jock
Hello Group
some month ago i bought a secound rk3229 box but with a stupid SV9082c wifi chip that is not supported by linux
i finally get hands on a rtl8723bs chip from china and succesfully swap the wifi modul . But the the china store mislabel the product and i got a rtl8723ds .
fortunately IWFINGER had a driver for this and i succesful build the kernel module and wifi now works .
is it possible to insert/activate the rtl8723ds driver in next build of rk322x ?
for the kernel module i had to Update the box there i got a message that some driver missing please can you check that @jock
Spoiler
Yes, it can be possibile if the driver is somehow already in mainline kernel; I can't test it though.
That's just firmware file missing for some kernel modules when the initramfs is going to be rebuilt. None to be really worried about.
im so used installing armbian on rk322x that I forgot to be careful about eMCP based boards, luckily it didnt result to a brick and the install work just fine, the only thing that didnt work is the wifi which using based on ESP8089. the board im using have 8GB storage with 1GB of ram which comes with that MXQ Android TV Boxes. Using Armbian_22.05.0-trunk_Rk322x-box_jammy_current_5.15.25_xfce_desktop.img
the only thing that had trouble booting up on this box is basically the libreelec builds for rk322x. all of them result to a crash with bunch of text on the screen. this crash happen very early in boot process, only like 1-2 seconds after your see the libreelec logo.
On 6/28/2022 at 12:11 AM, Luís Hansen said:
Hello there!
@jock so I spent the past few days reading through the topic and testing around with different settings for led configuration and esp8089 settings (the crystal_26M_en setting).
According to the outdated ESP8089 manual, 0 is for 40, 1 is for 26 and 2 is for 24 MHz, so today I tried every single combination of led configuration and crystal frequency. For every test I first rebooted the computer, then shut it off (I even unplugged it out of the wall) and the restarted to be sure all the settings had been updated.
None of the combinations worked, and I captured a dmesg for every single test.
Now let me get into why I decided to run those tests.
Last night I somehow managed to make the wifi work while messing with the settings. I hadn't yet read a message in here about the firmware only updating when completely shutting it off, so I'm not sure what configuration I had at the time. It was supposed to be led config 7 and crystal 0 (40MHz), but it doesn't make sense (you'll see why). While it was working, I captured a dmesg.
I remember that when I got it to work I was testing adding the esp8089 driver to the blacklist and then activating it using modprobe. But then again, I'm not sure if I was doing the right thing after doing so. Was I supposed to reboot after doing that? Or should it work right away once modprobed?
Anyway, at least now I have hope that it can work, since I was it with my won eyes.
This is the dmesg captured when the wifi worked:
  Reveal hidden contents
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.194-rk322x (root@runner7) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #2 SMP Wed Aug 25 20:09:42 UTC 2021
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Generic RK322x TV Box board
[    0.000000] cma: Reserved 16 MiB at 0x9f000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 253952
[    0.000000] free_area_init_node: node 0, pgdat b1253b40, node_mem_map ee6f1000
[    0.000000]   Normal zone: 2304 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 253952 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv65535.65535 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] PERCPU: Embedded 14 pages/cpu @ee68f000 s24856 r8192 d24296 u57344
[    0.000000] pcpu-alloc: s24856 r8192 d24296 u57344 alloc=14*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 251648
[    0.000000] Kernel command line: earlyprintk root=UUID=bce0e15e-76b7-4f9c-9149-332bcfd83573 console=ttyS2,115200n8 console=tty1 rootwait rootfstype=ext4  consoleblank=0 loglevel=1 ubootpart=343a1e5a-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u coherent_pool=2M  cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 961148K/1015808K available (12862K kernel code, 919K rwdata, 3240K rodata, 808K init, 1219K bss, 38276K reserved, 16384K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                   lowmem  : 0xb0000000 - 0xf0000000   (1024 MB)
                   pkmap   : 0xafe00000 - 0xb0000000   (   2 MB)
                   modules : 0xaf000000 - 0xafe00000   (  14 MB)
                     .text : 0xb0008000 - 0xb0c97c6c   (12864 kB)
                     .init : 0xb10b0000 - 0xb117a000   ( 808 kB)
                     .data : 0xb117a000 - 0xb125fe94   ( 920 kB)
                      .bss : 0xb1261000 - 0xb1391f14   (1220 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]     Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000024] Switching to timer-based delay loop, resolution 41ns
[    0.001861] Console: colour dummy device 80x30
[    0.002049] console [tty1] enabled
[    0.002081] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.002100] pid_max: default: 32768 minimum: 301
[    0.002245] Security Framework initialized
[    0.002260] Yama: becoming mindful.
[    0.002344] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002360] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.003352] Initializing cgroup subsys io
[    0.003392] Initializing cgroup subsys memory
[    0.003437] Initializing cgroup subsys devices
[    0.003458] Initializing cgroup subsys freezer
[    0.003477] Initializing cgroup subsys net_cls
[    0.003494] Initializing cgroup subsys perf_event
[    0.003512] Initializing cgroup subsys net_prio
[    0.003545] Initializing cgroup subsys pids
[    0.003706] CPU: Testing write buffer coherency: ok
[    0.003766] ftrace: allocating 41892 entries in 123 pages
[    0.086458] /cpus/cpu@f00 missing clock-frequency property
[    0.086498] /cpus/cpu@f01 missing clock-frequency property
[    0.086517] /cpus/cpu@f02 missing clock-frequency property
[    0.086538] /cpus/cpu@f03 missing clock-frequency property
[    0.086551] CPU0: update cpu_capacity 430
[    0.086564] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.086665] Setting up static identity map for 0x60008280 - 0x600082d8
[    0.089947] CPU1: update cpu_capacity 430
[    0.089957] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.091195] CPU2: update cpu_capacity 430
[    0.091204] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.092416] CPU3: update cpu_capacity 430
[    0.092425] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.092575] Brought up 4 CPUs
[    0.092617] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.092626] CPU: All CPU(s) started in SVC mode.
[    0.094350] devtmpfs: initialized
[    0.114776] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.115382] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.115430] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.116983] xor: measuring software checksum speed
[    0.154353]    arm4regs  :  1011.000 MB/sec
[    0.194456]    8regs     :   705.000 MB/sec
[    0.234557]    32regs    :   684.000 MB/sec
[    0.274658]    neon      :  1018.000 MB/sec
[    0.274668] xor: using function: neon (1018.000 MB/sec)
[    0.274716] pinctrl core: initialized pinctrl subsystem
[    0.276480] NET: Registered protocol family 16
[    0.279154] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.290841] cpuidle: using governor ladder
[    0.302852] cpuidle: using governor menu
[    0.320355] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0
[    0.320537] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1
[    0.320694] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2
[    0.320872] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3
[    0.327387] console [pstore-1] enabled
[    0.327399] pstore: Registered ramoops as persistent store backend
[    0.327412] ramoops: attached 0xf0000@0x62e00000, ecc: 0/0
[    0.330792] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.330813] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.427932] raid6: int32x1  gen()   133 MB/s
[    0.495931] raid6: int32x1  xor()   131 MB/s
[    0.564185] raid6: int32x2  gen()   166 MB/s
[    0.632236] raid6: int32x2  xor()   136 MB/s
[    0.700600] raid6: int32x4  gen()   163 MB/s
[    0.768688] raid6: int32x4  xor()   137 MB/s
[    0.836996] raid6: int32x8  gen()   166 MB/s
[    0.905261] raid6: int32x8  xor()   113 MB/s
[    0.973397] raid6: neonx1   gen()   382 MB/s
[    1.041520] raid6: neonx1   xor()   290 MB/s
[    1.109735] raid6: neonx2   gen()   519 MB/s
[    1.177859] raid6: neonx2   xor()   376 MB/s
[    1.246109] raid6: neonx4   gen()   581 MB/s
[    1.314295] raid6: neonx4   xor()   400 MB/s
[    1.382539] raid6: neonx8   gen()   559 MB/s
[    1.450751] raid6: neonx8   xor()   391 MB/s
[    1.450764] raid6: using algorithm neonx4 gen() 581 MB/s
[    1.450774] raid6: .... xor() 400 MB/s, rmw enabled
[    1.450784] raid6: using intx1 recovery algorithm
[    1.451939] rockchip-pm rockchip-suspend: not set wakeup-config
[    1.451967] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    1.452405] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@0[0]'
[    1.452969] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@1[0]'
[    1.453680] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-host-regulator[0]' - status (0)
[    1.454335] of_get_named_gpiod_flags: parsed 'gpio' property of node '/otg-vbus-regulator[0]' - status (0)
[    1.454975] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]'
[    1.455924] iommu: Adding device 20020000.vpu-service to group 0
[    1.456041] iommu: Adding device 20030000.rkvdec to group 1
[    1.456153] iommu: Adding device 20050000.vop to group 2
[    1.456253] iommu: Adding device 20070000.iep to group 3
[    1.456851] rk_iommu 20020800.iommu: can't get sclk
[    1.457585] rk_iommu 20030480.iommu: can't get sclk
[    1.457862] rk_iommu 20053f00.iommu: can't get sclk
[    1.458018] rk_iommu 20070800.iommu: can't get aclk
[    1.458038] rk_iommu 20070800.iommu: can't get hclk
[    1.458054] rk_iommu 20070800.iommu: can't get sclk
[    1.458988] SCSI subsystem initialized
[    1.459456] usbcore: registered new interface driver usbfs
[    1.459564] usbcore: registered new interface driver hub
[    1.459706] usbcore: registered new device driver usb
[    1.459935] media: Linux media interface: v0.10
[    1.460018] Linux video capture interface: v2.00
[    1.460289] pps_core: LinuxPPS API ver. 1 registered
[    1.460305] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.460349] PTP clock support registered
[    1.462562] Advanced Linux Sound Architecture Driver Initialized.
[    1.463723] Bluetooth: Core ver 2.21
[    1.463808] NET: Registered protocol family 31
[    1.463823] Bluetooth: HCI device and connection manager initialized
[    1.463848] Bluetooth: HCI socket layer initialized
[    1.463865] Bluetooth: L2CAP socket layer initialized
[    1.463930] Bluetooth: SCO socket layer initialized
[    1.464809] NetLabel: Initializing
[    1.464832] NetLabel:  domain hash size = 128
[    1.464842] NetLabel:  protocols = UNLABELED CIPSOv4
[    1.464922] NetLabel:  unlabeled traffic allowed by default
[    1.466492] clocksource: Switched to clocksource arch_sys_counter
[    1.567563] NET: Registered protocol family 2
[    1.568542] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    1.568666] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[    1.569023] TCP: Hash tables configured (established 8192 bind 8192)
[    1.569127] UDP hash table entries: 512 (order: 2, 24576 bytes)
[    1.569198] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[    1.569598] NET: Registered protocol family 1
[    1.570514] RPC: Registered named UNIX socket transport module.
[    1.570542] RPC: Registered udp transport module.
[    1.570553] RPC: Registered tcp transport module.
[    1.570564] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.570945] Trying to unpack rootfs image as initramfs...
[    2.072332] Freeing initrd memory: 7080K
[    2.073400] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    2.076629] Initialise system trusted keyring
[    2.091053] VFS: Disk quotas dquot_6.6.0
[    2.091395] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    2.094231] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.097887] NFS: Registering the id_resolver key type
[    2.097971] Key type id_resolver registered
[    2.097985] Key type id_legacy registered
[    2.098023] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.098157] ntfs: driver 2.1.32 [Flags: R/W].
[    2.099273] JFS: nTxBlock = 7692, nTxLock = 61538
[    2.110550] SGI XFS with security attributes, no debug enabled
[    2.120043] NET: Registered protocol family 38
[    2.120105] Key type asymmetric registered
[    2.120127] Asymmetric key parser 'x509' registered
[    2.120584] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    2.120980] io scheduler noop registered
[    2.121012] io scheduler deadline registered
[    2.121112] io scheduler cfq registered (default)
[    2.124812] phy phy-11000000.syscon:usb2-phy@800.2: Failed to get VBUS supply regulator
[    2.130406] rk-vcodec 20020000.vpu-service: no regulator for vcodec
[    2.130992] rk-vcodec 20020000.vpu-service: probe device
[    2.131490] rk-vcodec 20020000.vpu-service: drm allocator with mmu enabled
[    2.132865] rk-vcodec 20020000.vpu-service: could not find power_model node
[    2.132897] rk-vcodec 20020000.vpu-service: init success
[    2.133277] rk-vcodec 20030000.rkvdec: vcodec regulator not ready, retry
[    2.137766] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-241330
[    2.137797] dma-pl330 110f0000.pdma:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    2.139130] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    2.139671] pwm-regulator vdd-arm-regulator: GPIO lookup for consumer enable
[    2.139693] pwm-regulator vdd-arm-regulator: using device tree for GPIO lookup
[    2.139712] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-arm-regulator[0]'
[    2.139727] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-arm-regulator[0]'
[    2.139741] pwm-regulator vdd-arm-regulator: using lookup tables for GPIO lookup
[    2.139757] pwm-regulator vdd-arm-regulator: lookup for GPIO enable failed
[    2.140493] pwm-regulator vdd-log-regulator: GPIO lookup for consumer enable
[    2.140516] pwm-regulator vdd-log-regulator: using device tree for GPIO lookup
[    2.140533] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log-regulator[0]'
[    2.140547] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log-regulator[0]'
[    2.140561] pwm-regulator vdd-log-regulator: using lookup tables for GPIO lookup
[    2.140575] pwm-regulator vdd-log-regulator: lookup for GPIO enable failed
[    2.141729] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.142763] 11030000.serial: ttyS2 at MMIO 0x11030000 (irq = 30, base_baud = 1500000) is a 16550A
[    2.143615] console [ttyS2] enabled
[    2.145641] [drm] Initialized drm 1.1.0 20060810
[    2.148373] [drm] Rockchip DRM driver version: v1.0.1
[    2.148648] rockchip-drm display-subsystem: devfreq is not set
[    2.149487] rockchip-drm display-subsystem: bound 20050000.vop (ops 0xb0d1b2b0)
[    2.149926] i2c i2c-0: of_i2c: modalias failure on /hdmi@200a0000/ports
[    2.149957] dwhdmi-rockchip 200a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.150082] dwhdmi-rockchip 200a0000.hdmi: Detected HDMI TX controller v2.01a with HDCP (inno_dw_hdmi_phy)
[    2.151643] rockchip-drm display-subsystem: bound 200a0000.hdmi (ops 0xb0d13808)
[    2.151674] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.151685] [drm] No driver support for vblank timestamp query.
[    2.151830] rockchip-drm display-subsystem: failed to parse display resources
[    2.776143] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[    2.781654] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[    2.781663] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[    2.781670] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[    2.781677] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[    2.781683] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[    2.781690] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[    2.781697] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[    2.781703] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[    2.781710] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[    2.781717] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[    2.781723] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[    2.781730] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[    2.781736] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[    2.781742] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[    2.781750] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
[    2.853668] Console: switching to colour frame buffer device 240x67
[    2.903688] rockchip-drm display-subsystem: fb0:  frame buffer device
[    2.920164] Registered IR keymap rc-cec
[    2.920503] rc rc0: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0
[    2.921176] input: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0/input0
[    2.924201] brd: module loaded
[    2.938346] loop: module loaded
[    2.938620] lkdtm: No crash points registered, enable through debugfs
[    2.941768] libphy: Fixed MDIO Bus: probed
[    2.941813] tun: Universal TUN/TAP device driver, 1.6
[    2.941827] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.942314] CAN device driver interface
[    2.944164] rk_gmac-dwmac 30200000.ethernet: clock input or output? (output).
[    2.944209] rk_gmac-dwmac 30200000.ethernet: TX delay(0x30).
[    2.944228] rk_gmac-dwmac 30200000.ethernet: RX delay(0x10).
[    2.944286] rk_gmac-dwmac 30200000.ethernet: integrated PHY? (yes).
[    2.944503] rk_gmac-dwmac 30200000.ethernet: cannot get clock clk_mac_speed
[    2.949598] rk_gmac-dwmac 30200000.ethernet: init for RMII
[    2.982697] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    2.982717]  Ring mode enabled
[    2.982730]  DMA HW capability register supported
[    2.982743]  Normal descriptors
[    2.982758]  RX Checksum Offload Engine supported (type 2)
[    2.982771]  TX Checksum insertion supported
[    2.982780]  Wake-Up On Lan supported
[    2.982902] rk_gmac-dwmac 30200000.ethernet: rk_get_eth_addr: mac address: 4e:29:f7:d4:13:43
[    2.982919] eth%d: device MAC address 4e:29:f7:d4:13:43
[    2.982933]  Enable RX Mitigation via HW Watchdog Timer
[    2.983223] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@30200000[0]' - status (0)
[    3.403348] libphy: stmmac: probed
[    3.403393] eth%d: PHY ID 1234d400 at 0 IRQ POLL (stmmac-0:00) active
[    3.403411] eth%d: PHY ID 00000000 at 1 IRQ POLL (stmmac-0:01)
[    3.403425] eth%d: PHY ID 00000000 at 2 IRQ POLL (stmmac-0:02)
[    3.403440] eth%d: PHY ID 00000000 at 3 IRQ POLL (stmmac-0:03)
[    3.403455] eth%d: PHY ID 00000000 at 4 IRQ POLL (stmmac-0:04)
[    3.403470] eth%d: PHY ID 00000000 at 5 IRQ POLL (stmmac-0:05)
[    3.403486] eth%d: PHY ID 00000000 at 6 IRQ POLL (stmmac-0:06)
[    3.403501] eth%d: PHY ID 00000000 at 7 IRQ POLL (stmmac-0:07)
[    3.403516] eth%d: PHY ID 00000000 at 8 IRQ POLL (stmmac-0:08)
[    3.403530] eth%d: PHY ID 00000000 at 9 IRQ POLL (stmmac-0:09)
[    3.403546] eth%d: PHY ID 00000000 at 10 IRQ POLL (stmmac-0:0a)
[    3.403561] eth%d: PHY ID 00000000 at 11 IRQ POLL (stmmac-0:0b)
[    3.403575] eth%d: PHY ID 00000000 at 12 IRQ POLL (stmmac-0:0c)
[    3.403590] eth%d: PHY ID 00000000 at 13 IRQ POLL (stmmac-0:0d)
[    3.403605] eth%d: PHY ID 00000000 at 14 IRQ POLL (stmmac-0:0e)
[    3.403620] eth%d: PHY ID 00000000 at 15 IRQ POLL (stmmac-0:0f)
[    3.403635] eth%d: PHY ID 00000000 at 16 IRQ POLL (stmmac-0:10)
[    3.403650] eth%d: PHY ID 00000000 at 17 IRQ POLL (stmmac-0:11)
[    3.403665] eth%d: PHY ID 00000000 at 18 IRQ POLL (stmmac-0:12)
[    3.403679] eth%d: PHY ID 00000000 at 19 IRQ POLL (stmmac-0:13)
[    3.403694] eth%d: PHY ID 00000000 at 20 IRQ POLL (stmmac-0:14)
[    3.403709] eth%d: PHY ID 00000000 at 21 IRQ POLL (stmmac-0:15)
[    3.403724] eth%d: PHY ID 00000000 at 22 IRQ POLL (stmmac-0:16)
[    3.403738] eth%d: PHY ID 00000000 at 23 IRQ POLL (stmmac-0:17)
[    3.403753] eth%d: PHY ID 00000000 at 24 IRQ POLL (stmmac-0:18)
[    3.403768] eth%d: PHY ID 00000000 at 25 IRQ POLL (stmmac-0:19)
[    3.403783] eth%d: PHY ID 00000000 at 26 IRQ POLL (stmmac-0:1a)
[    3.403798] eth%d: PHY ID 00000000 at 27 IRQ POLL (stmmac-0:1b)
[    3.403813] eth%d: PHY ID 00000000 at 28 IRQ POLL (stmmac-0:1c)
[    3.403827] eth%d: PHY ID 00000000 at 29 IRQ POLL (stmmac-0:1d)
[    3.403842] eth%d: PHY ID 00000000 at 30 IRQ POLL (stmmac-0:1e)
[    3.403856] eth%d: PHY ID 00000000 at 31 IRQ POLL (stmmac-0:1f)
[    3.405674] PPP generic driver version 2.4.2
[    3.406198] Atmel at76x USB Wireless LAN Driver 0.17 loading
[    3.406373] usbcore: registered new interface driver at76c50x-usb
[    3.406651] usbcore: registered new interface driver rtl8187
[    3.406788] usbcore: registered new interface driver rndis_wlan
[    3.406927] usbcore: registered new interface driver zd1201
[    3.407504] usbcore: registered new interface driver rt2800usb
[    3.407666] Rockchip WiFi SYS interface (V1.00) ...
