haajee Posted November 10, 2019 Share Posted November 10, 2019 Hello everyone, I want to do something simple with my OrangePi One Plus. That is to connect a bluetooth speaker and play wireless from the Pi with a CSR8510 A10 USB dongel. The dongel works and i can pair with every device. Even with my JBL Go 2 bluetooth speaker: hj@PLUS-OrangePiOne:~ $ sudo bluetoothctl [NEW] Controller YY:YY:YY:YY PLUS-OrangePiOne [default] Agent registered [bluetooth]# power on Changing power on succeeded [bluetooth]# scan on Discovery started [CHG] Controller YY:YY:YY:YY Discovering: yes [NEW] Device XX:XX:XX:XX JBL GO 2 [bluetooth]# scan off Discovery stopped [CHG] Controller YY:YY:YY:YY Discovering: no [CHG] Device XX:XX:XX:XX TxPower is nil [CHG] Device XX:XX:XX:XX RSSI is nil [bluetooth]# trust XX:XX:XX:XX [CHG] Device XX:XX:XX:XX Trusted: yes Changing XX:XX:XX:XX trust succeeded [bluetooth]# pair XX:XX:XX:XX Attempting to pair with XX:XX:XX:XX [CHG] Device XX:XX:XX:XX Connected: yes [CHG] Device XX:XX:XX:XX UUIDs: 00001108-0000-1000-8000-00805f9b34fb [CHG] Device XX:XX:XX:XX UUIDs: 0000110b-0000-1000-8000-00805f9b34fb [CHG] Device XX:XX:XX:XX UUIDs: 0000110c-0000-1000-8000-00805f9b34fb [CHG] Device XX:XX:XX:XX UUIDs: 0000110e-0000-1000-8000-00805f9b34fb [CHG] Device XX:XX:XX:XX UUIDs: 0000111e-0000-1000-8000-00805f9b34fb [CHG] Device XX:XX:XX:XX ServicesResolved: yes [CHG] Device XX:XX:XX:XX Paired: yes Pairing successful [CHG] Device XX:XX:XX:XX ServicesResolved: no [CHG] Device XX:XX:XX:XX Connected: no [bluetooth]# connect XX:XX:XX:XX Attempting to connect to XX:XX:XX:XX Failed to connect: org.bluez.Error.Failed But, as you can see above, i can´t connect to the JBL Go2. If i open the bluetooth service i read: hj@PLUS-OrangePiOne:~ $ sudo service bluetooth status * bluetooth.service - Bluetooth service Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled) Active: active (running) since Sun 2019-11-10 14:53:35 CET; 1h 9min ago Docs: man:bluetoothd(8) Main PID: 732 (bluetoothd) Status: "Running" Tasks: 1 (limit: 1021) CGroup: /system.slice/bluetooth.service `-732 /usr/lib/bluetooth/bluetoothd Nov 10 15:42:13 PLUS-OrangePiOne bluetoothd[732]: a2dp-sink profile connect failed for XX:XX:XX:XX Protocol not available Nov 10 15:43:20 PLUS-OrangePiOne bluetoothd[732]: a2dp-sink profile connect failed for XX:XX:XX:XX Protocol not available Nov 10 15:43:36 PLUS-OrangePiOne bluetoothd[732]: a2dp-sink profile connect failed for XX:XX:XX:XX Protocol not available Nov 10 15:43:44 PLUS-OrangePiOne bluetoothd[732]: a2dp-sink profile connect failed for XX:XX:XX:XX Protocol not available Nov 10 15:43:53 PLUS-OrangePiOne bluetoothd[732]: a2dp-sink profile connect failed for XX:XX:XX:XX Protocol not available Nov 10 15:44:03 PLUS-OrangePiOne bluetoothd[732]: a2dp-sink profile connect failed for XX:XX:XX:XX Protocol not available Nov 10 15:44:09 PLUS-OrangePiOne bluetoothd[732]: a2dp-sink profile connect failed for XX:XX:XX:XX Protocol not available Nov 10 15:44:11 PLUS-OrangePiOne bluetoothd[732]: a2dp-sink profile connect failed for XX:XX:XX:XX Protocol not available Nov 10 15:44:18 PLUS-OrangePiOne bluetoothd[732]: a2dp-sink profile connect failed for XX:XX:XX:XX Protocol not available Nov 10 15:59:28 PLUS-OrangePiOne bluetoothd[732]: a2dp-sink profile connect failed for XX:XX:XX:XX Protocol not available Off course did i look on Google and i read something with pulseaudio but that should be installed also the ´pulse-module-bluetooth´ module. i have no idea to fix this. Btw: connecting to non-audio bluetooth devices works. Connecting to the JBL Go2 from Armbian-config does also not work... Does someone of you a sugestion to make a2dp working? Link to comment Share on other sites More sharing options...
