lmhhj Posted December 13, 2019 Share Posted December 13, 2019 Armbianmonitor: https://gist.github.com/qiuweichao/2893e21b8230cb3629f5b264a0a0675f Hi All! I am verifying the function about pcie to net port on armada-3720 ESPRESSObin. I insert 3 PCIE network cards in 3720 with PCIE bridge, connect to PC by switch. PC ping 3 net port at the same time ,but only one net port could be pinged successfully. I use the same test environment to test on the cavium's development board ,and PC can ping 3 network cards successfully at the same time. Besides, I used 3 network cards connect to 3 PC directly not by switch on 3720, and 3 PC can also ping 3 network cards successfully at the same time. Through the above cross-testing, it seems that this problem will occur as long as there is some communication connection between different network cards. I think it may be related to the 3720's pcie driver and compatibility. Is it? linux-kernel 4.14 https://github.com/MarvellEmbeddedProcessors/linux-marvell/tree/linux-4.14.76-armada-18.12 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted December 13, 2019 Share Posted December 13, 2019 25 minutes ago, lmhhj said: linux-kernel 4.14 armbianmonitor -u 0 Quote Link to comment Share on other sites More sharing options...
lmhhj Posted December 14, 2019 Author Share Posted December 14, 2019 On 12/13/2019 at 2:00 PM, Igor said: armbianmonitor -u 0 Quote Link to comment Share on other sites More sharing options...
lmhhj Posted December 14, 2019 Author Share Posted December 14, 2019 On 12/13/2019 at 2:00 PM, Igor said: armbianmonitor -u Armbianmonitor: https://gist.github.com/qiuweichao/2893e21b8230cb3629f5b264a0a0675f 0 Quote Link to comment Share on other sites More sharing options...
lmhhj Posted December 14, 2019 Author Share Posted December 14, 2019 6 minutes ago, lmhhj said: Armbianmonitor: https://gist.github.com/qiuweichao/2893e21b8230cb3629f5b264a0a0675f Hi everyone, Now I try with kernel 4.19 (Armbian_5.90_Espressobin_Ubuntu_bionic_next_4.19.57), uboot is 2018.03-devel-18.12.3-gc9aa92c-armbian. The issue aboout mini pcie to net port still exists. Best regards, Qiu 0 Quote Link to comment Share on other sites More sharing options...
Heisath Posted December 15, 2019 Share Posted December 15, 2019 Is there maybe a problem with the driver which occurs because you connect all 3 network adapters with each other (via the switch)? only logical conclusion for me, because you said connecting to all 3 with different devices works. Maybe some layer 2/3 routing problem? 0 Quote Link to comment Share on other sites More sharing options...
lmhhj Posted December 16, 2019 Author Share Posted December 16, 2019 6 hours ago, count-doku said: Is there maybe a problem with the driver which occurs because you connect all 3 network adapters with each other (via the switch)? only logical conclusion for me, because you said connecting to all 3 with different devices works. Maybe some layer 2/3 routing problem? The network card driver is no problem, because I test it in different device with the same network card driver, and the route is default. With some tests and capturing the network packet, I find that sometimes the network MSI interrupt is no reply, so is it related to the 3720's pcie driver and compatibility when it is OK in other test device? 0 Quote Link to comment Share on other sites More sharing options...
Pali Posted September 1, 2020 Share Posted September 1, 2020 @lmhhj: Can you try 5.8 kernel? It contains lot of fixes in 3720 pcie driver. Also, if you have problems with MSI interrupts, you can try to turn them off and use just classic PCI interrupts by appending pci=nomsi into boot args. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted September 3, 2020 Share Posted September 3, 2020 On 9/1/2020 at 11:18 PM, Pali said: @lmhhj: Can you try 5.8 kernel? It contains lot of fixes in 3720 pcie driver. Also, if you have problems with MSI interrupts, you can try to turn them off and use just classic PCI interrupts by appending pci=nomsi into boot args. https://github.com/armbian/build/pull/2101 its easy, "just" someone has to test and build. Then CI builds and user can upgrade hassle free. Espressobin maintenance log for past 3 years might also tell you how things are and explain our decisions in a better light: https://github.com/armbian/build/commits/master/config/sources/families/mvebu64.conf https://github.com/armbian/build/commits/v19.08/config/sources/mvebu64.conf 0 Quote Link to comment Share on other sites More sharing options...
