Qwalcon Posted November 16, 2019 Share Posted November 16, 2019 First of all sorry for the newbie's question. I compiled a kernel with custom configuration to use this instruction: https://docs.armbian.com/Developer-Guide_Build-Preparation/ OS: Ubuntu Bionic 18.04 x64 apt -y install git git clone https://github.com/armbian/build cd build ./compile.sh \ BOARD=orangepizero \ BRANCH=default \ BUILD_DESKTOP=no \ KERNEL_ONLY=yes \ KERNEL_CONFIGURE=yes After the kernel build is complete, the output directory contains output/config linux-sun8i-default.config output/debs /extra armbian-config_5.99_all.deb armbian-firmware-full_5.99_all.deb armbian-firmware_5.99_all.deb linux-headers-sun8i_5.99_armhf.deb linux-image-sun8i_5.99_armhf.deb linux-source-default-sun8i_5.99_all.deb linux-u-boot-orangepizero_5.99_armhf.deb Copied to the device this files linux-headers-sun8i_5.99_armhf.deb linux-image-sun8i_5.99_armhf.deb Executed sudo dpkg -i linux-headers-sun8i_5.99_armhf.deb sudo dpkg -i linux-image-sun8i_5.99_armhf.deb The kernel hasn't changed. Could you explain how to replace the kernel on the device, please? Thank you very much for your reply. Link to comment Share on other sites More sharing options...
Igor Posted November 16, 2019 Share Posted November 16, 2019 That is correct procedure. 17 minutes ago, Qwalcon said: The kernel hasn't changed. Have you reboot? Version is the same anyway. Did you check build date ... what have you changed? 1 Link to comment Share on other sites More sharing options...
Qwalcon Posted November 16, 2019 Author Share Posted November 16, 2019 4 hours ago, Igor said: what have you changed? I tried to compile kernel with following configuration: https://criu.org/Linux_kernel General setup options CONFIG_CHECKPOINT_RESTORE=y (Checkpoint/restore support) Networking support -> Networking options options for sock-diag subsystem CONFIG_UNIX_DIAG=y (Unix domain sockets -> UNIX: socket monitoring interface) CONFIG_INET_DIAG=y (TCP/IP networking -> INET: socket monitoring interface) CONFIG_INET_UDP_DIAG=y (TCP/IP networking -> INET: socket monitoring interface -> UDP: socket monitoring interface) CONFIG_NETFILTER_XT_MARK=y (Networking support -> Networking options -> Network packet filtering framework (Netfilter) -> Core Netfilter Configuration -> Netfilter Xtables support (required for ip_tables) -> nfmark target and match support) CONFIG_TUN=y (Device Driver -> Network device support -> Universal TUN/TAP device driver support) Link to comment Share on other sites More sharing options...
Igor Posted November 16, 2019 Share Posted November 16, 2019 7 hours ago, Qwalcon said: BRANCH=default \ The problem might be here. Branch default is legacy kernel version 3.4.y which is EOL. Features which you need might not be supported and we are also officially ditching it next week. NEXT is 4.19.y which will be upgraded to 5.3.y soon. 1 Link to comment Share on other sites More sharing options...
Qwalcon Posted November 18, 2019 Author Share Posted November 18, 2019 On 11/16/2019 at 11:39 PM, Igor said: NEXT is 4.19.y which will be upgraded to 5.3.y soon. Thank you very much for you answer. I choose NEXT. The kernel was replaced. Link to comment Share on other sites More sharing options...
