UART 3 configuration on BPI M2+
freeman32
hello I have a module of teleinformation on my GPIO port which must work on the UART 3 but I do not know at all how to configure it and it does not work, could you help me? I am under armbian 5.90.
here is the link to my telinformation module:
PiTinfo
thank you in advance for your help
root@bananapim2plus:/boot# dmesg | grep tty
[    0.000000] Kernel command line: root=UUID=207230f7-58a4-4c41-bdd6-8caa2cdad12c rootwait rootfstype=ext4 console=tty1 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart= ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
[    0.000188] console [tty1] enabled
[    1.823112] console [ttyS0] disabled
[    1.843262] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 41, base_baud = 1500000) is a U6_16550A
[    1.843316] console [ttyS0] enabled
[    1.864182] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 42, base_baud = 1500000) is a U6_16550A
[    1.887035] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 43, base_baud = 1500000) is a U6_16550A
[    1.909859] 1c28c00.serial: ttyS3 at MMIO 0x1c28c00 (irq = 44, base_baud = 1500000) is a U6_16550A
[    5.233907] systemd[1]: Created slice system-getty.slice.
Oh ! A bit strange : it seems that all uarts are enabled ...
Did you added DT overlays for all of them, ie "overlays=uart1 uart2 uart3" ?
If not, maybe they were already enabled in the Main DT ...
6 minutes ago, freeman32 said:
maybe by test with armbian-config, but I failed to market my module.
So, what do you see on the "overlays=" line in /boot/armbianEnv.txt ?
Keep only "uart3" there, and maybe remove the others ...
7 minutes ago, freeman32 said:
I must also apply this configuration but I do not know how to do it :  -b 1200 -d 7 -p e -f n
This is arguments for picocom, so : "picocom -b 1200 -d 7 -p e -f n /dev/ttyS3"
yes but i have not result, I should have something like this
root@pi01(ro):~# picocom -b 1200 -d 7 -p e -f n /dev/ttyAMA0
picocom v1.7
port is        : /dev/ttyAMA0
flowcontrol    : none
baudrate is    : 1200
parity is      : even
databits are   : 7
escape is      : C-a
local echo is  : no
noinit is      : no
noreset is     : no
nolock is      : no
send_cmd is    : sz -vv
receive_cmd is : rz -vv
imap is        :
omap is        :
emap is        : crcrlf,delbs,
Terminal ready
] _
HCHP 000000000 S
PTEC HC.. S
IINST 001 X
IMAX 001 @
PAPP 00170 )
HHPHC 3 ^
MOTDETAT 000000 B
ADCO 031428067147 B
OPTARIF HC.. <
ISOUSC 15 <
HCHC 000453337 _
HCHP 000000000 S
PTEC HC.. S
IINST 001 X
IMAX 001 @
PAPP 00170 )
HHPHC 3 ^
MOTDETAT 000000 B
ADCO 031428067147 B
OPTARIF HC.. <
ISOUSC 15 <
HCHC 000453337 _
HCHP 000000000 S
PTEC HC.. S
IINST 001 X
IMAX 001 @
PAPP 00170 )
HHPHC 3 ^
MOTDETAT 000000 B
ADCO 031428067147 B
OPTARIF HC.. <
ISOUSC 15 <
HCHC 000453337 _
HCHP 000000000 S
PTEC HC.
and i have this :
/home/guillaume# picocom -b 1200 -d 7 -p e -f n /dev/ttyS3
picocom v1.7
port is        : /dev/ttyS3
flowcontrol    : none
baudrate is    : 1200
parity is      : even
databits are   : 7
escape is      : C-a
local echo is  : no
noinit is      : no
noreset is     : no
nolock is      : no
imap is        :
omap is        :
Terminal ready
2 minutes ago, freeman32 said:
and i have this :
But this small PiTInfo board is only an optocoupler interface to UART3.
What hardware do you have on the optocoupler side named "teleinfo" ?
It is this hardware that should provide serial output, maybe this "teleinfo" is not working ...
1 minute ago, freeman32 said:
it's my electric meter, the teleinfo works correctly with another device
In this case, maybe this PiTInfo board is defective ...
To make sure the UART3 itself is working fine, remove that PiTInfo board and simply put a loopback wire between TX/RX pins.
Then, with the same "picocom" command, you should be able to type some keystrokes and seeing been echoed to the screen.
That will prove that UART3 is working fine !
38 minutes ago, freeman32 said:
nothing happens I have the same thing as before
Oh ! I've bring out my own BPi-M2-Plus out of the dust of one of my drawers ...
I've gave it a try and figured out something funny : although the schematic says that pin 8 and pin 10 are on UART3, it is actual wrong, doing the loopback wire test, it is on UART2 !
So, schematic is wrong !!!
EDIT : Sorry, it is on UART3, but when DT overlay is loaded it goes into /dev/ttyS2 ...
root@bananapim2plus:/home/guillaume# picocom -b 1200 -d 7 -p e -f n /dev/ttyS2
picocom v1.7
port is        : /dev/ttyS2
flowcontrol    : none
baudrate is    : 1200
parity is      : even
databits are   : 7
escape is      : C-a
local echo is  : no
noinit is      : no
noreset is     : no
nolock is      : no
imap is        :
omap is        :
FATAL: failed to add device /dev/ttyS2: Filedes is not a tty
i do the test for my 2 bpi m2+, on the first and after a fresh install, dmesg | grep tty tel me this :
dmesg | grep tty
[    0.000000] Kernel command line: root=UUID=bf12efb6-ded4-4f1b-8ad6-ddcfb1225f43 rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart= ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
[    0.000186] console [tty1] enabled
[    1.908371] console [ttyS0] disabled
[    1.928521] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 41, base_baud = 1500000) is a U6_16550A
[    1.928573] console [ttyS0] enabled
[    1.949516] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 42, base_baud = 1500000) is a U6_16550A
[    1.972389] 1c28c00.serial: ttyS3 at MMIO 0x1c28c00 (irq = 43, base_baud = 1500000) is a U6_16550A
I this picocom -b 1200 -d 7 -p e -f n /dev/ttyS2 for ttyS0, ttyS1 and ttyS3 same result as before.
on my second bpi m2+, with a fresh install too, the command dmesg | grep tty do not give me anything.
F***ing bananas !!!!
dmesg | grep tty
[    0.000000] Kernel command line: root=UUID=8ee8e552-6ee4-44c5-9908-aae87b53a4 b2 rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0        disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1
[    0.000185] console [tty1] enabled
[    1.819193] console [ttyS0] disabled
[    1.839341] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 41, base_baud = 15        00000) is a U6_16550A
[    1.839393] console [ttyS0] enabled
[    1.860298] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 42, base_baud = 15        00000) is a U6_16550A
[    1.883154] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 43, base_baud = 15        00000) is a U6_16550A
[    1.905992] 1c28c00.serial: ttyS3 at MMIO 0x1c28c00 (irq = 44, base_baud = 15        00000) is a U6_16550A
in this dmesg, I have : console=ttyS0,115200 console=tty1
should not this be removed? If so, how do you please
