petrmaje Posted May 29, 2016 Share Posted May 29, 2016 Hi, I am trying to install TVheadend using Debian-micro-home-server, but no success. Armbian Wheezy with legacy kernel. See printscreen. Any idea? PM Link to comment Share on other sites More sharing options...
Igor Posted May 29, 2016 Share Posted May 29, 2016 Are you using latest script? I just tested - working normally. cat /etc/apt/sources.list.d/tvheadend.list must result in: deb https://dl.bintray.com/tvheadend/deb wheezy release Link to comment Share on other sites More sharing options...
petrmaje Posted May 29, 2016 Author Share Posted May 29, 2016 (edited) Are you using latest script? I just tested - working normally. cat /etc/apt/sources.list.d/tvheadend.list must result in: deb https://dl.bintray.com/tvheadend/deb wheezy release It seems to be ok: root@TVheadend:~# cat /etc/apt/sources.list.d/tvheadend.list deb https://dl.bintray.com/tvheadend/deb wheezy release root@TVheadend:~# In the meantime I compiled tvheadend from source, but I have another issue with uploading firmware to USB dongle: [ 8.725304] dvb-usb: found a 'Leadtek WinFast DTV Dongle Gold' in warm state. [ 8.733722] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer. [ 8.744609] ERROR: 256 KiB atomic DMA coherent pool is too small! [ 8.744618] Please increase it with coherent_pool= kernel parameter! [ 8.751888] dvb-usb: Leadtek WinFast DTV Dongle Gold error while loading driver (-12) [ 8.757347] dvb_usb_af9015: probe of 1-1.2:1.0 failed with error -12 [ 8.762924] usbcore: registered new interface driver dvb_usb_af9015 I am googling about it ... Kernel 4.4.1-sunxi has no problem with uploading firmware .... Edited May 29, 2016 by petrmaje Link to comment Share on other sites More sharing options...
Miki131 Posted June 16, 2016 Share Posted June 16, 2016 i have the same error.tvheadend shows in : cat /etc/apt/sources.list.d/tvheadend.list but fails when trying to install (with both apt-get or script) : Unable to locate package Link to comment Share on other sites More sharing options...
petrmaje Posted June 17, 2016 Author Share Posted June 17, 2016 i have the same error.tvheadend shows in : cat /etc/apt/sources.list.d/tvheadend.list but fails when trying to install (with both apt-get or script) : Unable to locate package Try to compile it from source. It is easy with armbian, everything is preinstalled and you don't need to wait for somebody to fix it. Or, did you find another solution? Link to comment Share on other sites More sharing options...
Igor Posted June 17, 2016 Share Posted June 17, 2016 i have the same error.tvheadend shows in : cat /etc/apt/sources.list.d/tvheadend.list but fails when trying to install (with both apt-get or script) : Unable to locate package https://tvheadend.org/projects/tvheadend/wiki/AptRepository I don't see any significant changes or problems. You done packages update ? apt-get update any errors on this? Link to comment Share on other sites More sharing options...
Gravelrash Posted June 18, 2016 Share Posted June 18, 2016 N.M - post retracted Link to comment Share on other sites More sharing options...
Bernie_O Posted July 6, 2016 Share Posted July 6, 2016 It looks like there are problems with the new official AptRepository of tvheadend at bintray. When I do an apt-get update I get the following error: Error: http://dl.bintray.com jessie/release armhf Packages 403 Forbidden [IP: 5.153.35.248 80] I think they are working on it. Don't know when it will be fixed... Link to comment Share on other sites More sharing options...
technik007_cz Posted July 9, 2016 Share Posted July 9, 2016 @petrmaje Hi, I had same problem today. They stopped building it for arm cpu's from some unknown reason for me. Try download deb package manually from link bellow. Browser will complain about wrong certificate, so just add it. https://nihil.selfhost.eu/tvheadend/nightly/ You can install it with command: gdebi tvheadend*armhf.deb If it will complain about missing dependency like: Dependency is not satisfiable: libavcodec56 (>= 10:2.8.7) You need add deb-multimedia backport repository to your system. This is output of my repository list for example: cat /etc/apt/sources.list.d/multimedia.listdeb http://www.deb-multimedia.org jessie main non-freedeb http://www.deb-multimedia.org jessie-backports main If you have not added deb-multimedia repo yet follow complete procedure: (select/copy whole paragraph and paste it in your command line) echo "deb http://www.deb-multimedia.org jessie main non-free deb http://www.deb-multimedia.org jessie-backports main" > /etc/apt/sources.list.d/multimedia.list &&apt-get update -y &&apt-get install deb-multimedia-keyring --force-yes -y &&apt-get update -y Link to comment Share on other sites More sharing options...
roel Posted September 6, 2016 Share Posted September 6, 2016 @technik007_cz When I install tvheadend it abort on this message: Mutex not held at src/idnode.c:102 I don't know why, I used your current latest version: https://nihil.selfhost.eu/tvheadend/nightly/tvheadend_4.1-2236~g817f67e_armhf.deb In dmesg I got this: [ 475.945058] usb 1-1: dvb_frontend_start: failed to start kthread (-4)[ 1005.892539] rtl2832 2-0010: i2c reg read failed -11 reg 01 somebody an idea? Link to comment Share on other sites More sharing options...
roel Posted September 8, 2016 Share Posted September 8, 2016 I got tvheadend installed and running with the package of the official repo: sudo apt-get install apt-transport-httpssudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 379CE192D401AB61echo "deb https://dl.bintray.com/tvheadend/debjessie release" | sudo tee -a /etc/apt/sources.list.d/tvheadend sudo apt-get updatesudo apt-get install tvheadend No I can browse to the tvheadend server. It discovers my r280T DVB-T usb-stick (with the mainline kernel module), but doesn't start scanning. Then I installed RTL-SDR, blacklisted the kernel module and tried again. But now the DVB-T stick isn't recognized. If I check dmesg, the usb DVB-T stick is recognized but not initialized, something strange. Or the stick is defective or my cubie A10 isn't up to the task. I will try this evening on my PC running Arch with both the mainline kernel module and the rtl-sdr one. Link to comment Share on other sites More sharing options...
