What's your favorite heat sink
lanefu
On 3/10/2020 at 1:16 PM, Werner said:
What do you think?
I think they are a bit 'overkill' and quite expensive. See the answer below.  Means, unless you want to run at maximum all the time, a cheap heat sink should do the job.
On 3/10/2020 at 11:38 PM, manuti said:
(I think @tkaiser shared this model here
I guess this is correct and IIRC with the idea in mind helping to spread the heat (increase the surface of the SoC) for short high load. With the idea to have sane settings to throttle the SoC and keep the temperature on a healthy level software wise.
On 3/15/2020 at 8:17 AM, Werner said:
I like 'Go big or go home' stuff
#me too ... soon after the power connector died :(   https://forum.armbian.com/topic/6909-pi-factor-power-solution/?tab=comments#comment-52516
But some day I will amend the power-HAT from @TonyMac32  cut out the middle part in KiCAD and see if I can get it manufactured in China. So this great board, with the gorgeous heat sink gets back to live :-D
