Kernel 4.15.0-88 on Orangepi PC
istefanec
1 hour ago, istefanec said:
I need kernel 4.15.0-88 on Orangepi PC.
Why do you want to downgrade?
I used "apt-get install linux-generic" to install kernel 4.15.0-88.
After reboot Orangepi does not boot.
"linux-generic" has nothing to do with Armbian - those are Debian or Ubuntu generic kernels and - especially this old - usually lack support for most of the hardware we support. Even kernel might have support, boot process is different ... failure is expected.
3 hours ago, istefanec said:
Can I compile image for Orangepi PC with KERNELTAG="v4.15.0" or something else?
Thank you.
That is the failure given over serial port:
Spoiler
U-Boot SPL 2019.10-armbian (Jan 05 2020 - 10:06:25 +0100)
DRAM: 1024 MiB
Trying to boot from MMC1
U-Boot 2019.10-armbian (Jan 05 2020 - 10:06:25 +0100) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi PC
DRAM:  1 GiB
MC:   mmc@1c0f000: 0
Loading Environment from EXT4... ** File not found /boot/boot.env **
** Unable to read "/boot/boot.env" from mmc0:1 **
rror: 32 bit/pixel mode, but BMP has 8 bit/pixel
In:    serial
Out:   vidconsole
Err:   vidconsole
Net:   phy interface0
eth0: ethernet@1c30000
230454 bytes read in 14 ms (15.7 MiB/s)
starting USB...
Bus usb@1c1a000: USB EHCI 1.00
Bus usb@1c1a400: USB OHCI 1.0
Bus usb@1c1b000: USB EHCI 1.00
Bus usb@1c1b400: USB OHCI 1.0
Bus usb@1c1c000: USB EHCI 1.00
Bus usb@1c1c400: USB OHCI 1.0
Bus usb@1c1d000: USB EHCI 1.00
Bus usb@1c1d400: USB OHCI 1.0
scanning bus usb@1c1a000 for devices... 1 USB Device(s) found
scanning bus usb@1c1a400 for devices... 1 USB Device(s) found
scanning bus usb@1c1b000 for devices... 1 USB Device(s) found
scanning bus usb@1c1b400 for devices... 1 USB Device(s) found
scanning bus usb@1c1c000 for devices... 1 USB Device(s) found
scanning bus usb@1c1c400 for devices... ERROR:  USB-error: DATAOVERRUN: The amount of data returned by the endpoint exceeded
either the size of the maximum data packet allowed
from the endpoint (found in MaximumPacketSize field
of ED) or the remaining buffer size. (8)
2 USB Device(s) found
scanning bus usb@1c1d000 for devices...  USB Device(s) found
scanning bus usb@1c1d400 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3789 bytes read in 3 ms (1.2 MiB/s)
## Executing script at 43100000
U-boot loaded from SD
Boot script loaded from mmc
201 bytes read in 3 ms (65.4 KiB/s)
4865286 bytes read in 1657 ms (20.1 MiB/s)
7741936 bytes read in 370 ms (20 MiB/s)
Found mainline kernel configuration
28507 bytes read in 8 ms (3.4 MiB/s)
4155 bytes read in 8 ms (506.8 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 44000000
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    34865222 Bytes = 33.3 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... ad Data CRC
Ramdisk image is corrupt or invalid
SCRIPT FAILED: continuing...
Device 0: unknown device
ethernet@1c30000 Waiting for PHY auto negotiation to complete. done
BOOTP broadcast 1
BOOTP broadcast 2
OOTP broadcast 3
HCP client bound to address 172.16.2.197 (1354 ms)
*** ERROR: `serverip' not set
Cannot autoload with TFTPGET
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-02-81-10-d2-35-f9
Retrieving file: pxelinux.cfg/AC1002C5
Retrieving file: pxelinux.cfg/default-arm-sunxi-sunxi
Config file not found
BOOTP broadcast 1
DHCP client bound to address 172.16.2.197 (22 ms)
BOOTP broadcast 1
=> -Boot SPL 2019.10-armbian (Jan 05 2020 - 10:06:25 +0100)
Unknown command 'U-Boot' - try 'help'
=> DRAM: 1024 MiB
Unknown command 'DRAM:' - try 'help'
=> Trying to boot from MMC1
Unknown command 'Trying' - try 'help'
=> U-Boot 2019.10-armbian (Jan 05 2020 - 10:06:25 +0100) Allwinner Technology
=> CPU:   Allwinner H3 (SUN8I 1680)
Unknown command 'CPU:' - try 'help'
=> Model: Xunlong Orange Pi PCDRAMMC:   mmc@1c0f000: 0
Unknown command 'Model:' - try 'help'
=> Loading Environment from EXT4... ** File not found /boot/e*
Unknown command 'Loading' - try 'help'
=> ** Unable to read "/boot/boot.env" from mmc0:1 **
Unknown command '**' - try 'help'
=> rror: 32 bit/pixel mode, but BMP has 8 bit/pixel
Unknown command 'rror:' - try 'help'
=> In:    serial
Unknown command 'In:' - try 'help'
=> Out:   vidconsole
Unknown command 'Out:' - try 'help'
=> Err:   vidconsole
Unknown command 'Err:' - try 'help'
=> Net:   phy interface0
Unknown command 'Net:' - try 'help'
=> eth0: ethernet@1c30000
Unknown command 'eth0:' - try 'help'
=> 230454 bytes read in 14 ms (15.7 MiB/s)
Unknown command '230454' - try 'help'
=> starting USB...