[    3.407754] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    3.407864] usbcore: registered new interface driver pegasus
[    3.407964] usbcore: registered new interface driver rtl8150
[    3.408059] usbcore: registered new interface driver r8152
[    3.408169] usbcore: registered new interface driver asix
[    3.408283] usbcore: registered new interface driver ax88179_178a
[    3.408393] usbcore: registered new interface driver cdc_ether
[    3.408488] usbcore: registered new interface driver dm9601
[    3.408601] usbcore: registered new interface driver smsc75xx
[    3.408709] usbcore: registered new interface driver smsc95xx
[    3.408800] usbcore: registered new interface driver net1080
[    3.408890] usbcore: registered new interface driver rndis_host
[    3.408993] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    3.409163] usbcore: registered new interface driver cdc_ncm
[    3.409253] usbcore: registered new interface driver cdc_mbim
[    3.409911] 30040000.usb supply vusb_d not found, using dummy regulator
[    3.410028] 30040000.usb supply vusb_a not found, using dummy regulator
[    3.423664] dwc2 30040000.usb: DWC OTG Controller
[    3.423739] dwc2 30040000.usb: new USB bus registered, assigned bus number 1
[    3.423822] dwc2 30040000.usb: irq 49, io mem 0x30040000
[    3.424355] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.424378] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.424394] usb usb1: Product: DWC OTG Controller
[    3.424408] usb usb1: Manufacturer: Linux 4.4.194-rk322x dwc2_hsotg
[    3.424421] usb usb1: SerialNumber: 30040000.usb
[    3.425681] hub 1-0:1.0: USB hub found
[    3.425778] hub 1-0:1.0: 1 port detected
[    3.427727] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.427768] ehci-platform: EHCI generic platform driver
[    3.430580] ehci-platform 30080000.usb: EHCI Host Controller
[    3.431086] ehci-platform 30080000.usb: new USB bus registered, assigned bus number 2
[    3.431534] ehci-platform 30080000.usb: irq 50, io mem 0x30080000
[    3.442497] ehci-platform 30080000.usb: USB 2.0 started, EHCI 1.00
[    3.442880] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    3.442900] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.442918] usb usb2: Product: EHCI Host Controller
[    3.442932] usb usb2: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    3.442946] usb usb2: SerialNumber: 30080000.usb
[    3.444126] hub 2-0:1.0: USB hub found
[    3.444237] hub 2-0:1.0: 1 port detected
[    3.447399] ehci-platform 300c0000.usb: EHCI Host Controller
[    3.447916] ehci-platform 300c0000.usb: new USB bus registered, assigned bus number 3
[    3.448323] ehci-platform 300c0000.usb: irq 52, io mem 0x300c0000
[    3.458491] ehci-platform 300c0000.usb: USB 2.0 started, EHCI 1.00
[    3.458873] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    3.458895] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.458911] usb usb3: Product: EHCI Host Controller
[    3.458926] usb usb3: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    3.458940] usb usb3: SerialNumber: 300c0000.usb
[    3.460103] hub 3-0:1.0: USB hub found
[    3.460174] hub 3-0:1.0: 1 port detected
[    3.463312] ehci-platform 30100000.usb: EHCI Host Controller
[    3.463845] ehci-platform 30100000.usb: new USB bus registered, assigned bus number 4
[    3.464270] ehci-platform 30100000.usb: irq 54, io mem 0x30100000
[    3.474488] ehci-platform 30100000.usb: USB 2.0 started, EHCI 1.00
[    3.474848] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    3.474868] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.474883] usb usb4: Product: EHCI Host Controller
[    3.474898] usb usb4: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    3.474911] usb usb4: SerialNumber: 30100000.usb
[    3.476117] hub 4-0:1.0: USB hub found
[    3.476213] hub 4-0:1.0: 1 port detected
[    3.477134] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.477237] ohci-platform: OHCI generic platform driver
[    3.477838] ohci-platform 300a0000.usb: Generic Platform OHCI controller
[    3.478370] ohci-platform 300a0000.usb: new USB bus registered, assigned bus number 5
[    3.478894] ohci-platform 300a0000.usb: irq 51, io mem 0x300a0000
[    3.538824] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    3.538857] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.538874] usb usb5: Product: Generic Platform OHCI controller
[    3.538889] usb usb5: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    3.538903] usb usb5: SerialNumber: 300a0000.usb
[    3.540192] hub 5-0:1.0: USB hub found
[    3.540291] hub 5-0:1.0: 1 port detected
[    3.541320] ohci-platform 300e0000.usb: Generic Platform OHCI controller
[    3.541785] ohci-platform 300e0000.usb: new USB bus registered, assigned bus number 6
[    3.542148] ohci-platform 300e0000.usb: irq 53, io mem 0x300e0000
[    3.598804] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    3.598835] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.598852] usb usb6: Product: Generic Platform OHCI controller
[    3.598867] usb usb6: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    3.598881] usb usb6: SerialNumber: 300e0000.usb
[    3.600146] hub 6-0:1.0: USB hub found
[    3.600258] hub 6-0:1.0: 1 port detected
[    3.601265] ohci-platform 30120000.usb: Generic Platform OHCI controller
[    3.601767] ohci-platform 30120000.usb: new USB bus registered, assigned bus number 7
[    3.602170] ohci-platform 30120000.usb: irq 55, io mem 0x30120000
[    3.658809] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    3.658842] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.658859] usb usb7: Product: Generic Platform OHCI controller
[    3.658873] usb usb7: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    3.658889] usb usb7: SerialNumber: 30120000.usb
[    3.660049] hub 7-0:1.0: USB hub found
[    3.660127] hub 7-0:1.0: 1 port detected
[    3.661235] usbcore: registered new interface driver cdc_acm
[    3.661261] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    3.661395] usbcore: registered new interface driver cdc_wdm
[    3.661722] usbcore: registered new interface driver usb-storage
[    3.661993] usbcore: registered new interface driver usbserial
[    3.662091] usbcore: registered new interface driver usbserial_generic
[    3.662165] usbserial: USB Serial support registered for generic
[    3.662286] usbcore: registered new interface driver keyspan
[    3.662361] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    3.662572] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    3.662661] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    3.662739] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    3.662882] usbcore: registered new interface driver option
[    3.662949] usbserial: USB Serial support registered for GSM modem (1-port)
[    3.663709] usbcore: registered new interface driver oti6858
[    3.663791] usbserial: USB Serial support registered for oti6858
[    3.663910] usbcore: registered new interface driver qcserial
[    3.663985] usbserial: USB Serial support registered for Qualcomm USB modem
[    3.664156] usbcore: registered new interface driver sierra
[    3.664219] usbserial: USB Serial support registered for Sierra USB modem
[    3.666181] usbcore: registered new interface driver iforce
[    3.666389] usbcore: registered new interface driver xpad
[    3.666876] usbcore: registered new interface driver usbtouchscreen
[    3.668416] i2c /dev entries driver
[    3.670686] IR NEC protocol handler initialized
[    3.670724] IR RC5(x/sz) protocol handler initialized
[    3.670742] IR RC6 protocol handler initialized
[    3.670759] IR JVC protocol handler initialized
[    3.670780] IR Sony protocol handler initialized
[    3.670800] IR SANYO protocol handler initialized
[    3.670818] IR Sharp protocol handler initialized
[    3.670836] IR MCE Keyboard/mouse protocol handler initialized
[    3.670854] IR XMP protocol handler initialized
[    3.672887] usbcore: registered new interface driver uvcvideo
[    3.672907] USB Video Class driver (1.1.1)
[    3.675424] Boot mode: normal
[    3.676935] rockchip-thermal 11150000.tsadc: tsadc is probed successfully!
[    3.679097] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    3.679610] Bluetooth: Virtual HCI driver ver 1.5
[    3.679973] Bluetooth: HCI UART driver ver 2.3
[    3.679997] Bluetooth: HCI UART protocol H4 registered
[    3.680009] Bluetooth: HCI UART protocol LL registered
[    3.680020] Bluetooth: HCI UART protocol ATH3K registered
[    3.680033] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    3.680280] Bluetooth: HCI UART protocol BCM registered
[    3.680481] usbcore: registered new interface driver bfusb
[    3.680651] usbcore: registered new interface driver btusb
[    3.680679] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    3.681533] cpu cpu0: leakage=9
[    3.681575] cpu cpu0: leakage-volt-sel=1
[    3.681895] cpu cpu0: Failed to get pvtm
[    3.683838] cpu cpu0: avs=0
[    3.683947] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    3.683976] cpu cpu0: failed to read out thermal zone (-22)
[    3.684857] cpu cpu0: failed to find power_model node
[    3.685824] pwrseq_simple sdio-pwrseq: GPIO lookup for consumer reset
[    3.685851] pwrseq_simple sdio-pwrseq: using device tree for GPIO lookup
[    3.685880] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[0]' - status (0)
[    3.686386] Synopsys Designware Multimedia Card Interface Driver
[    3.687384] dwmmc_rockchip 30000000.dwmmc: IDMAC supports 32-bit address mode.
[    3.687558] dwmmc_rockchip 30000000.dwmmc: Using internal DMA controller.
[    3.687583] dwmmc_rockchip 30000000.dwmmc: Version ID is 270a
[    3.687675] dwmmc_rockchip 30000000.dwmmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo
[    3.687779] dwmmc_rockchip 30000000.dwmmc: No vmmc regulator found
[    3.687791] dwmmc_rockchip 30000000.dwmmc: No vqmmc regulator found
[    3.687821] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer cd
[    3.687832] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    3.687870] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/dwmmc@30000000[0]' - status (0)
[    3.687925] gpio-49 (cd): gpiod_set_debounce: missing set() or set_debounce() operations
[    3.687940] dwmmc_rockchip 30000000.dwmmc: Got CD GPIO
[    3.687953] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer wp
[    3.687962] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    3.687975] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30000000[0]'
[    3.687988] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30000000[0]'
[    3.687999] dwmmc_rockchip 30000000.dwmmc: using lookup tables for GPIO lookup
[    3.688012] dwmmc_rockchip 30000000.dwmmc: lookup for GPIO wp failed
[    3.698580] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.711598] dwmmc_rockchip 30000000.dwmmc: 1 slots initialized
[    3.712193] dwmmc_rockchip 30010000.dwmmc: num-slots property not found, assuming 1 slot is available
[    3.712317] dwmmc_rockchip 30010000.dwmmc: IDMAC supports 32-bit address mode.
[    3.712502] dwmmc_rockchip 30010000.dwmmc: Using internal DMA controller.
[    3.712526] dwmmc_rockchip 30010000.dwmmc: Version ID is 270a
[    3.712613] dwmmc_rockchip 30010000.dwmmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo
[    3.712711] dwmmc_rockchip 30010000.dwmmc: No vmmc regulator found
[    3.712725] dwmmc_rockchip 30010000.dwmmc: No vqmmc regulator found
[    3.712748] dwmmc_rockchip 30010000.dwmmc: GPIO lookup for consumer wp
[    3.712761] dwmmc_rockchip 30010000.dwmmc: using device tree for GPIO lookup
[    3.712778] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30010000[0]'
[    3.712791] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30010000[0]'
[    3.712803] dwmmc_rockchip 30010000.dwmmc: using lookup tables for GPIO lookup
[    3.712817] dwmmc_rockchip 30010000.dwmmc: lookup for GPIO wp failed
[    3.712925] dwmmc_rockchip 30010000.dwmmc: allocated mmc-pwrseq
[    3.725931] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 400000Hz, actual 244140HZ div = 2)
[    3.738586] dwmmc_rockchip 30010000.dwmmc: 1 slots initialized
[    3.738936] dwmmc_rockchip 30020000.dwmmc: IDMAC supports 32-bit address mode.
[    3.739081] dwmmc_rockchip 30020000.dwmmc: Using internal DMA controller.
[    3.739103] dwmmc_rockchip 30020000.dwmmc: Version ID is 270a
[    3.739190] dwmmc_rockchip 30020000.dwmmc: DW MMC controller at irq 47,32 bit host data width,256 deep fifo
[    3.739292] dwmmc_rockchip 30020000.dwmmc: No vmmc regulator found
[    3.739309] dwmmc_rockchip 30020000.dwmmc: No vqmmc regulator found
[    3.739332] dwmmc_rockchip 30020000.dwmmc: GPIO lookup for consumer wp
[    3.739342] dwmmc_rockchip 30020000.dwmmc: using device tree for GPIO lookup
[    3.739355] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30020000[0]'
[    3.739367] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30020000[0]'
[    3.739379] dwmmc_rockchip 30020000.dwmmc: using lookup tables for GPIO lookup
[    3.739392] dwmmc_rockchip 30020000.dwmmc: lookup for GPIO wp failed
[    3.752237] mmc_host mmc2: Bus speed (slot 0) = 2343750Hz (slot req 400000Hz, actual 390625HZ div = 3)
[    3.765041] dwmmc_rockchip 30020000.dwmmc: 1 slots initialized
[    3.765861] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/working[0]' - status (0)
[    3.766683] ledtrig-cpu: registered to indicate activity on CPUs
[    3.766821] hidraw: raw HID events driver (C) Jiri Kosina
[    3.767529] usbcore: registered new interface driver usbhid
[    3.767548] usbhid: USB HID core driver
[    3.768020] ashmem: initialized
[    3.770391] rknandbase v1.2 2018-05-08
[    3.770950] rknand 30030000.nandc: rknand_probe clk rate = 150000000
[    3.771260] ftl_init fffffffe
[    3.771273] rk_ftl_init fail
[    3.773384] usbcore: registered new interface driver snd-usb-audio
[    3.773775] usbcore: registered new interface driver snd-ua101
[    3.773993] usbcore: registered new interface driver snd-usb-caiaq
[    3.774201] usbcore: registered new interface driver snd-usb-6fire
[    3.774409] usbcore: registered new interface driver snd-usb-hiface
[    3.774775] usbcore: registered new interface driver snd-bcd2000
[    3.775067] usbcore: registered new interface driver snd_usb_pod
[    3.775319] usbcore: registered new interface driver snd_usb_podhd
[    3.775487] usbcore: registered new interface driver snd_usb_toneport
[    3.775643] usbcore: registered new interface driver snd_usb_variax
[    3.778807] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 300000Hz, actual 244140HZ div = 2)
[    3.786407] u32 classifier
[    3.786522]     input device check on
[    3.786537]     Actions configured
[    3.786581] Netfilter messages via NETLINK v0.30.
[    3.786645] nfnl_acct: registering with nfnetlink.
[    3.786821] nf_conntrack version 0.5.0 (15384 buckets, 61536 max)
[    3.788301] Initializing XFRM netlink socket
[    3.789991] NET: Registered protocol family 10
[    3.792701] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.793306] sit: IPv6 over IPv4 tunneling driver
[    3.794961] NET: Registered protocol family 17
[    3.795057] NET: Registered protocol family 15
[    3.795195] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    3.795279] Bridge firewalling registered
[    3.795304] can: controller area network core (rev 20120528 abi 9)
[    3.795454] NET: Registered protocol family 29
[    3.795497] can: raw protocol (rev 20120528)
[    3.795527] can: broadcast manager protocol (rev 20120528 t)
[    3.795568] can: netlink gateway (rev 20130117) max_hops=1
[    3.796479] Bluetooth: RFCOMM TTY layer initialized
[    3.796646] Bluetooth: RFCOMM socket layer initialized
[    3.796719] Bluetooth: RFCOMM ver 1.11
[    3.796776] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.796809] Bluetooth: HIDP socket layer initialized
[    3.797038] 8021q: 802.1Q VLAN Support v1.8
[    3.797127] lib80211: common routines for IEEE802.11 drivers
[    3.797150] lib80211_crypt: registered algorithm 'NULL'
[    3.797184] lib80211_crypt: registered algorithm 'WEP'
[    3.797214] lib80211_crypt: registered algorithm 'CCMP'
[    3.797243] lib80211_crypt: registered algorithm 'TKIP'
[    3.797387] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
[    3.797479] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    3.797935] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    3.797998] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = esp8089
[    3.798020] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    3.798036] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    3.798057] of_get_named_gpiod_flags: can't parse 'WIFI,poweren_gpio' property of node '/wireless-wlan[0]'
[    3.798078] of_get_named_gpiod_flags: can't parse 'WIFI,vbat_gpio' property of node '/wireless-wlan[0]'
[    3.798098] of_get_named_gpiod_flags: can't parse 'WIFI,reset_gpio' property of node '/wireless-wlan[0]'
[    3.798169] of_get_named_gpiod_flags: parsed 'WIFI,host_wake_irq' property of node '/wireless-wlan[0]' - status (0)
[    3.798190] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 28, flags = 1.
[    3.798220] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    3.798238] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    3.798261] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    3.798853] [BT_RFKILL]: Enter rfkill_rk_init
[    3.800243] Key type dns_resolver registered
[    3.800852] mmc2: new high speed MMC card at address 0001
[    3.802122] flash vendor_init_thread!
[    3.802171] flash vendor storage:20170308 ret = -1
[    3.802303] Error: Driver 'sc031gs' is already registered, aborting...
[    3.802878] mmcblk2: mmc2:0001 P1J95K 7.30 GiB
[    3.804033] mmcblk2boot0: mmc2:0001 P1J95K partition 1 2.00 MiB
[    3.804068] Registering SWP/SWPB emulation handler
[    3.805173] mmcblk2boot1: mmc2:0001 P1J95K partition 2 2.00 MiB
[    3.806255] mmcblk2rpmb: mmc2:0001 P1J95K partition 3 2.00 MiB
[    3.806550] registered taskstats version 1
[    3.806606] Loading compiled-in X.509 certificates
[    3.808801]  mmcblk2: p1
[    3.813658] Btrfs loaded
[    3.816033] rga2: Driver loaded successfully ver:4.01
[    3.816467] rga2: Module initialized.
[    3.816577] pvtm list NULL
[    3.818697] rk-vcodec 20030000.rkvdec: leakage=6
[    3.818756] rk-vcodec 20030000.rkvdec: leakage-volt-sel=1
[    3.818961] rk-vcodec 20030000.rkvdec: Failed to get pvtm
[    3.819707] rk-vcodec 20030000.rkvdec: avs=0
[    3.820245] rk-vcodec 20030000.rkvdec: probe device
[    3.821061] rk-vcodec 20030000.rkvdec: drm allocator with mmu enabled
[    3.823514] rk-vcodec 20030000.rkvdec: init success
[    3.825436] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]'
[    3.825474] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]'
[    3.827361] asoc-simple-card hdmi-sound: i2s-hifi <-> 100c0000.i2s0 mapping ok
[    3.830897] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]'
[    3.830946] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]'
[    3.832709] asoc-simple-card spdif-sound: dit-hifi <-> 100d0000.spdif mapping ok
[    3.834644] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 200000Hz, actual 162760HZ div = 3)
[    3.836756] hctosys: unable to open rtc device (rtc0)
[    3.859132] ALSA device list:
[    3.859178]   #0: DW-I2S-HDMI
[    3.859190]   #1: SPDIF
[    3.860631] Freeing unused kernel memory: 808K
[    3.860654] This architecture does not have kernel memory protection.
[    3.893453] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 100000Hz, actual 97656HZ div = 5)
[    3.966229] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[    3.995942] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[    4.009303] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[    4.013437] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    4.015654] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[    4.015821] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[    4.015955] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[    4.016032] mmc1: new high speed SDIO card at address 0001
[    4.054661] usb 5-1: new full-speed USB device number 2 using ohci-platform
[    4.268714] usb 5-1: New USB device found, idVendor=046d, idProduct=c534
[    4.268771] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.268788] usb 5-1: Product: USB Receiver
[    4.268800] usb 5-1: Manufacturer: Logitech
[    4.282989] input: Logitech USB Receiver as /devices/platform/300a0000.usb/usb5/5-1/5-1:1.0/0003:046D:C534.0001/input/input1
[    4.310866] vendor storage:20190527 ret = 0
[    4.341259] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-300a0000.usb-1/input0
[    4.352171] input: Logitech USB Receiver as /devices/platform/300a0000.usb/usb5/5-1/5-1:1.1/0003:046D:C534.0002/input/input2
[    4.408065] hid-generic 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-300a0000.usb-1/input1
[    5.452268] EXT4-fs (mmcblk2p1): mounted filesystem with writeback data mode. Opts: (null)
[    6.030952] systemd[1]: System time before build time, advancing clock.
[    6.049145] systemd[1]: Inserted module 'autofs4'
[    6.060086] ip_tables: (C) 2000-2006 Netfilter Core Team
[    6.075052] cgroup: cgroup2: unknown option "nsdelegate"
[    6.096413] systemd[1]: systemd 245.4-4ubuntu3.15 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    6.098313] systemd[1]: Detected architecture arm.
[    6.120466] systemd[1]: Set hostname to <rk322x-box>.
[    6.313340] ttyS2 - failed to request DMA, use interrupt mode
[    7.095525] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[    7.095979] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    7.096012] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    7.100230] systemd[1]: Created slice system-modprobe.slice.
[    7.101214] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[    7.103121] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    7.103881] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[    7.105401] systemd[1]: Created slice User and Session Slice.
[    7.106237] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[    7.106807] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.108201] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[    7.109023] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.110260] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[    7.110382] systemd[1]: Reached target Remote File Systems.
[    7.111147] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[    7.111252] systemd[1]: Reached target Slices.
[    7.111842] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[    7.111928] systemd[1]: Reached target Swap.
[    7.112427] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[    7.112510] systemd[1]: Reached target System Time Set.
[    7.113152] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[    7.117794] systemd[1]: Listening on Syslog Socket.
[    7.119752] systemd[1]: Listening on fsck to fsckd communication Socket.
