dolphs Posted November 27, 2019 Share Posted November 27, 2019 understood martinayotte, loiter for a while taking your rest! Meanwhile booted the dev image built - just sharing some info for the ones that are interested. One thing that immediately caught my attention it appears CPUFreq is still WIP ? Most likely this a .config kernel thingie, which simply needs to be enabled or more work to do ? root@orangepioneplus's password: ___ ____ _ ___ / _ \| _ \(_) / _ \ _ __ ___ _ | | | | |_) | | | | | | '_ \ / _ \_| |_ | |_| | __/| | | |_| | | | | __/_ _| \___/|_| |_| \___/|_| |_|\___| |_| Welcome to Armbian Buster with Linux 5.4.0-rc8-sunxi64 System load: 1.44 0.56 0.22 Up time: 4 min Memory usage: 12 % of 989MB IP: 192.168.10.121 CPU temp: 45°C Usage of /: 11% of 7.1G Last login: Wed Nov 27 02:34:54 2019 from 192.168.10.98 root@orangepioneplus:~# cpufreq-info cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009 Report errors and bugs to cpufreq@vger.kernel.org, please. analyzing CPU 0: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms. analyzing CPU 1: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms. analyzing CPU 2: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms. analyzing CPU 3: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms. Link to comment Share on other sites More sharing options...
megi Posted November 27, 2019 Share Posted November 27, 2019 8 hours ago, dolphs said: understood martinayotte, loiter for a while taking your rest! Meanwhile booted the dev image built - just sharing some info for the ones that are interested. One thing that immediately caught my attention it appears CPUFreq is still WIP ? Most likely this a .config kernel thingie, which simply needs to be enabled or more work to do ? root@orangepioneplus's password: ___ ____ _ ___ / _ \| _ \(_) / _ \ _ __ ___ _ | | | | |_) | | | | | | '_ \ / _ \_| |_ | |_| | __/| | | |_| | | | | __/_ _| \___/|_| |_| \___/|_| |_|\___| |_| Welcome to Armbian Buster with Linux 5.4.0-rc8-sunxi64 System load: 1.44 0.56 0.22 Up time: 4 min Memory usage: 12 % of 989MB IP: 192.168.10.121 CPU temp: 45°C Usage of /: 11% of 7.1G Last login: Wed Nov 27 02:34:54 2019 from 192.168.10.98 root@orangepioneplus:~# cpufreq-info cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009 Report errors and bugs to cpufreq@vger.kernel.org, please. analyzing CPU 0: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms. analyzing CPU 1: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms. analyzing CPU 2: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms. analyzing CPU 3: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms. Linux 5.4 now uses a different cpufreq driver for H6. I guess it needs to be enabled in Armbian's Linux defconfig. Link to comment Share on other sites More sharing options...
dolphs Posted November 27, 2019 Share Posted November 27, 2019 14 hours ago, megi said: Linux 5.4 now uses a different cpufreq driver for H6. I guess it needs to be enabled in Armbian's Linux defconfig. ta! , uhm right, I just quickly kicked off another build with " KERNEL_CONFIGURE=yes " and except many new features not configured yet I found these disabled: "PSCI CPU idle Driver (ARM_PSCI_CPUIDLE) [N/y/?] (NEW)" , "Allwinner nvmem based SUN50I CPUFreq driver (ARM_ALLWINNER_SUN50I_CPUFREQ_NVMEM) [N/m/y/?] (NEW) ", Optional and out of this scope, but nice have "exFAT fs support (EXFAT_FS) [N/m/y/?] (NEW) ", Set the last two to enabled [Y] and will compile it, once back home I can flash and see what happened ... Thus basically when new default ".config' is ready