Unknown command 'starting' - try 'help'
=> Bus usb@1c1a000: USB EHCI 1.00
Unknown command 'Bus' - try 'help'
=> Bus usb@1c1a400: USB OHCI 1.0
=> Bus usb@1c1b000: USB EHCI 1.00
=> Bus usb@1c1b400: USB OHCI 1.0
=> Bus usb@1c1c000: USB EHCI 1.00
=> Bus usb@1c1c400: USB OHCI 1.0
=> Bus usb@1c1d000: USB EHCI 1.00
=> Bus usb@1c1d400: USB OHCI 1.0
=> scanning bus usb@1c1a000 for di.Svscanning bus usb@1c1b000 foressnbbcfe.R -rARTm ttdtnte
Unknown command 'scanning' - try 'help'
=> e  hx ptoftdtunmciio hmnfi(R r OUhufau ep ee soemaa wfrom th o(dtx  eofrom the ed n mczeof E hagfi(RUr VNeuf rbepedi if macaefrtnnoniaSfof ED) or hagfi8ERROR:  USB-oAE:atdre eixdhhz amakl
nknown command 'e' - try 'help'
=>  eioixPtf
Unknown command 'eioixPtf' - try 'help'
=> D riu .ERROR: USB-r OUeufaubep deither tso maa eoep dMc0de  ef
Unknown command 'D' - try 'help'
=> s co
Unknown command 's' - try 'help'
=> sittn,mmc0 is current eScanning mmc 0:1...
Unknown command 'sittn,mmc0' - try 'help'
=> Fo orbbs378b   1Boot 7741936 bytri 2BFound mainlinecgi28507 byte##Etst40## Loading ini sogI 30
Unknown command 'Fo' - try 'help'
Edited by Igor
spoilers
Support we are paying for your amusement is limited to Armbian official builds: https://docs.armbian.com/User-Guide_Getting-Started/#how-to-check-download-authenticity under those conditions: https://github.com/armbian/build#support
After you adjust patches, yes. But this is 100% your job. Its a lot of work and perhaps mission impossible - depending of your skills. We only support build engine, not what you will give into it. When you go outside of supported versions, 4.19.y and 5.4.y, adjustment costs will go up and nobody will be assisting you. I hope you understand this is not our fault.
Hello.
I did find solution for my problem.
It was how to use Hauppauge Wintv DualHd USB Tv card on Orangepi PC with Tvheadend app.
I had problem with receiving DVB-T2 programs with Tvheadend.
On virtual Ubuntu 18.04 was good.
Now it works on Orangepi PC.
At the end I used:
Armbian_5.90_Orangepipc_Ubuntu_bionic_next_4.19.57.img, upgraded kernel to 5.4.20-sunxi,  add TV card firmware "dvb-demod-si2168-b40-01.fw", at the end Tvheadend install.
Tvheadend works better on Orangepi PC then on virtual Ubuntu.
My first approach was wrong.
Thank you again.
I am glad you did. :) Many people use those devices for TVheadend servers which is why our kernel support is good out of the box. (I also used it for many years)
Going on the other route you might end up hating Linux altogether :P
Tell me please if you know what is to best way to share successes for something
does work.
In my case tvheadend on Orangepi PC with hauppauge dvb-t2 card.
That is my case:
"For Orangepi PC working installation you need:
Set static IP address (optional).
apt-get update && apt-get upgrade
With armbian-config switch to other kernel select 5.4.20-sunxi.
In /lib/firmware add "dvb-demod-si2168-b40-01.fw" firmware.
Install Tvheadend.
I use:
sudo apt-add-repository ppa:mamarley/tvheadend-git-stable
sudo apt-get update
sudo apt install tvheadend
Good luck."
At the end I did use a lot of community knowledge and I want to share my successes with others.
Best regards,
Ivica.
Just for the heck of it, want to try this with a fresh current image? Most users will download current anyways and this makes the extra step of switching kernels obsolete.