[    7.120981] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    7.130693] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    7.131825] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.133506] systemd[1]: Listening on Journal Socket.
[    7.135261] systemd[1]: Listening on udev Control Socket.
[    7.136641] systemd[1]: Listening on udev Kernel Socket.
[    7.138006] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    7.144306] systemd[1]: Mounting POSIX Message Queue File System...
[    7.154326] systemd[1]: Mounting Kernel Debug File System...
[    7.165215] systemd[1]: Mounting Kernel Trace File System...
[    7.178066] systemd[1]: Starting Restore / save the current clock...
[    7.188500] systemd[1]: Starting Set the console keyboard layout...
[    7.203596] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    7.205334] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[    7.220730] systemd[1]: Started Nameserver information manager.
[    7.239277] systemd[1]: Reached target Network (Pre).
[    7.244115] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    7.244522] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    7.260411] systemd[1]: Starting Load Kernel Modules...
[    7.274035] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.289877] systemd[1]: Starting udev Coldplug all Devices...
[    7.309293] systemd[1]: Mounted POSIX Message Queue File System.
[    7.313204] systemd[1]: Mounted Kernel Debug File System.
[    7.317359] systemd[1]: Mounted Kernel Trace File System.
[    7.325769] systemd[1]: Finished Restore / save the current clock.
[    7.333894] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    7.341995] EXT4-fs (mmcblk2p1): re-mounted. Opts: commit=600,errors=remount-ro
[    7.357170] systemd[1]: Finished Load Kernel Modules.
[    7.362080] systemd[1]: Finished Remount Root and Kernel File Systems.
[    7.365107] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    7.372295] systemd[1]: Mounting Kernel Configuration File System...
[    7.375854] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    7.376565] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    7.385574] systemd[1]: Starting Load/Save Random Seed...
[    7.396488] systemd[1]: Starting Apply Kernel Variables...
[    7.412236] systemd[1]: Starting Create System Users...
[    7.436450] systemd[1]: Mounted Kernel Configuration File System.
[    7.500022] systemd[1]: Finished Apply Kernel Variables.
[    7.504283] systemd[1]: Finished Create System Users.
[    7.512642] systemd[1]: Starting Create Static Device Nodes in /dev...
[    7.587078] systemd[1]: Finished Create Static Device Nodes in /dev.
[    7.595294] systemd[1]: Starting udev Kernel Device Manager...
[    7.636346] systemd[1]: Finished Set the console keyboard layout.
[    7.638645] systemd[1]: Reached target Local File Systems (Pre).
[    7.648971] systemd[1]: Mounting /tmp...
[    7.672849] systemd[1]: Mounted /tmp.
[    7.675580] systemd[1]: Reached target Local File Systems.
[    7.685524] systemd[1]: Starting Armbian ZRAM config...
[    7.707848] systemd[1]: Starting Set console font and keymap...
[    7.732513] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    7.743485] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    7.778985] systemd[1]: Finished Set console font and keymap.
[    7.793173] systemd[1]: plymouth-read-write.service: Succeeded.
[    7.796778] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    7.963868] systemd[1]: Finished udev Coldplug all Devices.
[    7.983957] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[    7.996851] systemd[1]: Started udev Kernel Device Manager.
[    8.024278] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[    8.024661] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[    8.024969] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[    8.025404] systemd[1]: Reached target Local Encrypted Volumes.
[    8.072194] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[    8.097175] systemd[1]: Starting Raise network interfaces...
[    8.231965] zram: Added device: zram0
[    8.234782] zram: Added device: zram1
[    8.240224] zram: Added device: zram2
[    8.613324] rk3228-codec 12010000.codec: GPIO lookup for consumer spk-en
[    8.613363] rk3228-codec 12010000.codec: using device tree for GPIO lookup
[    8.613386] of_get_named_gpiod_flags: can't parse 'spk-en-gpios' property of node '/codec@12010000[0]'
[    8.613430] of_get_named_gpiod_flags: parsed 'spk-en-gpio' property of node '/codec@12010000[0]' - status (0)
[    8.613502] rk3228-codec 12010000.codec: spk_depop_time use default value.
[    8.614926] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]'
[    8.614971] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]'
[    8.626172] systemd[1]: Found device /dev/ttyS2.
[    8.631072] zram0: detected capacity change from 0 to 504537088
[    8.653625] asoc-simple-card sound: rk3228-hifi <-> 100b0000.i2s1 mapping ok
[    8.677192] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '20:09:06', on 'Aug 25 2021'.
[    8.677566] mali-utgard 20001000.gpu: mali_platform_device->num_resources = 13
[    8.677593] mali-utgard 20001000.gpu: resource[0].start = 0x0x20001000
[    8.677606] mali-utgard 20001000.gpu: resource[1].start = 0x0x20000000
[    8.677617] mali-utgard 20001000.gpu: resource[2].start = 0x0x20003000
[    8.677628] mali-utgard 20001000.gpu: resource[3].start = 0x0x20008000
[    8.677639] mali-utgard 20001000.gpu: resource[4].start = 0x0x20004000
[    8.677650] mali-utgard 20001000.gpu: resource[5].start = 0x0x2000a000
[    8.677661] mali-utgard 20001000.gpu: resource[6].start = 0x0x20005000
[    8.677672] mali-utgard 20001000.gpu: resource[7].start = 0x0x00000020
[    8.677682] mali-utgard 20001000.gpu: resource[8].start = 0x0x00000021
[    8.677694] mali-utgard 20001000.gpu: resource[9].start = 0x0x00000022
[    8.677705] mali-utgard 20001000.gpu: resource[10].start = 0x0x00000021
[    8.677764] mali-utgard 20001000.gpu: resource[11].start = 0x0x00000022
[    8.677774] mali-utgard 20001000.gpu: resource[12].start = 0x0x00000021
[    8.677787] D : [File] : drivers/gpu/arm/mali400/mali/platform/rk/rk.c; [Line] : 623; [Func] : mali_platform_device_init(); to add platform_specific_data to platform_device_of_mali.
[    8.679554] cfg80211: World regulatory domain updated:
[    8.679610] cfg80211:  DFS Master region: unset
[    8.679624] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    8.679643] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    8.679658] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    8.679669] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[    8.679683] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    8.679696] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[    8.679709] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[    8.679719] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[    8.679731] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[    8.680329] mali-utgard 20001000.gpu: leakage=6
[    8.680384] mali-utgard 20001000.gpu: leakage-volt-sel=1
[    8.680644] mali-utgard 20001000.gpu: Failed to get pvtm
[    8.684422] mali-utgard 20001000.gpu: avs=0
[    8.685025] mali-utgard 20001000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    8.697492] Mali: Mali device driver loaded
[    8.782725] devfreq 20001000.gpu: Couldn't update frequency transition information.
[    9.129414] gpio_ir_recv ir-receiver: GPIO lookup for consumer (null)
[    9.129460] gpio_ir_recv ir-receiver: using device tree for GPIO lookup
[    9.129538] of_get_named_gpiod_flags: parsed 'gpios' property of node '/ir-receiver[0]' - status (0)
[    9.129706] Registered IR keymap rc-rktvbox
[    9.131913] rc rc1: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1
[    9.134419] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1/input3
[    9.187420] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[    9.193554] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[    9.193588] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[    9.193602] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[    9.193613] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[    9.193623] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[    9.193634] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[    9.193644] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[    9.193654] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[    9.193664] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[    9.193674] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[    9.193685] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[    9.193695] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[    9.193705] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[    9.193715] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[    9.193726] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
[    9.262807] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    9.264779] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    9.266358] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    9.302382] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    9.341894] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[    9.342589] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[    9.343086] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[    9.344408] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    9.345220] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    9.345850] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    9.346332] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    9.382220] systemd[1]: plymouth-read-write.service: Succeeded.
[    9.403331] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    9.474030] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    9.477154] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    9.478956] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    9.494985] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    9.518840] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[    9.519524] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[    9.525436] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[    9.526703] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    9.531043] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    9.531960] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    9.536786] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    9.592446] systemd[1]: plymouth-read-write.service: Succeeded.
[    9.601381] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    9.677117] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    9.678314] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[    9.714999] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    9.716835] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    9.740168] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    9.787537] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[    9.788027] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[    9.788345] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[    9.789372] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    9.790071] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    9.793446] Adding 492708k swap on /dev/zram0.  Priority:5 extents:1 across:492708k SS
[    9.795176] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    9.795636] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    9.835781] mmc1: card 0001 removed
[    9.859047] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 400000Hz, actual 244140HZ div = 2)
[    9.885694] systemd[1]: plymouth-read-write.service: Succeeded.
[    9.914886] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 300000Hz, actual 244140HZ div = 2)
[    9.925546] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    9.966823] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 200000Hz, actual 162760HZ div = 3)
[   10.022862] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 100000Hz, actual 97656HZ div = 5)
[   10.095537] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[   10.147571] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[   10.151902] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   10.154231] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   10.165783] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[   10.175770] random: nonblocking pool is initialized
[   10.181124] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[   10.181888] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   10.185856] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[   10.188516] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[   10.188657] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[   10.188744] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[   10.188807] mmc1: new high speed SDIO card at address 0001
[   10.238003] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[   10.246936] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   10.247514] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[   10.248987] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   10.249864] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   10.257013] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   10.257930] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[   10.280287] systemd[1]: Finished Load/Save Random Seed.
[   10.394956] systemd[1]: plymouth-read-write.service: Succeeded.
[   10.413446] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[   10.436684] systemd[1]: Finished Raise network interfaces.
[   10.474021] zram1: detected capacity change from 0 to 52428800
[   10.477968] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   10.578128] systemd[1]: Finished Armbian ZRAM config.
[   10.593857] systemd[1]: Starting Armbian memory supported logging...
[   10.675229] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   10.747856] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
[   10.771261] systemd[1]: Started Load/Save RF Kill Switch Status.
[   15.501754] systemd[1]: Finished Armbian memory supported logging.
[   15.513888] systemd[1]: Starting Journal Service...
[   15.771205] systemd[1]: systemd-rfkill.service: Succeeded.
[   16.092346] systemd[1]: Started Journal Service.
[   16.154737] systemd-journald[669]: Received client request to flush runtime journal.
[   17.593832] nr_pdflush_threads exported in /proc is scheduled for removal
[   40.611192] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   40.785981] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   40.792745] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   41.234239] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   42.675064] rk_gmac-dwmac 30200000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[   43.847905] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   43.847989] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   43.848042] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   43.848077] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   43.848102] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   43.848130] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[  159.114042] wlan0: authenticate with 04:95:e6:a5:1d:c1
[  159.119166] wlan0: send auth to 04:95:e6:a5:1d:c1 (try 1/3)
[  159.121875] wlan0: authenticated
[  159.146401] wlan0: associate with 04:95:e6:a5:1d:c1 (try 1/3)
[  159.151094] wlan0: RX AssocResp from 04:95:e6:a5:1d:c1 (capab=0x411 status=0 aid=3)
[  159.151404] wlan0: associated
[  159.152134] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  170.678408] rk_gmac-dwmac 30200000.ethernet eth0: Link is Down
Here's one of the 21 other dmesgs I captured when testing the different combinations. They all look similar, but if we need to, I have all of them dafely stored here.
Every test had one of 2 possile outcomes: either the ESP8089 was detected and the wlan connection existed on the ifconfig but no networks were visible, or it wasn't detected at all and no wlan connection even existed.
For this one, the ESP8089 was detected and the wlan was there.
  Reveal hidden contents
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.194-rk322x (root@runner7) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #2 SMP Wed Aug 25 20:09:42 UTC 2021
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Generic RK322x TV Box board
[    0.000000] cma: Reserved 16 MiB at 0x9f000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 253952
[    0.000000] free_area_init_node: node 0, pgdat b1253b40, node_mem_map ee6f1000
[    0.000000]   Normal zone: 2304 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 253952 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv65535.65535 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] PERCPU: Embedded 14 pages/cpu @ee68f000 s24856 r8192 d24296 u57344
[    0.000000] pcpu-alloc: s24856 r8192 d24296 u57344 alloc=14*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 251648
[    0.000000] Kernel command line: earlyprintk root=UUID=bce0e15e-76b7-4f9c-9149-332bcfd83573 console=ttyS2,115200n8 console=tty1 rootwait rootfstype=ext4  consoleblank=0 loglevel=1 ubootpart=343a1e5a-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u coherent_pool=2M  cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 960640K/1015808K available (12862K kernel code, 919K rwdata, 3240K rodata, 808K init, 1219K bss, 38784K reserved, 16384K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                   lowmem  : 0xb0000000 - 0xf0000000   (1024 MB)
                   pkmap   : 0xafe00000 - 0xb0000000   (   2 MB)
                   modules : 0xaf000000 - 0xafe00000   (  14 MB)
                     .text : 0xb0008000 - 0xb0c97c6c   (12864 kB)
                     .init : 0xb10b0000 - 0xb117a000   ( 808 kB)
                     .data : 0xb117a000 - 0xb125fe94   ( 920 kB)
                      .bss : 0xb1261000 - 0xb1391f14   (1220 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]     Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000024] Switching to timer-based delay loop, resolution 41ns
[    0.001859] Console: colour dummy device 80x30
[    0.002049] console [tty1] enabled
[    0.002079] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.002098] pid_max: default: 32768 minimum: 301
[    0.002241] Security Framework initialized
[    0.002256] Yama: becoming mindful.
[    0.002341] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002358] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.003357] Initializing cgroup subsys io
[    0.003397] Initializing cgroup subsys memory
[    0.003443] Initializing cgroup subsys devices
[    0.003465] Initializing cgroup subsys freezer
[    0.003485] Initializing cgroup subsys net_cls
[    0.003503] Initializing cgroup subsys perf_event
[    0.003521] Initializing cgroup subsys net_prio
[    0.003553] Initializing cgroup subsys pids
[    0.003716] CPU: Testing write buffer coherency: ok
[    0.003776] ftrace: allocating 41892 entries in 123 pages
[    0.086461] /cpus/cpu@f00 missing clock-frequency property
[    0.086502] /cpus/cpu@f01 missing clock-frequency property
[    0.086521] /cpus/cpu@f02 missing clock-frequency property
[    0.086542] /cpus/cpu@f03 missing clock-frequency property
[    0.086557] CPU0: update cpu_capacity 430
[    0.086568] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.086668] Setting up static identity map for 0x60008280 - 0x600082d8
[    0.089943] CPU1: update cpu_capacity 430
[    0.089954] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.091195] CPU2: update cpu_capacity 430
[    0.091204] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.092420] CPU3: update cpu_capacity 430
[    0.092429] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.092587] Brought up 4 CPUs
[    0.092630] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.092638] CPU: All CPU(s) started in SVC mode.
[    0.094368] devtmpfs: initialized
[    0.114776] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.115382] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.115431] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.116958] xor: measuring software checksum speed
[    0.154361]    arm4regs  :  1011.000 MB/sec
[    0.194464]    8regs     :   705.000 MB/sec
[    0.234565]    32regs    :   684.000 MB/sec
[    0.274667]    neon      :  1018.000 MB/sec
[    0.274677] xor: using function: neon (1018.000 MB/sec)
[    0.274726] pinctrl core: initialized pinctrl subsystem
[    0.276493] NET: Registered protocol family 16
[    0.279161] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.290850] cpuidle: using governor ladder
[    0.302861] cpuidle: using governor menu
[    0.320383] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0
[    0.320566] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1
[    0.320721] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2
[    0.320896] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3
[    0.328025] console [pstore-1] enabled
[    0.328038] pstore: Registered ramoops as persistent store backend
[    0.328050] ramoops: attached 0xf0000@0x62e00000, ecc: 0/0
[    0.331537] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.331560] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.431980] raid6: int32x1  gen()   133 MB/s
[    0.500015] raid6: int32x1  xor()   131 MB/s
[    0.568223] raid6: int32x2  gen()   166 MB/s
[    0.636274] raid6: int32x2  xor()   136 MB/s
[    0.704638] raid6: int32x4  gen()   163 MB/s
[    0.772822] raid6: int32x4  xor()   137 MB/s
[    0.841045] raid6: int32x8  gen()   166 MB/s
[    0.909301] raid6: int32x8  xor()   113 MB/s
[    0.977440] raid6: neonx1   gen()   382 MB/s
[    1.045552] raid6: neonx1   xor()   290 MB/s
[    1.113770] raid6: neonx2   gen()   519 MB/s
[    1.181908] raid6: neonx2   xor()   376 MB/s
[    1.250154] raid6: neonx4   gen()   581 MB/s
[    1.318335] raid6: neonx4   xor()   400 MB/s
[    1.386588] raid6: neonx8   gen()   559 MB/s
[    1.454798] raid6: neonx8   xor()   391 MB/s
[    1.454810] raid6: using algorithm neonx4 gen() 581 MB/s
[    1.454820] raid6: .... xor() 400 MB/s, rmw enabled
[    1.454831] raid6: using intx1 recovery algorithm
[    1.455993] rockchip-pm rockchip-suspend: not set wakeup-config
[    1.456018] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    1.456449] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@0[0]'
[    1.457009] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@1[0]'
[    1.457720] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-host-regulator[0]' - status (0)
[    1.458376] of_get_named_gpiod_flags: parsed 'gpio' property of node '/otg-vbus-regulator[0]' - status (0)
[    1.459001] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]'
[    1.459942] iommu: Adding device 20020000.vpu-service to group 0
[    1.460060] iommu: Adding device 20030000.rkvdec to group 1
[    1.460177] iommu: Adding device 20050000.vop to group 2
[    1.460278] iommu: Adding device 20070000.iep to group 3
[    1.460876] rk_iommu 20020800.iommu: can't get sclk
[    1.461604] rk_iommu 20030480.iommu: can't get sclk
[    1.461874] rk_iommu 20053f00.iommu: can't get sclk
[    1.462024] rk_iommu 20070800.iommu: can't get aclk
[    1.462045] rk_iommu 20070800.iommu: can't get hclk
[    1.462061] rk_iommu 20070800.iommu: can't get sclk
[    1.462995] SCSI subsystem initialized
[    1.463462] usbcore: registered new interface driver usbfs
[    1.463567] usbcore: registered new interface driver hub
[    1.463708] usbcore: registered new device driver usb
[    1.463942] media: Linux media interface: v0.10
[    1.464027] Linux video capture interface: v2.00
[    1.464295] pps_core: LinuxPPS API ver. 1 registered
[    1.464312] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.464355] PTP clock support registered
[    1.466570] Advanced Linux Sound Architecture Driver Initialized.
[    1.467739] Bluetooth: Core ver 2.21
[    1.467822] NET: Registered protocol family 31
[    1.467837] Bluetooth: HCI device and connection manager initialized
[    1.467859] Bluetooth: HCI socket layer initialized
[    1.467877] Bluetooth: L2CAP socket layer initialized
[    1.467937] Bluetooth: SCO socket layer initialized
[    1.468878] NetLabel: Initializing
[    1.468902] NetLabel:  domain hash size = 128
[    1.468912] NetLabel:  protocols = UNLABELED CIPSOv4
[    1.468995] NetLabel:  unlabeled traffic allowed by default
[    1.470509] clocksource: Switched to clocksource arch_sys_counter
[    1.571630] NET: Registered protocol family 2
[    1.572602] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    1.572726] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[    1.573082] TCP: Hash tables configured (established 8192 bind 8192)
[    1.573184] UDP hash table entries: 512 (order: 2, 24576 bytes)
[    1.573255] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[    1.573654] NET: Registered protocol family 1
[    1.574464] RPC: Registered named UNIX socket transport module.
[    1.574586] RPC: Registered udp transport module.
[    1.574601] RPC: Registered tcp transport module.
[    1.574612] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.574992] Trying to unpack rootfs image as initramfs...
[    2.114391] Freeing initrd memory: 7588K
[    2.115585] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    2.118811] Initialise system trusted keyring
[    2.133243] VFS: Disk quotas dquot_6.6.0
[    2.133584] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    2.136476] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.140153] NFS: Registering the id_resolver key type
[    2.140252] Key type id_resolver registered
[    2.140265] Key type id_legacy registered
[    2.140303] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.140423] ntfs: driver 2.1.32 [Flags: R/W].
