Nevals_zgb Posted March 23, 2020 Share Posted March 23, 2020 Hello, I have app (in attachment) from Rasbian and I have problem when I try to install this app on Armbian. Is it possible to run this app on Armbian? root@mps-box-000:/home/username/Downloads# sudo dpkg -i EERaspbian_1.0.1.0.deb (Reading database ... 113955 files and directories currently installed.) Preparing to unpack EERaspbian_1.0.1.0.deb ... Unpacking eelinux:armhf (1.0.1.0) over (1.0.1.0) ... Setting up eelinux:armhf (1.0.1.0) ... Job for eelinux.service failed because the control process exited with error code. See "systemctl status eelinux.service" and "journalctl -xe" for details. dpkg: error processing package eelinux:armhf (--install): installed eelinux:armhf package post-installation script subprocess returned error exit status 1 Processing triggers for desktop-file-utils (0.23-4) ... Processing triggers for mime-support (3.62) ... Errors were encountered while processing: eelinux:armhf root@mps-box-000:~# systemctl status eelinux.service ● eelinux.service - EELinux device monitoring daemon Loaded: loaded (/lib/systemd/system/eelinux.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Mon 2020-03-23 14:14:12 CET; 15min ago Process: 3588 ExecStart=/opt/eelinux/stUp.sh start (code=exited, status=127) Mar 23 14:14:12 mps-box-000 systemd[1]: Starting EELinux device monitoring daemon... Mar 23 14:14:12 mps-box-000 stUp.sh[3588]: service starting... Mar 23 14:14:12 mps-box-000 stUp.sh[3588]: /opt/eelinux/stUp.sh: 19: /opt/eelinux/stUp.sh: /opt/eelinux/ExplorerE: not found Mar 23 14:14:12 mps-box-000 systemd[1]: eelinux.service: Control process exited, code=exited, status=127/n/a Mar 23 14:14:12 mps-box-000 systemd[1]: eelinux.service: Failed with result 'exit-code'. Mar 23 14:14:12 mps-box-000 systemd[1]: Failed to start EELinux device monitoring daemon. EERaspbian_1.0.1.0.deb Link to comment Share on other sites More sharing options...
Nevals_zgb Posted April 10, 2020 Author Share Posted April 10, 2020 Hello, does anyone have maybe solution for this problem? Link to comment Share on other sites More sharing options...
Werner Posted April 10, 2020 Share Posted April 10, 2020 Providing armbianmonitor -u would be a good start... Link to comment Share on other sites More sharing options...
