dittohead Posted November 28, 2019 Share Posted November 28, 2019 (edited) Have a orange pi pc plus with 3.5inch RPi LCD (A) I install bionic 5.3.9 and try to set up screen via this guide, but got this (dmesg |grep fbtft): [ 5.594066] fbtft: module is from the staging directory, the quality is unknown, you have been warned. [ 5.612714] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned. [ 5.613364] fbtft_device: unknown parameter 'gpios' ignored [ 6.010096] Modules linked in: fb_ili9486(C+) sch_fq_codel fbtft_device(C) fbtft(C) ip_tables x_tables pwrseq_simple sy8106a_regulator [ 6.042799] LR is at fbtft_register_framebuffer+0x6f/0x1bc [fbtft] [ 6.099269] [<bf81fbe7>] (fbtft_register_framebuffer [fbtft]) from [<bf820593>] (fbtft_probe_common+0x103/0x360 [fbtft]) [ 6.099291] [<bf820593>] (fbtft_probe_common [fbtft]) from [<bf813125>] (fbtft_driver_probe_spi+0x19/0x1c [fb_ili9486]) [ 6.099313] [<bf813125>] (fbtft_driver_probe_spi [fb_ili9486]) from [<c06c1821>] (spi_drv_probe+0x55/0x68) [ 6.099404] [<c0660689>] (driver_register) from [<bf805017>] (fbtft_driver_module_init+0x17/0x1000 [fb_ili9486]) [ 6.099420] [<bf805017>] (fbtft_driver_module_init [fb_ili9486]) from [<c0102beb>] (do_one_initcall+0x37/0x1a8) On one of some previous build screen works after assigment as main screen. Now - I down't know what to do next I swap screens from my RPI fligtfeeder - screen works fine HDMI to external monitor works fine Any ideas? Edited November 28, 2019 by dittohead fix topic Link to comment Share on other sites More sharing options...
dittohead Posted November 30, 2019 Author Share Posted November 30, 2019 install 5.83 xenial: all works [ 9.681206] fbtft_device: SPI devices registered: [ 9.681229] fbtft_device: spidev spi0.0 33000kHz 8 bits mode=0x00 [ 9.681242] fbtft_device: 'fb' Platform devices registered: [ 9.681320] fbtft_device: Deleting spi0.0 [ 9.681732] fbtft_device: GPIOS used by 'piscreen': [ 9.681743] fbtft_device: 'reset' = GPIO2 [ 9.681751] fbtft_device: 'dc' = GPIO71 [ 9.681758] fbtft_device: SPI devices registered: [ 9.681769] fbtft_device: fb_ili9486 spi0.0 16000kHz 8 bits mode=0x00 some problem in new builds Link to comment Share on other sites More sharing options...
Igor Posted December 3, 2019 Share Posted December 3, 2019 On 12/1/2019 at 10:54 AM, dittohead said: some problem in new builds Have you asked Noralf if he has some clues? Link to comment Share on other sites More sharing options...
dittohead Posted December 3, 2019 Author Share Posted December 3, 2019 5 minutes ago, Igor said: Have you asked Noralf if he has some clues? Its stupid, but I saw on commit history, and think that fbtft not support on github But.... https://github.com/notro/fbtft/issues/543 Link to comment Share on other sites More sharing options...
Igor Posted December 3, 2019 Share Posted December 3, 2019 2 minutes ago, dittohead said: and think that fbtft not support on github Hmm, I don't know how their support is organised and if it exists at all. But usually author driver/maintainer/their GitHub is IMO the best source. Link to comment Share on other sites More sharing options...
dittohead Posted December 3, 2019 Author Share Posted December 3, 2019 So I remove fbtft_device. But not underdsand how enable DT support for fbtft i add dtoverlay=waveshare35a to nano /boot/armbianEnv.txt and copied waveshare35a.dtbo to /boot/dtb and nothing changes Link to comment Share on other sites More sharing options...
Igor Posted December 3, 2019 Share Posted December 3, 2019 14 minutes ago, dittohead said: armbianEnv.txt Waveshare corporation does not support Armbian and vice versa. DT support for those display does not exists. Somebody has to make overlays. Then it becomes simple. Link to comment Share on other sites More sharing options...
dittohead Posted December 3, 2019 Author Share Posted December 3, 2019 4 minutes ago, Igor said: Waveshare corporation does not support Armbian and vice versa. DT support for those display does not exists. Somebody has to make overlays. Then it becomes simple. So for now no solution for 5.3 kernel and waweshare? Only roll to previous kernel? Link to comment Share on other sites More sharing options...
Igor Posted December 3, 2019 Share Posted December 3, 2019 37 minutes ago, dittohead said: So for now no solution for 5.3 kernel and waweshare? Only roll to previous kernel? 3rd party hardware was never supported because this is simply not possible to provide. It's your problem. Link to comment Share on other sites More sharing options...
