41 41
balbes150
Single Armbian image for RK + AML + AW
19 hours ago, gilberto said:
I tried all the dtbs but the wifi does not work the device does not appear with the command ifconfig the hardware configuration is just below. Thank you all for your help! Right now I'm downloading the last img 5/20 to try.
Your dmesg implies your built in wifi might be RTL8723BS but I couldnt tell you about kernel / dts support for it.
Have a look at this post https://forum.armbian.com/topic/2419-armbian-for-amlogic-s905-and-s905x-ver-544/?do=findComment&comment=65706 (which you probably know anyway how to probe) and my other posts about hardware.
You've not said what box/hardware you have - it may be covered by one of the other forums topics.
Share this post
Link to post
Share on other sites
0.000000] Linux version 5.1.0-aml-s905
old kernel
Share this post
Link to post
The new version 20.05.5 (20200522).
All images are build entirely on the ARM platform (rk3399 + NVMe). After fixing bugs, the process of building the first image (including downloading sources, building all packages, building the kernel, u-boot, and so on) took less than 50 minutes.  :)
Share this post
Link to post
Following instructions from you and balbes150, I changed the version of the image to kernel 5.6, as for the model of my box, how can I have details. The only thing written behind it is Model TX3 Mini -H.
Linux aml 5.5.0-rc6-aml-s9xxx #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020 aarch64 GNU/Linux this is my kernel
I try modprobe r8723bs
oot@aml:/home/fenixix# lsmod
Module                  Size  Used by
r8723bs               581632  0
cfg80211              417792  1 r8723bs
fuse                  131072  3
bnep                   32768  2
zram                   36864  2
nls_ascii              16384  1
joydev                 28672  0
hci_uart              143360  0
ir_nec_decoder         20480  0
btqca                  20480  1 hci_uart
meson_vdec             86016  0
btrtl                  24576  1 hci_uart
lima                   45056  0
btbcm                  16384  1 hci_uart
v4l2_mem2mem           40960  1 meson_vdec
rc_khadas              16384  0
gpu_sched              28672  1 lima
btintel                32768  1 hci_uart
videobuf2_dma_contig    24576  1 meson_vdec
crct10dif_ce           16384  1
videobuf2_memops       20480  1 videobuf2_dma_contig
meson_ir               16384  0
videobuf2_v4l2         36864  2 meson_vdec,v4l2_mem2mem
bluetooth             598016  13 btrtl,btqca,btintel,hci_uart,btbcm,bnep
rc_core                61440  4 rc_khadas,ir_nec_decoder,meson_ir
videobuf2_common       61440  3 meson_vdec,videobuf2_v4l2,v4l2_mem2mem
videodev              233472  4 meson_vdec,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem
ao_cec                 20480  0
ecdh_generic           16384  1 bluetooth
ecc                    32768  1 ecdh_generic
rfkill                 36864  5 bluetooth,cfg80211
mc                     61440  4 videodev,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem
meson_rng              16384  0
dw_hdmi_cec            16384  0
ip_tables              28672  0
x_tables               40960  1 ip_tables
ipv6                  585728  48
nf_defrag_ipv6         24576  1 ipv6
gpio_keys_polled       16384  0
adc_keys               16384  0
root@aml:/home/fenixix# uname -a
the result is
root@aml:/home/fenixix# ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.0.13  netmask 255.255.255.0  broadcast 192.168.0.255
        inet6 2804:14c:87c0:c3ca:99dd:aeb8:80fe:936a  prefixlen 64  scopeid 0x0<global>
        inet6 2804:14c:87c0:c3ca:215:18ff:fe01:8131  prefixlen 64  scopeid 0x0<global>
        inet6 fe80::215:18ff:fe01:8131  prefixlen 64  scopeid 0x20<link>
        ether 00:15:18:01:81:31  txqueuelen 1000  (Ethernet)
        RX packets 18935  bytes 17030091 (16.2 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 9778  bytes 1469003 (1.4 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 23
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 6  bytes 234 (234.0 B)
        TX packets 6  bytes 234 (234.0 B)
it seems to be a problem with the firmware the module loads but I see this message with dmesg
[  594.344364] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[  594.382245] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[  594.385982] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[  594.391731] cfg80211: failed to load regulatory.db
[  594.426432] r8723bs: module is from the staging directory, the quality is unknown, you have been warned.
