Rafael C Posted July 18, 2019 Share Posted July 18, 2019 Hello everyone. We have checked the forum extensively but have not found a good answer to our problem. Our system is based on a Orange Pi Zero Plus (512 MB), and it is running nicely. However, after some time, (10 - 15 days from the last boot) or /tmp directory gets full and most of the system is not operational. Only solution we have found for the moment is rebooting the system. This is the output of df -h in one of our systems which only shows 7% usage. This usage figure increases day by day. Filesystem Size Used Avail Use% Mounted on udev 174M 0 174M 0% /dev tmpfs 49M 5.4M 43M 12% /run /dev/mmcblk0p1 2.0G 1.6G 333M 83% / tmpfs 241M 12K 241M 1% /dev/shm tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs 241M 0 241M 0% /sys/fs/cgroup tmpfs 241M 16M 226M 7% /tmp tmpfs 10M 0 10M 0% /home/iawot/ficheros_ftp /dev/zram0 49M 27M 19M 60% /var/log tmpfs 49M 0 49M 0% /run/user/0 The contents of the /tmp directory is: ls -la /tmp total 8 drwxrwxrwt 8 root root 180 Jul 18 13:28 . drwxrwxrwt 22 root root 4096 Jan 17 02:04 .. -rw------- 1 root root 31 Jul 16 11:08 armbian-hardware-optimization.hhlnrd drwxrwxrwt 2 root root 40 Jul 16 11:08 .font-unix drwxrwxrwt 2 root root 40 Jul 16 11:08 .ICE-unix drwx------ 3 root root 60 Jul 16 11:08 systemd-private-98788f87752540c4a5cf054115c5741a-haveged.service-6uUDLd drwxrwxrwt 2 root root 40 Jul 16 11:08 .Test-unix drwxrwxrwt 2 root root 40 Jul 16 11:08 .X11-unix drwxrwxrwt 2 root root 40 Jul 16 11:08 .XIM-unix and inside systemd-private-98788f87752540c4a5cf054115c5741a-haveged.service-6uUDLd there is only an empty directory named tmp. So my question is: What is the proper way of clearing de /tmp directory? We have tried to simply erase everything inside it with rm /tmp/* -r but it seems that something (invisible) is still there since df -h still reports the /tmp is using 241 MB Thanks! Link to comment Share on other sites More sharing options...
lanefu Posted July 18, 2019 Share Posted July 18, 2019 48 minutes ago, Rafael C said: and inside systemd-private-98788f87752540c4a5cf054115c5741a-haveged.service-6uUDLd there is only an empty directory named tmp. So my question is: What is the proper way of clearing de /tmp directory? We have tried to simply erase everything inside it with rm /tmp/* -r but it seems that something (invisible) is still there since df -h still reports the /tmp is using 241 MB The file handles are probably still being held open by the service. try systemctl restart havegd and see if that releases them also whats output of systemctl status systemd-tmpfiles-setup.service Link to comment Share on other sites More sharing options...
Rafael C Posted July 18, 2019 Author Share Posted July 18, 2019 Thanks for the response. I will need to wait a few days until tmp is more filled and will try systemctl restart havegd This is the outpout of systemctl status systemd-tmpfiles-setup.service : ● systemd-tmpfiles-setup.service - Create Volatile Files and Directories Loaded: loaded (/lib/systemd/system/systemd-tmpfiles-setup.service; static; vendor preset: enabled) Active: active (exited) since Thu 2019-07-18 15:32:17 CEST; 2h 13min ago Docs: man:tmpfiles.d(5) man:systemd-tmpfiles(8) Process: 335 ExecStart=/bin/systemd-tmpfiles --create --remove --boot --exclude-prefix=/dev (code=exited, status=0/SUCCESS) Main PID: 335 (code=exited, status=0/SUCCESS) Tasks: 0 (limit: 4915) CGroup: /system.slice/systemd-tmpfiles-setup.service Jul 18 15:32:17 CESINEL_PACOM_Z0003 systemd[1]: Starting Create Volatile Files and Directories... Jul 18 15:32:17 CESINEL_PACOM_Z0003 systemd[1]: Started Create Volatile Files and Directories. Link to comment Share on other sites More sharing options...
