Question: Run the fan, only if cpu temperature is over 60º
maxlinux2000
Most of the time our Arm computer does nothing and the CPU is around 40º, and therefore no fan is needed.
But sometimes they work a lot and the fan is really necessary.
So I wonder if a 5V fan connected to the gpio pins can be used and that the same board sends power to the fan when for example the CPU exceeds 60 °.
And below 60º the orangepi that cuts the current to the fan.
Can it be done without external components?
I dont think the GPIO line had enough power to drive the fan.
I think you should wire the fan to the normal 5v line and put a switching device like a relais or switching transistor in the fan powerline connected to the GPIO or I2C line.
then you can read the temperature via script and switch the fan on/off with the script.
another idea would be a bimetal switch in the 5v powerline of the fan (so no script control)
Just my 5 cent ;)
