Enable PIDs cgroup
58 minutes ago, belegdol said:
was the lockup after soft reset in combination with CGROUPS caused by too new of a compiler? Kudos for figuring this out!
I don't think so. That's unrelated and left out by mistake .. I didn't pay attention to that :( I recreated images at the download section - if you can, try them if they work fine for you as well. We can later in the evening do one more update with CHROUPS enabled. (I am out of office until then)
Hi Igor, belegdol ... happy new year to both of you !
I see that a testing version of Armbian buster based on kernel 5.4.y is now available.
I have a spare node in the cluster that can be used to test this image.
Before reinstalling the node, could you check/confirm if pids cgroup is enabled on this testing image ?
Its enabled on kernel 4.14.y which is o.k. now (we also had some stability issues) - you need to download normal stable images - they have been updated, while (apt) update is not yet available since it has to be tested better, while 5.4.y is unstable atm.
I've downloaded the latest stable image based on kernel 4.14.y ... this one : https://dl.armbian.com/odroidxu4/archive/Armbian_19.11.6_Odroidxu4_buster_legacy_4.14.161.7z (build date: 2020/01/04) and reinstalled one of the cluster node (worker-02):
pids cgroup looks not enabled :
adrien@worker-02:~$ uname -a
Linux worker-02 4.14.161-odroidxu4 #40 SMP PREEMPT Sat Jan 4 12:41:15 CET 2020 armv7l GNU/Linux
adrien@worker-02:~$ cat /proc/cgroups
#subsys_name    hierarchy    num_cgroups    enabled
cpuset    2    14    1
cpu    7    97    1
cpuacct    7    97    1
blkio    8    97    1
memory    6    203    1
devices    5    97    1
freezer    3    14    1
net_cls    4    14    1
net_prio    4    14    1
adrien@bilbon:~/git/k8s$ kubectl get events -n default | grep worker-02 | grep pids
14s         Warning   FailedNodeAllocatableEnforcement   node/worker-02   Failed to update Node Allocatable Limits ["kubepods"]: failed to set supported cgroup subsystems for cgroup [kubepods]: failed to find subsystem mount for required subsystem: pids
Did i miss something ?
I know. I did enable them, but configuration is ignored for no apparent reason. Something must be wrong/missing in the kernel code or configuration ... which means someone needs to look deeper into the problem.
Are you sure the normal stable image i've downloaded for the test was built with the pids cgroup enabled in the kernel config file ?
- pids cgroup has been enabled in the kernel config the 2019/12/13:
https://github.com/armbian/build/commit/755388147d65a12d39b31898be29434f999700c8#diff-c793c3265bc32ca486ae790ba3c0ca59
- but a rollback of the config has been done the 2020/01/04:
https://github.com/armbian/build/commit/c1fbf0ab087e1be71a4b8edcf4736f5a6ffe211a#diff-c793c3265bc32ca486ae790ba3c0ca59
So this is certainly explaining why the pids cgroup was not enabled in the image i've downloaded ! ... no ?
FYI, i'm currently trying (first time for me !) to build an image following this doc: https://docs.armbian.com/Developer-Guide_Building-with-Docker/
I will let you know ...
I am sure they are not.
What I am trying to tell you is that kernel does not want to accept this feature even select from a menu. It's a bug in the kernel code which I have no time to fix.
That, plus the fact that enabling the feature seems to cause lockup on reboot according to the bisect run I did.
FYI:
- I've reinstalled one of the cluster node using the last image Armbian_20.02.1_Odroidxu4_buster_current_5.4.19_minimal.img:
adrien@bastion:~ $ kc get node worker-03 -o wide
NAME        STATUS   ROLES    AGE   VERSION   INTERNAL-IP     EXTERNAL-IP   OS-IMAGE                       KERNEL-VERSION     CONTAINER-RUNTIME
worker-03   Ready    <none>   11m   v1.17.3   192.168.0.106   <none>        Debian GNU/Linux 10 (buster)   5.4.19-odroidxu4   docker://19.3.8
- pids cgroup is enabled on this image:
adrien@worker-03:~$ cat /proc/cgroups | grep pids
pids    3    97
- No more warning at kubernetes logs level and the node looks stable for the moment :-)
I think this topic can be closed now.
