Igor Posted May 9, 2020 Share Posted May 9, 2020 31 minutes ago, fsb4000 said: But I guess board-h6-orangepi-lite2-fix-missing-all.patch is needed for something else... We would need some help with cleaning this up. Upstream is also changing a bit, many fixes were made ad hoc ... which is why things are getting messy. I merged this in. 0 Quote Link to comment Share on other sites More sharing options...
062621AM Posted July 19, 2020 Share Posted July 19, 2020 Panfrost running in OrangePi 3, Focal is nice. I had to use the server image, https://dl.armbian.com/orangepi3/archive/Armbian_20.05.4_Orangepi3_focal_current_5.4.45.img.xz and run sudo apt-get install ubuntu-desktop. Spoiler armbian@orangepi3:~$ lsb_release -a ; uname -a ; glxinfo -B Distributor ID: Ubuntu Description: Ubuntu 20.04 LTS Release: 20.04 Codename: focal Linux orangepi3 5.7.8-sunxi64 #trunk.40 SMP Fri Jul 17 19:09:21 UTC 2020 aarch64 aarch64 aarch64 GNU/Linux name of display: :0 display: :0 screen: 0 direct rendering: Yes Extended renderer info (GLX_MESA_query_renderer): Vendor: Panfrost (0xffffffff) Device: Mali T720 (Panfrost) (0xffffffff) Version: 20.0.8 Accelerated: yes Video memory: 1926MB Unified memory: yes Preferred profile: compat (0x2) Max core profile version: 0.0 Max compat profile version: 2.1 Max GLES1 profile version: 1.1 Max GLES[23] profile version: 2.0 OpenGL vendor string: Panfrost OpenGL renderer string: Mali T720 (Panfrost) OpenGL version string: 2.1 Mesa 20.0.8 OpenGL shading language version string: 1.20 OpenGL ES profile version string: OpenGL ES 2.0 Mesa 20.0.8 OpenGL ES profile shading language version string: OpenGL ES GLSL ES 1.0.16 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted July 19, 2020 Share Posted July 19, 2020 51 minutes ago, 062621AM said: and run sudo apt-get install ubuntu-desktop. And maybe switched the kernel? Quote 5.7.8-sunxi64 #trunk.40 0 Quote Link to comment Share on other sites More sharing options...
062621AM Posted July 19, 2020 Share Posted July 19, 2020 1 hour ago, Werner said: And maybe switched the kernel? yup. but i am not sure if i need to switch kernel and into nightly build to get Panfrost to work. There is sound. I don't think Bluetooth is working. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted July 19, 2020 Share Posted July 19, 2020 2 minutes ago, 062621AM said: yup. but i am not sure if i need to switch kernel and into nightly build to get Panfrost to work. There is sound. I don't think Bluetooth is working. Actually no, you do not have to. Though the performance seems slightly better with kernel >=5.6.x 1 Quote Link to comment Share on other sites More sharing options...
AligatorBkmz Posted July 27, 2020 Share Posted July 27, 2020 I still don't understand how you did it. So far I have rebuilt panfrost, drm, mesa but I didn't even have a device /dev/fb0 or /dev/dri/card0 on my OrangePi Zero (Allwinner H2+ Mali-400)(( 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted July 27, 2020 Share Posted July 27, 2020 1 hour ago, AligatorBkmz said: OrangePi Zero Wrong board. Panfrost is not for Mali400 GPU. 0 Quote Link to comment Share on other sites More sharing options...
d.uchida Posted August 2, 2020 Share Posted August 2, 2020 On 7/19/2020 at 12:30 PM, 062621AM said: Panfrost running in OrangePi 3, Focal is nice. I had to use the server image, https://dl.armbian.com/orangepi3/archive/Armbian_20.05.4_Orangepi3_focal_current_5.4.45.img.xz and run sudo apt-get install ubuntu-desktop. This way I have verified that Panfrost Driver is enabled, but when I run glxgear the OS freezes. The kernel remains unchanged OS image What should I check? 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted August 2, 2020 Share Posted August 2, 2020 2 hours ago, d.uchida said: This way I have verified that Panfrost Driver is enabled, but when I run glxgear the OS freezes. The kernel remains unchanged OS image What should I check? Try fixing the GPU clock like described here:https://armbian.atlassian.net/projects/AR/issues/AR-374?filter=allissues 0 Quote Link to comment Share on other sites More sharing options...
