Zram & SWAP - where is my memory?
Grass
Hi!
OS - Armbian bionic
Board - Orange pi one
I dont understand where goes 20-25% of 512mb ram.
18MB goes to video and wlan share. OK...
root@OrangePiPBX:~# zramctl
NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram1 lzo          98.2M 19.8M 10.2M   11M       4 [SWAP]
/dev/zram0                50M 17.7M  2.5M  2.9M       4 /var/log
Now we see - 150MB go's to swap and small partition for "logs".
root@OrangePiPBX:~# free
                         total        used        free      shared      buff/cache      available
Mem:         502932      242376       26380   20008      234176      232640
Swap:        100584       21504       79080
Here we see ram now in total(used and free) - 250MB
250+150 = 400
And now... can someone answer me - where is my 100MB ram?
Here is config for ZRAM:
nano /etc/default/armbian-zram-config
ENABLED=true
ZRAM_PERCENTAGE=20
Here is config for Ram-log:
nano /etc/default/armbian-ramlog
ENABLED=true
SIZE=50M
USE_RSYNC=true
root@OrangePiPBX:~# df -h
Filesystem      Size  Used Avail Use% Mounted on
udev            177M     0  177M   0% /dev
tmpfs            50M  5.4M   44M  11% /run
/dev/mmcblk0p1  7.1G  3.8G  3.3G  54% /
tmpfs           246M     0  246M   0% /dev/shm
tmpfs           5.0M   12K  5.0M   1% /run/lock
tmpfs           246M     0  246M   0% /sys/fs/cgroup
tmpfs           246M  380K  246M   1% /tmp
/dev/zram0       49M   18M   28M  40% /var/log
tmpfs            50M     0   50M   0% /run/user/0
That's all.
Maybe i am doing something wrong?
Probably not. Kernel is changing, features are added, something that we might not want gets in by mistake. I suspect 3D driver reservations or just something, which could be seen from the logs. Or not and a deep investigation is needed.
6 hours ago, Tido said:
Providing logs with
armbianmonitor -u
 significantly raises chances that someone is looking at it.
// sent from mobile phone //
Here is output:
http://ix.io/25rM
I think i have a problem with some default settings of Zram.
Like i see in doc's - Zram and swap is "preninstalled". And from first run i have only 50% of RAM
One more interesting thing!
ENABLED=true
#ZRAM_PERCENTAGE=20
i comment ZRAM_PERCENTAGE=20
and what we see now:
root@OrangePiPBX:~# swapon --show
NAME       TYPE        SIZE USED PRIO
/dev/zram1 partition 245.6M   0B    5
/dev/zram1 lzo         245.6M    4K   78B   12K       4 [SWAP]
/dev/zram0                50M 21.2M  2.9M  3.4M       4 /var/log
tmpfs            50M  1.7M   48M   4% /run
tmpfs           246M  4.0K  246M   1% /tmp
/dev/zram0       49M   22M   24M  48% /var/log
3 hours ago, Grass said:
Up.
Down.
https://forum.armbian.com/terms
Quote
Do not bump topics or create duplicate messages for the purpose of bringing attention to your issue. If bumping an old topic to resume conversation or provide new information, update the beginning post if possible.
Moderators can re-open.
  • Igor locked this topic
  • Igor unlocked this topic
Same issue here on Bullseye beta on N2+.    If a new thread is wanted just say so.
Armbian 20.11.0-trunk.9 Bullseye with Linux 5.8.12-meson64
df -h shows no /dev/zram(x)    zramctl shows nothing    same for fdisk -l     swap.target is active loaded.
sudo nano /etc/default/armbian-zram-config  ENABLED=TRUE  is only param set here.
Per Igor request:   armbianmonitor -u    at       http://ix.io/2z9h
All I got.  Any ideas to get this running ?
EDIT:  May be this  wasn't run at some point      sudo systemctl start  armbian-zram-config
per this thread https://forum.armbian.com/topic/15268-zswap-or-zram
I'll call this fixed after a few tweaks to the armbian-zram-config file.