[    2.141418] JFS: nTxBlock = 7692, nTxLock = 61538
[    2.152707] SGI XFS with security attributes, no debug enabled
[    2.162674] NET: Registered protocol family 38
[    2.162738] Key type asymmetric registered
[    2.162760] Asymmetric key parser 'x509' registered
[    2.163209] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    2.163725] io scheduler noop registered
[    2.163758] io scheduler deadline registered
[    2.163856] io scheduler cfq registered (default)
[    2.167524] phy phy-11000000.syscon:usb2-phy@800.2: Failed to get VBUS supply regulator
[    2.173228] rk-vcodec 20020000.vpu-service: no regulator for vcodec
[    2.173722] rk-vcodec 20020000.vpu-service: probe device
[    2.174194] rk-vcodec 20020000.vpu-service: drm allocator with mmu enabled
[    2.175729] rk-vcodec 20020000.vpu-service: could not find power_model node
[    2.175759] rk-vcodec 20020000.vpu-service: init success
[    2.176147] rk-vcodec 20030000.rkvdec: vcodec regulator not ready, retry
[    2.180700] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-241330
[    2.180733] dma-pl330 110f0000.pdma:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    2.182005] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    2.182610] pwm-regulator vdd-arm-regulator: GPIO lookup for consumer enable
[    2.182634] pwm-regulator vdd-arm-regulator: using device tree for GPIO lookup
[    2.182652] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-arm-regulator[0]'
[    2.182667] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-arm-regulator[0]'
[    2.182681] pwm-regulator vdd-arm-regulator: using lookup tables for GPIO lookup
[    2.182697] pwm-regulator vdd-arm-regulator: lookup for GPIO enable failed
[    2.183444] pwm-regulator vdd-log-regulator: GPIO lookup for consumer enable
[    2.183468] pwm-regulator vdd-log-regulator: using device tree for GPIO lookup
[    2.183485] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log-regulator[0]'
[    2.183500] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log-regulator[0]'
[    2.183514] pwm-regulator vdd-log-regulator: using lookup tables for GPIO lookup
[    2.183530] pwm-regulator vdd-log-regulator: lookup for GPIO enable failed
[    2.184682] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.185621] 11030000.serial: ttyS2 at MMIO 0x11030000 (irq = 30, base_baud = 1500000) is a 16550A
[    2.186553] console [ttyS2] enabled
[    2.188631] [drm] Initialized drm 1.1.0 20060810
[    2.191333] [drm] Rockchip DRM driver version: v1.0.1
[    2.191632] rockchip-drm display-subsystem: devfreq is not set
[    2.192472] rockchip-drm display-subsystem: bound 20050000.vop (ops 0xb0d1b2b0)
[    2.192931] i2c i2c-0: of_i2c: modalias failure on /hdmi@200a0000/ports
[    2.192962] dwhdmi-rockchip 200a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.193088] dwhdmi-rockchip 200a0000.hdmi: Detected HDMI TX controller v2.01a with HDCP (inno_dw_hdmi_phy)
[    2.194644] rockchip-drm display-subsystem: bound 200a0000.hdmi (ops 0xb0d13808)
[    2.194677] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.194688] [drm] No driver support for vblank timestamp query.
[    2.194831] rockchip-drm display-subsystem: failed to parse display resources
[    2.817314] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[    2.822842] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[    2.822851] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[    2.822858] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[    2.822865] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[    2.822871] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[    2.822878] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[    2.822885] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[    2.822891] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[    2.822898] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[    2.822905] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[    2.822911] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[    2.822918] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[    2.822924] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[    2.822930] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[    2.822938] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
[    2.894805] Console: switching to colour frame buffer device 240x67
[    2.944930] rockchip-drm display-subsystem: fb0:  frame buffer device
[    2.960358] Registered IR keymap rc-cec
[    2.960663] rc rc0: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0
[    2.961360] input: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0/input0
[    2.964290] brd: module loaded
[    2.978691] loop: module loaded
[    2.978803] lkdtm: No crash points registered, enable through debugfs
[    2.981961] libphy: Fixed MDIO Bus: probed
[    2.982007] tun: Universal TUN/TAP device driver, 1.6
[    2.982022] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.982637] CAN device driver interface
[    2.984426] rk_gmac-dwmac 30200000.ethernet: clock input or output? (output).
[    2.984460] rk_gmac-dwmac 30200000.ethernet: TX delay(0x30).
[    2.984476] rk_gmac-dwmac 30200000.ethernet: RX delay(0x10).
[    2.984524] rk_gmac-dwmac 30200000.ethernet: integrated PHY? (yes).
[    2.984704] rk_gmac-dwmac 30200000.ethernet: cannot get clock clk_mac_speed
[    2.989790] rk_gmac-dwmac 30200000.ethernet: init for RMII
[    3.022761] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    3.022781]  Ring mode enabled
[    3.022794]  DMA HW capability register supported
[    3.022807]  Normal descriptors
[    3.022822]  RX Checksum Offload Engine supported (type 2)
[    3.022834]  TX Checksum insertion supported
[    3.022843]  Wake-Up On Lan supported
[    3.022964] rk_gmac-dwmac 30200000.ethernet: rk_get_eth_addr: mac address: 4e:29:f7:d4:13:43
[    3.022982] eth%d: device MAC address 4e:29:f7:d4:13:43
[    3.022993]  Enable RX Mitigation via HW Watchdog Timer
[    3.023282] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@30200000[0]' - status (0)
[    3.461647] libphy: stmmac: probed
[    3.461692] eth%d: PHY ID 1234d400 at 0 IRQ POLL (stmmac-0:00) active
[    3.461708] eth%d: PHY ID 00000000 at 1 IRQ POLL (stmmac-0:01)
[    3.461722] eth%d: PHY ID 00000000 at 2 IRQ POLL (stmmac-0:02)
[    3.461737] eth%d: PHY ID 00000000 at 3 IRQ POLL (stmmac-0:03)
[    3.461752] eth%d: PHY ID 00000000 at 4 IRQ POLL (stmmac-0:04)
[    3.461766] eth%d: PHY ID 00000000 at 5 IRQ POLL (stmmac-0:05)
[    3.461780] eth%d: PHY ID 00000000 at 6 IRQ POLL (stmmac-0:06)
[    3.461795] eth%d: PHY ID 00000000 at 7 IRQ POLL (stmmac-0:07)
[    3.461810] eth%d: PHY ID 00000000 at 8 IRQ POLL (stmmac-0:08)
[    3.461825] eth%d: PHY ID 00000000 at 9 IRQ POLL (stmmac-0:09)
[    3.461840] eth%d: PHY ID 00000000 at 10 IRQ POLL (stmmac-0:0a)
[    3.461854] eth%d: PHY ID 00000000 at 11 IRQ POLL (stmmac-0:0b)
[    3.461869] eth%d: PHY ID 00000000 at 12 IRQ POLL (stmmac-0:0c)
[    3.461884] eth%d: PHY ID 00000000 at 13 IRQ POLL (stmmac-0:0d)
[    3.461899] eth%d: PHY ID 00000000 at 14 IRQ POLL (stmmac-0:0e)
[    3.461914] eth%d: PHY ID 00000000 at 15 IRQ POLL (stmmac-0:0f)
[    3.461929] eth%d: PHY ID 00000000 at 16 IRQ POLL (stmmac-0:10)
[    3.461943] eth%d: PHY ID 00000000 at 17 IRQ POLL (stmmac-0:11)
[    3.461958] eth%d: PHY ID 00000000 at 18 IRQ POLL (stmmac-0:12)
[    3.461973] eth%d: PHY ID 00000000 at 19 IRQ POLL (stmmac-0:13)
[    3.461987] eth%d: PHY ID 00000000 at 20 IRQ POLL (stmmac-0:14)
[    3.462003] eth%d: PHY ID 00000000 at 21 IRQ POLL (stmmac-0:15)
[    3.462016] eth%d: PHY ID 00000000 at 22 IRQ POLL (stmmac-0:16)
[    3.462029] eth%d: PHY ID 00000000 at 23 IRQ POLL (stmmac-0:17)
[    3.462042] eth%d: PHY ID 00000000 at 24 IRQ POLL (stmmac-0:18)
[    3.462055] eth%d: PHY ID 00000000 at 25 IRQ POLL (stmmac-0:19)
[    3.462069] eth%d: PHY ID 00000000 at 26 IRQ POLL (stmmac-0:1a)
[    3.462084] eth%d: PHY ID 00000000 at 27 IRQ POLL (stmmac-0:1b)
[    3.462099] eth%d: PHY ID 00000000 at 28 IRQ POLL (stmmac-0:1c)
[    3.462113] eth%d: PHY ID 00000000 at 29 IRQ POLL (stmmac-0:1d)
[    3.462128] eth%d: PHY ID 00000000 at 30 IRQ POLL (stmmac-0:1e)
[    3.462143] eth%d: PHY ID 00000000 at 31 IRQ POLL (stmmac-0:1f)
[    3.464053] PPP generic driver version 2.4.2
[    3.464629] Atmel at76x USB Wireless LAN Driver 0.17 loading
[    3.464807] usbcore: registered new interface driver at76c50x-usb
[    3.464969] usbcore: registered new interface driver rtl8187
[    3.465100] usbcore: registered new interface driver rndis_wlan
[    3.465207] usbcore: registered new interface driver zd1201
[    3.465803] usbcore: registered new interface driver rt2800usb
[    3.465963] Rockchip WiFi SYS interface (V1.00) ...
[    3.466052] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    3.466167] usbcore: registered new interface driver pegasus
[    3.466269] usbcore: registered new interface driver rtl8150
[    3.466363] usbcore: registered new interface driver r8152
[    3.466574] usbcore: registered new interface driver asix
[    3.466708] usbcore: registered new interface driver ax88179_178a
[    3.466805] usbcore: registered new interface driver cdc_ether
[    3.466941] usbcore: registered new interface driver dm9601
[    3.467084] usbcore: registered new interface driver smsc75xx
[    3.467204] usbcore: registered new interface driver smsc95xx
[    3.467296] usbcore: registered new interface driver net1080
[    3.467389] usbcore: registered new interface driver rndis_host
[    3.467473] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    3.467651] usbcore: registered new interface driver cdc_ncm
[    3.467757] usbcore: registered new interface driver cdc_mbim
[    3.468366] 30040000.usb supply vusb_d not found, using dummy regulator
[    3.468510] 30040000.usb supply vusb_a not found, using dummy regulator
[    3.482173] dwc2 30040000.usb: DWC OTG Controller
[    3.482246] dwc2 30040000.usb: new USB bus registered, assigned bus number 1
[    3.482330] dwc2 30040000.usb: irq 49, io mem 0x30040000
[    3.482868] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.482896] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.482914] usb usb1: Product: DWC OTG Controller
[    3.482930] usb usb1: Manufacturer: Linux 4.4.194-rk322x dwc2_hsotg
[    3.482944] usb usb1: SerialNumber: 30040000.usb
[    3.484283] hub 1-0:1.0: USB hub found
[    3.484370] hub 1-0:1.0: 1 port detected
[    3.486261] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.486303] ehci-platform: EHCI generic platform driver
[    3.489163] ehci-platform 30080000.usb: EHCI Host Controller
[    3.489653] ehci-platform 30080000.usb: new USB bus registered, assigned bus number 2
[    3.490081] ehci-platform 30080000.usb: irq 50, io mem 0x30080000
[    3.498568] ehci-platform 30080000.usb: USB 2.0 started, EHCI 1.00
[    3.498957] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    3.498980] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.498997] usb usb2: Product: EHCI Host Controller
[    3.499013] usb usb2: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    3.499026] usb usb2: SerialNumber: 30080000.usb
[    3.500299] hub 2-0:1.0: USB hub found
[    3.500396] hub 2-0:1.0: 1 port detected
[    3.503536] ehci-platform 300c0000.usb: EHCI Host Controller
[    3.504131] ehci-platform 300c0000.usb: new USB bus registered, assigned bus number 3
[    3.504551] ehci-platform 300c0000.usb: irq 52, io mem 0x300c0000
[    3.514561] ehci-platform 300c0000.usb: USB 2.0 started, EHCI 1.00
[    3.514939] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    3.514963] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.514980] usb usb3: Product: EHCI Host Controller
[    3.514997] usb usb3: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    3.515013] usb usb3: SerialNumber: 300c0000.usb
[    3.516275] hub 3-0:1.0: USB hub found
[    3.516365] hub 3-0:1.0: 1 port detected
[    3.519530] ehci-platform 30100000.usb: EHCI Host Controller
[    3.520110] ehci-platform 30100000.usb: new USB bus registered, assigned bus number 4
[    3.520533] ehci-platform 30100000.usb: irq 54, io mem 0x30100000
[    3.530568] ehci-platform 30100000.usb: USB 2.0 started, EHCI 1.00
[    3.530995] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    3.531019] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.531034] usb usb4: Product: EHCI Host Controller
[    3.531049] usb usb4: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    3.531063] usb usb4: SerialNumber: 30100000.usb
[    3.532303] hub 4-0:1.0: USB hub found
[    3.532399] hub 4-0:1.0: 1 port detected
[    3.533415] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.533478] ohci-platform: OHCI generic platform driver
[    3.534064] ohci-platform 300a0000.usb: Generic Platform OHCI controller
[    3.534585] ohci-platform 300a0000.usb: new USB bus registered, assigned bus number 5
[    3.534916] ohci-platform 300a0000.usb: irq 51, io mem 0x300a0000
[    3.594860] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    3.594888] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.594903] usb usb5: Product: Generic Platform OHCI controller
[    3.594917] usb usb5: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    3.594931] usb usb5: SerialNumber: 300a0000.usb
[    3.596206] hub 5-0:1.0: USB hub found
[    3.596300] hub 5-0:1.0: 1 port detected
[    3.597398] ohci-platform 300e0000.usb: Generic Platform OHCI controller
[    3.597867] ohci-platform 300e0000.usb: new USB bus registered, assigned bus number 6
[    3.598291] ohci-platform 300e0000.usb: irq 53, io mem 0x300e0000
[    3.654851] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    3.654881] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.654898] usb usb6: Product: Generic Platform OHCI controller
[    3.654915] usb usb6: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    3.654929] usb usb6: SerialNumber: 300e0000.usb
[    3.656183] hub 6-0:1.0: USB hub found
[    3.656286] hub 6-0:1.0: 1 port detected
[    3.657323] ohci-platform 30120000.usb: Generic Platform OHCI controller
[    3.657841] ohci-platform 30120000.usb: new USB bus registered, assigned bus number 7
[    3.658202] ohci-platform 30120000.usb: irq 55, io mem 0x30120000
[    3.714858] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    3.714892] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.714909] usb usb7: Product: Generic Platform OHCI controller
[    3.714923] usb usb7: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    3.714938] usb usb7: SerialNumber: 30120000.usb
[    3.716206] hub 7-0:1.0: USB hub found
[    3.716316] hub 7-0:1.0: 1 port detected
[    3.717662] usbcore: registered new interface driver cdc_acm
[    3.717686] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    3.717808] usbcore: registered new interface driver cdc_wdm
[    3.718113] usbcore: registered new interface driver usb-storage
[    3.718341] usbcore: registered new interface driver usbserial
[    3.718439] usbcore: registered new interface driver usbserial_generic
[    3.718636] usbserial: USB Serial support registered for generic
[    3.718803] usbcore: registered new interface driver keyspan
[    3.718877] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    3.718950] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    3.719016] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    3.719084] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    3.719221] usbcore: registered new interface driver option
[    3.719295] usbserial: USB Serial support registered for GSM modem (1-port)
[    3.720042] usbcore: registered new interface driver oti6858
[    3.720127] usbserial: USB Serial support registered for oti6858
[    3.720255] usbcore: registered new interface driver qcserial
[    3.720344] usbserial: USB Serial support registered for Qualcomm USB modem
[    3.720523] usbcore: registered new interface driver sierra
[    3.720597] usbserial: USB Serial support registered for Sierra USB modem
[    3.722674] usbcore: registered new interface driver iforce
[    3.722892] usbcore: registered new interface driver xpad
[    3.723194] usbcore: registered new interface driver usbtouchscreen
[    3.724689] i2c /dev entries driver
[    3.727042] IR NEC protocol handler initialized
[    3.727076] IR RC5(x/sz) protocol handler initialized
[    3.727099] IR RC6 protocol handler initialized
[    3.727117] IR JVC protocol handler initialized
[    3.727137] IR Sony protocol handler initialized
[    3.727157] IR SANYO protocol handler initialized
[    3.727175] IR Sharp protocol handler initialized
[    3.727193] IR MCE Keyboard/mouse protocol handler initialized
[    3.727213] IR XMP protocol handler initialized
[    3.729224] usbcore: registered new interface driver uvcvideo
[    3.729248] USB Video Class driver (1.1.1)
[    3.731784] Boot mode: normal
[    3.733428] rockchip-thermal 11150000.tsadc: tsadc is probed successfully!
[    3.735505] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    3.735984] Bluetooth: Virtual HCI driver ver 1.5
[    3.736362] Bluetooth: HCI UART driver ver 2.3
[    3.736385] Bluetooth: HCI UART protocol H4 registered
[    3.736397] Bluetooth: HCI UART protocol LL registered
[    3.736408] Bluetooth: HCI UART protocol ATH3K registered
[    3.736421] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    3.736660] Bluetooth: HCI UART protocol BCM registered
[    3.736857] usbcore: registered new interface driver bfusb
[    3.737019] usbcore: registered new interface driver btusb
[    3.737044] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    3.737880] cpu cpu0: leakage=9
[    3.737924] cpu cpu0: leakage-volt-sel=1
[    3.738195] cpu cpu0: Failed to get pvtm
[    3.740186] cpu cpu0: avs=0
[    3.740317] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    3.740351] cpu cpu0: failed to read out thermal zone (-22)
[    3.741219] cpu cpu0: failed to find power_model node
[    3.742204] pwrseq_simple sdio-pwrseq: GPIO lookup for consumer reset
[    3.742233] pwrseq_simple sdio-pwrseq: using device tree for GPIO lookup
[    3.742262] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[0]' - status (0)
[    3.742903] Synopsys Designware Multimedia Card Interface Driver
[    3.743751] dwmmc_rockchip 30000000.dwmmc: IDMAC supports 32-bit address mode.
[    3.743949] dwmmc_rockchip 30000000.dwmmc: Using internal DMA controller.
[    3.743978] dwmmc_rockchip 30000000.dwmmc: Version ID is 270a
[    3.744078] dwmmc_rockchip 30000000.dwmmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo
[    3.744155] dwmmc_rockchip 30000000.dwmmc: No vmmc regulator found
[    3.744168] dwmmc_rockchip 30000000.dwmmc: No vqmmc regulator found
[    3.744196] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer cd
[    3.744207] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    3.744244] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/dwmmc@30000000[0]' - status (0)
[    3.744299] gpio-49 (cd): gpiod_set_debounce: missing set() or set_debounce() operations
[    3.744314] dwmmc_rockchip 30000000.dwmmc: Got CD GPIO
[    3.744329] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer wp
[    3.744338] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    3.744350] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30000000[0]'
[    3.744363] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30000000[0]'
[    3.744374] dwmmc_rockchip 30000000.dwmmc: using lookup tables for GPIO lookup
[    3.744384] dwmmc_rockchip 30000000.dwmmc: lookup for GPIO wp failed
[    3.757287] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.770279] dwmmc_rockchip 30000000.dwmmc: 1 slots initialized
[    3.770901] dwmmc_rockchip 30010000.dwmmc: num-slots property not found, assuming 1 slot is available
[    3.771026] dwmmc_rockchip 30010000.dwmmc: IDMAC supports 32-bit address mode.
[    3.771173] dwmmc_rockchip 30010000.dwmmc: Using internal DMA controller.
[    3.771198] dwmmc_rockchip 30010000.dwmmc: Version ID is 270a
[    3.771312] dwmmc_rockchip 30010000.dwmmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo
[    3.771389] dwmmc_rockchip 30010000.dwmmc: No vmmc regulator found
[    3.771402] dwmmc_rockchip 30010000.dwmmc: No vqmmc regulator found
[    3.771427] dwmmc_rockchip 30010000.dwmmc: GPIO lookup for consumer wp
[    3.771441] dwmmc_rockchip 30010000.dwmmc: using device tree for GPIO lookup
[    3.771456] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30010000[0]'
[    3.771469] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30010000[0]'
[    3.771478] dwmmc_rockchip 30010000.dwmmc: using lookup tables for GPIO lookup
[    3.771490] dwmmc_rockchip 30010000.dwmmc: lookup for GPIO wp failed
[    3.771596] dwmmc_rockchip 30010000.dwmmc: allocated mmc-pwrseq
[    3.784559] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 400000Hz, actual 244140HZ div = 2)
[    3.797217] dwmmc_rockchip 30010000.dwmmc: 1 slots initialized
[    3.797577] dwmmc_rockchip 30020000.dwmmc: IDMAC supports 32-bit address mode.
[    3.797737] dwmmc_rockchip 30020000.dwmmc: Using internal DMA controller.