NicoD Posted August 2, 2020 Author Share Posted August 2, 2020 2 hours ago, d.uchida said: The kernel remains unchanged OS image What should I check? You could try upgrading your kernel to a later version. With : sudo armbian-config -> system -> other 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted August 2, 2020 Share Posted August 2, 2020 1 minute ago, NicoD said: You could try upgrading your kernel to a later version. With : sudo armbian-config -> system -> other Won't help it is the cause I was thinking about. Still present in 5.7 which are current and dev on now. @Clément Peron Did some initial work on the dvfs stuff I think and it will take some more time until it gets upstreamed. 0 Quote Link to comment Share on other sites More sharing options...
NicoD Posted August 2, 2020 Author Share Posted August 2, 2020 1 minute ago, Werner said: Won't help it is the cause I was thinking about. I haven't tried the H6 in a long time, so it was just a guess. If I weren't too busy with the N2+ I'd check it out. I wonder how it performs. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted August 2, 2020 Share Posted August 2, 2020 4 minutes ago, NicoD said: I haven't tried the H6 in a long time, so it was just a guess. If I weren't too busy with the N2+ I'd check it out. I wonder how it performs. Not very good...But I dont wanna spoiler you 1 Quote Link to comment Share on other sites More sharing options...
Clément Peron Posted August 3, 2020 Share Posted August 3, 2020 @Werner @NicoD There seems to have an issue with the clock implementation in the kernel. You can look at @megi explanation about PLL lock of the NKMP clock. Allwinner GPU clock is actually prone to overshooting which make the GPU DVFS not usable at the time. 1 Quote Link to comment Share on other sites More sharing options...
megi Posted August 3, 2020 Share Posted August 3, 2020 One way to verify if it's this NKMP clock issue is to fix the voltage at some relatively high level for all OPPs and just keep chganging the clock. If it still crashes, it's most probably the NKMP clock. 0 Quote Link to comment Share on other sites More sharing options...
jernej Posted August 3, 2020 Share Posted August 3, 2020 In the past, I tested @Clément Peron's patches on Tanix TX6 which has fixed GPU regulator and it has same problem. I'm pretty sure at this point that it's clock driver issue. 0 Quote Link to comment Share on other sites More sharing options...
JORGETECH Posted August 10, 2020 Share Posted August 10, 2020 On 8/3/2020 at 5:15 PM, jernej said: In the past, I tested @Clément Peron's patches on Tanix TX6 which has fixed GPU regulator and it has same problem. I'm pretty sure at this point that it's clock driver issue. It makes sense for it to be a clock driver issue, setting a fixed frequency for the GPU makes it more stable for me. There are also some weird problems with HDMI when VGA to HDMI adapters are used, I wonder if it's somehow related to this (I doubt it since it would most probably be an HDMI PHY or Display Engine problem). 0 Quote Link to comment Share on other sites More sharing options...
lanefu Posted August 10, 2020 Share Posted August 10, 2020 On 8/2/2020 at 12:52 PM, NicoD said: I haven't tried the H6 in a long time, so it was just a guess. If I weren't too busy with the N2+ I'd check it out. I wonder how it performs. I use opi3 as my headless work station. Using emmc for os and ssd on usb 3 for home dir and docker. It’s fairly spry and very stable. Currently testing unaccelerated desktop with 3gig pine h64b. Very usable, but Firefox can bog down a bit. Not as spunk as my opi4 or N2-. ....but it does see all my monitor 4K resolutions and I can set it to my desired 1440p res through the standard desktop settings tool. 0 Quote Link to comment Share on other sites More sharing options...
jernej Posted August 10, 2020 Share Posted August 10, 2020 15 hours ago, JORGETECH said: There are also some weird problems with HDMI when VGA to HDMI adapters are used, I wonder if it's somehow related to this (I doubt it since it would most probably be an HDMI PHY or Display Engine problem). GPU, Display Engine and HDMI all have different clock sources. It could still be HDMI clock issue, just different... 1 Quote Link to comment Share on other sites More sharing options...
