Which board download?
EricBgood
After reading through the forum I found the file I want to download - ARMBIAN 5.67 user-built Ubuntu 18.04.1 LTS 4.4.143-rk3328-tv 20181203 +compton.
How do I find this file when I don't know which of the almost 100 boards it's under without looking at the hardware specs of each.  Is there a way to cross-reference that I'm not seeing?
All downloads can be found here:
https://www.armbian.com/download/
The name you found does not directly reference to an unique board. It just tells that
- it is run by the RK3328 SoC and there are quite some boards this description could fit
- the kernel version which is pretty common for any Rockchip AFAIK
- it is a (inofficial) user built which means it someone took the build script from here https://github.com/armbian/build and maybe even modified the source before building which is by the name so far impossible to retrace.
Where did you get the board you are looking a download for? What did the dealer say about its name and specs?
  • Werner locked this topic
