Mpv Stack Overflow
Hello, I think there is a stackoverflow with mpv (sometimes hard to solve...) watching memory with "top" command, I can see memory increase indefinitly.
Is it possible to solve this problem ? I use armbian to play web radios....
Best Regards
uname -a
3.4.113-sun8i #2 SMP PREEMPT Sat Jan 12 15:54:26 CET 2019 armv7l armv7l armv7l GNU/Linux
mpv -v
mpv 0.14.0 (C) 2000-2015 mpv/MPlayer/mplayer2 projects
Ok, can I upgrade my current kernel instead of flash it ?
(I will spend many weeks to reconfigure if I flash it from the new version.... I try by myself, thank you for your anwser Tido :) )
Does the problem exists on the new kernel version ?
I have the same problem with the latest kernel (updated an upgraded)
Mpv memory starts from about 10% and increases about 0.1% each 15s and system crashes a few hours later.
(I don't have the problem on my ubuntu PC)
I am sure someone will find the solution :))))
Must I report a bug ?
(I install latest kernel, update and upgrade, activate analog input with armbian-config and I play an url with mpv)
I tried with moc but :
Running the server...
Trying JACK...
Trying ALSA...
Trying OSS...
FATAL_ERROR: No valid sound driver!
(I try to have a multiroom audio solution)
isn't MPV a video player?
armbianmonitor -u   tells the reader all the details about your Installation, like Kernel-Version and much more, please post the result of this command.
Mpv is a video and an audio player.
Can you launch mpv (with a stream url) and watch memory status with top command Tido ? :)
You are doing what I would like to do. May be you want to adjust the title of your topic to get more attention like: MPV Stack Overflow - while playing webradio
I don't have such a sophisticated installtion to help you testing. Also, have you had a look at the development/issues of MPV, maybe the maintain something on Github or Gitlab?
Do Mpv memory increases when playing on a standard install with the latest armbian ? (I think it will be the same on any install)
I must know if it is due to audio drivers before doing what you tell me to do.
Can you please tell me what you see on your install ? Launch for example the following command line and check :
mpv http://stream.radiohamburg.de/rhh-live/mp3-128/radiode/ &
(it is not my prefered radio lol)
And check with top command if memory increase indefinitly (just launch "top" after)
