Marko Buršič Posted December 6, 2019 Share Posted December 6, 2019 I don't really know if this is related to Armbian, but I have a USB disk that is not recognised when plugged into USB 3 (blue port) but it works in USB2.0 port. I have also tried SanDisk Ultra USB3.0 and it works. Shouldn't the USB3.1 also support USB3.0 if it supports USB2.0 ? Link to comment Share on other sites More sharing options...
Marko Buršič Posted May 8, 2020 Author Share Posted May 8, 2020 SOLVED: I does work in kernel 5.4.38. [ 2921.666286] usb 6-1: new SuperSpeed Gen 1 USB device number 3 using xhci-hcd [ 2921.687193] usb 6-1: New USB device found, idVendor=0781, idProduct=5583, bcdDevice= 1.00 [ 2921.687208] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 2921.687219] usb 6-1: Product: Ultra Fit [ 2921.687228] usb 6-1: Manufacturer: SanDisk [ 2921.687240] usb 6-1: SerialNumber: 0501634ed22050222bcbb18b9662cf60a71d58eb3accd361176c490dac57c439b94200000000000000000000f62b26dbff9d0f108355810778267974 [ 2921.688502] usb-storage 6-1:1.0: USB Mass Storage device detected [ 2921.689030] scsi host1: usb-storage 6-1:1.0 [ 2922.691087] scsi 1:0:0:0: Direct-Access SanDisk Ultra Fit 1.00 PQ: 0 ANSI: 6 [ 2922.691920] sd 1:0:0:0: Attached scsi generic sg0 type 0 [ 2922.692134] sd 1:0:0:0: [sdb] 60088320 512-byte logical blocks: (30.8 GB/28.7 GiB) [ 2922.692987] sd 1:0:0:0: [sdb] Write Protect is off [ 2922.693002] sd 1:0:0:0: [sdb] Mode Sense: 43 00 00 00 [ 2922.694608] sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA [ 2922.724780] sdb: sdb1 [ 2922.728106] sd 1:0:0:0: [sdb] Attached SCSI removable disk Link to comment Share on other sites More sharing options...
