sgjava Posted December 13, 2019 Share Posted December 13, 2019 Armbianmonitor: http://ix.io/24iC My end game is to use hardware h264 encoding for my security camera streams (using OpenCV, etc) . The first step is testing ffmpeg. It appears that all the necessary pieces are already present in the release I'm using. If I use: ffmpeg -i centaur_2.mpg -acodec aac -vcodec h264 -b:v 2M -pix_fmt nv21 test.mp4 CPU stays below 12% and I get 44 FPS. Seems like hardware encoding is working here. If I use: ffmpeg -i centaur_2.mpg -acodec aac -vcodec h264_v4l2m2m -b:v 2M -pix_fmt nv21 test.mp4 About the same performance, but the file is 10x larger! If I use: ffmpeg -i centaur_2.mpg -acodec aac -vcodec libx264 -b:v 2M -pix_fmt nv21 test.mp4 About the same as h264. So it looks to me like h264_v4l2m2m is used by h264 and libx264 codecs? Linux 4.14.150-odroidxu4 #1 SMP PREEMPT Mon Oct 28 07:56:57 CET 2019 armv7l armv7l armv7l GNU/Linux BOARD=odroidxu4 BOARD_NAME="Odroid XU4" BOARDFAMILY=odroidxu4 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=1221d592 VERSION=5.95 LINUXFAMILY=odroidxu4 BRANCH=default ARCH=arm IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=zImage ffmpeg -encoders | grep 264 V..... libx264 libx264 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (codec h264) V..... libx264rgb libx264 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 RGB (codec h264) V..... h264_omx OpenMAX IL H.264 video encoder (codec h264) V..... h264_v4l2m2m V4L2 mem2mem H.264 encoder wrapper (codec h264) V..... h264_vaapi H.264/AVC (VAAPI) (codec h264) 1 Link to comment Share on other sites More sharing options...
sgjava Posted December 14, 2019 Author Share Posted December 14, 2019 Just a follow up while trying to run 3 cameras on the UX4 like I was doing with HK's Ubuntu release. Armbian always is showing a large amount of nice time. I'm not sure if this is the hardware encoder, but I'm not seeing this with HK's release. I'm also having issues where the XU4 just dies and shuts down. I might dig around in the logs, but there's definitely something up. I'll switch back to HK release and try the same configuration and see what happens. Armbian release: HK release: 1 Link to comment Share on other sites More sharing options...
gounthar Posted December 14, 2019 Share Posted December 14, 2019 Interesting, to say the least. Link to comment Share on other sites More sharing options...
Igor Posted December 14, 2019 Share Posted December 14, 2019 Can you provide a kernel config diff too see if there is something odd? Link to comment Share on other sites More sharing options...
sgjava Posted December 14, 2019 Author Share Posted December 14, 2019 Trying HK's image now with same configuration. Using Linux video 4.14.157-171 #1 SMP PREEMPT Wed Dec 4 08:21:54 -03 2019 armv7l armv7l armv7l GNU/Linux. I'll circle back once I test this out to get past my current need. Looks like hardware encoding is embedded already as well. 1 Link to comment Share on other sites More sharing options...
sgjava Posted December 15, 2019 Author Share Posted December 15, 2019 OK, so I'm seeing the same behavior with HK's image. I have sample code in my OpenCV install script. https://github.com/sgjava/install-opencv/blob/master/opencv-python/codeferm/writer.py just takes a source video and encodes it to whatever Four CC is set. If I use X264 or H264 I get: %Cpu(s): 9.9 us, 1.1 sy, 24.6 ni, 63.2 id, 0.0 wa, 1.0 hi, 0.2 si, 0.0 st 2019-12-15 12:47:40,293 INFO writer OpenCV 4.2.0-pre 2019-12-15 12:47:40,294 INFO writer Input file: ../../resources/traffic.mp4 2019-12-15 12:47:40,294 INFO writer Output file: ../../output/writer-python.avi 2019-12-15 12:47:40,354 INFO writer Resolution: 480x360 2019-12-15 12:47:52,655 INFO writer 925 frames 2019-12-15 12:47:52,656 INFO writer 75.3 FPS, elapsed time: 12.29 seconds 859844 Dec 15 12:53 writer-python.avi With XVID (MP4 simple profile) I get: %Cpu(s): 9.9 us, 0.4 sy, 0.0 ni, 89.1 id, 0.0 wa, 0.5 hi, 0.0 si, 0.0 st 2019-12-15 12:50:05,547 INFO writer OpenCV 4.2.0-pre 2019-12-15 12:50:05,547 INFO writer Input file: ../../resources/traffic.mp4 2019-12-15 12:50:05,547 INFO writer Output file: ../../output/writer-python.avi 2019-12-15 12:50:05,608 INFO writer Resolution: 480x360 2019-12-15 12:50:21,139 INFO writer 925 frames 2019-12-15 12:50:21,139 INFO writer 59.6 FPS, elapsed time: 15.52 seconds 3025586 Dec 15 12:50 writer-python.avi I love the smaller file I get with H264, but the CPU overhead is much larger than I though it would be using hardware encoding. I'm going to play around with ffmpeg directly and see if I'm seeing the same issues. Link to comment Share on other sites More sharing options...
sgjava Posted December 17, 2019 Author Share Posted December 17, 2019 Using ffmpeg -i motion-19-05-10.avi -an -vcodec h264_v4l2m2m -b:v 2M -pix_fmt nv21 test.mp4 I get the results I expected. Hardware encoding works fine. The key is to look for Stream #0:0 -> #0:0 (mpeg4 (mpeg4_v4l2m2m) -> h264 (h264_v4l2m2m)). The issue with the CPU nice time was caused by OpevCV using the software H264 encorder/decoder. I need to look for a way for OpenCV to use the hardware encoder for video encoding. Basically h264_v4l2m2m is working as expected in HK's image, so it should work the same way in Armbian. 1 Link to comment Share on other sites More sharing options...
sgjava Posted December 18, 2019 Author Share Posted December 18, 2019 I ended up using ffmpeg-python since I know ffmpeg hardware encoding/decoding work. Unfortunately OpenCV doesn't allow a lot of flexibility on the video back end (VideoWriter). I'll end up using a ffmpeg adaptor for my security system since ffmpeg-python allows me to set vcodec and convert numpy arrays. To hardware encode h264 use: #!/usr/bin/env python import ffmpeg ( ffmpeg .input('test.avi') .output('out.mp4', vcodec='h264_v4l2m2m', pix_fmt='nv21', **{'b:v': 2000000}) .run() ) Output #0, mp4, to 'out.mp4': Metadata: encoder : Lavf57.83.100 Stream #0:0: Video: h264 (h264_v4l2m2m) (avc1 / 0x31637661), nv21, 1280x720, q=2-31, 2000 kb/s, 7 fps, 14336 tbn, 7 tbc Metadata: encoder : Lavc57.107.100 h264_v4l2m2m 1 Link to comment Share on other sites More sharing options...
sgjava Posted December 22, 2019 Author Share Posted December 22, 2019 And the final result. This will encode an OpenCV numpy format image using hardware encoding. https://github.com/kkroening/ffmpeg-python/issues/301 1 Link to comment Share on other sites More sharing options...
