Disable Hdmi Sunxi A20 Lime
Danielemazza
I'm trying to disable the HDMI output on my A20-OlinuXino LIME.
I have tried to disable the HDMI from the u-boot console using this commands :
-setenv video-mode sunxi:1024x768-24@60,monitor=none
-saveenv
I have also tried to recompile the boot.cmd but even in this way nothing.
Corrently i'm using :
Linux lime 4.19.62-sunxi #5.92
Where is my mistake?
Thanks in advance.
This method has been changed few times in past years. Last time I had to apply this patch:
https://github.com/armbian/build/blob/master/patch/u-boot/u-boot-sunxi/remove-boot-messages-from-hdmi.patch.disabled
... but its also outdated due to code changes. But it gives you an idea what to look for.
32 minutes ago, Danielemazza said:
but i do not have knowledge
Understand.
51 minutes ago, Danielemazza said:
but i can learn
I can't help you around that. If you don't understand hints, study study study or hire someone that have time and ability to use them. I don't have the time to study the problem once again - it has been years since - and guide you there. It is way too expensive for something that only generates costs.
Hi to all:
I do not if is the right way but it 's works and in my opinion the knowledge must be sharing(that is the only way for keep alive the open source ).
So following these instructions i recompile the u-boot and the kernel obviously i have had remove the graphic drivers.
U-boot:
https://linux-sunxi.org/U-Boot
Kernel:
https://linux-sunxi.org/Mainline_Kernel_Howto
This is not my work and it  been done in my spare time indeed may not be the right way
Best Reguards
A patch for easy change has been updated two weeks ago. If you want to remove boot messages from u-boot, you only enable it (remove .disabled)
https://github.com/armbian/build/commit/b41834796294709644a4e503086bfbdd27b87785#diff-cab794eb45546ba1b58d2948585a2cb2