for commit, let's not forget to include these please ( and many others I missed out at quick glance ) . thanks UPDATE1: 1,5GHz currently max? [ driver: cpufreq-dt ] <snip snip> analyzing CPU 3: driver: cpufreq-dt CPUs which run at the same hardware frequency: 0 1 2 3 CPUs which need to have their frequency coordinated by software: 0 1 2 3 maximum transition latency: 244 us. hardware limits: 480 MHz - 1.49 GHz available frequency steps: 480 MHz, 720 MHz, 816 MHz, 888 MHz, 1.08 GHz, 1.32 GHz, 1.49 GHz available cpufreq governors: conservative, userspace, powersave, ondemand, performance, schedutil current policy: frequency should be within 480 MHz and 1.49 GHz. The governor "ondemand" may decide which speed to use within this range. current CPU frequency is 480 MHz (asserted by call to hardware). cpufreq stats: 480 MHz:67.14%, 720 MHz:1.34%, 816 MHz:0.01%, 888 MHz:0.05%, 1.08 GHz:0.15%, 1.32 GHz:0.08%, 1.49 GHz:31.23% (84) UPDATE2: Checked /etc/default/cpufrequtils which shows ( as expected MAX_SPEED=1810000 ): ENABLE=true MIN_SPEED=480000 MAX_SPEED=1810000 GOVERNOR=ondemand But is it required to enable a flag to " /boot/armbianEnv.txt "in order to get 1.81Ghz back? I do recall, with NEO2 v1.1 board, in past something similar happened and it was needed to add the option " overlays " which is in this version currently missing: root@orangepioneplus:~# cat /boot/armbianEnv.txt verbosity=1 console=both overlay_prefix=sun50i-h6 rootdev=UUID=d1e21321-c4f1-407b-9903-d825f76d9e25 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Files listed in overlays rgd H6 ( for NEO2 the option is "sun50i-h5-cpu-clock-1.3GHz-1.3v.dtbo" ): root@orangepioneplus:/boot/dtb/allwinner/overlay# ls -la *h6* -rw-r--r-- 1 root root 4161 Nov 27 16:06 sun50i-h6-fixup.scr -rw-r--r-- 1 root root 374 Nov 27 16:06 sun50i-h6-i2c0.dtbo -rw-r--r-- 1 root root 374 Nov 27 16:06 sun50i-h6-i2c1.dtbo -rw-r--r-- 1 root root 374 Nov 27 16:06 sun50i-h6-i2c2.dtbo -rw-r--r-- 1 root root 268 Nov 27 16:06 sun50i-h6-ruart.dtbo -rw-r--r-- 1 root root 1177 Nov 27 16:06 sun50i-h6-spi-add-cs1.dtbo -rw-r--r-- 1 root root 804 Nov 27 16:06 sun50i-h6-spi-jedec-nor.dtbo -rw-r--r-- 1 root root 645 Nov 27 16:06 sun50i-h6-spi-spidev1.dtbo -rw-r--r-- 1 root root 780 Nov 27 16:06 sun50i-h6-spi-spidev.dtbo -rw-r--r-- 1 root root 502 Nov 27 16:06 sun50i-h6-uart1.dtbo -rw-r--r-- 1 root root 790 Nov 27 16:06 sun50i-h6-uart2.dtbo -rw-r--r-- 1 root root 790 Nov 27 16:06 sun50i-h6-uart3.dtbo -rw-r--r-- 1 root root 773 Nov 27 16:06 sun50i-h6-w1-gpio.dtbo Link to comment Share on other sites More sharing options...
dolphs Posted November 29, 2019 Share Posted November 29, 2019 On 11/27/2019 at 11:58 AM, megi said: Linux 5.4 now uses a different cpufreq driver for H6. I guess it needs to be enabled in Armbian's Linux defconfig. @megi - Hi megi - Would it be possible to bump ( tag ) orange-pi-5.4 to 5.4.1 please instead of 5-4.0RC8? thanks for your time Link to comment Share on other sites More sharing options...
megi Posted November 29, 2019 Share Posted November 29, 2019 3 hours ago, dolphs said: @megi - Hi megi - Would it be possible to bump ( tag ) orange-pi-5.4 to 5.4.1 please instead of 5-4.0RC8? thanks for your time Updated. Link to comment Share on other sites More sharing options...
dolphs Posted November 29, 2019 Share Posted November 29, 2019 28 minutes ago, megi said: Updated @megi lovely, cheers for that - fresh off the presses: "Armbian_19.11.3_Orangepioneplus_buster_dev_5.4.1_minimal.img" ( default .config settings ) Link to comment Share on other sites More sharing options...
