7-zip b/c |7-zip multi avg. of 3 |Blender Ubuntu http://ix.io/1uVr 9.50kH/s 1242 1818 7802 1h17m22s NanoPi M4 |SBC bench result |CPU Miner |7-zip s/c |7-zip b/c |7-zip multi avg. of 3 |Blender Armbian bionic hz1000 http://ix.io/1nLh 10.23kH/s 1335 2005 8352 1h13m50s CONFIG_HZ=250 http://ix.io/1BLW 10.45kH/s 1335 2007 8320 1h08m28s Armbionic@1.4/1.8 hz250 1253 1828 7821 1h12m52s Armbian bionic nightly http://ix.io/1pDo 10.24kH/s 1329 1990 8292 1h13m28s Armbian stretch desktop http://ix.io/1odF 8.66kH/s 1350 1977 8400 1h14m12s Armbian stretch dsk nightly //ix.io/1pM0 8.80kH/s 1359 1993 8500 1h15m04s Armbian stretch core no fan //ix.io/1pKU 8.80-8.65kH/s 1353 1989 8461 Armbian stretch core //ix.io/1pL9 8.76kH/s 1354 1988 8456 Armbian stretch core nightly //ix.io/1pLf 8.82kH/s 1357 1994 8494 Lubuntu Bionic arm64 http://ix.io/1oGJ 9.24kH/s CPU Miner 1056 1551 6943 1h28m13s Lubuntu Bionic armhf http://ix.io/1pJ1 1111 1769 7705 2h02m54s Lubuntu Xenial armhf http://ix.io/1oCb 989 1507 6339 2h20m51s Khadas Vim2 Max |SBC bench result |CPU Miner |7-zip s/c |7-zip b/c |7-zip multi avg. of 3 |Blender Ubuntu Xenial http://ix.io/1qkA 6.86kH/s 823 1134 6682 1h14m39s 7-zip only 600% of 800% used Odroid C2 |SBC bench result |CPU Miner |7-zip big core |7-zip multi avg. of 3 |Blender Armbian Stretch Core http://ix.io/1pZu 4.65kH/s 1390 5342 Armbian Stretch Core Nightly //ix.io/1pZJ 4.66kH/s 1391 5340 Armbian Stretch Desktop http://ix.io/1q1C 4.65kH/s 1394 5363 Armbian Stretch Desktop NGHT //ix.io/1p02 4.59kH/s 1394 5356 2h38m18s Meveric Stetch No-OC 1337 5223 2h40m00s Meveric Stretch Only RAM OC 1361 5292 Meveric Stretch OC 1548 6049 2h14m17s Ubuntu Mate Bionic http://ix.io/1q2S clocked to 100Mhz 2h35m10s Ubuntu Mate Bionic OC Doesn't work/Clocked to 100Mhz 1607 5960 2h10m21s Rock64 |SBC bench result |CPU Miner |7-zip small core |7-zip multi avg. of 3 |Blender Armbian Stretch 1.5Ghz http://ix.io/1nCj 4.06kH/s 1406 5407 3h00n32s OLD Armbian Stretch 1.3Ghz //ix.io/1iHB 3.80kH/s 1211 4904 Armbian Bionic 1.5Ghz core //ix.io/1qbK 5.00kH/s 1384 5379 Armbian Bionic 1.5Ghz dsk //ix.io/1qcb 4.94kH/s 1379 5326 2h55m56s 32-bit SBC's Odroid XU4 |SBC bench result |7-zip s/c |7-zip b/c |7-zip multi avg. of 3 |Blender Debian Jessie http://ix.io/1q6X 950 1653 8823 1h12m19s Ubuntu Bionic http://ix.io/1qbL 1219 2094 9395 1h44m19s Asus Tinker board |SBC bench result |7-zip big core|7-zip multi avg. of 3 |Blender Tinker OS 9.5 Stretch http://ix.io/1pRN 1983 7536 2h55m00s Raspberry Pi 3B+ |SBC bench result |7-zip small core |7-zip multi avg. of 3 |Blender Raspbian Default no fan http://ix.io/1q10 1471 5027 Raspbian Default http://ix.io/1q1Q 