0
ning
[HOWTO] build Debian-flavor kernel packages for Armbian
before you start:
    Armbian already provides kernel build script in armbian build framework, and you can download these packages via `apt`
    in common cases, you shouldn't build kernel yourself, even you want to build a customer kernel package, you should use armbian build framework.
    because you can get best supports.
   so below content is only for experts.
prepare source code:
    1, stable linux kernel source code:
        https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git
       https://kernel.googlesource.com/pub/scm/linux/kernel/git/torvalds/linux.git
   2, armbian build framework, for patches and kernel config
       https://github.com/armbian/build
   3, debian linux build rules:
      git clone https://salsa.debian.org/kernel-team/linux.git --depth=1
     optional: checkout to a branch to build a different kernel version, current version is 5.5.8
   4, add patches to debian linux build rules:
      copy all family patches to <debian-rules>/debian/patches/
      add all your patches to <debian-rules>/debian/patches/series
     make sure all your patch are appliable to mainline kernel.
     optional: remove all debian's kernel patch, only leave armbian kernel patch.
 5, apply the patches.
    apt install devscripts
    cd <debian-rules>
   debian/bin/genorig.py <path-to-stable-linux>
   debian/rules orig
6, copy kernel config to <debian-rules>/config/[armhf, arm64]/config
prepare native armhf/arm64 build env
1, donwload armbian's prebuild rootfs, or use debootstrap.
2, mount dev, sys, proc, tmp to armhf/arm64 rootfs. reference: https://github.com/armbian/build/blob/master/lib/image-helpers.sh#L27
3, mount <debian-rules> to armhf/arm64 rootfs.
start build, in chroot rootfs
1, cd <debian-rule>
2, apt install devscripts fakeroot
3, debian/rules debian/control DEBIAN_KERNEL_DISABLE_INSTALLER=true
4, debuild -i -us -uc -b # do it only once, to let build system promt missing build depends. you need to install all build depends at this step.
5, fakeroot debian/rules binary or fakeroot debian/rules binary-arch
6, long wait.
Share this post
Link to post
Share on other sites
0