Igor Posted November 29, 2019 Share Posted November 29, 2019 Nightly packages update is also coming to beta.armbian.com in few hours from now. Link to comment Share on other sites More sharing options...
martinayotte Posted December 2, 2019 Author Share Posted December 2, 2019 BTW, issue faced earlier with ramdom MAC on 8189fs has been narrowed : I'm using "old school" /etc/network/interface, but it is the NetworkManager that was assigning a random MAC, although it wasn't supposed to touch "wlan0" at all, so the fix is to disable it using "systemctl disable NetworkManager". My OPiPC+s, OPiLite and OPiPlus2E are back to their normal state ... Link to comment Share on other sites More sharing options...
Igor Posted December 2, 2019 Share Posted December 2, 2019 24 minutes ago, martinayotte said: but it is the NetworkManager that was assigning a random MAC IIRC it shouldn't / we fix this for Network Manager usage which still our default way. Either we break something in the last RFC or we have upstream changes defaulting to randomizing wireless MAC. Link to comment Share on other sites More sharing options...
martinayotte Posted December 2, 2019 Author Share Posted December 2, 2019 9 minutes ago, Igor said: it shouldn't But it does ... According to the link you provide, they mentioned this file /etc/NetworkManager/conf.d/00-macrandomize.conf, but it doesn't exist ! Maybe we need to create it and place "wifi.scan-rand-mac-address=no" instead of "yes" ? Link to comment Share on other sites More sharing options...
Igor Posted December 2, 2019 Share Posted December 2, 2019 1 minute ago, martinayotte said: Maybe we need to create it and place "wifi.scan-rand-mac-address=no" instead of "yes" ? Perhaps that would be a fix, yes. Once before 20.02 I would say. Link to comment Share on other sites More sharing options...
dolphs Posted December 5, 2019 Share Posted December 5, 2019 On 11/27/2019 at 1:25 PM, dolphs said: UPDATE1: 1,5GHz currently max? [ driver: cpufreq-dt ] Actually it is interesting finding these under " CPU Frequency scaling " kernel config options <M> Generic DT based cpufreq driver <M> Allwinner nvmem based SUN50I CPUFreq driver This last option should " add the nvmem based CPUFreq driver for Allwinner dule capable h6 SoC. ", thus also for the orangepioneplus imho Wonder if this is a driver issue in current kernel and if this has been fixed meanwhile in 5.4.2 ? The first driver gives result as indicated 27 Nov already, the " sun50i-cpufreq-nvmem " fails on this board so far.... Link to comment Share on other sites More sharing options...
dolphs Posted December 8, 2019 Share Posted December 8, 2019 Still exploring kernel 5.4, little bit out of scope as I am tuning the orangepioneplus board to my needs ( .config ) and no need for WiFi or Bluetooth Thus how to disable following wifi drivers that are added to the kernel ( as well wireguard ), [ o.k. ] Adding [ WireGuard tag:0.0.20190702 ] [ o.k. ] Checking git sources [ wireguard 0.0.20190702 ] [ .... ] Up to date [ o.k. ] Patching WireGuard [ Applying workaround for headers compilation ] [ o.k. ] Adding [ Wireless drivers for Realtek 8811, 8812, 8814 and 8821 chipsets branch:v5.2.20 ] [ o.k. ] Checking git sources [ rtl8812au v5.2.20 ] [ .... ] Up to date [ o.k. ] Adding [ Wireless drivers for Realtek 8188EU 8188EUS and 8188ETV chipsets branch:v5.3.9 ] [ o.k. ] Checking git sources [ rtl8188eu v5.3.9 ] [ .... ] Up to date [ o.k. ] Adding [ Wireless drivers for Realtek 88x2bu chipsets branch:master ] [ o.k. ] Checking git sources [ rtl88x2bu master ] Did read it somewhere but I forgot, one to guide me please? At least it is not here unless I am overlooking stuff TiA! Link to comment Share on other sites More sharing options...
Werner Posted December 8, 2019 Share Posted December 8, 2019 This just adds the source code needed to compile the modules. If you remove/disable them from your kernel config they won't be built. Though I do not think this is even necessary as they should be built as modules already and if you do not load them they would not eat up any ressources whatsoever besides a tiny bit of space on your sd card. If they get forcefully loaded on boot for unknown reason blacklist the appropriate modules. Link to comment Share on other sites More sharing options...
