Question about Uboot --> File not found
Erik
Hi
I have added the serial monitor (because i had some trouble booting up)
I can see the booting proces of the U-boot.
If i'm looking in the log, i see a few file not found entry's:
** File not found /boot/.verbose **
** File not found /boot/.next **
** Unrecognized filesystem type **
** File not found .next **
I did not see these files in the /boot directory either.
Can i change something to get ride of these messages.
Thx
The complete startup log on OrangePi plus with armbian for orangepiplus:
U-Boot SPL 2016.03-armbian-sun8i (Apr 30 2016 - 23:26:36)
DRAM: 1024 MiB
Trying to boot from MMC
U-Boot 2016.03-armbian-sun8i (Apr 30 2016 - 23:26:36 +0200) Allwinner Technology
CPU:   Allwinner H3 (SUN8I)
I2C:   ready
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 0 (SD), SUNXI SD/MMC: 1
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB EHCI 1.00
scanning bus 0 for devices... 4 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
Hit any key to stop autoboot:  0
=> boot
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
2347 bytes read in 172 ms (12.7 KiB/s)
## Executing script at 43100000
gpio: pin PL10 (gpio 298) value is 1
gpio: pin PG11 (gpio 203) value is 1
37052 bytes read in 517 ms (69.3 KiB/s)
3115884 bytes read in 3128 ms (972.7 KiB/s)
5116680 bytes read in 5104 ms (978.5 KiB/s)
Kernel image @ 0x48000000 [ 0x000000 - 0x4e1308 ]
## Loading init Ramdisk from Legacy Image at 42000000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    3115820 Bytes = 3 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
Using machid 0x1029 from environment
Starting kernel ...
[sun8i_fixup]: From boot, get meminfo:
        Start:  0x40000000
ion_carveout reserve: 160m@0 256m@0 130m@1 200m@1
ion_reserve_select: ion chipid  [0x2004620!
ion_reserve_common: ion reserve: [0x50000000, 0x60000000]!
In the /boot directory is the file .verbose, but not the file .next
The contents of the file .verbose are:
1464173183 sun8i armv7l   Orange Pi+ Linux version 3.4.112-sun8i (root@trusty) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #30 SMP PREEMPT Sat Apr 30 19:49:10 CEST 2016
If you want to see more on serial console, you will need to alter boot scripts.
There is nothing wrong.
.next is used to boot mainline kernel. If this is set, boot procedure is different.
.verbose is used to enable more verbosity in case of troubles
. unrecognized fs is because we try to load from other filesystems with one script.