[    3.797762] dwmmc_rockchip 30020000.dwmmc: Version ID is 270a
[    3.797855] dwmmc_rockchip 30020000.dwmmc: DW MMC controller at irq 47,32 bit host data width,256 deep fifo
[    3.797920] dwmmc_rockchip 30020000.dwmmc: No vmmc regulator found
[    3.797935] dwmmc_rockchip 30020000.dwmmc: No vqmmc regulator found
[    3.797959] dwmmc_rockchip 30020000.dwmmc: GPIO lookup for consumer wp
[    3.797973] dwmmc_rockchip 30020000.dwmmc: using device tree for GPIO lookup
[    3.797988] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30020000[0]'
[    3.797998] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30020000[0]'
[    3.798009] dwmmc_rockchip 30020000.dwmmc: using lookup tables for GPIO lookup
[    3.798023] dwmmc_rockchip 30020000.dwmmc: lookup for GPIO wp failed
[    3.810943] mmc_host mmc2: Bus speed (slot 0) = 2343750Hz (slot req 400000Hz, actual 390625HZ div = 3)
[    3.822913] dwmmc_rockchip 30020000.dwmmc: 1 slots initialized
[    3.823885] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/working[0]' - status (0)
[    3.824932] ledtrig-cpu: registered to indicate activity on CPUs
[    3.825164] hidraw: raw HID events driver (C) Jiri Kosina
[    3.826242] usbcore: registered new interface driver usbhid
[    3.826275] usbhid: USB HID core driver
[    3.827900] ashmem: initialized
[    3.832397] rknandbase v1.2 2018-05-08
[    3.833003] rknand 30030000.nandc: rknand_probe clk rate = 150000000
[    3.833650] ftl_init fffffffe
[    3.833672] rk_ftl_init fail
[    3.834952] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 300000Hz, actual 244140HZ div = 2)
[    3.835771] usbcore: registered new interface driver snd-usb-audio
[    3.835982] usbcore: registered new interface driver snd-ua101
[    3.836334] usbcore: registered new interface driver snd-usb-caiaq
[    3.836656] usbcore: registered new interface driver snd-usb-6fire
[    3.836906] usbcore: registered new interface driver snd-usb-hiface
[    3.837066] usbcore: registered new interface driver snd-bcd2000
[    3.837222] usbcore: registered new interface driver snd_usb_pod
[    3.837375] usbcore: registered new interface driver snd_usb_podhd
[    3.837524] usbcore: registered new interface driver snd_usb_toneport
[    3.837665] usbcore: registered new interface driver snd_usb_variax
[    3.847922] u32 classifier
[    3.847960]     input device check on
[    3.847969]     Actions configured
[    3.847996] Netfilter messages via NETLINK v0.30.
[    3.848037] nfnl_acct: registering with nfnetlink.
[    3.848182] nf_conntrack version 0.5.0 (15384 buckets, 61536 max)
[    3.849461] Initializing XFRM netlink socket
[    3.851033] NET: Registered protocol family 10
[    3.853475] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.854167] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
[    3.854591] sit: IPv6 over IPv4 tunneling driver
[    3.856127] NET: Registered protocol family 17
[    3.856376] NET: Registered protocol family 15
[    3.856806] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    3.857070] Bridge firewalling registered
[    3.857130] can: controller area network core (rev 20120528 abi 9)
[    3.857432] mmc2: new high speed MMC card at address 0001
[    3.858185] NET: Registered protocol family 29
[    3.858241] can: raw protocol (rev 20120528)
[    3.858271] can: broadcast manager protocol (rev 20120528 t)
[    3.858314] can: netlink gateway (rev 20130117) max_hops=1
[    3.859144] mmcblk2: mmc2:0001 P1J95K 7.30 GiB
[    3.860018] mmcblk2boot0: mmc2:0001 P1J95K partition 1 2.00 MiB
[    3.860706] Bluetooth: RFCOMM TTY layer initialized
[    3.860784] Bluetooth: RFCOMM socket layer initialized
[    3.860909] mmcblk2boot1: mmc2:0001 P1J95K partition 2 2.00 MiB
[    3.861121] Bluetooth: RFCOMM ver 1.11
[    3.861253] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.861639] Bluetooth: HIDP socket layer initialized
[    3.861832] mmcblk2rpmb: mmc2:0001 P1J95K partition 3 2.00 MiB
[    3.862580] 8021q: 802.1Q VLAN Support v1.8
[    3.863179] lib80211: common routines for IEEE802.11 drivers
[    3.863225] lib80211_crypt: registered algorithm 'NULL'
[    3.863262] lib80211_crypt: registered algorithm 'WEP'
[    3.863285] lib80211_crypt: registered algorithm 'CCMP'
[    3.863309] lib80211_crypt: registered algorithm 'TKIP'
[    3.863331] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    3.863559] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    3.863608] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = esp8089
[    3.863626] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    3.863640] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    3.863658] of_get_named_gpiod_flags: can't parse 'WIFI,poweren_gpio' property of node '/wireless-wlan[0]'
[    3.863672] of_get_named_gpiod_flags: can't parse 'WIFI,vbat_gpio' property of node '/wireless-wlan[0]'
[    3.863686] of_get_named_gpiod_flags: can't parse 'WIFI,reset_gpio' property of node '/wireless-wlan[0]'
[    3.863792] of_get_named_gpiod_flags: parsed 'WIFI,host_wake_irq' property of node '/wireless-wlan[0]' - status (0)
[    3.863814] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 28, flags = 1.
[    3.863907]  mmcblk2: p1
[    3.864380] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    3.864408] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    3.864432] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    3.866114] [BT_RFKILL]: Enter rfkill_rk_init
[    3.867228] Key type dns_resolver registered
[    3.867874] flash vendor_init_thread!
[    3.867901] flash vendor storage:20170308 ret = -1
[    3.867999] Error: Driver 'sc031gs' is already registered, aborting...
[    3.869178] Registering SWP/SWPB emulation handler
[    3.870321] vendor storage:20190527 ret = 0
[    3.871284] registered taskstats version 1
[    3.871329] Loading compiled-in X.509 certificates
[    3.875495] Btrfs loaded
[    3.877194] rga2: Driver loaded successfully ver:4.01
[    3.877582] rga2: Module initialized.
[    3.877641] pvtm list NULL
[    3.879491] rk-vcodec 20030000.rkvdec: leakage=6
[    3.879546] rk-vcodec 20030000.rkvdec: leakage-volt-sel=1
[    3.879722] rk-vcodec 20030000.rkvdec: Failed to get pvtm
[    3.880295] rk-vcodec 20030000.rkvdec: avs=0
[    3.880692] rk-vcodec 20030000.rkvdec: probe device
[    3.881339] rk-vcodec 20030000.rkvdec: drm allocator with mmu enabled
[    3.883371] rk-vcodec 20030000.rkvdec: init success
[    3.884927] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]'
[    3.884962] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]'
[    3.886636] asoc-simple-card hdmi-sound: i2s-hifi <-> 100c0000.i2s0 mapping ok
[    3.887751] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 200000Hz, actual 162760HZ div = 3)
[    3.889634] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]'
[    3.889666] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]'
[    3.891242] asoc-simple-card spdif-sound: dit-hifi <-> 100d0000.spdif mapping ok
[    3.894818] hctosys: unable to open rtc device (rtc0)
[    3.914748] ALSA device list:
[    3.914793]   #0: DW-I2S-HDMI
[    3.914807]   #1: SPDIF
[    3.916421] Freeing unused kernel memory: 808K
[    3.916443] This architecture does not have kernel memory protection.
[    3.946729] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 100000Hz, actual 97656HZ div = 5)
[    4.017797] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[    4.048008] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[    4.061442] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[    4.065557] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    4.068792] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[    4.068997] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[    4.069176] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[    4.069282] mmc1: new high speed SDIO card at address 0001
[    4.110659] usb 5-1: new full-speed USB device number 2 using ohci-platform
[    4.323873] usb 5-1: New USB device found, idVendor=046d, idProduct=c534
[    4.323924] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.323937] usb 5-1: Product: USB Receiver
[    4.323952] usb 5-1: Manufacturer: Logitech
[    4.335872] input: Logitech USB Receiver as /devices/platform/300a0000.usb/usb5/5-1/5-1:1.0/0003:046D:C534.0001/input/input1
[    4.393234] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-300a0000.usb-1/input0
[    4.403528] input: Logitech USB Receiver as /devices/platform/300a0000.usb/usb5/5-1/5-1:1.1/0003:046D:C534.0002/input/input2
[    4.461228] hid-generic 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-300a0000.usb-1/input1
[    5.425737] EXT4-fs (mmcblk2p1): mounted filesystem with writeback data mode. Opts: (null)
[    6.035835] systemd[1]: System time before build time, advancing clock.
[    6.052310] systemd[1]: Inserted module 'autofs4'
[    6.061584] ip_tables: (C) 2000-2006 Netfilter Core Team
[    6.073647] cgroup: cgroup2: unknown option "nsdelegate"
[    6.095989] systemd[1]: systemd 245.4-4ubuntu3.17 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    6.097359] systemd[1]: Detected architecture arm.
[    6.112733] systemd[1]: Set hostname to <klipper>.
[    6.322175] ttyS2 - failed to request DMA, use interrupt mode
[    6.402039] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[    6.408213] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[    6.408241] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[    6.408251] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[    6.408261] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[    6.408271] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[    6.408281] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[    6.408291] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[    6.408301] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[    6.408311] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[    6.408322] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[    6.408331] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[    6.408341] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[    6.408350] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[    6.408360] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[    6.408370] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
[    7.345012] random: systemd: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[    7.345613] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    7.345662] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    7.350718] systemd[1]: Created slice system-modprobe.slice.
[    7.351949] random: systemd: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[    7.354025] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    7.355070] random: systemd: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[    7.356926] systemd[1]: Created slice User and Session Slice.
[    7.357992] random: systemd: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[    7.358647] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.360332] random: systemd: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[    7.361325] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.362923] random: systemd: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[    7.363107] systemd[1]: Reached target Remote File Systems.
[    7.363885] random: systemd: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[    7.364010] systemd[1]: Reached target Slices.
[    7.364724] random: systemd: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[    7.364841] systemd[1]: Reached target Swap.
[    7.365465] random: systemd: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[    7.365583] systemd[1]: Reached target System Time Set.
[    7.366374] random: systemd: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[    7.367584] systemd[1]: Listening on Syslog Socket.
[    7.369313] systemd[1]: Listening on fsck to fsckd communication Socket.
[    7.370892] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    7.383519] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    7.384902] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.387016] systemd[1]: Listening on Journal Socket.
[    7.389065] systemd[1]: Listening on udev Control Socket.
[    7.390859] systemd[1]: Listening on udev Kernel Socket.
[    7.392512] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    7.400167] systemd[1]: Mounting POSIX Message Queue File System...
[    7.411803] systemd[1]: Mounting Kernel Debug File System...
[    7.425856] systemd[1]: Mounting Kernel Trace File System...
[    7.441827] systemd[1]: Starting Restore / save the current clock...
[    7.455644] systemd[1]: Starting Set the console keyboard layout...
[    7.470467] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    7.472732] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[    7.488145] systemd[1]: Started Nameserver information manager.
[    7.520684] systemd[1]: Reached target Network (Pre).
[    7.525354] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    7.525751] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    7.541629] systemd[1]: Starting Load Kernel Modules...
[    7.556139] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.572672] systemd[1]: Starting udev Coldplug all Devices...
[    7.603029] systemd[1]: Mounted POSIX Message Queue File System.
[    7.607089] systemd[1]: Mounted Kernel Debug File System.
[    7.610324] systemd[1]: Mounted Kernel Trace File System.
[    7.621027] systemd[1]: Finished Restore / save the current clock.
[    7.631514] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    7.647224] systemd[1]: Finished Load Kernel Modules.
[    7.653712] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    7.656037] EXT4-fs (mmcblk2p1): re-mounted. Opts: commit=600,errors=remount-ro
[    7.668425] systemd[1]: Mounting Kernel Configuration File System...
[    7.682082] systemd[1]: Starting Apply Kernel Variables...
[    7.707860] systemd[1]: Finished Remount Root and Kernel File Systems.
[    7.710957] systemd[1]: Mounted Kernel Configuration File System.
[    7.716158] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    7.727059] systemd[1]: Starting Platform Persistent Storage Archival...
[    7.744395] systemd[1]: Starting Load/Save Random Seed...
[    7.756529] systemd[1]: Starting Create System Users...
[    7.845583] systemd[1]: Finished Apply Kernel Variables.
[    7.857432] systemd[1]: Finished Platform Persistent Storage Archival.
[    7.892688] systemd[1]: Finished Create System Users.
[    7.903049] systemd[1]: Starting Create Static Device Nodes in /dev...
[    7.976071] systemd[1]: Finished Set the console keyboard layout.
[    8.000588] systemd[1]: Finished Create Static Device Nodes in /dev.
[    8.002928] systemd[1]: Reached target Local File Systems (Pre).
[    8.012557] systemd[1]: Mounting /tmp...
[    8.024258] systemd[1]: Starting udev Kernel Device Manager...
[    8.040735] systemd[1]: Mounted /tmp.
[    8.050001] systemd[1]: Reached target Local File Systems.
[    8.069614] systemd[1]: Starting Armbian leds state...
[    8.090014] systemd[1]: Starting Armbian ZRAM config...
[    8.111045] systemd[1]: Starting Set console font and keymap...
[    8.133077] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    8.142844] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    8.195732] systemd[1]: plymouth-read-write.service: Succeeded.
[    8.200213] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    8.224344] systemd[1]: Finished Set console font and keymap.
[    8.247547] systemd[1]: Finished Armbian leds state.
[    8.461930] systemd[1]: Finished udev Coldplug all Devices.
[    8.481339] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[    8.532153] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[    8.555682] systemd[1]: Starting Raise network interfaces...
[    8.575998] systemd[1]: Started udev Kernel Device Manager.
[    8.589889] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[    8.590467] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[    8.591086] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[    8.591673] systemd[1]: Reached target Local Encrypted Volumes.
[    8.633704] zram: Added device: zram0
[    8.643079] zram: Added device: zram1
[    8.647474] zram: Added device: zram2
[    8.751584] cfg80211: World regulatory domain updated:
[    8.751638] cfg80211:  DFS Master region: unset
[    8.751652] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    8.751671] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    8.751688] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    8.751711] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[    8.751745] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    8.751783] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[    8.751803] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[    8.751816] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[    8.751836] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[    9.146479] zram0: detected capacity change from 0 to 504537088
[    9.317512] systemd[1]: Found device /dev/ttyS2.
[    9.329354] rk3228-codec 12010000.codec: GPIO lookup for consumer spk-en
[    9.329364] rk3228-codec 12010000.codec: using device tree for GPIO lookup
[    9.329376] of_get_named_gpiod_flags: can't parse 'spk-en-gpios' property of node '/codec@12010000[0]'
[    9.329425] of_get_named_gpiod_flags: parsed 'spk-en-gpio' property of node '/codec@12010000[0]' - status (0)
[    9.329507] rk3228-codec 12010000.codec: spk_depop_time use default value.
[    9.331562] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]'
[    9.331574] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]'
[    9.340407] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '20:09:06', on 'Aug 25 2021'.
[    9.341969] mali-utgard 20001000.gpu: mali_platform_device->num_resources = 13
[    9.342013] mali-utgard 20001000.gpu: resource[0].start = 0x0x20001000
[    9.342027] mali-utgard 20001000.gpu: resource[1].start = 0x0x20000000
[    9.342040] mali-utgard 20001000.gpu: resource[2].start = 0x0x20003000
[    9.342054] mali-utgard 20001000.gpu: resource[3].start = 0x0x20008000
[    9.342067] mali-utgard 20001000.gpu: resource[4].start = 0x0x20004000
[    9.342078] mali-utgard 20001000.gpu: resource[5].start = 0x0x2000a000
[    9.342089] mali-utgard 20001000.gpu: resource[6].start = 0x0x20005000
[    9.342102] mali-utgard 20001000.gpu: resource[7].start = 0x0x00000020
[    9.342114] mali-utgard 20001000.gpu: resource[8].start = 0x0x00000021
[    9.342128] mali-utgard 20001000.gpu: resource[9].start = 0x0x00000022
[    9.342138] mali-utgard 20001000.gpu: resource[10].start = 0x0x00000021
[    9.342151] mali-utgard 20001000.gpu: resource[11].start = 0x0x00000022
[    9.342161] mali-utgard 20001000.gpu: resource[12].start = 0x0x00000021
[    9.342176] D : [File] : drivers/gpu/arm/mali400/mali/platform/rk/rk.c; [Line] : 623; [Func] : mali_platform_device_init(); to add platform_specific_data to platform_device_of_mali.
[    9.342849] mali-utgard 20001000.gpu: leakage=6
[    9.342897] mali-utgard 20001000.gpu: leakage-volt-sel=1
[    9.343071] mali-utgard 20001000.gpu: Failed to get pvtm
[    9.343708] mali-utgard 20001000.gpu: avs=0
[    9.344167] mali-utgard 20001000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    9.369397] asoc-simple-card sound: rk3228-hifi <-> 100b0000.i2s1 mapping ok
[    9.398230] Mali: Mali device driver loaded
[    9.443093] devfreq 20001000.gpu: Couldn't update frequency transition information.
[    9.940716] gpio_ir_recv ir-receiver: GPIO lookup for consumer (null)
[    9.940776] gpio_ir_recv ir-receiver: using device tree for GPIO lookup
[    9.940848] of_get_named_gpiod_flags: parsed 'gpios' property of node '/ir-receiver[0]' - status (0)
[    9.941004] Registered IR keymap rc-rktvbox
[    9.941302] rc rc1: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1
[    9.941999] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1/input3
[   10.034237] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[   10.036169] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   10.037627] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   10.057350] random: nonblocking pool is initialized
[   10.127802] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   10.180905] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[   10.181300] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   10.181590] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[   10.183901] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   10.184600] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   10.185228] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   10.212805] systemd[1]: Finished Load/Save Random Seed.
[   10.247574] systemd[1]: plymouth-read-write.service: Succeeded.
[   10.272507] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[   10.372109] Adding 492708k swap on /dev/zram0.  Priority:5 extents:1 across:492708k SS
[   10.654998] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[   10.656050] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   10.703965] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   10.705285] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   10.767587] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   10.815850] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[   10.816386] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   10.816704] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[   10.850746] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   10.851462] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   10.852249] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   10.852850] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   10.867036] systemd[1]: plymouth-read-write.service: Succeeded.
[   10.885453] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[   10.967816] mmc1: card 0001 removed
[   10.987624] systemd[1]: Finished Raise network interfaces.
[   10.990839] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 400000Hz, actual 244140HZ div = 2)
[   11.042909] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 300000Hz, actual 244140HZ div = 2)
[   11.089672] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[   11.090955] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   11.092247] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   11.093578] zram1: detected capacity change from 0 to 52428800
[   11.106830] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   11.121417] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 200000Hz, actual 162760HZ div = 3)
[   11.132038] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[   11.132611] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   11.133002] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[   11.134303] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   11.134985] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   11.135612] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   11.136236] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   11.141623] systemd[1]: plymouth-read-write.service: Succeeded.
[   11.150479] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[   11.178776] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 100000Hz, actual 97656HZ div = 5)
[   11.212825] systemd[1]: Finished Armbian ZRAM config.
[   11.240037] systemd[1]: Starting Armbian memory supported logging...
[   11.251330] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[   11.285851] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[   11.306687] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[   11.310819] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[   11.312374] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[   11.312479] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[   11.312567] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[   11.312620] mmc1: new high speed SDIO card at address 0001
[   11.393860] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
[   11.683347] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   11.760305] systemd[1]: Started Load/Save RF Kill Switch Status.
[   16.571114] systemd[1]: Finished Armbian memory supported logging.
[   16.583309] systemd[1]: Starting Journal Service...
[   16.769767] systemd[1]: systemd-rfkill.service: Succeeded.
[   17.147840] systemd[1]: Started Journal Service.
[   17.211582] systemd-journald[665]: Received client request to flush runtime journal.
[   18.649046] nr_pdflush_threads exported in /proc is scheduled for removal
[   41.707060] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   41.947183] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   41.950850] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   42.829618] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   46.385214] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   46.385299] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   46.385361] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   46.385401] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   46.385436] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   46.385464] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
For this one, the ESP8089 wasn't even detected:
  Reveal hidden contents
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.194-rk322x (root@runner7) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #2 SMP Wed Aug 25 20:09:42 UTC 2021
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Generic RK322x TV Box board
[    0.000000] cma: Reserved 16 MiB at 0x9f000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 253952
[    0.000000] free_area_init_node: node 0, pgdat b1253b40, node_mem_map ee6f1000
[    0.000000]   Normal zone: 2304 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 253952 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv65535.65535 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] PERCPU: Embedded 14 pages/cpu @ee68f000 s24856 r8192 d24296 u57344
[    0.000000] pcpu-alloc: s24856 r8192 d24296 u57344 alloc=14*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 251648
[    0.000000] Kernel command line: earlyprintk root=UUID=bce0e15e-76b7-4f9c-9149-332bcfd83573 console=ttyS2,115200n8 console=tty1 rootwait rootfstype=ext4  consoleblank=0 loglevel=1 ubootpart=343a1e5a-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u coherent_pool=2M  cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 960640K/1015808K available (12862K kernel code, 919K rwdata, 3240K rodata, 808K init, 1219K bss, 38784K reserved, 16384K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                   lowmem  : 0xb0000000 - 0xf0000000   (1024 MB)
                   pkmap   : 0xafe00000 - 0xb0000000   (   2 MB)
                   modules : 0xaf000000 - 0xafe00000   (  14 MB)
                     .text : 0xb0008000 - 0xb0c97c6c   (12864 kB)
                     .init : 0xb10b0000 - 0xb117a000   ( 808 kB)
                     .data : 0xb117a000 - 0xb125fe94   ( 920 kB)
                      .bss : 0xb1261000 - 0xb1391f14   (1220 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]     Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000025] Switching to timer-based delay loop, resolution 41ns
[    0.001857] Console: colour dummy device 80x30
[    0.002048] console [tty1] enabled
[    0.002077] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.002096] pid_max: default: 32768 minimum: 301
[    0.002241] Security Framework initialized
[    0.002255] Yama: becoming mindful.
