theguyuk Posted April 30, 2016 Share Posted April 30, 2016 Yet another crowd funding hopeful MiQi is a $35 single-board computer with Rockchip RK3288 Looking for a credit card-sized computer with a quad-core, ARM-based processor and only have $35 to spend? You could opt for the Raspberry Pi 3. But another option is on the way. The MiQi is the same size and price as a Raspberry Pi 3, but this little single-board computer/developer board features a Rockchip processor, up to 32GB of built-in storage, Gigabit Ethernet, and a few other features that help set it apart. http://liliputing.com/2016/04/miqi-is-a-35-single-board-computer-with-rockchip-rk3288.html Link to comment Share on other sites More sharing options...
tkaiser Posted April 30, 2016 Share Posted April 30, 2016 Unless it's confirmed that the board can be powered through something else than Micro USB (GPIO pins for example) it's a simple decision: Don't buy any board that relies on Micro USB: http://www.cnx-software.com/2016/04/20/android-and-linux-benchmarks-on-miqi-development-board/#comment-525260 Detailed explanation why 'powering through Micro USB' is always wrong: http://forum.armbian.com/index.php/topic/1092-usb-made-simple/?p=8311 Link to comment Share on other sites More sharing options...
zador.blood.stained Posted April 30, 2016 Share Posted April 30, 2016 It appears that some kind of schematic is already available(though last update dated December 2015): http://ftp.mqmaker.com/MiQi/Docs/rk3288-sch.pdf First notes: USB ports are behind USB hub 5V power input is not wired to GPIO headers Has PMU, so it still should deal with undervoltage (at least without connecting anything to USB ports) Edit: +5V is wired to fan header through big enough 0R resistor, so you can bypass microUSB for powering Edit 2: 0805 package zero ohm resistors are rated for up to 2A current, or you can replace it / solder atop a piece of wire Link to comment Share on other sites More sharing options...
tkaiser Posted April 30, 2016 Share Posted April 30, 2016 USB ports are behind USB hub Thx for your findings! Unfortunately that alone is reason enough to ignore the MiQi from now on. Somewhat strange that all boards with fast CPUs lack I/O bandwidth. Link to comment Share on other sites More sharing options...