Igor Posted December 8, 2019 Share Posted December 8, 2019 11 hours ago, dolphs said: how to disable following wifi drivers https://github.com/armbian/build/blob/master/lib/compilation-prepare.sh WIREGUARD="no" EXTRAWIFI="no" AUFS="no" Link to comment Share on other sites More sharing options...
dolphs Posted December 15, 2019 Share Posted December 15, 2019 On 12/5/2019 at 7:57 AM, dolphs said: Actually it is interesting finding these under " CPU Frequency scaling " kernel config options <> Generic DT based cpufreq driver <*> Allwinner nvmem based SUN50I CPUFreq driver This last option should " add the nvmem based CPUFreq driver for Allwinner dule capable h6 SoC. ", thus also for the orangepioneplus imho Wonder if this is a driver issue in current kernel and if this has been fixed meanwhile in 5.4.2 ? The first driver gives result as indicated 27 Nov already, the " sun50i-cpufreq-nvmem " fails on this board so far.... noticed current dev build ( default kernel ) takes still 5.4.2, would like to try 5.4.3 to see if the this generic driver takes clock speedback to 1,8GHz ( currently 1.5 ) on the orangepioneplus. Not sure if the newer driver ( Alwinner CPUFreq ) is working now, but in 5.4.3 kernel updates has been made to the Generic driver as far I read the ChangeLogs. imho AR-86 is not closed yet, it works with a workaround unless it has been confirmed the Generic driver is the one to use ( though it should be the SUN50I CPUFreq driver imho? ) Link to comment Share on other sites More sharing options...
Igor Posted December 15, 2019 Share Posted December 15, 2019 4 hours ago, dolphs said: is not closed yet I got 1.8 Ghz on my Opi3. Perhaps there is a problem with other boards, haven't test them ... Link to comment Share on other sites More sharing options...
dolphs Posted December 15, 2019 Share Posted December 15, 2019 1 hour ago, Igor said: I got 1.8 Ghz on my Opi3. Perhaps there is a problem with other boards, haven't test them ... in which I can contribute to test, as I owe the "orangepioneplus" ( pihole and ovpn server ) as well a spare, so excellent for testing purposes Yet as we unfortunately can see it is not showing 1,8 which I reported also 5 December: root@orangepioneplus's password: ___ ____ _ ___ / _ \| _ \(_) / _ \ _ __ ___ _ | | | | |_) | | | | | | '_ \ / _ \_| |_ | |_| | __/| | | |_| | | | | __/_ _| \___/|_| |_| \___/|_| |_|\___| |_| Welcome to Armbian buster with Linux 5.4.2-sunxi64 System load: 0.27 0.24 0.10 Up time: 2 min Memory usage: 7 % of 989MB IP: 192.168.10.121 CPU temp: 45°C Usage of /: 4% of 15G root@orangepioneplus:~# cpufreq-info |grep cpufreq cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009 Report errors and bugs to cpufreq@vger.kernel.org, please. driver: cpufreq-dt available cpufreq governors: conservative, userspace, powersave, ondemand, performance, schedutil cpufreq stats: 480 MHz:91.69%, 720 MHz:0.53%, 816 MHz:0.02%, 888 MHz:0.25%, 1.08 GHz:0.28%, 1.32 GHz:0.48%, 1.49 GHz:6.74% (147) driver: cpufreq-dt available cpufreq governors: conservative, userspace, powersave, ondemand, performance, schedutil cpufreq stats: 480 MHz:91.69%, 720 MHz:0.53%, 816 MHz:0.02%, 888 MHz:0.25%, 1.08 GHz:0.28%, 1.32 GHz:0.48%, 1.49 GHz:6.74% (147) driver: cpufreq-dt available cpufreq governors: conservative, userspace, powersave, ondemand, performance, schedutil cpufreq stats: 480 MHz:91.69%, 720 MHz:0.53%, 816 MHz:0.02%, 888 MHz:0.25%, 1.08 GHz:0.28%, 1.32 GHz:0.48%, 1.49 GHz:6.74% (147) driver: cpufreq-dt available cpufreq governors: conservative, userspace, powersave, ondemand, performance, schedutil cpufreq stats: 480 MHz:91.69%, 720 MHz:0.53%, 816 MHz:0.02%, 888 MHz:0.25%, 1.08 GHz:0.28%, 1.32 GHz:0.48%, 1.49 GHz:6.74% (147) Will give it another shot once @megi has 5.4.3 incorporated in orangepi-5.4 branch, both default and with the " Allwinner nvmem based SUN50I CPUFreq " driver Link to comment Share on other sites More sharing options...