[    0.002340] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002357] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.003361] Initializing cgroup subsys io
[    0.003401] Initializing cgroup subsys memory
[    0.003449] Initializing cgroup subsys devices
[    0.003470] Initializing cgroup subsys freezer
[    0.003488] Initializing cgroup subsys net_cls
[    0.003506] Initializing cgroup subsys perf_event
[    0.003524] Initializing cgroup subsys net_prio
[    0.003558] Initializing cgroup subsys pids
[    0.003715] CPU: Testing write buffer coherency: ok
[    0.003775] ftrace: allocating 41892 entries in 123 pages
[    0.086467] /cpus/cpu@f00 missing clock-frequency property
[    0.086508] /cpus/cpu@f01 missing clock-frequency property
[    0.086526] /cpus/cpu@f02 missing clock-frequency property
[    0.086547] /cpus/cpu@f03 missing clock-frequency property
[    0.086560] CPU0: update cpu_capacity 430
[    0.086572] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.086673] Setting up static identity map for 0x60008280 - 0x600082d8
[    0.089915] CPU1: update cpu_capacity 430
[    0.089927] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.091159] CPU2: update cpu_capacity 430
[    0.091168] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.092381] CPU3: update cpu_capacity 430
[    0.092390] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.092544] Brought up 4 CPUs
[    0.092588] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.092596] CPU: All CPU(s) started in SVC mode.
[    0.094345] devtmpfs: initialized
[    0.114737] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.115340] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.115389] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.116931] xor: measuring software checksum speed
[    0.154345]    arm4regs  :  1011.000 MB/sec
[    0.194449]    8regs     :   705.000 MB/sec
[    0.234549]    32regs    :   684.000 MB/sec
[    0.274652]    neon      :  1018.000 MB/sec
[    0.274663] xor: using function: neon (1018.000 MB/sec)
[    0.274708] pinctrl core: initialized pinctrl subsystem
[    0.276476] NET: Registered protocol family 16
[    0.279157] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.290834] cpuidle: using governor ladder
[    0.302843] cpuidle: using governor menu
[    0.320305] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0
[    0.320486] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1
[    0.320640] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2
[    0.320816] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3
[    0.327941] console [pstore-1] enabled
[    0.327954] pstore: Registered ramoops as persistent store backend
[    0.327967] ramoops: attached 0xf0000@0x62e00000, ecc: 0/0
[    0.331466] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.331491] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.427942] raid6: int32x1  gen()   133 MB/s
[    0.495970] raid6: int32x1  xor()   131 MB/s
[    0.564196] raid6: int32x2  gen()   166 MB/s
[    0.632254] raid6: int32x2  xor()   136 MB/s
[    0.700618] raid6: int32x4  gen()   163 MB/s
[    0.768868] raid6: int32x4  xor()   137 MB/s
[    0.837015] raid6: int32x8  gen()   166 MB/s
[    0.905277] raid6: int32x8  xor()   113 MB/s
[    0.973413] raid6: neonx1   gen()   382 MB/s
[    1.041524] raid6: neonx1   xor()   290 MB/s
[    1.109747] raid6: neonx2   gen()   519 MB/s
[    1.177882] raid6: neonx2   xor()   376 MB/s
[    1.246148] raid6: neonx4   gen()   581 MB/s
[    1.314304] raid6: neonx4   xor()   400 MB/s
[    1.382568] raid6: neonx8   gen()   559 MB/s
[    1.450771] raid6: neonx8   xor()   391 MB/s
[    1.450784] raid6: using algorithm neonx4 gen() 581 MB/s
[    1.450794] raid6: .... xor() 400 MB/s, rmw enabled
[    1.450804] raid6: using intx1 recovery algorithm
[    1.451957] rockchip-pm rockchip-suspend: not set wakeup-config
[    1.451985] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    1.452420] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@0[0]'
[    1.452979] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@1[0]'
[    1.453689] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-host-regulator[0]' - status (0)
[    1.454348] of_get_named_gpiod_flags: parsed 'gpio' property of node '/otg-vbus-regulator[0]' - status (0)
[    1.454985] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]'
[    1.455942] iommu: Adding device 20020000.vpu-service to group 0
[    1.456060] iommu: Adding device 20030000.rkvdec to group 1
[    1.456169] iommu: Adding device 20050000.vop to group 2
[    1.456267] iommu: Adding device 20070000.iep to group 3
[    1.456870] rk_iommu 20020800.iommu: can't get sclk
[    1.457601] rk_iommu 20030480.iommu: can't get sclk
[    1.457879] rk_iommu 20053f00.iommu: can't get sclk
[    1.458029] rk_iommu 20070800.iommu: can't get aclk
[    1.458049] rk_iommu 20070800.iommu: can't get hclk
[    1.458065] rk_iommu 20070800.iommu: can't get sclk
[    1.458995] SCSI subsystem initialized
[    1.459458] usbcore: registered new interface driver usbfs
[    1.459564] usbcore: registered new interface driver hub
[    1.459707] usbcore: registered new device driver usb
[    1.459939] media: Linux media interface: v0.10
[    1.460021] Linux video capture interface: v2.00
[    1.460291] pps_core: LinuxPPS API ver. 1 registered
[    1.460309] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.460353] PTP clock support registered
[    1.462545] Advanced Linux Sound Architecture Driver Initialized.
[    1.463725] Bluetooth: Core ver 2.21
[    1.463809] NET: Registered protocol family 31
[    1.463825] Bluetooth: HCI device and connection manager initialized
[    1.463849] Bluetooth: HCI socket layer initialized
[    1.463867] Bluetooth: L2CAP socket layer initialized
[    1.463930] Bluetooth: SCO socket layer initialized
[    1.464871] NetLabel: Initializing
[    1.464896] NetLabel:  domain hash size = 128
[    1.464906] NetLabel:  protocols = UNLABELED CIPSOv4
[    1.464989] NetLabel:  unlabeled traffic allowed by default
[    1.466486] clocksource: Switched to clocksource arch_sys_counter
[    1.567571] NET: Registered protocol family 2
[    1.568543] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    1.568664] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[    1.569021] TCP: Hash tables configured (established 8192 bind 8192)
[    1.569124] UDP hash table entries: 512 (order: 2, 24576 bytes)
[    1.569195] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[    1.569577] NET: Registered protocol family 1
[    1.570391] RPC: Registered named UNIX socket transport module.
[    1.570420] RPC: Registered udp transport module.
[    1.570431] RPC: Registered tcp transport module.
[    1.570442] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.570922] Trying to unpack rootfs image as initramfs...
[    2.110714] Freeing initrd memory: 7588K
[    2.111850] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    2.115090] Initialise system trusted keyring
[    2.129535] VFS: Disk quotas dquot_6.6.0
[    2.129878] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    2.132761] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.136448] NFS: Registering the id_resolver key type
[    2.136541] Key type id_resolver registered
[    2.136554] Key type id_legacy registered
[    2.136592] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.136710] ntfs: driver 2.1.32 [Flags: R/W].
[    2.137706] JFS: nTxBlock = 7692, nTxLock = 61538
[    2.148997] SGI XFS with security attributes, no debug enabled
[    2.159004] NET: Registered protocol family 38
[    2.159066] Key type asymmetric registered
[    2.159088] Asymmetric key parser 'x509' registered
[    2.159533] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    2.160046] io scheduler noop registered
[    2.160077] io scheduler deadline registered
[    2.160173] io scheduler cfq registered (default)
[    2.163844] phy phy-11000000.syscon:usb2-phy@800.2: Failed to get VBUS supply regulator
[    2.169495] rk-vcodec 20020000.vpu-service: no regulator for vcodec
[    2.169997] rk-vcodec 20020000.vpu-service: probe device
[    2.170544] rk-vcodec 20020000.vpu-service: drm allocator with mmu enabled
[    2.172009] rk-vcodec 20020000.vpu-service: could not find power_model node
[    2.172040] rk-vcodec 20020000.vpu-service: init success
[    2.172426] rk-vcodec 20030000.rkvdec: vcodec regulator not ready, retry
[    2.176967] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-241330
[    2.177000] dma-pl330 110f0000.pdma:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    2.178270] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    2.178923] pwm-regulator vdd-arm-regulator: GPIO lookup for consumer enable
[    2.178948] pwm-regulator vdd-arm-regulator: using device tree for GPIO lookup
[    2.178967] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-arm-regulator[0]'
[    2.178982] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-arm-regulator[0]'
[    2.178995] pwm-regulator vdd-arm-regulator: using lookup tables for GPIO lookup
[    2.179011] pwm-regulator vdd-arm-regulator: lookup for GPIO enable failed
[    2.179741] pwm-regulator vdd-log-regulator: GPIO lookup for consumer enable
[    2.179764] pwm-regulator vdd-log-regulator: using device tree for GPIO lookup
[    2.179780] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log-regulator[0]'
[    2.179795] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log-regulator[0]'
[    2.179809] pwm-regulator vdd-log-regulator: using lookup tables for GPIO lookup
[    2.179825] pwm-regulator vdd-log-regulator: lookup for GPIO enable failed
[    2.180983] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.181901] 11030000.serial: ttyS2 at MMIO 0x11030000 (irq = 30, base_baud = 1500000) is a 16550A
[    2.182828] console [ttyS2] enabled
[    2.184858] [drm] Initialized drm 1.1.0 20060810
[    2.187577] [drm] Rockchip DRM driver version: v1.0.1
[    2.187881] rockchip-drm display-subsystem: devfreq is not set
[    2.188710] rockchip-drm display-subsystem: bound 20050000.vop (ops 0xb0d1b2b0)
[    2.189163] i2c i2c-0: of_i2c: modalias failure on /hdmi@200a0000/ports
[    2.189194] dwhdmi-rockchip 200a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.189321] dwhdmi-rockchip 200a0000.hdmi: Detected HDMI TX controller v2.01a with HDCP (inno_dw_hdmi_phy)
[    2.190866] rockchip-drm display-subsystem: bound 200a0000.hdmi (ops 0xb0d13808)
[    2.190899] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.190910] [drm] No driver support for vblank timestamp query.
[    2.191056] rockchip-drm display-subsystem: failed to parse display resources
[    2.813458] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[    2.818988] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[    2.818996] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[    2.819004] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[    2.819010] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[    2.819017] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[    2.819024] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[    2.819030] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[    2.819037] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[    2.819044] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[    2.819051] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[    2.819057] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[    2.819064] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[    2.819070] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[    2.819077] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[    2.819084] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
[    2.891157] Console: switching to colour frame buffer device 240x67
[    2.941211] rockchip-drm display-subsystem: fb0:  frame buffer device
[    2.956268] Registered IR keymap rc-cec
[    2.956579] rc rc0: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0
[    2.957285] input: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0/input0
[    2.960189] brd: module loaded
[    2.974367] loop: module loaded
[    2.974570] lkdtm: No crash points registered, enable through debugfs
[    2.977726] libphy: Fixed MDIO Bus: probed
[    2.977770] tun: Universal TUN/TAP device driver, 1.6
[    2.977783] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.978302] CAN device driver interface
[    2.980217] rk_gmac-dwmac 30200000.ethernet: clock input or output? (output).
[    2.980257] rk_gmac-dwmac 30200000.ethernet: TX delay(0x30).
[    2.980275] rk_gmac-dwmac 30200000.ethernet: RX delay(0x10).
[    2.980328] rk_gmac-dwmac 30200000.ethernet: integrated PHY? (yes).
[    2.980511] rk_gmac-dwmac 30200000.ethernet: cannot get clock clk_mac_speed
[    2.985612] rk_gmac-dwmac 30200000.ethernet: init for RMII
[    3.018653] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    3.018673]  Ring mode enabled
[    3.018688]  DMA HW capability register supported
[    3.018701]  Normal descriptors
[    3.018717]  RX Checksum Offload Engine supported (type 2)
[    3.018728]  TX Checksum insertion supported
[    3.018737]  Wake-Up On Lan supported
[    3.018856] rk_gmac-dwmac 30200000.ethernet: rk_get_eth_addr: mac address: 4e:29:f7:d4:13:43
[    3.018874] eth%d: device MAC address 4e:29:f7:d4:13:43
[    3.018885]  Enable RX Mitigation via HW Watchdog Timer
[    3.019186] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@30200000[0]' - status (0)
[    3.459382] libphy: stmmac: probed
[    3.459429] eth%d: PHY ID 1234d400 at 0 IRQ POLL (stmmac-0:00) active
[    3.459446] eth%d: PHY ID 00000000 at 1 IRQ POLL (stmmac-0:01)
[    3.459460] eth%d: PHY ID 00000000 at 2 IRQ POLL (stmmac-0:02)
[    3.459474] eth%d: PHY ID 00000000 at 3 IRQ POLL (stmmac-0:03)
[    3.459489] eth%d: PHY ID 00000000 at 4 IRQ POLL (stmmac-0:04)
[    3.459504] eth%d: PHY ID 00000000 at 5 IRQ POLL (stmmac-0:05)
[    3.459519] eth%d: PHY ID 00000000 at 6 IRQ POLL (stmmac-0:06)
[    3.459534] eth%d: PHY ID 00000000 at 7 IRQ POLL (stmmac-0:07)
[    3.459549] eth%d: PHY ID 00000000 at 8 IRQ POLL (stmmac-0:08)
[    3.459563] eth%d: PHY ID 00000000 at 9 IRQ POLL (stmmac-0:09)
[    3.459578] eth%d: PHY ID 00000000 at 10 IRQ POLL (stmmac-0:0a)
[    3.459592] eth%d: PHY ID 00000000 at 11 IRQ POLL (stmmac-0:0b)
[    3.459608] eth%d: PHY ID 00000000 at 12 IRQ POLL (stmmac-0:0c)
[    3.459623] eth%d: PHY ID 00000000 at 13 IRQ POLL (stmmac-0:0d)
[    3.459637] eth%d: PHY ID 00000000 at 14 IRQ POLL (stmmac-0:0e)
[    3.459652] eth%d: PHY ID 00000000 at 15 IRQ POLL (stmmac-0:0f)
[    3.459667] eth%d: PHY ID 00000000 at 16 IRQ POLL (stmmac-0:10)
[    3.459682] eth%d: PHY ID 00000000 at 17 IRQ POLL (stmmac-0:11)
[    3.459697] eth%d: PHY ID 00000000 at 18 IRQ POLL (stmmac-0:12)
[    3.459712] eth%d: PHY ID 00000000 at 19 IRQ POLL (stmmac-0:13)
[    3.459726] eth%d: PHY ID 00000000 at 20 IRQ POLL (stmmac-0:14)
[    3.459740] eth%d: PHY ID 00000000 at 21 IRQ POLL (stmmac-0:15)
[    3.459756] eth%d: PHY ID 00000000 at 22 IRQ POLL (stmmac-0:16)
[    3.459770] eth%d: PHY ID 00000000 at 23 IRQ POLL (stmmac-0:17)
[    3.459786] eth%d: PHY ID 00000000 at 24 IRQ POLL (stmmac-0:18)
[    3.459800] eth%d: PHY ID 00000000 at 25 IRQ POLL (stmmac-0:19)
[    3.459815] eth%d: PHY ID 00000000 at 26 IRQ POLL (stmmac-0:1a)
[    3.459829] eth%d: PHY ID 00000000 at 27 IRQ POLL (stmmac-0:1b)
[    3.459845] eth%d: PHY ID 00000000 at 28 IRQ POLL (stmmac-0:1c)
[    3.459859] eth%d: PHY ID 00000000 at 29 IRQ POLL (stmmac-0:1d)
[    3.459874] eth%d: PHY ID 00000000 at 30 IRQ POLL (stmmac-0:1e)
[    3.459889] eth%d: PHY ID 00000000 at 31 IRQ POLL (stmmac-0:1f)
[    3.461733] PPP generic driver version 2.4.2
[    3.462331] Atmel at76x USB Wireless LAN Driver 0.17 loading
[    3.462607] usbcore: registered new interface driver at76c50x-usb
[    3.462791] usbcore: registered new interface driver rtl8187
[    3.462922] usbcore: registered new interface driver rndis_wlan
[    3.463037] usbcore: registered new interface driver zd1201
[    3.463640] usbcore: registered new interface driver rt2800usb
[    3.463784] Rockchip WiFi SYS interface (V1.00) ...
[    3.463859] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    3.463987] usbcore: registered new interface driver pegasus
[    3.464079] usbcore: registered new interface driver rtl8150
[    3.464165] usbcore: registered new interface driver r8152
[    3.464272] usbcore: registered new interface driver asix
[    3.464356] usbcore: registered new interface driver ax88179_178a
[    3.464438] usbcore: registered new interface driver cdc_ether
[    3.464553] usbcore: registered new interface driver dm9601
[    3.464690] usbcore: registered new interface driver smsc75xx
[    3.464809] usbcore: registered new interface driver smsc95xx
[    3.464900] usbcore: registered new interface driver net1080
[    3.464994] usbcore: registered new interface driver rndis_host
[    3.465087] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    3.465263] usbcore: registered new interface driver cdc_ncm
[    3.465378] usbcore: registered new interface driver cdc_mbim
[    3.466052] 30040000.usb supply vusb_d not found, using dummy regulator
[    3.466182] 30040000.usb supply vusb_a not found, using dummy regulator
[    3.479948] dwc2 30040000.usb: DWC OTG Controller
[    3.480024] dwc2 30040000.usb: new USB bus registered, assigned bus number 1
[    3.480104] dwc2 30040000.usb: irq 49, io mem 0x30040000
[    3.480537] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.480586] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.480601] usb usb1: Product: DWC OTG Controller
[    3.480615] usb usb1: Manufacturer: Linux 4.4.194-rk322x dwc2_hsotg
[    3.480629] usb usb1: SerialNumber: 30040000.usb
[    3.481901] hub 1-0:1.0: USB hub found
[    3.482000] hub 1-0:1.0: 1 port detected
[    3.484063] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.484104] ehci-platform: EHCI generic platform driver
[    3.486867] ehci-platform 30080000.usb: EHCI Host Controller
[    3.487367] ehci-platform 30080000.usb: new USB bus registered, assigned bus number 2
[    3.487788] ehci-platform 30080000.usb: irq 50, io mem 0x30080000
[    3.498552] ehci-platform 30080000.usb: USB 2.0 started, EHCI 1.00
[    3.498934] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    3.498954] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.498972] usb usb2: Product: EHCI Host Controller
[    3.498987] usb usb2: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    3.499001] usb usb2: SerialNumber: 30080000.usb
[    3.500261] hub 2-0:1.0: USB hub found
[    3.500364] hub 2-0:1.0: 1 port detected
[    3.503588] ehci-platform 300c0000.usb: EHCI Host Controller
[    3.504199] ehci-platform 300c0000.usb: new USB bus registered, assigned bus number 3
[    3.504610] ehci-platform 300c0000.usb: irq 52, io mem 0x300c0000
[    3.514541] ehci-platform 300c0000.usb: USB 2.0 started, EHCI 1.00
[    3.514923] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    3.514949] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.514965] usb usb3: Product: EHCI Host Controller
[    3.514979] usb usb3: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    3.514993] usb usb3: SerialNumber: 300c0000.usb
[    3.516263] hub 3-0:1.0: USB hub found
[    3.516360] hub 3-0:1.0: 1 port detected
[    3.519516] ehci-platform 30100000.usb: EHCI Host Controller
[    3.520084] ehci-platform 30100000.usb: new USB bus registered, assigned bus number 4
[    3.520519] ehci-platform 30100000.usb: irq 54, io mem 0x30100000
[    3.530531] ehci-platform 30100000.usb: USB 2.0 started, EHCI 1.00
[    3.530916] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    3.530936] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.530952] usb usb4: Product: EHCI Host Controller
[    3.530965] usb usb4: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    3.530979] usb usb4: SerialNumber: 30100000.usb
[    3.532167] hub 4-0:1.0: USB hub found
[    3.532256] hub 4-0:1.0: 1 port detected
[    3.533261] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.533329] ohci-platform: OHCI generic platform driver
[    3.533920] ohci-platform 300a0000.usb: Generic Platform OHCI controller
[    3.534538] ohci-platform 300a0000.usb: new USB bus registered, assigned bus number 5
[    3.534955] ohci-platform 300a0000.usb: irq 51, io mem 0x300a0000
[    3.594854] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    3.594879] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.594896] usb usb5: Product: Generic Platform OHCI controller
[    3.594913] usb usb5: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    3.594927] usb usb5: SerialNumber: 300a0000.usb
[    3.596193] hub 5-0:1.0: USB hub found
[    3.596286] hub 5-0:1.0: 1 port detected
[    3.597338] ohci-platform 300e0000.usb: Generic Platform OHCI controller
[    3.597751] ohci-platform 300e0000.usb: new USB bus registered, assigned bus number 6
[    3.598164] ohci-platform 300e0000.usb: irq 53, io mem 0x300e0000
[    3.654840] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    3.654870] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.654886] usb usb6: Product: Generic Platform OHCI controller
[    3.654900] usb usb6: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    3.654914] usb usb6: SerialNumber: 300e0000.usb
[    3.656179] hub 6-0:1.0: USB hub found
[    3.656282] hub 6-0:1.0: 1 port detected
[    3.657315] ohci-platform 30120000.usb: Generic Platform OHCI controller
[    3.657840] ohci-platform 30120000.usb: new USB bus registered, assigned bus number 7
[    3.658196] ohci-platform 30120000.usb: irq 55, io mem 0x30120000
[    3.714832] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    3.714863] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.714881] usb usb7: Product: Generic Platform OHCI controller
[    3.714898] usb usb7: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    3.714913] usb usb7: SerialNumber: 30120000.usb
[    3.716185] hub 7-0:1.0: USB hub found
[    3.716288] hub 7-0:1.0: 1 port detected
[    3.717646] usbcore: registered new interface driver cdc_acm
[    3.717671] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    3.717808] usbcore: registered new interface driver cdc_wdm
[    3.718139] usbcore: registered new interface driver usb-storage
[    3.718390] usbcore: registered new interface driver usbserial
[    3.718600] usbcore: registered new interface driver usbserial_generic
[    3.718718] usbserial: USB Serial support registered for generic
[    3.718864] usbcore: registered new interface driver keyspan
[    3.718934] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    3.718998] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    3.719068] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    3.719130] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    3.719255] usbcore: registered new interface driver option
[    3.719330] usbserial: USB Serial support registered for GSM modem (1-port)
[    3.720153] usbcore: registered new interface driver oti6858
[    3.720229] usbserial: USB Serial support registered for oti6858
[    3.720348] usbcore: registered new interface driver qcserial
[    3.720432] usbserial: USB Serial support registered for Qualcomm USB modem
[    3.720613] usbcore: registered new interface driver sierra
[    3.720683] usbserial: USB Serial support registered for Sierra USB modem
[    3.722781] usbcore: registered new interface driver iforce
[    3.722986] usbcore: registered new interface driver xpad
[    3.723291] usbcore: registered new interface driver usbtouchscreen
[    3.724807] i2c /dev entries driver
[    3.727164] IR NEC protocol handler initialized
[    3.727203] IR RC5(x/sz) protocol handler initialized
[    3.727221] IR RC6 protocol handler initialized
[    3.727242] IR JVC protocol handler initialized
[    3.727261] IR Sony protocol handler initialized
[    3.727281] IR SANYO protocol handler initialized
[    3.727304] IR Sharp protocol handler initialized
[    3.727322] IR MCE Keyboard/mouse protocol handler initialized
[    3.727340] IR XMP protocol handler initialized
[    3.729336] usbcore: registered new interface driver uvcvideo
[    3.729356] USB Video Class driver (1.1.1)
[    3.731883] Boot mode: normal
[    3.733538] rockchip-thermal 11150000.tsadc: tsadc is probed successfully!
