FredrikA Posted March 28, 2020 Share Posted March 28, 2020 Armbianmonitor: http://ix.io/2fOd My board works pretty well upto 1 000 00 Hz without fan and up to 1 200 000 Hz with (noctua) fan. However I am still using an usb wifi card, to be able to connect with ssh. Anyone having wifi with the built in wifi card work properly? Mine just shuts off. With an external wifi usb card, it works like a charm. Since my 3-d printers are in the living room I i have the orange pi:s in the living room. They are primary used for octoprint. I would like to have the built in wifi on orangepi prime to work. Link to comment Share on other sites More sharing options...
Werner Posted March 28, 2020 Share Posted March 28, 2020 You are using a very old version. Try either to update your kernel to current branch or if you have a spare sd card (which everybody should have ) grab a recent version and try again: https://www.armbian.com/download/ Link to comment Share on other sites More sharing options...
FredrikA Posted March 31, 2020 Author Share Posted March 31, 2020 Thanks @Werner, I actually believed I got upgrades automatically. I have updated now by re-flashing the SD card and will supervise if wifi is stable. Seems Ok after a couple of hours, but previously it could take a day or two before the instability showed. (Now armbianmonitor -u at http://ix.io/2g61 ) Link to comment Share on other sites More sharing options...
FredrikA Posted April 2, 2020 Author Share Posted April 2, 2020 http://ix.io/2glp I have updated to latest armbian And the built in wifi was still unstable After a while the link goes down and I get the following in dmesg 2767.152762] RTL8723BS: linked_status_chk(wlan0) disconnect or roaming It is annoying but no catastrophe. I run this bash script once every hour in crontab to restart wifi0 #!/bin/bash list=`ifconfig|grep 192|awk '{print $2}'` for l in $list; do #echo $list count=$(($count + 1)) done; #echo $count # if we got less than 2 interfaces, restart networking if [ $count -lt 2 ] ; then echo restarting network and network-manager sudo systemctl stop network-manager sudo systemctl stop networking sudo systemctl start networking sudo systemctl start network-manager fi Link to comment Share on other sites More sharing options...