Igor Posted December 15, 2019 Share Posted December 15, 2019 7 minutes ago, dolphs said: which I reported also 5 December: Thank you for report. Development needs time and this problem is far far from critical. 8 minutes ago, dolphs said: has 5.4.3 incorporated in orangepi-5.4 branch We use the same branch. Just lots of patches which could also break something ... some work has to be applied. Link to comment Share on other sites More sharing options...
dolphs Posted December 15, 2019 Share Posted December 15, 2019 15 minutes ago, Igor said: Thank you for report. Development needs time and this problem is far far from critical. agreed, was just following the Jira stories and noticed AR-86 is not fully solved, just wanted to report back and that is it. So I do not want to put any rush on this, but at least we know now it is not fully solved yet. As said once I see either branch or kernel being updated will spin up another test drive. cheers for your efforts as you know it is appreciated! Link to comment Share on other sites More sharing options...
megi Posted December 15, 2019 Share Posted December 15, 2019 1 hour ago, dolphs said: Will give it another shot once @megi has 5.4.3 incorporated in orangepi-5.4 branch, both default and with the " Allwinner nvmem based SUN50I CPUFreq " driver I don't think waiting will help. I almost never update non-rc branches after release, I only merge from linux-stable. Anyway, I can only see you're missing 1.8GHz, because Armbian changes my CPU OPP table to something else, because my OPP table has 1.8GHz operating point. https://megous.com/git/linux/commit/?h=ths-5.4&id=8bad58044be498d409400dbf9757f2ae25c6ad9d Link to comment Share on other sites More sharing options...
Werner Posted December 16, 2019 Share Posted December 16, 2019 The OPP table change has quite a story behind but that is another thing. Anyway. Armbians patch containing 1.8GHz as well as far as I understand. It just alters the voltages. https://github.com/armbian/build/blob/master/patch/kernel/sunxi-dev/0012-general-h6-new-opp-table.patch Link to comment Share on other sites More sharing options...
dolphs Posted December 16, 2019 Share Posted December 16, 2019 So this means basically more efforts to be done before the orangepioneplus board will have 1,8GHz using the " cpufreq-dt " driver. cheers for clarifying Link to comment Share on other sites More sharing options...
Cheater Posted February 20, 2020 Share Posted February 20, 2020 I tried version 5.4(.20) - Ubuntu/Bionic (downloaded from https://www.armbian.com/nanopi-duo-2/ ) Since this topic is about creating 5.4 version for a processor series that I use, I think my posting here is correct. I have the Allwinner H3 (SUN8I 1680) processor on a NanoPi Duo2 board. The startup of Bionic hangs at a certain point, always the same point. Here the complete log (in a spoiler block so not everyone has to see this/scroll over it) Spoiler U-Boot SPL 2019.10-armbian (Feb 17 2020 - 06:26:18 +0100) DRAM: 512 MiB Trying to boot from MMC1 U-Boot 2019.10-armbian (Feb 17 2020 - 06:26:18 +0100) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: FriendlyARM NanoPi DUO 2 DRAM: 512 MiB MMC: mmc@1c0f000: 0 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial Out: serial Err: serial Net: No ethernet found. Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3789 bytes read in 4 ms (924.8 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 190 bytes read in 2 ms (92.8 KiB/s) 8677345 bytes read in 650 ms (12.7 MiB/s) 7744344 bytes read in 580 ms (12.7 MiB/s) Found mainline kernel configuration 28951 bytes read in 8 ms (3.5 MiB/s) 504 bytes read in 9 ms (54.7 KiB/s) Applying kernel provided DT overlay sun8i-h3-usbhost0.dtbo 504 bytes read in 10 ms (48.8 KiB/s) Applying kernel provided DT overlay sun8i-h3-usbhost2.dtbo 504 bytes read in 9 ms (54.7 KiB/s) Applying kernel provided DT overlay sun8i-h3-usbhost3.dtbo 4155 bytes read in 10 ms (405.3 KiB/s) Applying kernel provided DT fixup script (sun8i-h3-fixup.scr) ## Executing script at 44000000 ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 8677281 Bytes = 8.