JORGETECH Posted August 12, 2020 Share Posted August 12, 2020 On 8/10/2020 at 7:14 PM, jernej said: GPU, Display Engine and HDMI all have different clock sources. It could still be HDMI clock issue, just different... I forgot about that, thanks for the info! 0 Quote Link to comment Share on other sites More sharing options...
Chuck the Duck Posted August 14, 2020 Share Posted August 14, 2020 Thanks to Werner, I have a stable desktop on my Orange Pi 3 running the Armbian_20.05.4_Orangepi3_focal_current_5.4.45_desktop.img.xz (stable release). MOD can put this elsewhere if it belongs in tutorials and not bugs. Here is how to step through his fix for anyone new to linux (like myself). 1. After flashing and setting root and user, the user will be logged into the graphical Xfce desktop environment (DE) and will freeze soon. 2. On the next reboot you can try to use one of the separate terminals instead of the DE. This is done by holding CTRL+ALT and selecting F1-F6 3. Quickly log into root account and type the following "sudo systemctl set-default multi-user" This will disable the DE next time you load. 4. The system may freeze as the DE is being loaded, so its best to reset and log into the bash shell with root again. 5. We have to setup a shell script that runs every boot, as the files that Werner overwrites get replaced every time. We will edit/etc/rc.local 6. Goto "cd /etc/ " and chose your favorite editor. I used vim, so I type "vim rc.local" to start editing. 7. Add the lines that Werner posted earlier to the rc.local file cd /sys/devices/platform/soc/1800000.gpu/devfreq/1800000.gpu/ echo userspace > governor echo 756000000 > max_freq echo 756000000 > min_freq 8. Save and exit to shell. 9. last step is to enable the DE again, type "systemctl set-default graphical" 10. Reboot and enjoy a stable desktop. It took me about a day to have this working, mainly because of me not understanding the the GPU clock values were getting reset and not knowing unix commands & file structure. It reminded me as a kid messing with the autoexec.bat on a ms-dos machine. I am hoping to use an SDR and make this into a HD Radio Decoder (already built the NRSC-5 & GUI) , have it stream to an android head unit in my car & control via VNC. 5 Quote Link to comment Share on other sites More sharing options...
JORGETECH Posted August 14, 2020 Share Posted August 14, 2020 6 hours ago, Charles Thomas Morton said: Thanks to Werner, I have a stable desktop on my Orange Pi 3 running the Armbian_20.05.4_Orangepi3_focal_current_5.4.45_desktop.img.xz (stable release). MOD can put this elsewhere if it belongs in tutorials and not bugs. Here is how to step through his fix for anyone new to linux (like myself). 1. After flashing and setting root and user, the user will be logged into the graphical Xfce desktop environment (DE) and will freeze soon. 2. On the next reboot you can try to use one of the separate terminals instead of the DE. This is done by holding CTRL+ALT and selecting F1-F6 3. Quickly log into root account and type the following "sudo systemctl set-default multi-user" This will disable the DE next time you load. 4. The system may freeze as the DE is being loaded, so its best to reset and log into the bash shell with root again. 5. We have to setup a shell script that runs every boot, as the files that Werner overwrites get replaced every time. We will edit/etc/rc.local 6. Goto "cd /etc/ " and chose your favorite editor. I used vim, so I type "vim rc.local" to start editing. 7. Add the lines that Werner posted earlier to the rc.local file cd /sys/devices/platform/soc/1800000.gpu/devfreq/1800000.gpu/ echo userspace > governor echo 756000000 > max_freq echo 756000000 > min_freq 8. Save and exit to shell. 9. last step is to enable the DE again, type "systemctl set-default graphical" 10. Reboot and enjoy a stable desktop. It took me about a day to have this working, mainly because of me not understanding the the GPU clock values were getting reset and not knowing unix commands & file structure. It reminded me as a kid messing with the autoexec.bat on a ms-dos machine. I am hoping to use an SDR and make this into a HD Radio Decoder (already built the NRSC-5 & GUI) , have it stream to an android head unit in my car & control via VNC. This is exactly the same fix I applied on my Orange Pi Lite 2 and I've been having an stable desktop, the panfrost driver needs more work though. I recommend adding the Oibaf PPA to the system (in case Ubuntu is being used) to get the latest Mesa version. 0 Quote Link to comment Share on other sites More sharing options...
