spender Posted November 15, 2019 Share Posted November 15, 2019 I had try build a new kernel with tft screen , module ssd1322, find source , and build patch file, just like attach file <spender-ssd1322.patch>, and put it to patch : build/userpatches/kernel/sunxi-next, . then do "compile.sh", view patching.log, and compilation.log, compiler.log, no error! , directory build/cache/sources/linux-mainline/linux-4.19.y/drivers/staging/fbtft , no fb_ssd1322.o, .mod.c, .ko file output. build failed! help me , how to do spender-ssd1322.patch Link to comment Share on other sites More sharing options...
spender Posted November 17, 2019 Author Share Posted November 17, 2019 had build, and now boot from os, dmesg |grep fbtft, display : root@nanopineo:/etc/lirc# dmesg|grep fbtft [ 10.705494] fbtft: module is from the staging directory, the quality is unknown, you have been warned. [ 10.712490] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned. [ 10.714226] fbtft_device: spi_busnum_to_master(0) returned NULL [ 10.714235] fbtft_device: failed to register SPI device my patch is build from: https://github.com/prius0304/fbtft---SSD1322/blob/master/fb_ssd1322.c any one can help me Link to comment Share on other sites More sharing options...
Igor Posted November 17, 2019 Share Posted November 17, 2019 2 hours ago, spender said: any one can help me Perhaps driver authors or fbtft maintainer?https://github.com/prius0304/fbtft---SSD1322/blob/master/fb_ssd1322.c#L175 https://github.com/notro/fbtft/wiki Link to comment Share on other sites More sharing options...
spender Posted November 19, 2019 Author Share Posted November 19, 2019 Thinks . I will try again! Link to comment Share on other sites More sharing options...
spender Posted November 20, 2019 Author Share Posted November 20, 2019 Here is Debug information: # cd /lib/modules/4.19.84-sunxi/kernel/drivers/staging/fbtft root@nanopineo:/lib/modules/4.19.84-sunxi/kernel/drivers/staging/fbtft# modinfo fbtft_device filename: /lib/modules/4.19.84-sunxi/kernel/drivers/staging/fbtft/fbtft_device.ko license: GPL author: Noralf Tronnes description: Add a FBTFT device. depends: fbtft staging: Y intree: Y name: fbtft_device vermagic: 4.19.84-sunxi SMP mod_unload ARMv7 thumb2 p2v8 parm: name:Devicename (required). name=list => list all supported devices. (charp) parm: rotate:Angle to rotate display counter clockwise: 0, 90, 180, 270 (uint) parm: busnum:SPI bus number (default=0) (uint) parm: cs:SPI chip select (default=0) (uint) parm: speed:SPI speed (override device default) (uint) parm: mode:SPI mode (override device default) (int) parm: gpios:List of gpios. Comma separated with the form: reset:23,dc:24 (when overriding the default, all gpios must be specified) (charp) parm: fps:Frames per second (override driver default) (uint) parm: gamma:String representation of Gamma Curve(s). Driver specific. (charp) parm: txbuflen:txbuflen (override driver default) (int) parm: bgr:BGR bit (supported by some drivers). (int) parm: startbyte:Sets the Start byte used by some SPI displays. (uint) parm: custom:Add a custom display device. Use speed= argument to make it a SPI device, else platform_device (bool) parm: width:Display width, used with the custom argument (uint) parm: height:Display height, used with the custom argument (uint) parm: buswidth:Display bus width, used with the custom argument (uint) parm: init:Init sequence, used with the custom argument (array of short) parm: debug:level: 0-7 (the remaining 29 bits is for advanced usage) (ulong) parm: verbose:0 silent, >0 show gpios, >1 show devices, >2 show devices before (default=3) (uint) root@nanopineo:/lib/modules/4.19.84-sunxi/kernel/drivers/staging/fbtft# modprobe fbtft_device name=list modprobe: ERROR: could not insert 'fbtft_device': Operation canceled root@nanopineo:/lib/modules/4.19.84-sunxi/kernel/drivers/staging/fbtft# dmesg|grep fbtft [16009.687584] fbtft_device: Supported displays: [16009.687599] fbtft_device: adafruit18 [16009.687605] fbtft_device: adafruit18_green [16009.687610] fbtft_device: adafruit22 [16009.687614] fbtft_device: adafruit22a [16009.687620] fbtft_device: adafruit28 [16009.687625] fbtft_device: adafruit13m [16009.687629] fbtft_device: lm560g <- This my ssd1322 driver name, and build can create a file , named "fb_ssd1322.ko" [16009.687634] fbtft_device: admatec_c-berry28 [16009.687639] fbtft_device: agm1264k-fl [16009.687644] fbtft_device: dogs102 [16009.687649] fbtft_device: er_tftm050_2 [16009.687654] fbtft_device: er_tftm070_5 [16009.687659] fbtft_device: ew24ha0 [16009.687663] fbtft_device: ew24ha0_9bit [16009.687668] fbtft_device: flexfb [16009.687673] fbtft_device: flexpfb [16009.687678] fbtft_device: freetronicsoled128 [16009.687683] fbtft_device: hx8353d [16009.687688] fbtft_device: hy28a [16009.687693] fbtft_device: hy28b [16009.687698] fbtft_device: ili9481 [16009.687703] fbtft_device: itdb24 [16009.687707] fbtft_device: itdb28 [16009.687712] fbtft_device: itdb28_spi [16009.687717] fbtft_device: mi0283qt-2 [16009.687722] fbtft_device: mi0283qt-9a [16009.687727] fbtft_device: mi0283qt-v2 [16009.687732] fbtft_device: nokia3310 [16009.687737] fbtft_device: nokia3310a [16009.687742] fbtft_device: nokia5110 [16009.687747] fbtft_device: piscreen [16009.687751] fbtft_device: pitft [16009.687756] fbtft_device: pioled [16009.687761] fbtft_device: rpi-display [16009.687766] fbtft_device: s6d02a1 [16009.687771] fbtft_device: sainsmart18 [16009.687776] fbtft_device: sainsmart32 [16009.687781] fbtft_device: sainsmart32_fast [16009.687786] fbtft_device: sainsmart32_latched [16009.687791] fbtft_device: sainsmart32_spi [16009.687796] fbtft_device: spidev [16009.687801] fbtft_device: ssd1331 [16009.687806] fbtft_device: tinylcd35 [16009.687811] fbtft_device: tm022hdh26 [16009.687815] fbtft_device: tontec35_9481 [16009.687820] fbtft_device: tontec35_9486 [16009.687825] fbtft_device: upd161704 [16009.687830] fbtft_device: waveshare32b [16009.687835] fbtft_device: waveshare22 [16009.687839] fbtft_device: root@nanopineo:/lib/modules/4.19.84-sunxi/kernel/drivers/staging/fbtft# modprobe fbtft_device custom name=lm560g startbyte=0x00 speed=8000000 gpios=reset:201,dc:200 root@nanopineo:/lib/modules/4.19.84-sunxi/kernel/drivers/staging/fbtft# dmesg |grep fbtft [16164.294787] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned. [16164.296943] fbtft_device: spi_busnum_to_master(0) returned NULL [16164.296956] fbtft_device: failed to register SPI device Link to comment Share on other sites More sharing options...
