orang pi one enable spi
renky
orange pi one
armbian buster
purged non free software
I installed flashrom.
In sudo armbian-config -> system settings -> toogle hardware I
marked spi-spidev. Saved. Restarted computer.
/dev/spi* displays nothing.
How can I enable spi in armbian?
Thank you.
you need the following in /boot/armbianEnv.txt and running a CURRENT or DEV kernel (not Legacy) :
overlays=spi-spidev
param_spidev_spi_bus=0
EDIT : Fix my own typo : should be "param_spidev_spi_bus=0" instead of "param_spinor_spi_bus=0"
Quote
running a CURRENT
I installed newest armbian buster having version
5.4.14-sunxi.
Is that current or not legacy?
Armbianenvtxt is
verbosity=1
logo=disabled
console=both
disp_mode=1920x1080p60
overlay_prefix=sun8i-h3
rootdev=UUID=
rootfstype=ext4
overlays=spi-spidev
usbstoragequirks=
It does not work.
Command
sudo ls -l /dev/spi*
returns
ls: cannot access '/dev/spi*': No such file or directory
On raspberry pi you enable spi this way
https://www.raspberrypi.org/documentation/hardware/raspberrypi/spi/README.md
14 minutes ago, renky said:
5.4.14-sunxi.
Is that current?
Yes !
It does not work.
You need to debug more :
- check that overlay is actually loaded during the u-boot phase. (Did you rebooted since the /boot/armbianEnv.txt changes ?)
- do a "dmesg | grep -i spi" to figure out about any errors, (maybe pins are used elsewhere ?)
Forget about this way, it is not Armbian way ... :P
EDIT: Oh ! I didn't look thoroughly : You wrote "param_spinor_spi_bus=0" instead of "param_spidev_spi_bus=0" because of my own typo done previously ... :lol:
Thank you.
After I corrected the code, it might work. Command
returns
crw------- 1 root root 153, 0 jan 30 /dev/spidev0.0
Are there commands such that you can verify if spi has set?
mosi
miso
ceo_n
sclk
On a raspberry pi 0 command
returns
crw-rw----1 root spi 153, 0 jan 30 /dev/spidev0.0
crw-rw----1 root spi 153, 1 jan 30 /dev/spidev0.1
On orange pi one it says crw. On raspberry pi 0 it says crw-rw. A raspberry pi
0 can flash the flashchip of a thinkpad t400. Can the orange pi one do it, if
the orange pi one's spi says crw and not crw-rw?
What do you mean ?
the orange pi one says crw and not crw-rw?
As long as you are executing as "root", you don't need to have "crw-rw" flags ...
Quote
What do you mean ?
How you can test if spi will work. On libreboot's homepage this test
command is displayed:
./flashrom -p linux_spi:dev=/dev/spidev0.0,spispeed=512
It should return
Calibrating delay loop... OK. No EEPROM/flash device found. Note: flashrom can never write if the flash chip isn't found automatically.
does not work on the raspberry pi 0 and orange pi one.
It returns
returns
Using clock_gettime for delay loops (clk_id: 1, resolution: 1ns).
on both the raspberry pi 0 and orange pi one. Since the
raspberry pi 0 can flash the flashchip of a thinkpad t400 then
maybe the orange pi one also can flash it. Because both
return the same message from
The simpliest way is to test MOSI/MISO with a loopback wire between those two pins and then use "spidev_test" after having it compiled :
https://github.com/torvalds/linux/blob/master/tools/spi/spidev_test.c
Did you properly connected a SPINOR flash chip on the proper pins or you connected some other kind of devices ?
Quote
Nothing was connected. You are supposed to run command
with nothing connected. And if it returns
then there is a chance that spi works on the computer.
Like I wrote, on the raspberry pi 0 it returns
Still the raspberry pi 0 was able to flash the
flashchip.