[    3.735697] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    3.736164] Bluetooth: Virtual HCI driver ver 1.5
[    3.736535] Bluetooth: HCI UART driver ver 2.3
[    3.736558] Bluetooth: HCI UART protocol H4 registered
[    3.736570] Bluetooth: HCI UART protocol LL registered
[    3.736583] Bluetooth: HCI UART protocol ATH3K registered
[    3.736598] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    3.736839] Bluetooth: HCI UART protocol BCM registered
[    3.737031] usbcore: registered new interface driver bfusb
[    3.737194] usbcore: registered new interface driver btusb
[    3.737219] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    3.738034] cpu cpu0: leakage=9
[    3.738078] cpu cpu0: leakage-volt-sel=1
[    3.738351] cpu cpu0: Failed to get pvtm
[    3.740365] cpu cpu0: avs=0
[    3.740494] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    3.740526] cpu cpu0: failed to read out thermal zone (-22)
[    3.741400] cpu cpu0: failed to find power_model node
[    3.742394] pwrseq_simple sdio-pwrseq: GPIO lookup for consumer reset
[    3.742422] pwrseq_simple sdio-pwrseq: using device tree for GPIO lookup
[    3.742541] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[0]' - status (0)
[    3.743116] Synopsys Designware Multimedia Card Interface Driver
[    3.743946] dwmmc_rockchip 30000000.dwmmc: IDMAC supports 32-bit address mode.
[    3.744143] dwmmc_rockchip 30000000.dwmmc: Using internal DMA controller.
[    3.744170] dwmmc_rockchip 30000000.dwmmc: Version ID is 270a
[    3.744270] dwmmc_rockchip 30000000.dwmmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo
[    3.744346] dwmmc_rockchip 30000000.dwmmc: No vmmc regulator found
[    3.744360] dwmmc_rockchip 30000000.dwmmc: No vqmmc regulator found
[    3.744393] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer cd
[    3.744407] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    3.744447] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/dwmmc@30000000[0]' - status (0)
[    3.744498] gpio-49 (cd): gpiod_set_debounce: missing set() or set_debounce() operations
[    3.744512] dwmmc_rockchip 30000000.dwmmc: Got CD GPIO
[    3.744528] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer wp
[    3.744540] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    3.744551] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30000000[0]'
[    3.744563] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30000000[0]'
[    3.744573] dwmmc_rockchip 30000000.dwmmc: using lookup tables for GPIO lookup
[    3.744585] dwmmc_rockchip 30000000.dwmmc: lookup for GPIO wp failed
[    3.757497] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.770554] dwmmc_rockchip 30000000.dwmmc: 1 slots initialized
[    3.771093] dwmmc_rockchip 30010000.dwmmc: num-slots property not found, assuming 1 slot is available
[    3.771217] dwmmc_rockchip 30010000.dwmmc: IDMAC supports 32-bit address mode.
[    3.771365] dwmmc_rockchip 30010000.dwmmc: Using internal DMA controller.
[    3.771390] dwmmc_rockchip 30010000.dwmmc: Version ID is 270a
[    3.771504] dwmmc_rockchip 30010000.dwmmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo
[    3.771582] dwmmc_rockchip 30010000.dwmmc: No vmmc regulator found
[    3.771600] dwmmc_rockchip 30010000.dwmmc: No vqmmc regulator found
[    3.771625] dwmmc_rockchip 30010000.dwmmc: GPIO lookup for consumer wp
[    3.771637] dwmmc_rockchip 30010000.dwmmc: using device tree for GPIO lookup
[    3.771651] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30010000[0]'
[    3.771665] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30010000[0]'
[    3.771675] dwmmc_rockchip 30010000.dwmmc: using lookup tables for GPIO lookup
[    3.771688] dwmmc_rockchip 30010000.dwmmc: lookup for GPIO wp failed
[    3.771794] dwmmc_rockchip 30010000.dwmmc: allocated mmc-pwrseq
[    3.784792] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 400000Hz, actual 244140HZ div = 2)
[    3.797420] dwmmc_rockchip 30010000.dwmmc: 1 slots initialized
[    3.797717] dwmmc_rockchip 30020000.dwmmc: IDMAC supports 32-bit address mode.
[    3.797849] dwmmc_rockchip 30020000.dwmmc: Using internal DMA controller.
[    3.797875] dwmmc_rockchip 30020000.dwmmc: Version ID is 270a
[    3.797961] dwmmc_rockchip 30020000.dwmmc: DW MMC controller at irq 47,32 bit host data width,256 deep fifo
[    3.798035] dwmmc_rockchip 30020000.dwmmc: No vmmc regulator found
[    3.798049] dwmmc_rockchip 30020000.dwmmc: No vqmmc regulator found
[    3.798075] dwmmc_rockchip 30020000.dwmmc: GPIO lookup for consumer wp
[    3.798085] dwmmc_rockchip 30020000.dwmmc: using device tree for GPIO lookup
[    3.798097] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30020000[0]'
[    3.798111] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30020000[0]'
[    3.798121] dwmmc_rockchip 30020000.dwmmc: using lookup tables for GPIO lookup
[    3.798132] dwmmc_rockchip 30020000.dwmmc: lookup for GPIO wp failed
[    3.811044] mmc_host mmc2: Bus speed (slot 0) = 2343750Hz (slot req 400000Hz, actual 390625HZ div = 3)
[    3.822821] dwmmc_rockchip 30020000.dwmmc: 1 slots initialized
[    3.823786] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/working[0]' - status (0)
[    3.824851] ledtrig-cpu: registered to indicate activity on CPUs
[    3.825070] hidraw: raw HID events driver (C) Jiri Kosina
[    3.826173] usbcore: registered new interface driver usbhid
[    3.826204] usbhid: USB HID core driver
[    3.827737] ashmem: initialized
[    3.832142] rknandbase v1.2 2018-05-08
[    3.832747] rknand 30030000.nandc: rknand_probe clk rate = 150000000
[    3.833400] ftl_init fffffffe
[    3.833424] rk_ftl_init fail
[    3.835400] usbcore: registered new interface driver snd-usb-audio
[    3.835624] usbcore: registered new interface driver snd-ua101
[    3.835824] usbcore: registered new interface driver snd-usb-caiaq
[    3.836099] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 300000Hz, actual 244140HZ div = 2)
[    3.836432] usbcore: registered new interface driver snd-usb-6fire
[    3.836684] usbcore: registered new interface driver snd-usb-hiface
[    3.836846] usbcore: registered new interface driver snd-bcd2000
[    3.836996] usbcore: registered new interface driver snd_usb_pod
[    3.837145] usbcore: registered new interface driver snd_usb_podhd
[    3.837299] usbcore: registered new interface driver snd_usb_toneport
[    3.837437] usbcore: registered new interface driver snd_usb_variax
[    3.847722] u32 classifier
[    3.847752]     input device check on
[    3.847762]     Actions configured
[    3.847785] Netfilter messages via NETLINK v0.30.
[    3.847824] nfnl_acct: registering with nfnetlink.
[    3.847967] nf_conntrack version 0.5.0 (15384 buckets, 61536 max)
[    3.849267] Initializing XFRM netlink socket
[    3.850856] NET: Registered protocol family 10
[    3.853364] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.853912] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
[    3.854365] sit: IPv6 over IPv4 tunneling driver
[    3.856110] NET: Registered protocol family 17
[    3.856409] NET: Registered protocol family 15
[    3.856839] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    3.857165] mmc2: new high speed MMC card at address 0001
[    3.857855] Bridge firewalling registered
[    3.857915] can: controller area network core (rev 20120528 abi 9)
[    3.858600] NET: Registered protocol family 29
[    3.858751] mmcblk2: mmc2:0001 P1J95K 7.30 GiB
[    3.858966] can: raw protocol (rev 20120528)
[    3.859003] can: broadcast manager protocol (rev 20120528 t)
[    3.859055] can: netlink gateway (rev 20130117) max_hops=1
[    3.859667] mmcblk2boot0: mmc2:0001 P1J95K partition 1 2.00 MiB
[    3.860491] mmcblk2boot1: mmc2:0001 P1J95K partition 2 2.00 MiB
[    3.861358] mmcblk2rpmb: mmc2:0001 P1J95K partition 3 2.00 MiB
[    3.862035] Bluetooth: RFCOMM TTY layer initialized
[    3.862090] Bluetooth: RFCOMM socket layer initialized
[    3.862733] Bluetooth: RFCOMM ver 1.11
[    3.862881] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.862928] Bluetooth: HIDP socket layer initialized
[    3.863046] 8021q: 802.1Q VLAN Support v1.8
[    3.863127] lib80211: common routines for IEEE802.11 drivers
[    3.863146] lib80211_crypt: registered algorithm 'NULL'
[    3.863175] lib80211_crypt: registered algorithm 'WEP'
[    3.863246] lib80211_crypt: registered algorithm 'CCMP'
[    3.863278] lib80211_crypt: registered algorithm 'TKIP'
[    3.863302] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    3.863408]  mmcblk2: p1
[    3.863574] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    3.863624] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = esp8089
[    3.863638] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    3.863651] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    3.863669] of_get_named_gpiod_flags: can't parse 'WIFI,poweren_gpio' property of node '/wireless-wlan[0]'
[    3.863684] of_get_named_gpiod_flags: can't parse 'WIFI,vbat_gpio' property of node '/wireless-wlan[0]'
[    3.863698] of_get_named_gpiod_flags: can't parse 'WIFI,reset_gpio' property of node '/wireless-wlan[0]'
[    3.863752] of_get_named_gpiod_flags: parsed 'WIFI,host_wake_irq' property of node '/wireless-wlan[0]' - status (0)
[    3.863766] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 28, flags = 1.
[    3.863788] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    3.863801] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    3.863821] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    3.864237] [BT_RFKILL]: Enter rfkill_rk_init
[    3.864648] Key type dns_resolver registered
[    3.865419] flash vendor_init_thread!
[    3.865463] flash vendor storage:20170308 ret = -1
[    3.865627] Error: Driver 'sc031gs' is already registered, aborting...
[    3.867335] Registering SWP/SWPB emulation handler
[    3.868426] vendor storage:20190527 ret = 0
[    3.869493] registered taskstats version 1
[    3.869537] Loading compiled-in X.509 certificates
[    3.873665] Btrfs loaded
[    3.875506] rga2: Driver loaded successfully ver:4.01
[    3.875904] rga2: Module initialized.
[    3.875964] pvtm list NULL
[    3.877737] rk-vcodec 20030000.rkvdec: leakage=6
[    3.877793] rk-vcodec 20030000.rkvdec: leakage-volt-sel=1
[    3.877962] rk-vcodec 20030000.rkvdec: Failed to get pvtm
[    3.878732] rk-vcodec 20030000.rkvdec: avs=0
[    3.879177] rk-vcodec 20030000.rkvdec: probe device
[    3.879846] rk-vcodec 20030000.rkvdec: drm allocator with mmu enabled
[    3.881754] rk-vcodec 20030000.rkvdec: init success
[    3.883507] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]'
[    3.883546] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]'
[    3.885069] asoc-simple-card hdmi-sound: i2s-hifi <-> 100c0000.i2s0 mapping ok
[    3.887785] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 200000Hz, actual 162760HZ div = 3)
[    3.888196] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]'
[    3.888226] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]'
[    3.889610] asoc-simple-card spdif-sound: dit-hifi <-> 100d0000.spdif mapping ok
[    3.893157] hctosys: unable to open rtc device (rtc0)
[    3.913419] ALSA device list:
[    3.913469]   #0: DW-I2S-HDMI
[    3.913482]   #1: SPDIF
[    3.915032] Freeing unused kernel memory: 808K
[    3.915060] This architecture does not have kernel memory protection.
[    3.942737] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 100000Hz, actual 97656HZ div = 5)
[    4.110640] usb 5-1: new full-speed USB device number 2 using ohci-platform
[    4.323841] usb 5-1: New USB device found, idVendor=046d, idProduct=c534
[    4.323886] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.323898] usb 5-1: Product: USB Receiver
[    4.323912] usb 5-1: Manufacturer: Logitech
[    4.335433] input: Logitech USB Receiver as /devices/platform/300a0000.usb/usb5/5-1/5-1:1.0/0003:046D:C534.0001/input/input1
[    4.393175] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-300a0000.usb-1/input0
[    4.404494] input: Logitech USB Receiver as /devices/platform/300a0000.usb/usb5/5-1/5-1:1.1/0003:046D:C534.0002/input/input2
[    4.460133] hid-generic 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-300a0000.usb-1/input1
[    5.499743] EXT4-fs (mmcblk2p1): mounted filesystem with writeback data mode. Opts: (null)
[    6.141033] systemd[1]: System time before build time, advancing clock.
[    6.158729] systemd[1]: Inserted module 'autofs4'
[    6.169798] ip_tables: (C) 2000-2006 Netfilter Core Team
[    6.185101] cgroup: cgroup2: unknown option "nsdelegate"
[    6.211639] systemd[1]: systemd 245.4-4ubuntu3.17 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    6.213207] systemd[1]: Detected architecture arm.
[    6.230776] systemd[1]: Set hostname to <klipper>.
[    6.491902] ttyS2 - failed to request DMA, use interrupt mode
[    7.489275] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    7.489872] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    7.489918] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    7.495195] systemd[1]: Created slice system-modprobe.slice.
[    7.496389] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    7.498437] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    7.499530] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    7.501411] systemd[1]: Created slice User and Session Slice.
[    7.502568] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    7.503153] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.504800] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    7.505780] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.507367] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    7.507538] systemd[1]: Reached target Remote File Systems.
[    7.508338] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    7.508465] systemd[1]: Reached target Slices.
[    7.509164] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    7.509275] systemd[1]: Reached target Swap.
[    7.509908] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    7.510012] systemd[1]: Reached target System Time Set.
[    7.510998] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    7.511995] systemd[1]: Listening on Syslog Socket.
[    7.513767] systemd[1]: Listening on fsck to fsckd communication Socket.
[    7.515297] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    7.527609] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    7.528988] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.531177] systemd[1]: Listening on Journal Socket.
[    7.533297] systemd[1]: Listening on udev Control Socket.
[    7.535132] systemd[1]: Listening on udev Kernel Socket.
[    7.536827] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    7.544456] systemd[1]: Mounting POSIX Message Queue File System...
[    7.556196] systemd[1]: Mounting Kernel Debug File System...
[    7.570184] systemd[1]: Mounting Kernel Trace File System...
[    7.586653] systemd[1]: Starting Restore / save the current clock...
[    7.599920] systemd[1]: Starting Set the console keyboard layout...
[    7.614655] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    7.616868] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[    7.631500] systemd[1]: Started Nameserver information manager.
[    7.658390] systemd[1]: Reached target Network (Pre).
[    7.663577] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    7.663966] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    7.679803] systemd[1]: Starting Load Kernel Modules...
[    7.695653] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.712418] systemd[1]: Starting udev Coldplug all Devices...
[    7.736476] systemd[1]: Mounted POSIX Message Queue File System.
[    7.739559] systemd[1]: Mounted Kernel Debug File System.
[    7.742707] systemd[1]: Mounted Kernel Trace File System.
[    7.751328] systemd[1]: Finished Restore / save the current clock.
[    7.760391] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    7.776627] systemd[1]: Finished Load Kernel Modules.
[    7.781106] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    7.792497] systemd[1]: Mounting Kernel Configuration File System...
[    7.796052] EXT4-fs (mmcblk2p1): re-mounted. Opts: commit=600,errors=remount-ro
[    7.806408] systemd[1]: Starting Apply Kernel Variables...
[    7.833188] systemd[1]: Finished Remount Root and Kernel File Systems.
[    7.843611] systemd[1]: Mounted Kernel Configuration File System.
[    7.849057] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    7.861395] systemd[1]: Starting Platform Persistent Storage Archival...
[    7.880670] systemd[1]: Starting Load/Save Random Seed...
[    7.894411] systemd[1]: Starting Create System Users...
[    7.984744] systemd[1]: Finished Apply Kernel Variables.
[    8.015829] systemd[1]: Finished Platform Persistent Storage Archival.
[    8.021502] systemd[1]: Finished Create System Users.
[    8.032772] systemd[1]: Starting Create Static Device Nodes in /dev...
[    8.126913] systemd[1]: Finished Create Static Device Nodes in /dev.
[    8.136598] systemd[1]: Starting udev Kernel Device Manager...
[    8.147150] systemd[1]: Finished Set the console keyboard layout.
[    8.149552] systemd[1]: Reached target Local File Systems (Pre).
[    8.162289] systemd[1]: Mounting /tmp...
[    8.190641] systemd[1]: Mounted /tmp.
[    8.203549] systemd[1]: Reached target Local File Systems.
[    8.231620] systemd[1]: Starting Armbian leds state...
[    8.259728] systemd[1]: Starting Armbian ZRAM config...
[    8.280523] systemd[1]: Starting Set console font and keymap...
[    8.309697] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    8.325114] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    8.371146] systemd[1]: plymouth-read-write.service: Succeeded.
[    8.376119] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    8.395872] systemd[1]: Finished Set console font and keymap.
[    8.415672] systemd[1]: Finished Armbian leds state.
[    8.584837] random: nonblocking pool is initialized
[    8.607709] systemd[1]: Finished Load/Save Random Seed.
[    8.625103] systemd[1]: Finished udev Coldplug all Devices.
[    8.645218] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[    8.655143] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[    8.680844] systemd[1]: Started udev Kernel Device Manager.
[    8.703740] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[    8.782096] systemd[1]: Starting Raise network interfaces...
[    8.807957] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[    8.808405] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[    8.808720] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[    8.809061] systemd[1]: Reached target Local Encrypted Volumes.
[    8.868403] zram: Added device: zram0
[    8.887458] zram: Added device: zram1
[    8.904426] zram: Added device: zram2
[    8.922321] cfg80211: World regulatory domain updated:
[    8.922376] cfg80211:  DFS Master region: unset
[    8.922389] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    8.922407] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    8.922424] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    8.922436] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[    8.922585] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    8.922610] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[    8.922622] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[    8.922634] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[    8.922652] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[    9.293474] zram0: detected capacity change from 0 to 504537088
[    9.425747] Adding 492708k swap on /dev/zram0.  Priority:5 extents:1 across:492708k SS
[    9.454758] systemd[1]: Found device /dev/ttyS2.
[    9.479546] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '20:09:06', on 'Aug 25 2021'.