1411 5371 5h47m31s Raspbian OC http://ix.io/1q5J 1591 6141 Ubuntu Mate Xenial http://ix.io/1q65 7-zip didn't work Software versions ----------------- GIMP Blender GTKPerf SysBench SBC-bench M4 : Lubuntu Xenial armhf 2.8.18 2.79b 0.40 0.4.12 0.6.1 Lubuntu Bionic armhf : 2.8.22 2.79b 0.40 1.0.11 LuaJIT 2.1.0-beta3 0.6.1 Armbian Stretch desktop 9.5 : 2.8.18 2.79b 0.40 0.4.12 0.6.1 Armbian Bionic : 2.8.22 2.79b 0.40 1.0.11 LuaJIT 2.1.0-beta3 0.6.1 Tinker : TinkerOS 9.5 Stretch : 2.8.18 2.79b 0.40 0.4.12 0.6.1 Odroid C2 : Armbian Stretch 9.5 : 2.8.18 2.79b 0.40 0.4.12 0.6.1 : Ubuntu Mate Bionic : 2.8.22 2.79b 0.40 1.0.11 LuqJIT 2.1.0-beta3 0.6.1 Doesn't work clocks to 100Mhz Meveric Stretch 9.5 : 2.8.18 2.79b 0.40 0.4.12 Doesn't work Rock64 : Armbian Stretch 9.5: 2.8.18 2.79b 0.40 0.4.12 0.6.1 : Armbian Bionic : 2.8.22 2.79b 0.40 1.0.11 0.6.2 RPi 3b+ : Raspbian Stretch 9.5 : 2.8.18 2.78a 0.40 0.4.12 0.6.1 Ubuntu Mate Xenial : 2.8.16 0.40 0.4.12 0.6.1 Odroid XU4 : Debian Jessie : 2.8.14 2.72b 0.40 0.4.12 0.6.1 7-zip doesn't work : Ubuntu Bionic : 2.8.22 2.79b 0.40 1.0.11 0.6.2 NanoPC T3+ : Armbian Bionic : 2.8.22 2.79b 0.40 1.0.11 0.4.6 Armbian Stretch : 2.79b 0.40 0.4.12 0.6.2 Khadas Vim2 Max : Ubuntu Xenial : 2.8.16 2.76b 0.40 0.4.12 0.6.2 CPU Clocks ---------- Khadas VIM3 : Ubuntu Bionic : 2x1.8Ghz(A53) + 4x2.2Ghz(A73) 64-bit Odroid N2 : Ubuntu Bionic : 2x1.9Ghz(A53) + 4x1.8Ghz(A73) 64-bit NanoPi M4 : Armbian Bionic/Stretch : 2x2Ghz + 4X1.5Ghz 64-bit Lubuntu armhf/ARM64 : 2x1.8Ghz + 4X1.4Ghz armhf 32-bit / ARM64 64-bit Tinker Board : TinkerOS Stretch : 4x1.8Ghz 32-bit Odroid C2 : Armbian Stretch : 4x1.5Ghz 64-bit Ubuntu Mate Bionic : 4x1.5Ghz RAM 912Mhz 64-bit Ubuntu Mate Bionic OC : 4x1.75Ghz + RAM 1104Mhz 64-bit Rock64 : Armbian Stretch : 4x1.5Ghz 64-bit Armbian Bionic : 4x1.5Ghz 64-bit RPi 3B+ : Raspbian Stretch : 4x1.4Ghz no fan 4x1.2Ghz above 60°C 32-bit Raspbian Stretch OC : 4x1.570Ghz over_voltage=4 core_freq=500 sd_freq=510 32-bit Ubuntu Xenial : 4x1.4Ghz 32-bit Odroid XU4 : Debian Stretch : 4x1.4Ghz + 4x1.9Ghz 32-bit : Ubuntu Mate Bionic : 4x1.5Ghz + 4x2Ghz Underclocks when above 75°C 32-bit NanoPC T3+ : Armbian Bionic : 8x1.4Ghz 64-bit Some benchmark tools can give an estimate of the performance. But they are never an exact reflection. 2 Link to comment Share on other sites More sharing options...
Richard.Kang Posted September 12, 2019 Share Posted September 12, 2019 Any luck of installing TensorFlow on the board? I need it for my project so it will be a deal breaker if I can't get TF installed and running on it. Thanks! Richard 1 Link to comment Share on other sites More sharing options...
