RenatoLorenzi Posted October 11, 2019 Share Posted October 11, 2019 I have several orange pi pc plus using armbian and need to upgrade. I was able to upgrade to bionic but the kernel continued on version 3.4.113-sun8i. How do I upgrade the kernel? I need to upgrade because I will use the docker and it requires a kernel at least with version 3.10 Link to comment Share on other sites More sharing options...
062621AM Posted October 12, 2019 Share Posted October 12, 2019 Why don't you flash a new image instead? Even Ubuntu doesn't upgrade the kernel after certain version. https://dl.armbian.com/orangepipcplus/archive/Armbian_5.90_Orangepipcplus_Ubuntu_bionic_next_4.19.57.7z Link to comment Share on other sites More sharing options...
RenatoLorenzi Posted October 15, 2019 Author Share Posted October 15, 2019 On 10/12/2019 at 5:08 AM, 062621AM said: Why don't you flash a new image instead? Even Ubuntu doesn't upgrade the kernel after certain version. https://dl.armbian.com/orangepipcplus/archive/Armbian_5.90_Orangepipcplus_Ubuntu_bionic_next_4.19.57.7z the problem is that I have it spread out over several regions and this process is going to be expensive Link to comment Share on other sites More sharing options...
Igor Posted October 16, 2019 Share Posted October 16, 2019 In theory: you need to remove existing kernel package, u-boot, board support package, upgrade and manually update u-boot, check boot script if its the same as the one in the build script, check if armbianEnv.txt is present and you have a correct UUID inside. Then install DTB kernel package, kernel IMAGE and board support package. Link to comment Share on other sites More sharing options...