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 Loading Ramdisk to 497b9000, end 49fff7a1 ... OK Loading Device Tree to 49749000, end 497b8fff ... OK Starting kernel ... Uncompressing Linux... done, booting the kernel. Loading, please wait... starting version 237 Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.31.1 [/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1 /dev/mmcblk0p1: clean, 35020/59904 files, 202121/239616 blocks done. done. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... done. Welcome to Ubuntu 18.04.4 LTS! [ OK ] Reached target Swap. [ OK ] Started Forward Password Requests to Wall Directory Watch. [ OK ] Reached target System Time Synchronized. [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ OK ] Set up automount Arbitrary Executab…rmats File System Automount Point. [ OK ] Reached target Remote File Systems. [ OK ] Reached target Local Encrypted Volumes. [ OK ] Created slice System Slice. [ OK ] Listening on /dev/initctl Compatibility Named Pipe. [ OK ] Listening on udev Control Socket. [ OK ] Listening on Journal Socket (/dev/log). [ OK ] Listening on udev Kernel Socket. [ OK ] Listening on fsck to fsckd communication Socket. [ OK ] Created slice system-serial\x2dgetty.slice. [ OK ] Listening on Journal Socket. Starting Nameserver information manager... Mounting POSIX Message Queue File System... Starting udev Coldplug all Devices... Starting Load Kernel Modules... Starting Restore / save the current clock... Starting Create list of required st…ce nodes for the current kernel... Mounting Kernel Debug File System... [ OK ] Listening on Journal Audit Socket. Starting Set the console keyboard layout... [ OK ] Listening on Syslog Socket. Starting Journal Service... Starting Remount Root and Kernel File Systems... [ OK ] Created slice User and Session Slice. [ OK ] Reached target Slices. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Started Load Kernel Modules. [ OK ] Started Restore / save the current clock. [ OK ] Started Create list of required sta…vice nodes for the current kernel. [ OK ] Mounted Kernel Debug File System. [ OK ] Started Remount Root and Kernel File Systems. [ OK ] Started Nameserver information manager. [ OK ] Reached target Network (Pre). Starting Load/Save Random Seed... Starting Create Static Device Nodes in /dev... Starting Apply Kernel Variables... Mounting Kernel Configuration File System... [ OK ] Mounted Kernel Configuration File System. [ OK ] Started Load/Save Random Seed. [ OK ] Started Journal Service. [ OK ] Started Create Static Device Nodes in /dev. [ OK ] Started Apply Kernel Variables. Starting udev Kernel Device Manager... Starting Flush Journal to Persistent Storage... [ OK ] Started udev Coldplug all Devices. [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Started udev Kernel Device Manager. [ OK ] Found device /dev/ttyGS0. [ OK ] Started Set the console keyboard layout. [ OK ] Reached target Local File Systems (Pre). Mounting /tmp... [ OK ] Mounted /tmp. [ OK ] Reached target Local File Systems. Starting Armbian ZRAM config... Starting Raise network interfaces... Starting Create Volatile Files and Directories... Starting Set console font and keymap... [ OK ] Started Set console font and keymap. [ OK ] Started Create Volatile Files and Directories. [ OK ] Started Entropy daemon using the HAVEGE algorithm. Starting Update UTMP about System Boot/Shutdown... Starting Network Name Resolution... [ 9.455761] lima 1c40000.gpu: IRQ ppmmu2 not found [ 9.460719] lima 1c40000.gpu: IRQ ppmmu3 not found [ 9.465727] lima 1c40000.gpu: IRQ pp2 not found [ 9.470351] lima 1c40000.gpu: IRQ pp3 not found [ OK ] Found device /dev/ttyS0. [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ OK ] Started Network Name Resolution. [ OK ] Reached target Host and Network Name Lookups. Starting Load/Save RF Kill Switch Status... [ OK ] Started Load/Save RF Kill Switch Status. [ OK ] Started Raise network interfaces. [ OK ] Started Armbian ZRAM config. Starting Armbian memory supported logging... [ OK ] Started Armbian memory supported logging. [ OK ] Reached target System Initialization. