MCP2515 CAN bus user overlay
BertHav
Hereby a tutorial to connect an MCP2515 based CAN bus interface to an OrangePi 3 running successfull with Buster minimal nightly with 5.3 kernel. It uses the attached user overlay only and doesn’t need any other overlay.
Connections
CAN module
OPi3
26 pin header
Raspberry
CAN interface
40 pin header
Vcc 3.3 CON12-P01 1
Gnd CON12-P06 6
MOSI CON12-P19 19
MISO CON12-P21 21
CLK CON12-P23 23
CS CON12-P24 24
INT CON12-P26 22
Optional 5V for
Transceiver
on cheap
Chinese modules
CON12-P02
Not used
when
equiped
with a
3.3V transceiver
Add the attached overlay with the command:
sudo armbian-add-overlay spi-h6-mcp2515.dts
The file /boot/armbianEnv.txt now contains a line:
user_overlays=spi-h6-mcp2515
Reboot the OrangePi 3
Check if the MCP2515 is recognized:
pi@orangepi3:~$ dmesg | grep mcp
If properly connected it should return a line containing:
mcp251x spi1.0 can0: MCP2515 successfully initialized.
As stated a can0 interface should be generated check it with:
pi@orangepi3:~$ sudo ifconfig -a
Bring up the network:
sudo ip link set can0 up type can bitrate 250000
Check if the interrupt is hooked:
cat /proc/interrupts
should return a line like this
46:          1          0          0          0  sunxi_pio_edge   8 Edge      mcp251x
Check for traffic on the CAN bus with candump from can-utils  (sudo apt-get install can-utils)
candump can0
spi-h6-mcp2515.dts
Searching the forum will give an explanation, sometimes Google is your best friend.....
For short, replace  "sudo armbian-add-overlay spi-h6-mcp2515.dts" with the following commands:
 dtc -@ -q -I dts -O dtb -o spi-h6-mcp2515.dtbo spi-h6-mcp2515.dts
 sudo nano /boot/armbianEnv.txt
          insert the line: user_overlays=spi-h6-mcp2515
          write and exit nano
sudo mkdir -p /boot/overlay-user
sudo cp spi-h6-mcp2515.dtbo /boot/overlay-user/spi-h6-mcp2515.dtbo
Reboot the OrangePi 3 and continue with check if the MCP2515 is recognized
Hello, i work on  Lime-a64 board (olimex).
Based on this topic and some other around, i wrote the overlay attached.
The module i used is use on this topic for the raspberry : tutorial raspberryi.
The pinout:
| Lime-A64  | UEXT Nb |   Function   | Output | Module  |
| +3.3      | 1       |              | VCC    | 7       |
| GND       | 2       |              | GND    | 6       |
| PH4       | 3       | UART3TX      |        |         |
| PH5       | 4       | UART3RX      |        |         |
| PH2       | 5       | TWI1-SCK     | INT    | 1       |
| PH3       | 6       | TWI1-SDA     |        |         |
| PC1       | 7       | SPI_MISO     | SO     | 4       |
| PC0       | 8       | SPI_MOSI     | SI     | 3       |
| PC2       | 9       | SPI_CLK      | SCK    | 2       |
| PC3       | 10      | SPI_CS       | CS     | 5       |
The mcp seem will initialized and i can up the interfaces. however, i am not sure interrupts works.
This line seem wrong :
 interrupts = <0 194 2>; /* PH2 IRQ_TYPE_EDGE_FALLING */
Someone know how to correctly set the line with the Allwinner A64,  PH2 pin ?
spi-a64-mcp2515.dts
I get a complete system hang on 'sudo ip link set can0 up type can bitrate 250000'
ifconfig -a shows Can0 and no errors that i can see in dmesg
I am using the Waveshare CanHat https://www.waveshare.com/rs485-can-hat.htm
dtparam=spi=on dtoverlay=mcp2515-can0,oscillator=12000000,interrupt=25,spimaxfrequency=2000000
so i changed the following lines in the dts file.
clock-frequency  = <12000000>;
spi-max-frequency = <20000000>;
nothing else, I am Wired as per directions
Orange Pi 3.0.6 Bullseye with Linux 5.16.17-sun50iw6
Anybody got any idea's ??
I know im close, but with a complete hang, its hard to see the error.
You are not using Armbian. Therefore this is the wrong place to ask. Try where you go your OS from. We cannot support 3rd party systems.