[  594.443870] RTL8723BS: module init start
[  594.443910] RTL8723BS: rtl8723bs v4.3.5.5_12290.20140916_BTCOEX20140507-4E40
[  594.449220] RTL8723BS: rtl8723bs BT-Coex version = BTCOEX20140507-4E40
[  594.455843] RTL8723BS: module init ret =0
I have with armbianmonitor -u
http://ix.io/2n0i
I believe that other people will have the same problem with their boxes. How can I be sure the model of my box only has the sticker that I said behind it. I have a project and I will have several models being tested. I compiled the 7.7 kernel and it was the same. Guys do you have any idea ..
Thanks for responding and I want to help as much as possible on the s905 cards
Share this post
Link to post
TV boxes can be anything inside despite being identical so you have to dig around.
If I was in your position, I would boot into android to determine what wifi chip you have and what firmware file it uses - see this post plus whats in /sys/class/net/.
The type of AMLogic hardware 'details' can be determined from this post which give you an starting point for the dtb file that is required.
Wifi & BT are not guaranteed to work as per the developer/forum thread originator. Hardware can be supported one day and then the next release a bug creeps into the kernel or dts.
You also need to try every dtb file.
Share this post
Link to post
Really impressive. Thank you for the excellent work you're doing.
I've migrated recently from Armbian to Manjaro ARM (some credit for balbes150 again) on my Khadas Vim2 Pro like (dtb) machines : Dealdig-Boxd6/Beelink GT1 Ultimate. Everything works great there too (eth, wlan even in AP mode, bluetooth) and OpenGL ES with Panfrost (but unfortunnaly not yet on XFCE4 with its default compositor nor with picom either).
Share this post
Link to post
The first thing I will try and in the 5.7 kernel, test all dtbs I already installed Android and I will access the / sys / class / net / and discover the modules used by the kernel on android. I'm installing an app on android called King root to access the shell and discover this information. For me to be root and discover this. Thank you very much for all your help. I will try to be active on the channel to help everyone as well .... I will soon pass on my discoveries about this BOX .... If you have suggestions I will follow ...
Share this post
Link to post
A clean test build of the Focal-server image on the Ugoos X2 TV box (s905x2). The build system (Armbian Bionic desktop) is started from the SD card. I cloned GIT, started the build, and the system automatically got all the necessary packages (dependencies), installed them, and started the build (downloading sources, building the kernel, and so on). The entire process from the start of the build to the output of the finished image took exactly 201 minutes. The total amount of space used on the SD card (together with the finished image) it was about 11 GB. This means that 16 GB of storage will be enough to build the server version (perhaps 16 GB will be enough for the desktop version). I consider this a good result for a minimal device with 4 cores and the slowest media (SD card). :)
It would be interesting to compare the results of the build process on different TV boxes (chips) with different media.
Share this post
Link to post
Checked the test build on AM6 (s922). When starting the system and building from the SD card, the clean build of the Focal-server version took 101 minutes. Installed the same system from the SD card to eMMC. Launched a clean build of the Bionic-desktop version for s812 (running, downloading all sources, full kernel build, u-boot, all packages, etc.). build Time is 73 minutes. This shows how media parameters affect the overall build time.
Share this post
Link to post
A question for those who use the header package for the kernel. Previously reported errors with this package (due to the build on x86). I'm wondering if there are any header errors after transferring the build to the ARM platform ?
deb files with the new kernel collected on the ARM platform
https://yadi.sk/d/4swKv82e0Cd29A
Share this post
Link to post
Even though the old sources packages also work fine for me, now i can compile rtl8812au driver with the parts that use floating point.  Is now the kernel compiled without mgeneral-regs-only?
Thank you,
Share this post
Link to post
No problem here :
❯ dpkg -i linux-image-current-arm-64_20.05.5_arm64.deb linux-headers-current-arm-64_20.05.5_arm64.deb
(Reading database ... 74883 files and directories currently installed.)
Preparing to unpack linux-image-current-arm-64_20.05.5_arm64.deb ...
Unpacking linux-image-current-arm-64 (20.05.5) over (20.05.4) ...
Preparing to unpack linux-headers-current-arm-64_20.05.5_arm64.deb ...
Unpacking linux-headers-current-arm-64 (20.05.5) over (20.05.4) ...
Setting up linux-image-current-arm-64 (20.05.5) ...
update-initramfs: Generating /boot/initrd.img-5.7.0-rc6-arm-64
W: Couldn't identify type of root file system for fsck hook
update-initramfs: Converting to u-boot format
Setting up linux-headers-current-arm-64 (20.05.5) ...
