71rogi Posted October 31, 2019 Share Posted October 31, 2019 Hi I have issue to run bluetooth on OrangePI Zero Plus2 H5 with Armbian 4.14.63-suxi64 - what I donloaded from the armbian page where is my device and this image is supported. Wifi is working but I have issue tu run Bluetooth - I read many topics here but I dont understand what to do. Maybe Im doing some wrong. Can someone advice me what should be done, please. Current status after installation: * ap6212-bluetooth.service - LSB: Patch firmware for ap6212 adapter Loaded: loaded (/etc/init.d/ap6212-bluetooth; generated; vendor preset: enabled) Active: failed (Result: exit-code) since Thu 2019-10-31 08:45:14 UTC; 24min ago Docs: man:systemd-sysv-generator(8) Process: 675 ExecStart=/etc/init.d/ap6212-bluetooth start (code=exited, status=1/FAILURE) Oct 31 08:45:04 orangepizeroplus2 ap6212-bluetooth[675]: Memory mapped at address 0xffffa12ef000. Oct 31 08:45:04 orangepizeroplus2 ap6212-bluetooth[675]: Value at address 0x1F00060 (0xffffa12ef060): 0x0 Oct 31 08:45:04 orangepizeroplus2 ap6212-bluetooth[675]: Written 0x1; readback 0x1 Oct 31 08:45:14 orangepizeroplus2 ap6212-bluetooth[675]: Initialization timed out. Oct 31 08:45:14 orangepizeroplus2 ap6212-bluetooth[675]: bcm43xx_init Oct 31 08:45:14 orangepizeroplus2 ap6212-bluetooth[675]: Can't get device info: No such device Oct 31 08:45:14 orangepizeroplus2 systemd[1]: ap6212-bluetooth.service: Control process exited, code=exited status=1 Oct 31 08:45:14 orangepizeroplus2 systemd[1]: Failed to start LSB: Patch firmware for ap6212 adapter. Oct 31 08:45:14 orangepizeroplus2 systemd[1]: ap6212-bluetooth.service: Unit entered failed state. Oct 31 08:45:14 orangepizeroplus2 systemd[1]: ap6212-bluetooth.service: Failed with result 'exit-code'. Link to comment Share on other sites More sharing options...
71rogi Posted October 31, 2019 Author Share Posted October 31, 2019 I did update firmware and update kernel to lastest release. Still the same issue... I dont know what Im doing wrong. Also I tested on Debian Bionic 5.3.7-suixi64. Link to comment Share on other sites More sharing options...
