SaiHou Posted August 29, 2019 Share Posted August 29, 2019 Hello everyone, I am looking for an answer regarding the Orange Pi PC2 Armbian OS is 32-bit or 64-bit version? Thanks in advance. Best regards, SaiHou Link to comment Share on other sites More sharing options...
guidol Posted August 29, 2019 Share Posted August 29, 2019 armbian for OPi PC2 H5-CPU is 64bit (aarch64) 1 Link to comment Share on other sites More sharing options...
SaiHou Posted August 29, 2019 Author Share Posted August 29, 2019 9 minutes ago, guidol said: armbian for OPi PC2 H5-CPU is 64bit (aarch64) @guidol, Thanks for the info. Is it possible to get 32-bit Armbian for it to run on OPi PC2? Regards. Link to comment Share on other sites More sharing options...
martinayotte Posted August 29, 2019 Share Posted August 29, 2019 3 minutes ago, SaiHou said: Is it possible to get 32-bit Armbian for it to run on OPi PC2? No ! Armbian is built for native capabilties ! But why do you need it in 32 bits ? If you have a closed source application which is only available in 32 bits, you can still install required 32 bits libraries, such libc ... 1 Link to comment Share on other sites More sharing options...
SaiHou Posted August 29, 2019 Author Share Posted August 29, 2019 59 minutes ago, martinayotte said: No ! Armbian is built for native capabilties ! But why do you need it in 32 bits ? If you have a closed source application which is only available in 32 bits, you can still install required 32 bits libraries, such libc ... @martinayotte, Thanks for the reply. I don't know what version of OS does Raspbian Stretch / Buster is... But for sure some application package cannot be installed in "aarch64" or "meson64" due to no such packages available. That is why I ask such "question" in this forum. I have OPi PC (H3) and most what Raspbian packages can installed, the same as armbian for OPi PC also can be installed. I think I stick back to OPi PC (H3). I am just beginner, so not much knowledge I have on armbian or raspbian. Thanks mates. Link to comment Share on other sites More sharing options...
Igor Posted August 29, 2019 Share Posted August 29, 2019 55 minutes ago, SaiHou said: But for sure some application package cannot be installed 1 Link to comment Share on other sites More sharing options...
SaiHou Posted August 29, 2019 Author Share Posted August 29, 2019 6 hours ago, Igor said: @Igor, Thanks for the info. I refer to the page you shared and follow the instructions and now it works on my Nano Pi K2 Amlogic S905. Really appreciated your support team here. Best regards. Link to comment Share on other sites More sharing options...