sfx2000 Posted August 3, 2019 Share Posted August 3, 2019 On 7/18/2019 at 5:06 AM, Rafael C said: We have checked the forum extensively but have not found a good answer to our problem. logrotate is one item to look at to close out logs and age them out. FWIW - There's armbian specific services in systemd that you might want to actually disable - armbian-ramlog for example, as when it runs out of space it gets ugly. systemctl list-unit-files | grep armbian armbian-firstrun-config.service enabled armbian-firstrun.service disabled armbian-hardware-monitor.service enabled armbian-hardware-optimize.service enabled armbian-ramlog.service disabled armbian-resize-filesystem.service disabled armbian-zram-config.service disabled Anyways - the ram logging and ZRAM stuff tend to be problematic for some that come into Armbian from other platforms... The two services I would disable from SystemD are below: armbian-ramlog.service armbian-zram-config.service I know folks might be offended here - but disabling this results in expected behavior. 1 Link to comment Share on other sites More sharing options...
sfx2000 Posted September 28, 2019 Share Posted September 28, 2019 On 7/18/2019 at 5:06 AM, Rafael C said: Our system is based on a Orange Pi Zero Plus (512 MB), and it is running nicely. However, after some time, (10 - 15 days from the last boot) or /tmp directory gets full and most of the system is not operational. Only solution we have found for the moment is rebooting the system. This is the output of df -h in one of our systems which only shows 7% usage. This usage figure increases day by day. That's odd in any case - current Armbian tweaked a little bit... two weeks uptime one NanoPI Neo2 I'm mainly using it as a NTP time source (with GPSD and Chrony), as well as a ssh jump box $ uname -a Linux nano2 4.19.63-sunxi64 #5.92 SMP Fri Aug 2 00:18:27 CEST 2019 aarch64 aarch64 aarch64 GNU/Linux $ uptime 16:15:54 up 14 days, 6:45, 1 user, load average: 0.00, 0.05, 0.06 $ df -h Filesystem Size Used Avail Use% Mounted on udev 428M 0 428M 0% /dev tmpfs 100M 14M 86M 14% /run /dev/mmcblk0p1 15G 6.4G 8.0G 45% / tmpfs 497M 0 497M 0% /dev/shm tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs 497M 0 497M 0% /sys/fs/cgroup tmpfs 497M 8.0K 497M 1% /tmp tmpfs 100M 0 100M 0% /run/user/1000 $ ls -la /tmp total 12 drwxrwxrwt 11 root root 280 Sep 28 16:11 . drwxr-xr-x 22 root root 4096 Oct 26 2018 .. -rw------- 1 root root 31 Sep 14 09:30 armbian-hardware-optimization.r0SxiO drwxrwxrwt 2 root root 40 Sep 14 09:30 .font-unix drwxrwxrwt 2 root root 40 Sep 14 09:30 .ICE-unix -rw-rw-rw- 1 root root 387 Sep 23 21:03 nanohat-oled.log -rw-rw-rw- 1 root root 0 Sep 14 09:30 nanoled-python.log drwx------ 3 root root 60 Sep 14 09:32 systemd-private-43a0a10b262541e4bbf35bf5370fcd35-chrony.service-5M7ZYn drwx------ 3 root root 60 Sep 14 09:30 systemd-private-43a0a10b262541e4bbf35bf5370fcd35-haveged.service-xAs0dT drwx------ 3 root root 60 Sep 14 09:30 systemd-private-43a0a10b262541e4bbf35bf5370fcd35-ModemManager.service-GdBGMf drwx------ 3 root root 60 Sep 14 09:30 systemd-private-43a0a10b262541e4bbf35bf5370fcd35-systemd-resolved.service-H04TSn drwxrwxrwt 2 root root 40 Sep 14 09:30 .Test-unix drwxrwxrwt 2 root root 40 Sep 14 09:30 .X11-unix drwxrwxrwt 2 root root 40 Sep 14 09:30 .XIM-unix Link to comment Share on other sites More sharing options...
