Sun Xuan Posted August 28, 2019 Share Posted August 28, 2019 I used both buster and ubuntu images (Armbian_5.91_Nanopineo4_Debian_buster_default_4.4.179_desktop.img and Armbian_5.90_Nanopineo4_Ubuntu_bionic_default_4.4.179_desktop.img), both have no wifi, only show "device not ready". So I extracted firmware from official friendly desktop image and unzip to /lib/firmware/rkwifi/ and wifi works. I'm a newbie and hope this could be fixed properly soon. For those new to linux like me, download the attachment, extract everything to /lib/firmware/rkwifi/, reboot and wifi should be there. ap6212.zip 1 Link to comment Share on other sites More sharing options...
Igor Posted August 28, 2019 Share Posted August 28, 2019 Last time when I was testing those boards, WiFi was working out of the box. Strange. Did you use images from official download locations? Link to comment Share on other sites More sharing options...
Sun Xuan Posted August 29, 2019 Author Share Posted August 29, 2019 18 hours ago, Igor said: Last time when I was testing those boards, WiFi was working out of the box. Strange. Did you use images from official download locations? Yes, downloaded from https://www.armbian.com/nanopi-neo4/, tried both latest stable buster and bionic image. When I typed dmesg it showed that it was looking for fw_bcm43438a1.bin in /lib/firmware/rkwifi/, but only fw_bcm43438a0.bin was there. I also checked the github repo https://github.com/armbian/firmware/tree/master/rkwifi, no fw_bcm43438a1.bin in there. Actually it can be found in /lib/firmware/ap6212/, but it seemed that the system was not looking into that position. Link to comment Share on other sites More sharing options...
Igor Posted August 29, 2019 Share Posted August 29, 2019 8 minutes ago, Sun Xuan said: I also checked the github repo https://github.com/armbian/firmware/tree/master/rkwifi, no fw_bcm43438a1.bin in there. Actually it can be found in /lib/firmware/ap6212/, but it seemed that the system was not looking into that position. There is a mess with this firmware ... perhaps we only need to adjust this patch: https://github.com/armbian/build/blob/master/patch/kernel/rk3399-default/adjust_wireless_firmware_path.patch ... or rather make a copy/link from ap6212 -> rkwifi because it is highly possible we have different chips on the same board model. Link to comment Share on other sites More sharing options...
GeorgeP Posted September 13, 2019 Share Posted September 13, 2019 On 8/29/2019 at 4:24 PM, Igor said: There is a mess with this firmware ... perhaps we only need to adjust this patch: https://github.com/armbian/build/blob/master/patch/kernel/rk3399-default/adjust_wireless_firmware_path.patch ... or rather make a copy/link from ap6212 -> rkwifi because it is highly possible we have different chips on the same board model. I've just come across this same problem. I copied the two files 'fw_bcm43438a1.bin' and 'fw_bcm43438a1_apsta.bin' (I'm not sure if that second one is needed) from /lib/firmware/ap6212/ to /lib/firmware/rkwifi/ and rebooted and the wifi now works OK. My board is very much a 'test bed' at the moment so I'm happy to test any possible fixes. George Link to comment Share on other sites More sharing options...
