1 hour ago, Werner said:
If somebody wants a provided fix faster they
That goes for 3rd party, but the problem with those patch / hotfix releases are mainly to cover our problems, things that were missed out ... everything that we / contributors have a wish to fix it up.
Quick question: I put some bugfixes/improvements in the past on Jira, but they did not make it into the release change log (Examples: https://armbian.atlassian.net/browse/AR-478 https://armbian.atlassian.net/browse/AR-600 https://armbian.atlassian.net/browse/AR-599 https://armbian.atlassian.net/browse/AR-585)
Is there any additional step I must take for it to be displayed in the changelog? Well, the changes make it into the binaries anyway, but I'd rather have them documented also in the changelog.
3 minutes ago, Heisath said:
You need to assign a fix version
Cool. I put as Fix version "20.05" in all the issues mentioned above. As a matter of fact, they are already merged and present in the 20.02 release, but at least they will be documented even though in a later release.
For the future - you can have things in more than one release, so you add more tag(s). Some projects should be mentioned in current and upcoming release documentation.
BTW. If you care, you can add things manually to the release documentation. https://docs.armbian.com/Release_Changelog/ Perhaps just to the latest, if things are merged.
Okay, but since I added the "Fix version" tag, will not they be added automatically to next release? Just in case, so there are not duplicates.
  • Igor unpinned this topic
