Jens Bauer Posted July 24, 2019 Share Posted July 24, 2019 A while back, I noticed that Armbian was compatible with this Ugreen GbE adapter. As I purchase on eBay rather than Amazon, I found the above one plus this adapter, which has the same AX88179 chipset plus a built-in 3-port USB3-Hub. So I decided to try it and see if it worked with Armbian and report back here. (I'm using the EspressoBIN for this and Ubuntu Bionic 4.19.56). These are my results: Straight out-of-the-box, I can see it using LSUSB, but it does not plug-and-play-work. After struggling and attempting to get the network manager to do something about it, I added this line to /etc/udev/rules.d/70-persistent-net.rules: SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="00:0e:c6:a3:d0:c6", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="usbnet0" It now shows up as usbnet0 when I type ... ip a networkctl -a networkctl status usbnet0 ... I've successfully been able to set its MAC-Address (just to confirm that I can make a /etc/systemd/network/10-usbnet0.network file: [Match] Name=usbnet0 [Network] #DHCP=ipv4 DHCP=no Address=10.0.1.5/8 Gateway=10.0.0.1 DNS=208.67.222.222,208.67.220.220,10.0.0.1 [Link] MACAddress=defa.cebe.ef08 However, If I type ... ip link | grep -A 1 'usbnet0' ... I get ... 7: usbnet0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DEFAULT group default qlen 1000 link/ether de:fa:ce:be:ef:08 brd ff:ff:ff:ff:ff:ff Notice "state DOWN" networkctl -a shows this line: 7 usbnet0 ether no-carrier configuring (which is a little more than when not having the udev rule) nmcli device shows this line: usbnet0 ethernet unavailable -- The command ... dmesg | egrep 'eth|usbnet0|ax88179|link.*ready' ... shows ... [ 0.000000] psci: probing for conduit method from DT. [ 4.281896] mvneta d0030000.ethernet eth0: Using device tree mac address de:fa:ce:fa:ca:de [ 17.785161] mvneta d0030000.ethernet eth0: configuring for fixed/rgmii-id link mode [ 17.785225] mvneta d0030000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off [ 17.797420] device eth0 entered promiscuous mode [ 18.480286] ax88179_178a 3-1.1:1.0 eth1: register 'ax88179_178a' at usb-d0058000.usb-1.1, ASIX AX88179 USB 3.0 Gigabit Ethernet, 00:0e:c6:a3:d0:c6 [ 18.480614] usbcore: registered new interface driver ax88179_178a [ 20.583008] IPv6: ADDRCONF(NETDEV_UP): br0: link is not ready [ 20.889613] ax88179_178a 3-1.1:1.0 usbnet0: renamed from eth1 [ 21.366583] IPv6: ADDRCONF(NETDEV_UP): usbnet0: link is not ready [ 21.369227] IPv6: ADDRCONF(NETDEV_CHANGE): br0: link becomes ready [ 31.927910] IPv6: ADDRCONF(NETDEV_UP): usbnet0: link is not ready [ 146.550026] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready ... So as far as I can tell, it does not seem to work right out-of-the-box, and currently, I seem to have used up all my ideas on how it could be brought up. The USB3-hub seems to be detected. If I insert a USB2 SD/MMC card reader, the device shows up as /dev/sd?, so the USB3 hub seems to work just fine. The question is whether the USB3 hub might confuse the driver in Armbian, because as I understand it, the adapter without the USB3 hub work out-of-the-box (please confirm). Link to comment Share on other sites More sharing options...
