How to control FAN on Rockpro64?
mabs
@GreyLinux - The "flexi sata cables" was a MUST to fit the 5 drives.
I have used SimpNAS with sucess, works for the most "out of the box" with many of the sata cards i used.
Now i run Armbian buster and OMV again, the reason is i use OMV on my other machines. And also that i can boot from the sata card and no sd or emmc is needed.
@soerenderfor
its going really really well , I've just installed simpnas on the rockpro64 and I'm seriously impressed, it's brilliant . The card has been working flawlessly doesn't skip a beat with heavy uploading and the rockpro64 barely uses any of it's processing power to run several docker  containers and simpnas .
I'm running kernel 5.8.17
@GreyLinux - Sorry for the delay, i did use 2020.01-ayufan-2014-gff2cdd38 uboot. I'm pretty sure just flashed it on sd card (not 100% sure) and flashed spi, the i could boot Armbian from my "5" port on sata pcie card.
Maybe it is possible with
armbian-config
I'm not sure, because i haven't tryed uboot update from armbian-config.
armbian-config
Nice 👍 thanks @soerenderfor
this is my next objective . I will have a look into whether I can do it with armbian-config .
armbian-config
Hi @soerenderfor, can you explain a bit further the process?
I downloaded the u-boot-flash-spi-rockpro64 from there : https://github.com/ayufan-rock64/linux-mainline-u-boot/releases/tag/2020.01-ayufan-2014-gff2cdd38
I downloaded the last release of armbian for RockPro64.
Then :
 -Flash u-boot
- Install armbian then use armbian-config to move the system to my Sata SSD (Boot from SPI - System on SATA)
- Still in armbian-config, I accepted/declined the option to update the bootloader in the SPI flash
I did those three in every order, flashing first then installing, installing then flashing, accepting the update to the bootloader in armbian-config, then declining it...
Leaving the bootloader on the SD card does works ("Boot from SD - System on SATA" in Armbian-config), but I can get my RockPro64 to boot directly from the SATA SSD.
What am I doing wrong / What did you do exactly to make it work?
@Waryle - Myself did use, uboot from.. Auyfan, i'm pretty sure, it was an img to burn on the sdcard to the spi. It was pretty easy. I will look for it tonight. Thanks.
*Im not 100% sure if the uboot, was able to boot from any port, what card do you use?
*This one on your sdcard -  u-boot-flash-spi-rockpro64.img.xz, boot up. If remember right it is that one, and when your box start blinking, it should be done. I did wait a minut, just to make sure it was done right.
NOTE
**2020.01-ayufan-2014-gff2cdd38 released
ayufan: rockchip: allow to boot scsi4, as JMS585 can have 5 drives
Sorry, the forum limits me to 1 comment every once in a while, I couldn't answer earlier.
@soerenderfor
I did use a Samsung SD Card ( https://www.amazon.com/Samsung-Class-Micro-Adapter-MB-MC32GA/dp/B0749KG1JK/ref=sr_1_3?dchild=1&keywords=samsung%2Bsd%2B32gb&qid=1607026358&sr=8-3&th=1 ).
I did flash the u-boot-flash-spi-rockpro64.img.xz using those instructions : https://github.com/sigmaris/u-boot/wiki/Flashing-U-Boot-to-SPI
I even waited an extra 5 minutes afterwards before rebooting just to be sure.
I also tried Sigmaris' 2020.10 uboot version, and asked for help there : https://forum.pine64.org/showthread.php?tid=8685&pid=84734#pid84734
Just to be sure : you are currently booting from SPI directly to a SATA drive, not from EMMC, right?
That is part of some (unfortunately necessary) spam prevention measure.
I gave you a like, so that restriction should lift within 24 hours.
Cheers!  And welcome to the forums.
That was very kind of you, thank you!
On 12/3/2020 at 10:01 PM, soerenderfor said:
@Waryle I boot up from SSD drive, i use a 5 port sata card. And boot from the upper port "5"
Im not sure if it can boot from other ports, but i did disconnet all other drives, than the "boot" drive, on first boot-up
I have finally found the problem after hours of looking up for documentation and retries. I had the idea to take a PC monitor and plug the RockPro64 on it to see what kind of error it could throw, and work from there :
  • Uboot seem to boot only on the first SATA drive of the list : I had a SATA card with 4 ports, I plugged my SDD in the port 1 and my two other drives in the 3 and 4.
  • Uboot does not like BTRFS. Once I have plugged the SSD on the port 1, I had a initramfs error, so I went again in armbian-config, used the "Boot from SPI - System on SATA" option, and this time I chosed Ext4 instead of BTRFS.
It's working now. I could have found a way to put only the /boot on an Ext4 partition and the system on BTRFS, but I have lost too much time and I'm gettting lazy, so I'll just leave it that way, Ext4 is perfectly fine anyway.
Thanks for you help !
