ERROR in function compile_kernel [ common.sh:176 ]
Hi there,
i want to stick to the 4.4 kernel an tried to compile kernel 4.4.12 (cubietruck) via:
apt-get -y install git
git clone https://github.com/igorpecovnik/lib--depth 1
cp lib/compile.sh .
chmod +x compile.sh
./compile.sh
after that, i built the following directory and file:
mkdir userpatches
vi userpatches/lib.config
and added:
KERNELBRANCH="v4.4.12" (also tried KERNELBRANCH="v4.5.6")
as described here:
http://forum.armbian...est-kernel-447/
Whenn running ./compile, i get the following messages:
  │   LD [M]  drivers/media/v4l2-core/tuner.o        â”‚
  │   LD      drivers/media/v4l2-core/built-in.o        │
  │   LD      drivers/media/built-in.o        │
  │ make: *** [drivers] Error 2        â”‚
[ error ] ERROR in function compile_kernel [ common.sh:176 ]
[ error ] Kernel was not built [ @host ]
[ o.k. ] Process terminated #
Any hints?
Regards,
A.
Guest SkilsiMet
Is it possible to compile a custom kernel in a virtual machine, and transfer it over to replace the current kernel in my real my machine? If so, how can i make it happen?
I changed compile.sh.
FORCE_CHECKOUT="no"
I tried, but it was the following error.
Is this the same cause?
