OrangePi Zero cant use SPI1 pins as GPIO
mustafa_meta
I'm using OPi LTS and cant change state of PA13-14-15-16 pins.
I trying on fresh Armbian Bionic. Checked SPI is disabled.
Trying this code for access pins:
import OPi.GPIO as GPIO
pin = "PA13"
GPIO.cleanup()
GPIO.setmode(GPIO.SUNXI)
#GPIO.setwarnings(False)
GPIO.setup(pin, GPIO.OUT)
GPIO.output(pin, 1)
and take this error altrough write in code "GPIO.cleanup()"
ERROR: "UserWarning: Channel PA13 is already in use, continuing anyway. Use GPIO.setwarnings(False) to disable warnings."
When trying "GPIO.setwarnings (False)" before change output of pin.
Pin voltages when write "1" to output:
 PA13 -> 3V
 PA14 -> 3V
 PA15 -> 0.95V
 PA16 -> 3V
Pin voltages when write "0" to output:
 PA13 -> 3V
 PA14 -> 2.77V
 PA15 -> 0.78V
 PA16 -> 3V
How can i find problem ? What else can i do ?
Edited by mustafa_meta
What "cat /sys/kernel/debug/gpio" is reporting ?
Which kernel are you using ? What "uname -a" shows ?
BTW, "GPIO.cleanup()" is usually called when program exit, but at the beginning ...
~cat /sys/kernel/debug/gp
gpiochip0: GPIOs 0-223, parent: platform/1c20800.pinctrl, 1c20800.pinctrl:
 gpio-17  (                    |orangepi:red:status ) out lo
 gpio-20  (                    |reg_vcc_wifi        ) out hi
 gpio-110 (                    |onewire@0           ) out lo
 gpio-166 (                    |cd                  ) in  lo ACTIVE LOW
 gpio-204 (                    |usb0_id_det         ) in  hi IRQ
gpiochip1: GPIOs 352-383, parent: platform/1f02c00.pinctrl, 1f02c00.pinctrl:
 gpio-358 (                    |vdd-cpux            ) out hi
 gpio-359 (                    |reset               ) out hi ACTIVE LOW
 gpio-362 (                    |orangepi:green:pwr  ) out hi
~uname -a
Linux orangepizero 5.4.20-sunxi #20.02.1 SMP Mon Feb 17 02:09:41 CET 2020 armv7l armv7l armv7l GNU/Linux
Yes "GPIO.cleanup()" work for only in used script, read it from comment now. Thanks.
But what can i do for "UserWarning: Channel PA13 is already in use...."  ?
PA13 is SPI1_CS ... Are you sure the SPI1 is disabled ?
What "cat /proc/device-tree/soc/spi@1c69000/status" is reporting ?
I'm sure, SPI is disabled.
"cat /proc/device-tree/soc/spi@1c69000/status" is nothing show.
I tried completely the same steps on another OPi Zero and everything okay with it.
Is there storage for gpio config other than sd card?
Maybe pins damaged ?
It should show something, but without newline, only at left of command prompt, it must be either "okay" or "disabled"
Are both boards are identical, same revision number ?
I don't understand the question ...
I doubt, i says "already in use" ...
Sorry for it
"cat /proc/device-tree/soc/spi@1c69000/status" report disabled.
Quote
No.  OPi Zero and OPi Zero LTS. I have problem with OPi Zero LTS now.  OPi Zero work fine.
Quote
Is there an internal disk in the OPi card, such as eMMC flash.  I guess the answer is no.
Did you try to use the same SDCard from the working one into the other one ?
Yes, there is a SPINOR flash, but since SPI isn't enable, it should not interfere ...
BTW, the whole thing remind me a 2 years old thread here :
Do you have UART3 overlay in /boot/armbianEnv.txt ? The PA13/PA14 pins would be in-use if UART3 is enabled ...
I was read it and sure UART is disabled.  Here is output  " cat /boot/armbianEnv.txt":
verbosity=1
logo=disabled
console=serial
disp_mode=1920x1080p60
overlay_prefix=sun8i-h3
overlays=w1-gpio
rootdev=UUID=4618846b-19e6-421b-8872-767a46ed5e1e
rootfstype=ext4
usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
Now a new board is came. I tried same sd card both.  Old one still not working and new one works with same sdcard.
Few weeks before this mistake i've tried work with rc522 module on spi1 pins. I unconsciously tried everything.  If this not a software issue I think it damaged these pins.
What is SPINOR role on board? Maybe I intervened in this before?
