Orange pi zero plus play audio CD or mount external USB cd dtive
barry2212
Hi, I'm the new guy and I started use orange pi boards so go straight to the problem:
I'm trying to turn my orange pi plus board into a fully function cd player.I have done the code. So when I try to connect the USB cd drive to the board and type:"ls /dev/cdrom" And it shown "ls: cannot access '/dev/cdrom': No such file or directory" that happened to "sr0" too.
I don't know how to solve this
Please help me.Thanks for reading this
6 hours ago, martinayotte said:
Unplug and Replug the USB device and check the few last lines of the output of "dmesg" command, and report back those few lines here.
Here is my termian output about the usb cd drive:
[   92.009005] usb 3-1: new high-speed USB device number 3 using ehci-platform
[   92.166692] usb 3-1: New USB device found, idVendor=05e3, idProduct=0701, bcdDevice= 0.33
[   92.166710] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   92.166720] usb 3-1: Product: USB TO IDE
[   92.167854] usb-storage 3-1:1.0: USB Mass Storage device detected
[   92.168274] usb-storage 3-1:1.0: Quirks match for vid 05e3 pid 0701: 520
[   92.168447] scsi host0: usb-storage 3-1:1.0
[   93.277422] scsi 0:0:0:0: CD-ROM            TEAC     DW-224E-V        C.CC PQ: 0 ANSI: 0
[   93.278267] scsi 0:0:0:0: Attached scsi generic sg0 type 5
My terminal output ist also a /dev/sg0 device:
[1339704.355462] usb 5-1: new high-speed USB device number 2 using ehci-platform
[1339704.516262] usb 5-1: New USB device found, idVendor=0e8d, idProduct=1836, bcdDevice= 0.00
[1339704.516278] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[1339704.516289] usb 5-1: Product: SES084D
[1339704.516300] usb 5-1: Manufacturer: TSST Inc
[1339704.516310] usb 5-1: SerialNumber: R96X542
[1339704.519631] usb-storage 5-1:1.0: USB Mass Storage device detected
[1339704.532320] scsi host0: usb-storage 5-1:1.0
[1339705.554226] scsi 0:0:0:0: CD-ROM            TSSTcorp CDDVDW SE-S084F  TS00 PQ: 0 ANSI: 0
[1339705.555057] scsi 0:0:0:0: Attached scsi generic sg0 type 5
On the net I do only found a information that https://forums.gentoo.org/viewtopic-p-1316644.html
/dev/sg0 is a character-device
and onyl
/dev/sr0 would be a block-device
A block device is needed for the text-cdaudio-player packages "cdtool" or "cdcd".
The URL also tells that block-device support has to be compiled in the kernel.
I dont know if armbian has that block-device-support in there :(
So with my /dev/sg0 (as yours) I only do get the following message from cdtool:
root@npi-k1-plus(192.168.6.70):~# cdplay -d /dev/sg0
cdplay: can't open cdrom (/dev/sg0): not a block device.
# apt-cache search cdtool
cdtool - text-based audio CD player and CD-ROM control commands
# apt-cache search cdcd
cdcd - command line or console based CD player
The following URL tells how to play audio-cd via comman line:
http://www.pc-freak.net/blog/how-to-play-audio-music-cds-in-gnulinux-and-freenetopen-bsds/
Its also possible via mplayer on the commandline:
mplayer cdda:// /dev/cdrom
You can add a track number or range after the // (ex: cdda://1-5), if you want.
[EDIT]
normally armbian seems to support /dev/sr0 because of the udev-rule in
 /lib/udev/rules.d/50-udev-default.rules:
SUBSYSTEM=="block", GROUP="disk"
SUBSYSTEM=="block", KERNEL=="sr[0-9]*", GROUP="cdrom"
SUBSYSTEM=="scsi_generic", SUBSYSTEMS=="scsi", ATTRS{type}=="4|5", GROUP="cdrom"
KERNEL=="sch[0-9]*", GROUP="cdrom"
KERNEL=="pktcdvd[0-9]*", GROUP="cdrom"
KERNEL=="pktcdvd", GROUP="cdrom"
and onyl
This is a little bit confused cause my orange pi one detect the device and more than that it have "cdrom" inside /dev
This is a little bit confuse cause my orange pi one detect the device and it have the /dev/cdrom and the orange pi zero is not
"ls: cannot access '/dev/cdrom': No such file or directory"  is normal then a audio-syste has no "real" filesystem (for a computer).
is you got /dev/sr0 or /dev/cdrom, then you could try to install cdtools (apt intall cdtools) and  then try the command
cdplay -d /dev/sr0
or
cdplay -d /dev/cdrom
cdplay -d /dev/sr0
or
i have a another problem that wish to be helped that i try to play the cd with mplayer but i cant get the audio out cause unlike the orange pi zero it doesnt have analog audio out so i move on to the orange pi zero.But now this problem came in.
So do you know how to get the audio out of the board.That would be great
Edited by barry2212
i dont have any kind of hdmi tv right now so that suck :((
You have two options with the OPi One ;)
1.) buy a cheap HDMI2VGA adaptor on eBay - they also provide a 3.5mm audio-out-jack - like
https://www.ebay.co.uk/itm/PC-TV-1080p-HDMI-Male-to-VGA-Female-Converter-Adapter-with-3-5mm-Audio-Cable/223582664227
2.) buy a USB-soundcard