[    9.479552] rk3228-codec 12010000.codec: GPIO lookup for consumer spk-en
[    9.479570] rk3228-codec 12010000.codec: using device tree for GPIO lookup
[    9.479586] of_get_named_gpiod_flags: can't parse 'spk-en-gpios' property of node '/codec@12010000[0]'
[    9.479635] of_get_named_gpiod_flags: parsed 'spk-en-gpio' property of node '/codec@12010000[0]' - status (0)
[    9.479755] rk3228-codec 12010000.codec: spk_depop_time use default value.
[    9.487416] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]'
[    9.487478] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]'
[    9.508587] mali-utgard 20001000.gpu: mali_platform_device->num_resources = 13
[    9.508653] mali-utgard 20001000.gpu: resource[0].start = 0x0x20001000
[    9.508668] mali-utgard 20001000.gpu: resource[1].start = 0x0x20000000
[    9.508683] mali-utgard 20001000.gpu: resource[2].start = 0x0x20003000
[    9.508717] mali-utgard 20001000.gpu: resource[3].start = 0x0x20008000
[    9.508746] mali-utgard 20001000.gpu: resource[4].start = 0x0x20004000
[    9.508760] mali-utgard 20001000.gpu: resource[5].start = 0x0x2000a000
[    9.508773] mali-utgard 20001000.gpu: resource[6].start = 0x0x20005000
[    9.508786] mali-utgard 20001000.gpu: resource[7].start = 0x0x00000020
[    9.508797] mali-utgard 20001000.gpu: resource[8].start = 0x0x00000021
[    9.508819] mali-utgard 20001000.gpu: resource[9].start = 0x0x00000022
[    9.508853] mali-utgard 20001000.gpu: resource[10].start = 0x0x00000021
[    9.508875] mali-utgard 20001000.gpu: resource[11].start = 0x0x00000022
[    9.508890] mali-utgard 20001000.gpu: resource[12].start = 0x0x00000021
[    9.508909] D : [File] : drivers/gpu/arm/mali400/mali/platform/rk/rk.c; [Line] : 623; [Func] : mali_platform_device_init(); to add platform_specific_data to platform_device_of_mali.
[    9.509576] mali-utgard 20001000.gpu: leakage=6
[    9.509658] mali-utgard 20001000.gpu: leakage-volt-sel=1
[    9.509957] mali-utgard 20001000.gpu: Failed to get pvtm
[    9.511275] mali-utgard 20001000.gpu: avs=0
[    9.512097] mali-utgard 20001000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    9.522970] asoc-simple-card sound: rk3228-hifi <-> 100b0000.i2s1 mapping ok
[    9.524941] Mali: Mali device driver loaded
[    9.614850] devfreq 20001000.gpu: Couldn't update frequency transition information.
[   10.034378] gpio_ir_recv ir-receiver: GPIO lookup for consumer (null)
[   10.034448] gpio_ir_recv ir-receiver: using device tree for GPIO lookup
[   10.034736] of_get_named_gpiod_flags: parsed 'gpios' property of node '/ir-receiver[0]' - status (0)
[   10.035114] Registered IR keymap rc-rktvbox
[   10.035579] rc rc1: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1
[   10.036260] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1/input3
[   10.104007] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[   10.105974] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   10.111947] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   10.131062] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   10.165986] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[   10.167444] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   10.168003] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[   10.169368] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   10.183277] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   10.184204] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   10.188922] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   10.229020] systemd[1]: plymouth-read-write.service: Succeeded.
[   10.236567] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[   10.293841] zram1: detected capacity change from 0 to 52428800
[   10.345046] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[   10.356231] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   10.357632] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   10.409506] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   10.452094] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[   10.452804] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   10.453194] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[   10.454329] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   10.457072] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   10.457990] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   10.471471] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   10.537181] systemd[1]: plymouth-read-write.service: Succeeded.
[   10.549737] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[   10.675801] systemd[1]: Finished Armbian ZRAM config.
[   10.742375] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[   10.752878] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   10.780260] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   10.785742] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   10.817714] systemd[1]: Starting Armbian memory supported logging...
[   10.879730] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   10.920880] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[   10.921594] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   10.922078] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[   10.923668] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   10.924252] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   10.924947] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   10.925486] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   10.968733] systemd[1]: plymouth-read-write.service: Succeeded.
[   10.976263] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[   11.181299] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
[   11.211513] systemd[1]: Finished Raise network interfaces.
[   11.260421] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[   11.262424] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   11.264356] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   11.280839] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   11.294255] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[   11.296438] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   11.297089] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[   11.298799] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   11.299545] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   11.300545] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   11.301371] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   11.325133] systemd[1]: plymouth-read-write.service: Succeeded.
[   11.334454] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[   16.878388] systemd[1]: Finished Armbian memory supported logging.
[   16.891631] systemd[1]: Starting Journal Service...
[   17.426648] systemd[1]: Started Journal Service.
[   17.490944] systemd-journald[642]: Received client request to flush runtime journal.
[   18.907992] nr_pdflush_threads exported in /proc is scheduled for removal
[   42.252630] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   46.796494] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   46.796578] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   46.796638] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   46.796667] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   46.796703] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   46.796734] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   85.206185] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[   85.206238] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[   85.206257] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[   85.206278] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[   85.206296] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[   85.206315] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[   85.206333] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[   85.206355] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[   85.206376] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[   85.206396] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[   85.206414] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[   85.206435] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[   85.206673] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[   85.206716] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[   85.206745] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
To finish up, here are some photos of my board (it's the exact same, as far as I can tell, as the one @Hoa Nguyen Vuhad) - alhough the marks say it's a "MXQPRO_V72". There are 2 oscilators, one close the wifi chip and one close to the RK3228A. The one close to the ESP8089 is 26 MHz and the other one 24MHz (i assume) - that's why I thought i didn't make sense for anything to work with the crystal set to 40 MHz.
https://photos.app.goo.gl/ggv6xZmMhybY9J77A
That's all I got for today haha. Once again, thanks for the help, and I'm sure I'll get this working with your help!
I just got a few of these boards myself. Here is a copy of the DTS file I extracted from the android image.
RK3228A_ESP8089.dts
On 7/4/2022 at 11:36 AM, Luís Hansen said:
Hi @jock! So after a few days of testing, I can say with 100% certainty: it's random.
I tested with every led config on some versions with the new kernel (5), including the latest one on your original post. With none of them the ESP8089 was even powered on.
cat /sys/bus/sdio/devices/mmc1:0001:1/vendor always failed.
So I went back to the old kernel (4), and the chip was detected with most configs, but with none it detected any wifi networks. Then I realized something - what if I only overlaid the wlan part, not the led config.
Well, turns out I got the wifi to work quite a few times like that. It was absolutely random: without changing any config, sometimes it would just work, and then stop working once I rebooted. Sometimes, on those reboots, it wouldn't even recognize the chip was plugged in the next time. Only for it to work again in the next boot. Sometimes it booted up working, and then, without rebooting, stopped all of a sudden and wouldn't even detect the chip anymore - without me changing anything.
I captured quite a few data: from device trees of when wifi was working to armbianmonitor outputs and even commands histories.
But, from what I can tell, there are no differences between working vs non-working DTBs. So I'm not sure those are useful.
Anyway, what I'm doing now, as a last effort, is to change the iwlwifi module configs - maybe it's putting the device to sleep and it's not recovering? I think that may be one cause because one of the things I noticed when comparing the wlan device trees of the original firmware (running Android) and the armbian ones, is that there are some pins missing from the later.
@Luís HansenI hope you don't give up. I just got some boards similar to yours. I am kind of wondering how you were able to get wifi to work some of the time? So far, the native wifi on this board has worked none of the time.
On 10/15/2021 at 6:53 AM, tommy said:
Finally, I could compile Lakka (Retroarch fork of LibreElec) for RK322x,  thanks to Lakka  LibreElec and modified knaerzche LibreElec for provide neccessary source code.
Retroarch interface has more functions than LibreElec game addon. Performance is excellent to PSX @60fps level. I could upload binary if someone interested.
I just look into mainline kenel. I use Armbian Focal kernel 5.10.y at main download page still study how to use hardware acceleration by Lima driver. Retroarch looks like slow because no active hardware acceleration yet. Hope I will figure out soon.
Hey @tommy, just read this and have also found the images you provided here, but my performance is not even close to yours. Can you tell me what sort of configuration you've made?
I have toyed around the options but my games mostly crash. For example, I have tried Tekken 3 and it feels very slow. If I try to swap the video driver for anything but "gl", it will crash. Same with other options that I thought would give a result.
Thanks!
Hello there, i read all the thread (50 pages) and i cant find how to boot armbian from sd without erase de emmc or nand storage device. I successfully boot lakka on my device.
Its a android tv box with rk3229. The dts file from lakka says v884k. Is there a way to make it work armbian and this dts? I dont want to erase Android in the device.
Or another distro is fine for me. Hexdump deleted the images on his driver. If somebody can help me i will be gratefull. thanxxx
Google Translator:
Hey guys!
I remember seeing a few years ago a list of downloads that included some Linux servers for the Legacy Rk322x.
Looking for a minimal image, I didn't find any.
Could someone tell me where I would find a Minimal Image for these boards?
Thanks...
Português:
Ei pessoal! Lembre-me de alguns anos atrás de uma lista de downloads que inclui alguns servidores Linux para o Legacy Rk322x.
Procurando uma imagem mínima, não encontrei nenhuma.
Alguém poderia me dizer onde eu encontraria uma imagem Mínima para essas placas?
Obrigado...
Edited by deciorocha
errei a Tradução.
vor 7 Minuten schrieb fukowaka:
think there isnt server options for this board yet, remember that we are installing unofficial versions . Check @jock versions.
You need dts file especifically for your hardware
your wrong the minimal are the headless variant = that is server like
also the dtb is very compatible to all rk322x board , you can use the rk322x-config in bash  for your special hardware after first start ( like nand and emmc or ddr2 or ddr3 )
@fukowaka
Hello, some answers:
  • no mixed android/armbian boot. It is done this way on purpose: no random proprietary pre-installed crap, for a number of reasons. It is possible to manually make the thing work, but on first u-boot upgrade the installation will probably break and you will come here asking why apt upgrade broke your system
  • the "dts from lakka" is not suitable, don't mix things, they won't work
  • as @RaptorSDS said, minimal variant is suitable for headless server usage
  • again, as @RaptorSDSsaid, armbian makes use of device tree overlays and rk322x-config makes easier to configure board specialties. There would be hundreds of device trees to support boards minor and major differences, device tree overlays solves this thing. Don't use other distro dtbs, they will break things.
Google Translator:
Hey guys!
@Jock is right, it happened to me while trying to update... 🤣
@furokawa Thanks for the Link... and the tip.
I installed the Minimum Version - Armbian_21.02.1_Rk322x-box_buster_legacy_4.4.194.img.
I'm not able to configure SSH, to have access from my computer.
Does Armbian have any secrets for SSH to work or am I wrong?
I would like to use Armbiam with Webmin + Lamp. That's why I chose this image.
Does anyone have an image with one of these packages to tell me if I can run a site on it normally?
@RaptorSDS I'll just use it for testing.
I would like to see how a TVBox performs as a WebServer...🤪
Português:
Olá, Pessoal!
@jock tem razão, aconteceu comigo enquanto tentei atualizar...🤣
@furokawa Obrigado pelo Link... e pela dica.
Instalei a Versão Mínima - Armbian_21.02.1_Rk322x-box_buster_legacy_4.4.194.img.
Não estou conseguindo configurar o SSH, para ter acesso do meu computador.
O Armbian tem algum segredo para que o SSH funcione ou eu que estou  errando?
Gostaria de usar o Armbiam com Webmin + Lamp. Por isto escolhi esta imagem.
Alguém teria uma imagem com um destes pacotes para me dizer se consigo rodar um site nele normalmente?
@RaptorSDS eu vou usar apenas para testes.
Gostaria de ver como uma TVBox se sai como WebServer... 🤪
Google Translator:
Hello guys!
If the words are blurry on your equipment screen, it's my tears for not having completed my attempt... 🤣🤣🤣🤣🤣
After our conversations, I even tried to install Lamp+Webmin on Armbian Minimal, but I couldn't.
I even transferred the /home to a 32gb card to put the site inside, but there was always a different problem.
If any "charitable soul" has managed to run Lamp on Armbian and wants to send me the working image, I'd appreciate it. Mine didn't work properly...
Without more for the moment, I go to some corner of the house to cry... 🤣🤣🤣🤣🤣
Português:
Olá Pessoal!
Se as palavras estiverem borradas na tela do seu equipamento são minhas lágrimas por não ter concluído o meu intento...  🤣🤣🤣🤣🤣
Depois de nossas conversas, eu até tentei instalar o Lamp+Webmin no Armbian Mínimo, mas, não consegui.
Eu até transferi o home para uma cartão de 32gb para colocar o site dentro, mas, sempre acontecia algum problema diferente.
Se alguma "alma caridosa" tiver  conseguido executar o Lamp no Armbian e quiser me enviar a imagem funcionando, agradeço. A minha não funcionou direito...
Sem mais para o momento, vou para algum canto da casa chorar...  🤣🤣🤣🤣🤣
@deciorocha I don't see anything special to run a lamp server on armbian.
Just follow any tutorial for debian (I guess you're using a debian minimal image) and it will be fine; there's really nothing special in armbian to do, since the image is a totally regular debian distro.
Today I assembled a fully working image of OpenWRT 22.03.0  for this rk322x tvbox.
It's a patchwork/mix from multitool/debian kernel 5.16.11 and the userland from the latest OpenWRT I could find for raspberry PI 2/B (same cpu arch):
OpenWrt 22.03.0-rc6 r19590-042d558536 / LuCI openwrt-22.03 branch git-22.213.35949-d09fbe0
I've tested wireguard/vxlan/wifi, all working nice (wireless AP too, much to my surprise!).
You can turn this (rather old for 2022) TVBOX into an extremely capable router with a nice www interface (too bad for the 100Mbit LAN port...). I guess you can add some more ethernet interfaces using USB ports, but do not expect too much on the performance side.
The best way to add ethernet ports for these devices is a managed switch, so you can use VLANs (€20 for a cheap 5 ports on Amazon).
Speed of wireguard VPN is quite nice (around 70Mbps on iperf3).
If anyone is interested I can post the link for the image (flashable via multitool).
It was - as usual -  painful, but  a nice challenge.
edit:
I had to do this because there are no OpenWRT releases for rockchip/32bit armv7: arm64 builds for Rockchip 3318/3328 are officially available.
Edited by Vittorio Mori
EDIT: Added further explanation
@Vittorio Mori I was thinking about just the other day about, indeed OpenWRT is a great addition for such cheap hardware and is very welcome!
Reading the post I intend it is a "hacked" rpi2 image to work on rk322x
I guess it should not be too hard to fork the openwrt project and add bullt-in support for rk322x, as long as the base architecture is armhf as much as rpi2 and below.
The challenging part is the bootstrapping which is totally different.
Maybe opening a thread on the official openwrt forum could attract more interested people there, I would be one for example...
edit: for example, openwrt already has official support for Xunlong OrangePi SBC boards; roughly our tvboxes are in the same area. Indeed OrangePI boards have all the same hardware, instead tv boxes boards hardware is a mix and match, that is troublesome for having official support, but at least having a repository which can be clone and used as a reference for the image generation is indeed a big step forward!
Since I'm not really a developer but a Linux System Administrator with hacky tendencies, that's what I usually do to use different Linux-es on these rk322x boxes:
- I use MultiTool to burn a .. Multitool image on the internal flash of the box, so I get a fat32 uboot/extlinux partition that boots
- I boot from Multitool again, drop to a shell and repartition the internal flash w fdisk, then I modify the extlinux.conf with the kernel boot parameters I need (kernel, initrd, dtb ..)
In OpenWRT case it was pretty easy: it has no initrd, and it's as bare-bone as it can be: you just have to add a line "init=/sbin/init" to the kernel line and youre basically good to go.
The challenge was to find a suitable arch: rpi2b (bcm 2709) is the perfect match i.e.: arm_cortex-a7_neon-vfpv4:
So I grabbed the .img from OpenWRT, put it into the multitool SD card, mounted it with a loop device, and did a simple "cp -R" of the whole sys partition to the second partition of the internal flash.
Then I extracted a 5.16.11-rk322x kernel & modules & firmware from bullseye-minimal build from @jock, and copied them into /lib.
The next step was to find a suitable .dtb to boot: I used @ilmich dtbs from his LIbreELEC 10.0 builds, since they worked beautifully in the tvboxes rk3228a/rev 3.1 I own.
Then I modified the /etc/modules.d files of OpenWRT to load proper modules for the rk322x board: wifi, thermal, etc.
Then I added the bootup "hardware-optimization" armbian script, just to optimize things further, IRQ routing, eth0 queues etc.
Sync & reboot: OpenWRT is up & running, awaiting connection on default address 192.168.1.1 on the ethernet port.
All packages work, kmods are simply written in the wrong directory inside /lib/modules but the kernel gets them from the right place /lib/modules/$(uname -r) so in practice everything is 100% OK, as long as the modules are present. I copied ALL the modules since I have a lot of free space in the internal flash, it's a full ext4 install, not a squashfs rootfs.
Even updates are OK.
I'm fine-tuning some parameters, then I'll add link to the .gz image, ready to flash w Multitool, later today.
@jock I've noticed that enabling wifi  (i.e. loading module ssv6051) decreases performance A LOT in OpenWRT.
Everything slows down 60/70 percent. With module NOT LOADED OpenWRT becomes VERY responsive and way faster.
I think it would be better to keep it disabled/unloaded: the performance of those chips is terrible, their behaviour erratic, they're attached to the mmc bus, and I think they somewhat screw up things. The wifi interface maxes out at around 28Mbps at 1mt distance, and drops to 5/6Mbps at just 2,5 metres away.
Overall they're useless in my opinion.
This on your kernel 5.16.11 from bullseye. Is it a known issue ?
Out of curiosity I bought an MXQ Pro 4k 5G tv box on Aliexpress.
I compiled my own image for rk822X:
./compile.sh BOARD=rk322x-box BRANCH=current RELEASE=bullseye BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=yes COMPRESS_OUTPUTIMAGE=sha,gpg,xz
The image was successfully burned to eMMc with Multitool. Thanks for all the efforts that whent into createing the image and the multitool.
The only issue I have is that wifi is not working.
If I select led-conf6 in rk322x-config after reboot rk322x-config is unable to detected the esp8089
If I select led-conf7 in rk322x-config after reboot rk322x-config detects the esp8089 but no wifi device can be found.
armbianmonitor.txt
Edited by armbianorange2hero
@armbianorange2hero hello! esp8089 unfortunately has some rough edges that need to be addressed. And AFAIR the driver is not included in mainline kernel but only in legacy kernel.
The driver was just not compiling on mainline kernel.
Modifying and trying to fix a kernel module without being able to test it later - I don't have any board with esp8089 - is a bit pointless IMHO 🤷‍♂️
I have uploaded the OpenWRT-22.03-rc6 image for rk322x on my google drive here's the link:
https://drive.google.com/file/d/1MxEDd1COSNiQDrocZLgSscracWDXdVqT/view?usp=sharing
NOTES/INSTRUCTIONS:
The .dtb for booting is the GENERIC
rk3229 from LibreELEC made by @ilmich.
Other .dtb files are in the FIRST PARTITION (fat32/boot) of the image. Copy & overwrite the one you prefer to rk322x-box.dtb. i.e.:
Once the box has booted, enter the console via an attached keyboard and:
mount /dev/mmcblk0p1 /mnt
cp /mnt/<name of the dtb you prefer>.dtb /mnt/rk322x-box.dtb
umount /mnt
reboot
The .dtb files are fom LIbreELEC 10 - check this post
https://forum.libreelec.tv/thread/25236-unofficial-rk3228-rk3229-libreelec-10-x-builds/
on "supported devices" for names/clock etc.
ON FIRST BOOT the eth0 (br-lan) interface has default IP to 192.168.1.1
SOMETIMES ON FIRST BOOT - AND ONLY FIRST ONE - eth0 gets "stuck" and does not respond: to make it work just enter the console with an attached keyboard and do a
ping 192.168.1.xxx
with xxx as a "live" host on your network: after a couple of pings the interface responds. It happened to me a couple of times, just on FIRST BOOT. Once you configure the interface in OpenWRT everything is ok.
Point your browser to 192.168.1.1, configure OpenWRT.
P.S. obviously you have to configure br-lan with an appropriate gateway/dns to install/upgrade packages.
Check OpenWRT docs if in doubt.
WIFI is disabled by default: to enable it, do :
echo <name of wifi module> > /etc/modules.d/<name of wifi module>
example:
echo ssv6051 > /etc/modules.d/ssv6051
(do not enable ssv6051: for some reason it slows down everything)
Enjoy.
fix typo/link
Announce:
Hello, I want to announce that Community Supported Configuration (CSC) board images are now built again by Armbian servers on a weekly basis!
This means that you can now download images for CSC boards (including rk322x-box) browsing from https://github.com/armbian/community
Images are built from trunk, GPG-signed and SHA-sum is provided.
Feel free to donate if you find this useful and wish to offer support to the Armbian developers and maintainers.
Enjoy!