Compiling headers - please wait ...
Share this post
Link to post
Hello world!
I wanted to ask if there is a possibility of updating my current Armbian build 20.05.4 to a new one 20.05.5? I run it on S905 with balbes150's build. apt upgrade fetches the newest versions of packages, but armbian-config still shows the old version. Updating the kernel to the newest one (with 20.05.5 headers) also does not affect the version.
I did some digging and it appears that 20.05.4 shows up in a couple of files, including armbian-release (which advises not to modify the file).
Did I miss something or is the clean installation the only option?
Thanks!
Share this post
Link to post
To find out the information about the BOX, I am posting images of Android with the information, discover the module:  which is the ssv6051 but the error with the command sudo modprobe ssv6051
As I am testing with the new images of Balbes150 I believe that many will have this problem with this wifi.
The images below are from android and show amlogic box. I tried to load the module ssv6051 but it shows error says that the module does not exist.
the kernel and 5.6 any suggestions?
Share this post
Link to post
I tried this commands
root@aml:/lib/modules/5.5.0-rc6-aml-s9xxx/kernel/net# cd wireless/
root@aml:/lib/modules/5.5.0-rc6-aml-s9xxx/kernel/net/wireless# ls
cfg80211.ko             lib80211_crypt_tkip.ko  lib80211.ko
lib80211_crypt_ccmp.ko  lib80211_crypt_wep.ko
root@aml:/lib/modules/5.5.0-rc6-aml-s9xxx/kernel/net/wireless# modprobe ssv6051
modprobe: FATAL: Module ssv6051 not found in directory /lib/modules/5.5.0-rc6-aml-s9xxx
Share this post
Link to post
8 hours ago, gilberto said:
ssv6051
any suggestions?
One suggestion is to forget about this WiFi chip and use a USB chip.
Share this post
Link to post
I pulled you latest Build-Armbian tree yesterday to attempt a native build on some of my hardware.  I got the following error:
  DTC     arch/arm/dts/rk3399-rockpro64.dtb
  SHIPPED dts/dt.dtb
  FDTGREP dts/dt-spl.dtb
  CAT     u-boot-dtb.bin
Image Type:   Rockchip RK33 (SD/MMC) boot image
Data Size:    73728 bytes
warning: TCG doesn't support requested feature: CPUID.01H:ECX.vmx [bit 5]
/lib64/ld-linux-x86-64.so.2: No such file or directory
[ error ] ERROR in function compile_uboot [ compilation.sh:227 ]
[ error ] U-boot file not found [ uboot.img ]
[ o.k. ] Process terminated
(I was attempting the following build:  Full OS Image, arm-64, bionic, server, standard).
Should your Build-Armbian github repo be working for native builds?
I haven't tried to debug this error yet, just wanted to check with you if you felt this should work given what you have checked into your github repository.
Share this post
Link to post
What system do you run the build on ? And write in detail, all the steps that you do.
Share this post
Link to post
Judging from this line, you didn't use the latest Armbian Bionic image. Only they have all the pre-settings for the correct operation of the build system.
Share this post
Link to post
So I need a new install of a current image, and I can't use an environment that has been upgraded?  Correct?  I will try that when I have a chance.  Thanks
Share this post
Link to post
49 minutes ago, SteeMan said:
You can use the current system, but you need to manually add two directories\files to work with qemu (you can take them from the last finished image), see the log, it will indicate what is missing. The rest should work and install automatically.
Share this post
Link to post
Mr. Balbes 150 or do you think you can try to compile this code in the kernel? libreelec people use this driver, would it be cool to put it in your images? I'll try to compile !!! What kernel header should I use I didn't find s9xx. the code below looks promising to me
http://kszaq.libreelec.tv/sources/ssv6xxx-1041e7d.tar.gz
Share this post
Link to post
If you want to try it, it's your right. I won't waste any more time answering you.
Share this post
Link to post
I am sorry you are right, I just wanted to help I discovered this in my research.
The company making the SV6051P wifi chip went bankrupt.
So you won't get any new Android OS with that driver or old ones where the driver didn't exist.
Linux kernel developers also said they won't update the driver for newer kernels and mainline it because it's in a terrible state and it must go extinct.
It's a very bad idea to buy such no-name devices, now later on you sit with problems.
Share this post
Link to post
41 41
