Henrik Larsson Posted August 13, 2019 Share Posted August 13, 2019 Running "sudo armbianmonitor -r" fails with this output: Installing RPi-Monitor. This can take up to 5 minutes. Be patient pleaseE: Unable to locate package rpimonitor /usr/bin/armbianmonitor: line 694: /usr/share/rpimonitor/scripts/updatePackagesStatus.pl: No such file or directory Now patching RPi-Monitor to deal correctly with H3 Now you're able to enjoy RPi-Monitor at http://192.168.11.149:8888 It isn't possible to access RPi-Monitor on http://192.168.11.149:8888. The folder /usr/share/rpimonitor does not exist. This is on a Nano PI Neo Air board with freshly installed "buster". (would have included armbianmonitor -u output but that gives this error since yesterday "(52) Empty reply from server") Any idea or fix to the RPi-Monitor install issue? Link to comment Share on other sites More sharing options...
drice Posted August 13, 2019 Share Posted August 13, 2019 14 minutes ago, Henrik Larsson said: E: Unable to locate package rpimonitor The script is simply using apt to install this package, but it can't be found. What is the output of apt list | grep rpimonitor Link to comment Share on other sites More sharing options...
Henrik Larsson Posted August 13, 2019 Author Share Posted August 13, 2019 This is the output: chip@nanopiair:~$ apt list | grep rpimonitor WARNING: apt does not have a stable CLI interface. Use with caution in scripts. chip@nanopiair:~$ Link to comment Share on other sites More sharing options...
drice Posted August 13, 2019 Share Posted August 13, 2019 Strange. Looks like your repository doesn't have the package. I only have Armbian Bionic available to test at the moment, and rpimonitor is in the bionic repo. I see this when I run the same command: rpimonitor/bionic,bionic 2.12-r0 all Have you run apt update and apt upgrade on this system yet? If not, try that. Link to comment Share on other sites More sharing options...
Henrik Larsson Posted August 13, 2019 Author Share Posted August 13, 2019 Yes, apt update and apt ugrade is all I literally have done before trying to install rpimonitor. However now that I understand that it only installs the package from apt then I will try follow this to add a repository with rpimonitor: https://rpi-experiences.blogspot.com/p/rpi-monitor-installation.html Thank you for your help! Link to comment Share on other sites More sharing options...
Henrik Larsson Posted August 13, 2019 Author Share Posted August 13, 2019 Ok, I got it working using these commands sudo wget http://goo.gl/vewCLL -O /etc/apt/sources.list.d/rpimonitor.list sudo apt-key adv --recv-keys --keyserver keyserver.ubuntu.com 2C0D3C0F sudo apt-get update sudo armbianmonitor -r Thanks again, rpimonitor is a great tool so I am happy to have it working! Link to comment Share on other sites More sharing options...