jernej Posted August 14, 2020 Share Posted August 14, 2020 Given than GPU DVFS is not in mainline yet, I think best solution would be to remove those patches from Armbian build system and maybe add a patch which would increase frequency and adjust voltage... 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted August 14, 2020 Share Posted August 14, 2020 Acceleration is disabled by default atm to make desktop stable. 0 Quote Link to comment Share on other sites More sharing options...
062621AM Posted August 17, 2020 Share Posted August 17, 2020 On 8/14/2020 at 10:04 PM, Werner said: Acceleration is disabled by default atm to make desktop stable. How do I enable it? 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted August 17, 2020 Share Posted August 17, 2020 2 hours ago, 062621AM said: How do I enable it? https://github.com/armbian/build/blob/eb8cc72eb3aa28addc65f4bcab0b94591cd6110f/lib/makeboarddeb.sh#L172 0 Quote Link to comment Share on other sites More sharing options...
JORGETECH Posted August 25, 2020 Share Posted August 25, 2020 On 8/17/2020 at 7:03 AM, Werner said: https://github.com/armbian/build/blob/eb8cc72eb3aa28addc65f4bcab0b94591cd6110f/lib/makeboarddeb.sh#L172 If I'm reading this correctly the acceleration is only disabled for Ubuntu bionic and focal, so compiling a groovy image (20.10) should enable acceleration? I didn't remember Armbian still had no groovy available. What other values are available besides "none"? Reading the manpage for "modesetting" reveals that setting the "AccelMethod" to "glamor" should enable acceleration. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted August 25, 2020 Share Posted August 25, 2020 Non-LTS Ubuntu releases wont be added unless by community contribution and even then they will not receive any support. Disco/Eoan were community contributions too. 0 Quote Link to comment Share on other sites More sharing options...
delius Posted August 31, 2020 Share Posted August 31, 2020 Hi, Sorry that being kind of late for this party. I need to make a Pine H64 ready to X window. I try to read over this thread carefully, but it's a bit too diversive. I met very same problem as NicoD in the thread start. Here are few questions. I wish someone who has clearer idea wouldn't mind lending me a hand. 1. Is current 5.6 kernel ready now? Or it take more patches? 2. Or are there DTS/DTB specially needed not merged required? 3. Which branch of armbian is recommended now? dev or current? Thank you. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted August 31, 2020 Share Posted August 31, 2020 3 hours ago, delius said: I need to make a Pine H64 ready to X window. Pine H64 is ready for X windows (with disabled Panfrost since its unstable) for several months. Just download desktop image: https://www.armbian.com/pine-h64-b/ https://www.armbian.com/pine-h64/ 3 hours ago, delius said: 1. Is current 5.6 kernel ready now? Or it take more patches? We have kernel 5.7.y which is already bumped to 5.8.y and will be released ASAP, probably this weekend. 3 hours ago, delius said: 2. Or are there DTS/DTB specially needed not merged required? What about there is some ongoing development and features you want are not developed or stabilised - like Panfrost. 3 hours ago, delius said: 3. Which branch of armbian is recommended now? dev or current? If you are a developer and contributor, checkout development. If you are a maintainer and user, use current. 0 Quote Link to comment Share on other sites More sharing options...