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Started Discard unused blocks once a week. [ OK ] Listening on D-Bus System Message Bus Socket. [ OK ] Reached target Sockets. [ OK ] Started Daily apt download activities. [ OK ] Started Daily apt upgrade and clean activities. Starting Armbian filesystem resize... [ OK ] Started resolvconf-pull-resolved.path. [ OK ] Reached target Paths. [ OK ] Started Message of the Day. [ OK ] Reached target Timers. Starting Armbian hardware optimization... Starting Armbian hardware monitoring... [ OK ] Started Armbian hardware optimization. [ OK ] Started Armbian hardware monitoring. [ OK ] Started Armbian filesystem resize. [ OK ] Reached target Basic System. Starting Resets System Activity Data Collector... [ OK ] Started Regular background program processing daemon. Starting rng-tools.service... Starting Login Service... [ OK ] Started D-Bus System Message Bus. Starting Network Manager... Starting WPA supplicant... Starting resolvconf-pull-resolved.service... Starting Dispatcher daemon for systemd-networkd... Starting System Logging Service... [ OK ] Started Armbian first run tasks. Starting LSB: Load kernel modules needed to enable cpufreq scaling... [ OK ] Started Resets System Activity Data Collector. [ OK ] Started rng-tools.service. [ OK ] Started resolvconf-pull-resolved.service. [ OK ] Started Login Service. [ OK ] Started LSB: Load kernel modules needed to enable cpufreq scaling. Starting LSB: set CPUFreq kernel parameters... [ OK ] Started WPA supplicant. [ OK ] Started System Logging Service. [ OK ] Started LSB: set CPUFreq kernel parameters. Starting LSB: Set sysfs variables from /etc/sysfs.conf... [ OK ] Started LSB: Set sysfs variables from /etc/sysfs.conf. Starting Hostname Service... [ OK ] Started Hostname Service. [ OK ] Started Network Manager. Starting Network Manager Script Dispatcher Service... Starting Network Manager Wait Online... [ OK ] Reached target Network. Starting OpenBSD Secure Shell server... Starting chrony, an NTP client/server... [ OK ] Started Unattended Upgrades Shutdown. Starting Permit User Sessions... [ OK ] Started Network Manager Script Dispatcher Service. [ OK ] Started Permit User Sessions. Starting Set console scheme... [ OK ] Started Set console scheme. [ OK ] Created slice system-getty.slice. [ OK ] Started chrony, an NTP client/server. [ OK ] Started OpenBSD Secure Shell server. [ OK ] Started Dispatcher daemon for systemd-networkd. I tried reflashing a couple of times to the SD card. I tried a different image flasher tool (tried win32diskimager and etcher) I tried 2 SD cards, both with same result. Now the interesting bit: the Buster (Debian) variant of 5.4.20 DOES work corrrectly and boots up perfectly. Is this interesting feedback for you? Is there a solution for my Bionic/Ubuntu version? Can I give you more information you possibly need? Link to comment Share on other sites More sharing options...
Werner Posted February 21, 2020 Share Posted February 21, 2020 8 hours ago, Cheater said: the Buster (Debian) variant of 5.4.20 DOES work Therefore your post has nothing to do with the kernel building I'll suggest someone to split this topic up. This may not even be related to Armbian since Armbians job is to put together a working kernel for various sbcs and build a operating system with minimal customization (Buster and Bionic to say) on top. The kernel boots fine as seen above so this might be OS related and therefore an issue that Ubuntu have to fix themselves. Link to comment Share on other sites More sharing options...
Cheater Posted February 25, 2020 Share Posted February 25, 2020 After MANY trials of restarting, Debian has finally started correctly. I have not changed anything, but I THINK it was something with a too hot (temperature) processor. My support question can be ignored, because there is no problem anymore. Link to comment Share on other sites More sharing options...
