/etc/update-motd.d/41-armbian-config
Shoka
This "motd" fragment has a bug/inconsistency.
# any changes will be lost on board support package update
THIS_SCRIPT="armbian-config"
MOTD_DISABLE=""
/etc/defaults/armbian-motd has :
# add space-separated list of MOTD script names (without number) to exclude them from MOTD
# Example:
# MOTD_DISABLE="header tips updates"
This works correctly for the other "motd" fragments which contain, for instance :
THIS_SCRIPT="sysinfo"
MOTD_DISABLE=""
but fails to disable 41-armbian-config unless the MOTD_DISABLE string includes armbian-config.
I've verified that nothing untoward happens if you change 41-armbian-config to
THIS_SCRIPT="config"
MOTD_DISABLE=""
and suppression then occurs correctly with /etc/defaults/armbian-motd set to:
# Example:
MOTD_DISABLE=" header tips updates config"
ONE_WIRE="" # yes = show 1-wire temperature sensor if attached
 On a separate, but related note, I do use the 30-armbian-sysinfo script.
However my version has a minimally modified output. My modified version first.
System load:   0.02 0.01 0.00      Up time:       1:18 hour
Memory usage:  29 % of 238MB      Zram usage:    16 % of 119Mb
IP:            eth0: 192.168.1.5
CPU temp:      43°C
Usage of /:    5% of 29G
Memory usage:  29 % of 238MB      Zram usage:    16 % of 119Mb      IP:            192.168.1.5
CPU temp:      44°C
Note the IP information starting on a new line, and the interface information included.
netadmin@probe3:~$ diff ~/motd/30-armbian-sysinfo /etc/update-motd.d/30-armbian-sysinfo
141c141
<             [[ -n $tmp ]] && ips+=("$intf: $tmp")
>             #[[ -n $tmp ]] && ips+=("$intf: $tmp")
143c143
<             #[[ -n $tmp ]] && ips+=("$tmp")
199c199
< printf "\nIP:            "
> printf "IP:            "
I prefer my version.  :)
I'm very much a newbie on this board, I have no idea where to post the suggestion.
Cheers Harry
